Hi Guys, first post here so I shall try to make it short and sweet.
Story so far, got a call of my pal last week, his friend had brought his car in with the airbag light on. they got someone to look at it with a scan tool, I cant remember which one he said it was but it wasn't VCDS, he diagnosed a fault with the airbag module and they whipped it out and sent it off somewhere to get "repaired". it came back allegedly repaired, they fitted it and found the light still on so thought that it just needed flagged faults cleared which is where I came in.
As you can see from the scan there are faults with modules:
15- airbags (which is looking to me to be a defective unit)
37 and 56 (presumably these are both the same physical RNS300 head unit and have a coding issue)
7D- aux heating
3 questions
1) does the airbag controller req replaced or is there anything else that would throw up that fault ie wiring issue?
2) the radio/nav coding DTC clears but comes back on refresh, but coding seems correct according to here http://wiki.ross-tech.com/wiki/index.php/VW_Radio_Navigation_System_(RNS300)#Coding am I using the correct page?
3) the Aux heating DTC's do not clear (request not acknowledged by controller) any ideas?
thanks
Matt
7D- aux heating
3 questions
VCDS Version: 17.8.0.1 (x64)
Saturday,14,October,2017,16:16:19:42941
VIN: WVWZZZ1KZ7B000007 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 69 72 76
7D
VIN: WVWZZZ1KZ7B000007 Mileage: 158470km-98468miles
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 021 BA HW: 03G 906 021 BA
Component: R4 1,9L EDC G000SG 8818
Revision: --H02--- Serial number: VWZ7Z0E3033087
Coding: 0000072
Shop #: WSC 00046 000 00000
VCID: 5FCA3A7F8E9A21BED3-800A
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F8ADAFF6EDA01BEB3-806A
Part No: 1K0 907 044 BE
Component: ClimatronicPQ35 090 0808
VCID: 6BD25EAF4A224D1E4F-803E
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003768903
Coding: E68B8F2700041800001400001400000000087B075C
Shop #: WSC 00046 000 08192
VCID: 2B529EAF8AA28D1E0F-807E
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 181105 020 0501
Coding: 00038805
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 00046
Part No SW: 1K0 909 605 Q HW: 1K0 909 605 Q
Component: 12 AIRBAG VW8R 033 7900
Revision: 04033000 Serial number: 0038LD0900DO
Coding: 0012594
Shop #: WSC 00046 412 24576
VCID: 3A7CABEB75F8249684-806E
Subsystem 1 - Serial number: 6332MSME0E1A0E22E
Subsystem 2 - Serial number: 6342MSME0E673D10G
Subsystem 3 - Serial number: 6352QSME093077339
Subsystem 4 - Serial number: 6362QSME09381A31D
00003 - Control Module
014 - Defective - Intermittent - MIL ON
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 035 0070
Coding: 0000042
Shop #: WSC 00046 412 442368
VCID: 74E045D3171C92E69E-8020
Part No SW: 1K0 920 973 B HW: 1K0 920 973 B
Component: KOMBIINSTRUMENT VDD 0604
Revision: X0002000 Serial number: VWZ7Z0E3033087
Coding: 0003403
Shop #: WSC 00339 067 57207
VCID: 2C509DB38FAC8A2606-8078
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 3100105A1289A6
Coding: 7D3F4F4807000003
Component: IMMO VDD 0604
Shop #: WSC 00339 210 91067
Address 37: Navigation Labels: None
Part No SW: 1K0 919 887 J HW: 1K0 035 191 D
Component: J401 0111
Revision: 00014000 Serial number: VWZ1Z2F6017747
Coding: 0041400
Shop #: WSC 00046 234 24576
VCID: 4088D90313247E46CA-8014
Fault Status: 00000011
Reset counter: 31
Mileage: 158471 km
Time: 00:49:51
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 003 09X4
Coding: 0000694
VCID: 397EB4E770FE2F8E8D-806C
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.069 H07 1804
VCID: 3566B8D75CE6CBEE69-8060
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 019002005103087F2D0484057008DFC690FC00
VCID: 0302160F42B2A55E97-8056
Subsystem 2 - Part No: 1K0 951 178
Component: Neigungssensor 001 0101
Subsystem 3 - Part No: 1K0 951 178
Component: Innenraumueberw.001 0101
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000950
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
Address 56: Radio Labels: None
Part No SW: 1K0 035 153 G HW: 1K0 035 191 D
Component: R 0111
Coding: 0041400
VCID: 24407593E77C4266CE-8070
Reset counter: 31
Mileage: 158471 km
Time: 00:49:51
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 003 0901
Coding: 0000144
Shop #: WSC 00046 000 1012544
VCID: 3878B1E34BF4368672-806C
Address 69: Trailer Labels: 1K0-907-383-V1.clb
Part No SW: 1K0 907 383 HW: 1K0 907 383
Component: ANHAENGERELEKTR 001 0020
Shop #: WSC 00046 412 163840
VCID: 6ADC5BAB45D8541634-803E
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 22 Einparkhilfe 0101
VCID: 2D5690B7B4B6832E11-8078
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
014 - Defective
End-------------------------(Elapsed Time: 02:08)--------------------------
thanks
Matt
