Results 1 to 4 of 4
Thread: New Audi S5 - What functions are possible using older Hex-Can cable
    Nov 2015
    Hi All,
    I just took delivery of new Audi S5 more or less fully loaded but as always something missing what in my opinion is quite useful
    I refer to the function where by placing the gear to Park Position automatically engages the electromechanical handbrake.
    Below is the scan from my hex-can cable, however I have very limited use of the functions unable to modify most modules due to access limitation
    Would this be due to the older version cable or the updated Audi software ?
    If not, can anyone advise me where to implement this change ?
    Previously on my Audi A6 Avant 63 Plate, I was able to adjust most convenience modules
    Many Thanks...........
    Saturday,30,September,2017,14:32:18:01150
    VCDS Version: 16.8.0.3 (x64)
    Data version: 20160803 DS255
    VIN: WAUZZZF54HA001xxx   License Plate:
    Chassis Type  F5 (8W7)
    Scan: 01 02 03 06 08 09 13 15 16 17 19 1B 2B 32 36 3C 42 44 47 52
              5F 6C 81 82 8B A5 A9 BB BC
    BB-Door Rear Drv -- Status: Not registered 0001
    BC-Door Rear Pass -- Status: Not registered 0001
    Address 01: Engine (------CWGD)       Labels: None
       Part No SW: 8W0 907 559 G    HW: 06M 907 309 D
       Component: 3.0l V6 TFSI  H21 0007
       Revision: B2H21000
       Coding: 1A2A00322366050B34380000000000000000000000000000
       Shop #: WSC 06314 790 00001
       ASAM Dataset: EV_ECM30TFS0118W0907559G 001010
       ROD: N/A
       VCID: 4999971AE8BD7C0A37-801C
    No ASAM data for: "EV_ECM30TFS0118W0907559G" ()
    Address 02: Auto Trans (J217)       Labels: None
       Part No SW: 8W0 927 158 B    HW: 0D5 927 156 H
       Component: 0D5  30TSIRdW H03 1004
       Revision: --H03---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 41898F3AD08DB44AEF-8014
       Part No SW: 8W0 907 379 F    HW: 8W0 907 379 D
       Component: ESP9 Premium  H09 0593
       Coding: 1CAA149A30A20A9715A64898407E58A2E6A59A38280C50A812021A4567A559
       Shop #: WSC 06324 790 00001
       ASAM Dataset: EV_ESP9BOSCHAU49X 012014
       ROD: EV_ESP9BOSCHAU49X.rod
       VCID: 489F921EF3B7850228-801C
       Part No SW: 4M0 959 760 A    HW: 4M0 959 760 A
       Component: MEM-BFS       008 0031
       Serial number: 00000216261499
       Coding: 00321004000CB0010003010141010000000000000000000000000000802003
       Shop #: WSC 06325 790 00001
       ROD: EV_SCMDriveSideCONTIAU736_AU73.rod
       VCID: 3663ECE6894303F24A-8062
    Address 08: Auto HVAC (E87)       Labels: None
       Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
       Component: Klima Zone 3  H32 0071
       Coding: 4608000D5544450D02020100880000000000000000000000000000000000
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 377DE1E28E49FAFA51-8062
       Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000001024603
       Component: AQ_Hum_Sensor  H01 0005
       Serial number: FC19464800PAG0MUFU02
       Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
       Component: Klima Heck  H40 0073
       Part No SW: 8W0 907 063 BG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0248
       Coding: 07501143C13900CD050D59191BAD84B9130B31040000000000000000600016810A4502ABA2B70A
       ASAM Dataset: EV_BCM1BOSCHAU736 016006
       ROD: N/A
       VCID: 01094F3A900D744AAF-8054
       Subsystem 1 - Part No SW: 8W6 955 119 A    HW: 8W6 955 119 A
       Component: 494 RL 160331  036 0471
       Serial number: 00000001603290300435
       Coding: 5FC7F7
       Serial number: 20038066X81A955555A0
       Coding: 02005D
       Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
       Component: E1 - LDS  H06 0008
       Serial number: 31 05 2016  00386899
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE127061612010148
       Coding: 230000
       Subsystem 5 - Part No SW: 8W0 947 135 BQ    HW: 8W0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: B10236860
       Subsystem 6 - Part No SW: 8W0 925 301 BF    HW: 8W0 925 301 BF
       Component: SL-B9/Q5NF  H15 0010
       Serial number: 2615000152367004
       Subsystem 7 - Part No SW: 8W0 907 182     HW: 8W0 907 182
       Component: J873 MKS_FSv  H03 0033
       Serial number: 7008174235B161902885
       Coding: BF0500
       Subsystem 8 - Part No SW: 8W0 907 182     HW: 8W0 907 182
       Component: J872 MKS_BFSv  H03 0033
       Serial number: 7008174235B161902867
       Coding: B30500
    No ASAM data for: "EV_BCM1BOSCHAU736" ()
    Address 13: Auto Dist. Reg (J428)       Labels: None
       Part No SW: 8W0 907 561 B    HW: 8W0 907 561
       Component: LRR4          H09 0220
       Coding: 3477FFF358FFEC06747860A0
       ASAM Dataset: EV_ACCBOSCHAU49X 002018
       ROD: EV_ACCBOSCHAU49X.rod
       VCID: 3D71F3CAAC75D0AA8B-8068
    Address 15: Airbags (J234)       Labels: None
       Part No SW: 8W0 959 655 B    HW: 8W0 959 655 B
       Component: Airbag10.44   H73 0086
       Serial number: 003QQ000521K
       Coding: AACCF0C00C800000985000F3C0CC00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: N/A
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2033
       Serial number: 8W6857705A0033R00703
       Coding: 88001B
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2033
       Serial number: 8W6857706A0235Q00449
       Coding: 88001B
       Subsystem 3 - Part No SW: -----------    HW: 442 062 508 16
       Serial number: 3577Y00C31FBD72214EC
       Subsystem 4 - Part No SW: -----------    HW: 442 062 508 16
       Serial number: 3587Y00C11FBD7204240
       Subsystem 5 - Part No SW: -----------    HW: 442 0B2 307 16
       Serial number: 35177009D2106CB602BA
       Subsystem 6 - Part No SW: -----------    HW: 442 0B2 307 16
       Serial number: 3527700B92106CB26277
       Subsystem 7 - Part No SW: -----------    HW: 442 0C0 308 16
       Serial number: 3557500A920F7C25F11I
       Subsystem 8 - Part No SW: -----------    HW: 442 0C0 308 16
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500A920F7C24E07M
       Subsystem 9 - Part No SW: -----------    HW: 442 0C0 308 16
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500A1211FA12F17/
       Subsystem 10 - Part No SW: -----------    HW: 442 430 808 16
       Component: PedPSensor_D2  256 0887
       Serial number: I0M9M00991FB75F3B21V
       Subsystem 11 - Part No SW: -----------    HW: 442 430 808 16
       Component: PedPSensor_P2  256 0887
       Serial number: I0N9M00991FB75F202DW
    No ASAM data for: "EV_AirbaAU10BPAAU736" ()
       Part No SW: 4M0 907 129 HH    HW: 4M0 907 129 HH
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_AU49.rod
       VCID: 7DF133CAECF510AACB-8028
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 8W5 920 790 C    HW: 8W5 920 790 C
       Component: FBenRDW       H15 0299
       Coding: 248D19DA7CB8060001B3E9601000400000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       ROD: EV_DashBoardAU736.rod
       VCID: 428B8036D58BAF52F6-8016
       Part No SW: 8W7 907 468 C    HW: 8W7 907 468 C
       Component: Gateway       H27 1298
       Revision: 4M090005    Serial number: 0584M273516905
       Coding: 0301000100008E405407000000590012F4900007920000000175078E00000000
       ASAM Dataset: EV_CGateCONTIAU491 002060
       ROD: EV_CGateCONTIAU491.rod
       VCID: 4B95AD12E2C16E1A05-801E
       Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0002
       Serial number: 20160816183416 21071
       Serial number: 0528641304
       Part No SW: 8W0 907 144 E    HW: 8W0 907 144 C
       Component: SCU_MLBevo    H03 0706
       Coding: 40
       ASAM Dataset: EV_SCUZFLSAU49X 002014
       ROD: EV_SCUZFLSAU49X.rod
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 16000145953006
       Coding: 8800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 326BD0F6652B1FD266-8066
    Address 32: Differential Locks (J187)       Labels: None
       Part No SW: 8W0 907 163     HW: 8W0 907 163
       Component: QSP QCU Gen2  H07 0030
       Revision: 5WK12700    Serial number: 605633215250607
       Coding: 0001
       ASAM Dataset: EV_TVDCQSP22 001007
       ROD: N/A
       VCID: 79F927DAF8DD2C8AE7-802C
    No ASAM data for: "EV_TVDCQSP22" ()
       Component: MEM-FS        008 0031
       Serial number: 00000213647679
       Coding: 00621004000CB0010003010141010000000000000000000000000000802003
    Address 3C: Lane Change (J769)       Labels: None
       Part No SW: 4M0 907 566 B    HW: 4M0 907 566
       Component: MRR1Rear      H13 0230
       Revision: --------
       Coding: 4EC002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001015
       ROD: EV_RearRadarS1BoschAU736.rod
       VCID: 3467D6EE9F3F11E274-8060
       Part No SW: 4M0 959 793 E    HW: 4M0 959 793 C
       Component: TSG FS        009 0055
       Serial number: 0000214928819
       Coding: 005D5A4250010085000034B2
       ROD: EV_DCU2DriveSideMAXHCONT.rod
       VCID: 408F8A3EDB87BD42E0-8014
    196660 - Motor for Window Regulator
              B1487 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 40
                        Mileage: 42 km
                        Date: 2017.06.08
                        Time: 00:00:06
    Address 44: Steering Assist (J500)       Labels: None
       Part No SW: 8W0 909 144 F    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0407
       Coding: 85888380008080
       ASAM Dataset: EV_EPSZFAU49X 002015
       ROD: EV_EPSZFAU49X.rod
       Part No SW: 8W0 035 465     HW: 8W0 035 465
       Component: MIB2_amp_P_B9 H11 0420
       Revision: 00000001    Serial number: AUZ8ZAGJA00EG7
       Coding: 0194040800AFAAAFAA0000010000
       ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
       ROD: N/A
       VCID: 76E32CE6C9C343F28A-8022
    No ASAM data for: "EV_AMPMst16C2Gen2ALPI" ()
       Part No SW: 4M0 959 792 E    HW: 4M0 959 792 C
       Component: TSG BFS       009 0055
       Serial number: 0000216016087
       Coding: 005D5A425C010085000034B0
       ROD: EV_DCU2PasseSideMAXHCONT.rod
       VCID: 3F8D89C2A679C2BA99-806A
                        Reset counter: 40
                        Mileage: 42 km
                        Date: 2017.06.08
                        Time: 00:00:06
       Part No SW: 8W0 035 035 C    HW: 8W0 035 035 A
       Component: MU-P-LND-EU   052 0678
       Serial number: A791H0G2501883
       Coding: 019454010000000053111102000A00332F0012E7017001009E
       ROD: N/A
       Subsystem 1 - Part No SW: V03 959 801 FB    HW: -----------
       Component: ECE 2016/2017  --- 0153
       Subsystem 2 - Part No SW: 8W2 919 605     HW: 8W2 919 605
       Component: AU49x_DU_HIGH  H40 0008
       Serial number: AUZ8Z9GBK008XN
       Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
       Serial number: APVAK110081600040235
       Component: Gracenote2---  --- 1013
    No ASAM data for: "EV_MUHig6C3Gen2HBAS" ()
    Address 6C: Back-up Cam. (J928)       Labels: None
       Part No SW: 4M0 907 428 D    HW: 4M0 907 428
       Component: Areaview 2    H12 0311
       Serial number: C854607JG002497
       Coding: 02940401BE0FA10008404080
       ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
       ROD: EV_CamSysRVAV2CE2MLBEv_AU49.rod
       VCID: 3365D5F29A3116DA6D-8066
       Part No SW: 8W2 713 041 D    HW: 4M2 713 041 D
       Component: GSM-LL        H08 0068
       Revision: 0L0D5012    Serial number: 20160709000396
       ASAM Dataset: EV_GSMWaehlZFAU736 001013
       ROD: N/A
       VCID: 3561EBEA944508EA43-8060
    No ASAM data for: "EV_GSMWaehlZFAU736" ()
    Address 82: Heads Up Display (J898)       Labels: None
       Part No SW: 8W6 919 617 A    HW: 8W6 919 617 A
       Component: HeadUpDisplay H07 1603
       Coding: 4F01C0
       ASAM Dataset: EV_HudNSEIKAU736 001015
       ROD: EV_HudNSEIKAU736.rod
       VCID: 479D9122FEA98A7A21-8012
    Address 8B: Adaptive Cruise 2 (J850)       Labels: None
       Part No SW: 8W0 907 541 B    HW: 8W0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU49X 002018
       ROD: EV_ACC2BOSCHAU736_AU73.rod
       VCID: 3B75FDD2B261DE9AB5-806E
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
       Part No SW: 8W6 907 217     HW: 8W6 907 217
       Component: BVS           H14 0042
       Coding: 0404090400000404014023A6CD0000FCB0F0C020E280
       ROD: N/A
       VCID: 7F0DC9C2E6F902BAD9-802A
    No ASAM data for: "EV_BVSMLBevKOSTAAU736" ()
    1123600 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 42
                        Mileage: 47 km
                        Date: 2017.06.12
                        Time: 15:10:10
    1123601 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 42
                        Mileage: 73 km
                        Date: 2017.06.24
                        Time: 12:07:41
    Address A9: Struct. Borne Sound (J869)       Labels: None
       Part No SW: 8W0 907 159 F    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0005
       Serial number: 160318200957
       VCID: 4487862ECF9FA162C4-8010
    Address BB: Door Rear Drv
    Address BC: Door Rear Pass
    End-------------------------(Elapsed Time: 05:53)--------------------------
    It's a combination of things:
    The very first thing to do with a brand-new car is to update to a current version of VCDS. 16.8 isn't current at all. There have been two major releases since then; 17.1 and 17.8... Anyway, the update is free, so there's no reason not to.
    Next, it looks like there's some stuff in that car that the old HEX+CAN interface you're using can't talk to at all and you really should consider upgrading to a current interface.
    Lastly, with a brand-new car there is always the question of how much is documented.
  3. Likes Eric liked this post
    Nov 2015
    Updated VCDS 17.80.1
    Thanks UWE
    I've updated the software and just took the following scan
    I appears that I can open more modules now but still not allowing entry to coding.
    When it does, obviously with the new Audi software we are still in catch up to understand all of the functions
    I contacted Gendan today to purchase the latest Hex V2. However, would be interesting to know if I am able to change the coding with existing cable to active the handbrake when selecting park function on the gear stick ?
    Many Thanks
    gwakef
    Friday,20,October,2017,16:37:01:01150
    VCDS Version: 17.8.0.1 (x64)
    Mileage: 657km-408mi   Repair Order: S5 20.10.2017
    Chassis Type  F5-AU49 (8W7)
    VIN: WAUZZZF54HA001xxx   Mileage: 657km-408miles
       Revision: B2H21000
       ROD: EV_ECM30TFS0118W0907559G.rod
       VCID: 4999971AE8BD7C0E1D-801C
    Address 02: Auto Trans (J217)       Labels:* None
       Revision: --H03---
       Coding: 100000
       ROD: EV_TCMALX52011_AU49.rod
       VCID: 41898F3AD08DB44EC5-8014
    Address 03: ABS Brakes (J104)       Labels:. 8W0-907-379-PRE-V1.clb
       ROD: EV_ESP9BOSCHAU49X_012.rod
       VCID: 489F921EF3B7850602-801C
       ROD: EV_SCMPasseSideCONTIAU736_AU37.rod
       VCID: 3663ECE6894303F660-8062
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       VCID: 377DE1E28E49FAFE7B-8062
       ROD: EV_BCM1BOSCHAU736_016_AU49.rod
       VCID: 01094F3A900D744E85-8054
       Coding: 5FC7F7
       Coding: 02005D
       Light switch:
       Coding: 230000
       Interior Light Module:
       Coding: BF0500
       Coding: B30500
       ROD: EV_ACCBOSCHAU49X_002.rod
       VCID: 3D71F3CAAC75D0AEA1-8068
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
       ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
       Belt Pretensioner left:
       Coding: 88001B
       Belt Pretensioner right:
       Coding: 88001B
       Front Sensor Passenger:
       Pedestrian Protection Center:
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 7DF133CAECF510AEE1-8028
    Address 17: Instruments (J285)       Labels:* 8W5-920-xxx-17.clb
       VCID: 428B8036D58BAF56DC-8016
       ROD: EV_CGateCONTIAU491_002_AU49.rod
       VCID: 4B95AD12E2C16E1E2F-801E
       Coding: 40
       ROD: EV_SCUZFLSAU49X_002.rod
       ROD: EV_ELVMarquMQBB_VW37.rod
       VCID: 326BD0F6652B1FD64C-8066
       Coding: 0001
       ROD: EV_TVDCQSP22_AU49.rod
       VCID: 79F927DAF8DD2C8ECD-802C
       ROD: EV_SCMDriveSideCONTIAU736_AU37.rod
    Address 3C: Lane Change (J769)       Labels:* None
       Revision: --------
       Coding: 4EC002
       VCID: 3467D6EE9F3F11E65E-8060
       VCID: 408F8A3EDB87BD46CA-8014
       ROD: EV_EPSZFAU49X_002.rod
       ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
       VCID: 76E32CE6C9C343F6A0-8022
       VCID: 3F8D89C2A679C2BEB3-806A
       Multimedia Operating Unit:
       ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
       VCID: 3365D5F29A3116DE47-8066
       ROD: EV_GSMWaehlZFAU736_AU49.rod
       VCID: 3561EBEA944508EE69-8060
       Coding: 4F01C0
       ROD: EV_HudNSEIKAU736_AU49.rod
       VCID: 479D9122FEA98A7E0B-8012
       ROD: EV_ACC2BOSCHAU736_002_AU73.rod
       VCID: 3B75FDD2B261DE9E9F-806E
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
       VCID: 7F0DC9C2E6F902BEF3-802A
    1123600 - predictive route data
              B1630 02 [008] - Signal Failure
                        Reset counter: 61
                        Mileage: 539 km
                        Date: 2017.10.18
                        Time: 13:46:28
                        Control Module temperature: 24 C
                        Voltage terminal 15: 14.90 V
       ROD: EV_SoundActuaGen2AU64X_VW26.rod
       VCID: 4487862ECF9FA166EE-8010
    Virus-free. www.avg.com
  5. Likes Uwe liked this post
  6. #4
    Quite a few of those modules will have "experimental" coding information available with the new cable.
    I do not know what would be involved in getting the EPB to auto-set when you put the transmission in park, or even whether this is possible at all, sorry.
