- Joined
- Sep 30, 2014
- Messages
- 14
- Reaction score
- 5
- Location
- Pacific Northwest
- VCDS Serial number
- C?ID=105413
Please find below Autoscan using HEX-NET via wifi for the Audi 2018 TT RS. Have map files already been submitted for this vehicle so label files can be updated for the next VCDS release?
I also posted scan using HEX-USB+CAN for comparison. Other than the much slower scan times, can you confirm it will continue to be capable of reading all the modules for the MK3 TT's once the next VCDS is released, or will HEX-NET or HEX-V2 be required?
Thanks!
Autoscan using HEX-NET Wifi
Autoscan using HEX-USB+CAN:
Thanks!
Saturday,21,October,2017,21:21:48:62243
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 17.8.0.1 HEX-NET CB: 0.4401.4
VIN: WUACSAFV1J1111222 License Plate: TTRSHEXNETWIFI
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 3C 42 44 47 52 55 5F
6C
Address 01: Engine (------DAZA) Labels: None
Part No SW: 8S0 907 404 G HW: 07K 907 309 E
Component: 2.5l R5/4V TF H22 0002
Revision: 53H22000
Coding: 1A250032242600053620
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM25TFS0118S0907404G 001002
ROD: EV_ECM25TFS0118S0907404B.rod
VCID: BA3865EF3DAC3A9604-80EE
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0DL 300 012 H HW: 0GC 927 711 G
Component: GSG DQ500 H06 2111
Revision: 00H06V07
VCID: AE1059BFF1E4E636A8-80FA
Part No SW: 8S0 907 379 J HW: 8S0 907 379 J
Component: ESC H42 0050
Revision: 00000000 Serial number: 62996000000115
Coding: 99AAF08D6A9915A9009A08668394900635990F56A80010C10960AC
ASAM Dataset: EV_Brake1UDSContiMK100IPB 061007
ROD: EV_Brake1UDSContiMK100IPB_061.rod
VCID: C8DC0F277340580682-809C
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0447085082
Coding: 030C0C1720
VCID: BE3069FF218416B638-80EA
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 043 HW: 8S0 820 043
Component: AC Automat H05 0040
Revision: 20010000 Serial number: 17050000009000
Coding: 400050100001041100
ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
ROD: EV_AirCondiVAPrehAU33x.rod
VCID: EC9493B707785426C6-80B8
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 2A7017B800PAG0MUFU03
Operating and display unit 1 for air conditioning:
Subsystem 2 - Part No SW: 8S0 820 373 A HW: 8S0 820 373 A
Component: E774 BuA_1 H07 0020
Serial number: 00000000000000042268
Operating and display unit 2 for air conditioning:
Subsystem 3 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Operating and display unit 3 for air conditioning:
Subsystem 4 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Operating and display unit 4 for air conditioning:
Subsystem 5 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
Operating and display unit 5 for air conditioning:
Subsystem 6 - Part No SW: 8S0 820 373 B HW: 8S0 820 373 B
Component: E778 BuA_5 H07 0020
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 BP HW: 5Q0 937 085 BG
Component: BCM MQBAB HNA H36 0253
Serial number: 01001718500340
ROD: EV_BCMBOSCH_018.rod
VCID: 885CCF2733C0980642-80DC
Subsystem 1 - Part No SW: 8S1 955 119 B HW: 8K1 955 119 B Labels: 5QX-955-119-V1.CLB
Component: 43x LL 170503 038 0371
Serial number: 00000001704270300355
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 62917241
Coding: 00005D
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - LDS MQB H05 0032
Serial number: 04 02 2017 00001570
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H08 0050
Serial number: 0000009600363Z0I1H02
Coding: 150000
Subsystem 5 - Part No SW: 8S0 959 719 HW: 8S0 959 719
Component: GTO BF H05 0010
Serial number: 20170531072118 00030
Subsystem 6 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000070123983
Subsystem 7 - Part No SW: 8S0 907 182 HW: 8S0 907 182
Component: N475 VB1 FSv H07 0021
Serial number: 7008173235E172403355
Coding: 810500
Subsystem 8 - Part No SW: 8S0 907 182 HW: 8S0 907 182
Component: N477 VB1 BFSv H07 0021
Serial number: 7008173235E172002885
Coding: 810500
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331718100439
Coding: 0070150011
VCID: C3C6180B4A667B5E57-8096
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 G HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0082
Serial number: 010717021
ASAM Dataset: EV_AudiMagneRide 002008
ROD: EV_AudiMagneRide_002_AU37.rod
VCID: C5C206134452456E79-8090
Part No SW: 5Q0 959 655 R HW: 5Q0 959 655 R
Component: AirbagVW20 010 0830
Serial number: 003M9R007CRL
Coding: BFCCF0C000800000A000001FC24800000065
VCID: CFEE243B962E8F3EC3-809A
Occupant Detection:
Subsystem 1 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH000000000007IM84J
Coding: 303333
Subsystem 2 - Part No SW: ----------- HW: 480 001 207 17
Serial number: 35700000000584346529
Subsystem 3 - Part No SW: ----------- HW: 480 001 207 17
Serial number: 358000000001A4346528
Subsystem 4 - Part No SW: ----------- HW: 480 012 006 17
Component: SideSensor_Dr 005 0108
Serial number: 351001A090B553233E3Z
Subsystem 5 - Part No SW: ----------- HW: 480 402 605 17
Serial number: 3550002A524F3841A393
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 480 402 605 17
Serial number: 3560002A124F3844B2C6
Part No SW: 8S0 907 129 AS HW: 8S0 907 129 AS
Component: Lenks. Modul H07 0150
Revision: -------- Serial number: 91335QFO01484
Coding: 2058
ASAM Dataset: EV_SMLSKLOMQB 050001
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 8B56F02B22B6F31E6F-80DE
Address 17: Instruments (J285) Labels:* Redir Fail!
Part No SW: 8S0 920 790 C HW: 8S0 920 790 C
Component: FBenRDW H42 0325
Coding: 082F1041398900080222ECC09800801000000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001027
ROD: EV_DashBoardBOSCHAU33X.rod
VCID: B93A7AE338AA318E0D-80EC
Part No SW: 8S0 907 468 F HW: 8S0 907 468 E
Component: GW MQB TT3 022 0304
Serial number: 03071710802613
Coding: 0301000424025D004B008028B80B00000000000000000000000000000001
ASAM Dataset: EV_GatewContiAU33X 013005
ROD: EV_GatewContiAU33X.rod
Subsystem 2 - Part No SW: 8S0 951 523 K HW: 8S0 951 523 K
Component: J453 MFL H01 0002
Serial number: 20161124040724 RD596
Subsystem 3 - Part No SW: 8W0 915 181 HW: 8W0 915 181
Serial number: 2570824404
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H52 7762
Serial number: HA1-00009.06.17
Coding: 0701
ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
VCID: CDD23E339C22BD2EB1-8098
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 8S0 907 566 HW: 4H0 907 566 F
Component: SWA Master H08 0060
Serial number: 0445223455
Coding: 030211
ROD: EV_LaneChangAssis_VW51.rod
VCID: FCB4A3F77718C4A656-80A8
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8S0 907 568 HW: 4H0 907 568 F
Component: SWA Slave H08 0060
Serial number: 0444142682
Coding: 030211
Component: TSG FS 020 0041
Serial number: 040717EG409686
Coding: 001F53225C00040100000402
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8106
ROD: EV_SteerAssisMQB_013_VW37.rod
Address 47: Sound System (J525) Labels:* None
Part No SW: 8S0 035 466 A HW: 8S0 035 466
Component: MIB2_amp_P_TT H10 0440
Revision: 00000001 Serial number: AUZ8ZAH5C005K8N
Coding: 0133040000AA2A2AAA0000010000
ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
VCID: B4244BD71FC8CCE6DE-80E0
Component: TSG BFS 020 0041
Serial number: 300617EFT37388
Coding: 001F53225E00040100000402
VCID: C2C81D0F557C72565C-8096
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Coding: 0362001123200400
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
VCID: B62071DF09B4DEF6E0-80E2
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01800
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01800
Subsystem 3 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 S002
Coding: E01800
Subsystem 4 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 S002
Coding: E01800
Part No SW: 8S0 035 025 F HW: 8S0 035 025 B
Component: MU-H-LNS-US 054 1135
Serial number: A707G0HS001853
Coding: 013364020000000011220002041A00002F0000E0007000047E
VCID: B02C47C7EBD0F0C6BA-80E4
Subsystem 1 - Part No SW: V03 959 801 GH HW: -----------
Component: NAR 2017/2018 --- 0060
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8S0 919 614 M HW: 8S0 919 614 M
Component: ControlUnit_H H30 0206
Serial number: APVAK124061700010099
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 3012
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 A HW: 5Q0 980 556
Component: RVC Compact H08 0172
Coding: 0233640102002001000040
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
VCID: B83C7FE703A02886F2-80EC
End----------(Elapsed Time: 01:38, VBatt start/end: 13.2V/13.2V)-----------
Saturday,21,October,2017,19:31:53:52505
VIN: WUACSAFV1J1111222 License Plate: TTRSHEXCANUSB
Mileage: 1054 Repair Order:
6C
Revision: 53H22000
VCID: 3A710377BD92809684-806E
Revision: 00H06V07
VCID: 2E593F2771DA5C3628-807A
VCID: 489569BFF37EE20602-801C
Coding: 030C0C1720
VCID: 3E790F67A1BAACB6B8-806A
VCID: 6CDDF52F8746EE2646-8038
VCID: 0815A9BFB3FE2206C2-805C
Coding: 1BC7F7
Coding: 00005D
Light switch:
Coding: 150000
Coding: 810500
Coding: 810500
Coding: 0070150011
VCID: 438F7E93CA58C15ED7-8016
VCID: 458B608BC46CFF6EF9-8010
VCID: 4FA742A31610353E43-801A
Occupant Detection:
Coding: 303333
Coding: 2058
VCID: 0B1F96B3A288491EEF-805E
VCID: 39731C7BB8948B8E8D-806C
Coding: 0701
VCID: 4D9B58AB1C1C072E31-8018
Coding: 030211
VCID: 7CFDC56FF7267EA6D6-8028
Coding: 030211
Coding: 8106
VCID: 346D2D4F9FF676E65E-8060
VCID: 42817B97D542C856DC-8016
VCID: 36691747898A64F660-8062
Coding: E01800
Coding: E01800
Coding: E01800
Coding: E01800
VCID: 3065215F6BEE4AC63A-8064
VCID: 3875197F839E928672-806C
End-------------------------(Elapsed Time: 04:55)--------------------------
