Car has retrofitted Original Control Stalk and now I try to get that working.
I tried to code it and ECU accepted cruise control coding, but after that I got drivetrain fault in dashboard.
Fault codes say that some Coding of Powertrain Control Modules is wrong. That fault code comes only ECU, all another control modules won't show any fault codes.
So any idea what else should be coded that cruise would start to work ?
Autoscan was taken which out coding and fault codes..
VIN: TRUZZZFV3F1004802 License Plate:
Chassis Type: FV-AU37 (8S0)
Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 47 52 55 5F A5 A9
Address 01: Engine (J623-CHHC) Labels:. 06K-907-425-V1.clb
Part No SW: 8S0 906 259 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1900322404010B3002
Shop #: WSC 00145 205 00020
ASAM Dataset: EV_ECM20TFS0208S0906259 001003
ROD: EV_ECM20TFS0208S0906259.rod
VCID: 7AAEFA8CCC5BFF3715E-802E
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 8S0 907 379 B HW: 8S0 907 379 B
Component: ESC H31 0504
Revision: 00000000 Serial number: 62814000000641
Coding: 32AA108D0A9915AD40990064C2938306444C0850A8020043C16022
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
ROD: EV_Brake1UDSContiMK100IPB_052.rod
VCID: 40DA4864EA0765E71BA-8014
Part No SW: 3Q0 959 435 HW: 3Q0 959 435
Component: VWKESSYMQB 023 0522
Revision: 00023000 Serial number: 0347536200
Coding: 000F0F1620
ASAM Dataset: EV_KessyHellaMQBAB 004027
VCID: 77A8E3B8FF49E25F6A0-8022
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 043 HW: 8S0 820 043
Component: AC Automat H05 0020
Revision: 20008000 Serial number: 89300000004318
Coding: 400040000011101100
ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
ROD: EV_AirCondiVAPrehAU33x.rod
VCID: 6C82CCD4B60F5187972-8038
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: D0494557000000000001
Operating and display unit 1 for air conditioning:
Subsystem 2 - Part No SW: 8S0 820 373 A HW: 8S0 820 373 A
Component: E774 BuA_1 H06 0010
Serial number: 00000000000000004046
Operating and display unit 2 for air conditioning:
Subsystem 3 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H06 0010
Operating and display unit 3 for air conditioning:
Subsystem 4 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H06 0010
Operating and display unit 4 for air conditioning:
Subsystem 5 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H06 0010
Operating and display unit 5 for air conditioning:
Subsystem 6 - Part No SW: 8S0 820 373 B HW: 8S0 820 373 B
Component: E778 BuA_5 H06 0010
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 BR HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0136
Serial number: 01011428000196
Coding: 04054A46C20124DD43044004000007A80080000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 094C954099BDE4AF0C4-805C
Subsystem 1 - Part No SW: 8S1 955 119 A HW: 8K1 955 119 B Labels: 5QX-955-119-V1.CLB
Component: 43x LL 140612 032 0371
Serial number: 00000001406100706072
Coding: 1BC7F7
Light switch:
Subsystem 2 - Part No SW: 8V0 941 531 T HW: 8V0 941 531 T
Component: E1 - LDS MQB H05 0032
Serial number: 07 08 2014 00001344
Subsystem 3 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20890119
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 E HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0051
Revision: -------- Serial number: 39231428700262
Coding: 0000040001
ROD: EV_EPHVA14AU3700000_002_AU37.rod
VCID: 3B203F8883E1063F4E8-806E
Part No SW: 5Q0 959 655 P HW: 5Q0 959 655 P
Component: AirbagVW20 009 0870
Serial number: 003M7R0038RB
Coding: 88CCF0000C8000005C5000CFC04800000065
VCID: 4DC461502D55B88FE0C-8018
Subsystem 1 - Part No SW: ----------- HW: 480 002 410 14
Serial number: 35700000000840547112
Subsystem 2 - Part No SW: ----------- HW: 480 002 410 14
Serial number: 35800000000FCC44711T
Subsystem 3 - Part No SW: ----------- HW: 480 012 708 14
Component: SideSensor_Dr 004 0108
Serial number: 351001A0154CA2D27F05
Subsystem 4 - Part No SW: ----------- HW: 480 400 808 14
Serial number: 3550002C516DB812225/
Front Sensor Passenger:
Subsystem 5 - Part No SW: ----------- HW: 480 400 808 14
Serial number: 3560002C516DB814C1CG
Pedestrian Protection Center:
Subsystem 6 - Part No SW: ----------- HW: 480 402 605 14
Component: PedP_Sensor_C 001 6149
Serial number: 23000029914D3E72D231
Subsystem 7 - Part No SW: ----------- HW: 480 000 210 14
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000CB3E46116
Subsystem 8 - Part No SW: ----------- HW: 480 000 210 14
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000EF6F4611H
Part No SW: 8S0 907 129 AC HW: 8S0 907 129 AC
Component: Lenks. Modul H06 0140
Revision: -------- Serial number: 91335NJ900541
Coding: 2808
ASAM Dataset: EV_SMLSKLOMQB 019002
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 7BA0FF88C361C63F0E8-802E
Address 17: Instruments (J285) Labels:* Redir Fail!
Part No SW: 8S0 920 790 HW: 8S0 920 790
Component: FBenRDW H32 0221
Coding: 04050110698000080000E8C09000800000000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001013
ROD: EV_DashBoardBOSCHAU33X.rod
VCID: 76B6EEBCF8439B57716-8022
Part No SW: 8S0 907 468 A HW: 8S0 907 468
Component: GW MQB TT3 012 0203
Revision: -------- Serial number: 30091410800158
Coding: 030100042F025A004B000268080000000000000000000000000000000001
ASAM Dataset: EV_GatewContiAU33X 011002
ROD: EV_GatewContiAU33X.rod
VCID: 3E26369C90F31317696-806A
Subsystem 2 - Part No SW: 8S0 951 523 B HW: 8S0 951 523 B
Component: J453 MFL H06 0001
Serial number: 20140820134245 RD368
Subsystem 3 - Part No SW: 8S0 915 181 A HW: 8S0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 8855264703
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 14000208673003
Coding: 0100000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71BCDDA0912DBC6FA44-8024
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 28101403111377
Coding: 001F47224100040100001402
VCID: 42DE426CE40B77F70DE-8016
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5061
Coding: 9103
ROD: EV_SteerAssisMQB.rod
VCID: 372823B8BFC9225FAA0-8062
Address 47: Sound System (J525) Labels:* None
Part No SW: 8S0 035 465 HW: 8S0 035 465
Component: MIB2_amp_P_TT H06 0170
Revision: 00000001 Serial number: AUZ8ZAEH7001YG2
Coding: 0133040000AA2A2AAA0000010000
ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
VCID: 72BED2AC942B87775DE-8026
0590 - Double Bass Speaker 1; Front Left
B1345 13 [009] - Open Circuit
Reset counter: 193
Mileage: 59114 km
Date: 2017.10.18
Time: 10:14:58
Voltage terminal 30: 11.8 V
0595 - Double Bass Speaker 2; Front Left
B1347 13 [009] - Open Circuit
Reset counter: 193
Mileage: 59114 km
Date: 2017.10.18
Time: 10:14:58
0605 - Double Bass Speaker 2; Front Right
B1348 13 [009] - Open Circuit
Reset counter: 193
Mileage: 59114 km
Date: 2017.10.18
Time: 10:14:58
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 01111402080123
VCID: 41DC4D60E10D6CEF144-8014
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 0398000E01000000
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
VCID: 75B4E9B0E545904F78C-8020
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8S0 035 043 HW: 8S0 035 043
Component: MU-H-N-EU H33 0117
Serial number: A260J0E7509882
Coding: 013304010000000011110002000800032F0000E100700000DE
VCID: 6A8ECACCBCFB4FB7E5E-803E
Subsystem 1 - Part No SW: V03 959 801 ES HW: -----------
Component: ECE 2014/2015 --- 0086
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8S0 919 614 A HW: 8S0 919 614 A
Component: ControlUnit_H H21 0124
Serial number: C1000003091400010018
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1010
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3AA-980-654.clb
Part No SW: 8S0 980 653 HW: 5Q0 980 653
Component: MQB_MFK H06 0002
Serial number: 10000141496
Coding: 0100000001010305000401000000000100
ROD: EV_MFKBoschAU370.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8S0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0002
Serial number: 140925204183
ROD: EV_SoundActuaGen2AU64X_VW26.rod
End(Elapsed Time: 14:26, VBatt start/end: 12.0V/11.9V. VIgn 12.0V, Deb=2)--
