2004 A4 B6 2.0 FSI (AWA) Sport Avant lack of power
Graham
C?ID=313609
Earlier on in the week, I had the Traction Control / ESP warning light and the EPC warning light illuminate. The engine idled, but wouldn't rev. I switched the engine off for a few seconds and then restarted. This time, only the EPC light illuminated and the engine seemed to run fine. I drove for approx 15 mins when suddenly, while travelling at 70mph on a motorway, the engine just lost all power. I dipped the clutch fearing the timing had let go, to find the engine sat at idle and again wouldn't rev. I managed to get onto hard shoulder and switched the engine off for approx 30 seconds. Engine restarted, and drove fine for rest of journey. Read and cleared fault codes. I then decided to remove Throttle Body and gave it a decoke as I had tried to carry out an adaption which failed several times. Once clean and refitted, I successfully carried out an adaption. I drove the car today, it was okay for the 1st hour. When I came to restart after being parked up for 1 1/2 hours the faults have reappeared.
Below is a copy of the latest scan.
Saturday,21,October,2017,17:00:33:44933
Chassis Type: 8E (8EH - Audi A4 B6 (2004))
Scan: 01 03 08 09 15 16 17 45 46
VIN: WAUZZZ8E44A202712   Mileage: 215610km-133973miles
Address 01: Engine        Labels: 06D-906-018-AWA.lbl
   Part No SW: 8E1 910 018     HW: 8E1 906 018
   Component: 2.0L R4/4V FSI  G   0030
   Shop #: WSC 63251 000 00000
   VCID: 619CADB05D53525F344-5184
   Subsystem 1 - Part No: 8E0 907 807 B
   Component: NOX  0310090088 003 3205
   8E0907807B  NOX  0310090088 003 3205
7 Faults Found:
17698 - Coolant Temp Sensor at Radiator Outlet (G83)
            P1290 - 002 - Signal too Small - Intermittent
17480 - NOx Sensor (G295) Heater Control
            P1072 - 008 - Circuit Malfunction
16990 - Internal Control Module
            P0606 - 004 - Processor Fault - Intermittent
17987 - Throttle Actuator (J338)
            P1579 - 001 - Adaptation Not Started - Intermittent
17966 - Throttle Actuator (G186)
            P1558 - 002 - Electrical Malfunction - Intermittent
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
            P1171 - 008 -  - Intermittent
17976 - Throttle Actuator (J338)
            P1568 - 001 - Mechanical Failure
Readiness: 1010 0000
   Part No: 8E0 907 279 C
   Component: int. Lastmodul  RDW 0606
   Coding: 00101
   Shop #: WSC 63251
   VCID: 323E12FC4D3599C79DE-4B00
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 J
   Component: Airbag 8.4EP        1002
   Coding: 0010602
   VCID: 3E2636CC8C6D4DA7696-5184
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 01042
   Shop #: WSC 06325
   VCID: 41DC4D30F893325F144-4B00
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 -  -
   Part No: 8E0 920 950 N
   Component: KOMBI+WEGFAHRS. RB4 D42
   Coding: 02401
   Shop #: WSC 00186
   VCID: 343214E4B72197F78F2-5184
   WAUZZZ8E44A202712     AUZ6Z0C0460567
01304 - Radio
            49-00 - No Communications
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0704
   Coding: 00001
   Shop #: WSC 00186
   VCID: 6B80CF98AA9F080F9E8-5118
Address 46: Central Conv.        Labels:. 8E0-959-433-MIN.clb
   Part No: 8E0 959 433 BD
   Component: Komfortgerát TBF    1511
   Coding: 32763
   Shop #: WSC 00186
   VCID: 74B2D4E4F7A1D7F74F2-4B00
01134 - Alarm Horn (H12)
01616 - Signal Wire to Interior Monitor
End----------(Elapsed Time: 01:45, VBatt start/end: 12.1V/12.2V)-----------
Has anyone any ideas of what could be at fault or failing?
Thanks,
Graham
Ouch.
This fault: "16990 - Internal Control Module - Processor Fault - Intermittent" makes me wonder if the source of these issues isn't the ECU itself.
Graham
C?ID=313609
Not sure which route to take here. I can either take the ECU to BBA-Reman to be checked out and repaired if defective or see if I can source another ECU from somewhere. A lot depends on price.
Thanks for having a look for me.
Graham.
Graham
C?ID=313609
Took the ECU to be checked out. I have been told that the Ecu is not repairable due to corrupt data / internal processor fault , although it was passing the tests. I decided to buy a set of clocks and matched ECU. I fitted this to the car last night, swapped immobiliser in fob over to current key and started the engine. It still wouldn't rev above 3000rpm. I tried to carry out Throttle Body Alignment, but still resulted in errors. I decided to leave it last night and have another look today. Went to car this morning to find the battery totally flat. I had suspicions that a cell may be failing as it was 0ºC 32ºF in old money last night. Put battery on charge while I refitted original Throttle Body, tried to carry out Alignment but failed. Took car for a run once I managed to get it to rev above 3000rpm no load. Still had Steering fault and EPC lights illuminated. Couldn't even carry out basic setting on steering angle sensor. Decided to walk away before tools started taking flying lessons!!! Went to get something from shed and could here a faint beeping coming from the car alarm, but no hazards flashing. Then the cooling fan decided to run up to full speed then back off again. It did this several times. The engine was cold at this point. That's what probably flattened the battery. WTF is happening to my car??? Is it possessed!!!
If needed, i'll post the latest scan later.
Graham.
