Results 1 to 7 of 7
Thread: HEX-V2 on Golf MK7.5 - RLS Activation Coding
    Pirate
    Oct 2017
    Turkey
    Hello all,
    I need to activate Rain Light Sensor on VCDS Menu. But I have problem with BCM Coding. IN 17.8 VCDS when i enter Cent. Elec. -> Long Coding Menu. All codes fill with 0.
    In adaptation menu, there is no option for activate rain light sensor. I found something in adaptation, but nothing changed.
    How can i activate "light sensor is installed" option?
    Thank you so much.
    Pirate
    Oct 2017
    Turkey
    Hello Uwe,
    Here is the result.
    Removed.  Data from clone/pirate copies of VCDS is not welcome here.
    Quote Originally Posted by unalkarakus View Post
    Hello all,
    Thank you so much.
    unalkarakus: Merhaba -senin İngilizcen çok iyi
    I can't be absolutely certain without seeing an admap for your BCM, but instead of going to the coding screen, look in the adaptation screen for the following channel
    REDACTED. Set this to REDACTED -
    VW Golf MkVII (103TSI) my13
  5. Likes Uwe liked this post
    REDACTED
    - set this to REDACTED
    Anything he sees/tries to save with his clone will be doubtful at best
  7. Likes Uwe, DV52 liked this post
    ^^^^^^^^^ ooops I was too interested in the technical aspects of the problem to notice that this was someone who had participated in IP theft!!
    Back to the naughty corner for me!!
  9. Likes Uwe liked this post
  10. #7
    Put on your MAGA hat and go sit with Trumpy Bear!
    J/K. It's all good. I missed that earlier because someone else beat me to the CODE tags on that post.
  11. Likes DV52, Boki Ar liked this post
