Hi guys
I have a Jetta 1.4tsi 2016 trendline (equivalent to SE approximately), panel with simple on-board pc (no selectable multifunction menu):
I installed the TPMS and ASR OFF buttons, ASR OFF worked okay, however on the TPMS I am not able to hit the coding, despite numerous attempts
In Central 03 - ABS -> Measuring Blocks group 016 when the TPMS button is pressed it indicates the operation, ie, working ok on pin 35
Configuration:
1. IN CENTRAL 03 - ABS BRAKES:
- Byte 16 enable bit 2
- Byte 17 manually change the hexadecimal address (which should be at 18) to 1E, to do so, just type 1E and give enter to confirm the change
- Byte 19 manually change the hexadecimal address (which should be at 10) to 73, for that, just type 73 and give enter to confirm the change
2. IN CENTRAL 17 - INSTRUMENTS:
- Byte 2 activate bit 0
3. IN CENTRAL 19 - CAN GATEWAY:
In Installation List activate the 4C control unit - Tire Pressure II
(I had installed the 65, it was error, after I noticed it has to be at 4C)
Well, with calibrated tires I was in the Central 03 - ABS went to Basic Settings and I accessed the channel 42 to reset, I rode a more of 10 km variable speed, I returned to the post, I lowered the calibration of a tire from 32 to 24psi, I left and in approximately 1km ... the tpms light lit with a chime
But the problem, I returned to the post, recalibrated the 32psi, I pressed the button and nothing of the light erase, I pressed with asr off and nothing, I held tight for 5s and nothing, I turned a few kilometers and I pressed again anyway ... nothing
Just need to reset by the button to be perfect, as I said at the beginning: in group block 16 indicates that the button works, what do I need to change?
Original ABS code:
A43B40F8092500FB250C02E6901D004120100010
related is
A43B40F8092500FB250C02E6901D0041241E0073
My actual scan, in tests, is:
Thanks guys
Configuration:
Original ABS code:
related is
Wednesday,18,October,2017,21:14:32:07368
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: 3VW2J2165GM0XXXXX License Plate:
Chassis Type: 16-VW32 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4C 52 56 62 72
VIN: 3VW2J2165GM0XXXXX Mileage: 11380km-7071miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (J623-CZDA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 JM HW: 04E 907 309 BK
Component: R4 1.4l TFS H23 2494
Revision: R9H23---
Coding: 001A0012230418080000
Shop #: WSC 00066 123 00293
ASAM Dataset: EV_ECM14TFS01104E906027JM 001003
ROD: EV_ECM14TFS01104E906027JM.rod
VCID: 78AAE0192252874763A-802C
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 749 AA HW: 09G 927 749 AA
Component: AISIN AG6 G3 129 2944
Coding: 010100000C000000000000000000000000000000
Shop #: WSC 00066 790 00016
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031_002_VW25.rod
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: A43B40F8092500FB250C02E6901D004125180073
Shop #: WSC 00066 123 12345
VCID: 75B4E92D35C0FA2F78C-8020
Part No SW: 1K8 907 426 AB HW: 1K8 907 426 AB
Component: AC Manuell H20 0808
Revision: 00001002
Coding: 0010004002
Shop #: WSC 00066 000 00319
VCID: 73B0D7353B34E41F568-8026
Part No SW: 5K0 937 087 AG HW: 5K0 937 087 AG
Component: BCM PQ35 H+ 122 0183
Revision: BF122001
Coding: 0E000A2C882FE3D0408800800400002407200008508089205C8000000040
VCID: 7AAEFA111CDE955715E-802E
Subsystem 1 - Part No: 5C0 951 171
Component: Sensor, DWA 0 005 0502
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0479
Revision: -------- Serial number: 39391534404122
Coding: 0031050011
Shop #: WSC 00066 123 00319
ASAM Dataset: EV_EPHVA18VW364GP00 001006
VCID: 36362E2168C6B137B16-8062
Part No SW: 5C0 959 655 AF HW: 5C0 959 655 AF
Component: AirbagVW10 015 0614
Serial number: 003S2M07EBUV
Coding: 00004334
ASAM Dataset: EV_AirbaVW10SMEVW360 001032
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 76B6EE212846F137716-8022
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Serial number: 3572MSME30361A55ZZZQ
Serial number: 3582MSME15361A55ZZZU
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME7520673BZZZU
Serial number: 3526KSME6801603BZZZP
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: --X01--- Serial number: 20151031300379
Coding: 4892040000
Shop #: WSC 01286 386 08256
ROD: EV_SMLSNGVOLWS.rod
VCID: 025E82F1748EDD974DE-8056
Subsystem 1 - Part No SW: 2H0 959 442 HW: 2H0 959 442
Component: E221__MFL-DC1 H01 0103
Serial number: 27140002091400024343
Coding: A5FFFF
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5C6 920 865 HW: 5C6 920 865
Component: KOMBI H04 1008
Coding: 170B010000
VCID: 6C82CC49660A3BE7972-8038
Part No SW: 7N0 907 530 BD HW: 7N0 907 530 AK
Component: J533 Gateway H57 1673
Revision: H57 Serial number: 04021603010455
Coding: 351002
VCID: 73B0D7353BB4E41F568-8026
Reset counter: 73
Mileage: 11386 km
Date: 2017.10.18
Time: 21:10:19
03109 - Tire Pressure Monitoring Control Module 2 (J793)
Reset counter: 73
Mileage: 11386 km
Date: 2017.10.18
Time: 21:10:23
Component: IMMO H04 1008
VCID: 6A8ECA516CFE25D7E5E-803E
Part No SW: 561 959 701 B HW: 3C0 959 793 H
Component: TUER-SG FT 002 0631
Revision: 13100010 Serial number: 0010249725
Coding: 0400B5
Shop #: WSC 00066 790 00083
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
VCID: 1D64D18DED30026F50C-8048
Slave Driver:
Subsystem 1 - Part No SW: 6R0 959 811 T HW: 6R0 959 811 T
Component: J388__TSG_HL 019 1467
Serial number: 14102745160112171450
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 69 3501
Revision: 00H22000
VCID: 392C251D55585E4F5C4-806C
Part No SW: 561 959 702 B HW: 3C0 959 792 H
Component: TUER-SG BT 002 0631
Revision: 15100010 Serial number: 0010257917
Coding: 0401B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
VCID: 1E66D681E0361977496-804A
Slave Passenger:
Subsystem 1 - Part No SW: 6R0 959 812 T HW: 6R0 959 812 T
Component: J389__TSG_HR 019 1467
Serial number: 14202744160114093128
Address 56: Radio
End----------(Elapsed Time: 00:59, VBatt start/end: 12.0V/12.0V)-----------
Thanks guys
