Hi All,
I just took delivery of new Audi S5 more or less fully loaded but as always something missing what in my opinion is quite useful
I refer to the function where by placing the gear to Park Position automatically engages the electromechanical handbrake.
Below is the scan from my hex-can cable, however I have very limited use of the functions unable to modify most modules due to access limitation
Would this be due to the older version cable or the updated Audi software ?
If not, can anyone advise me where to implement this change ?
Previously on my Audi A6 Avant 63 Plate, I was able to adjust most convenience modules
Many Thanks...........
Saturday,30,September,2017,14:32:18:01150
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: WAUZZZF54HA001xxx License Plate:
Chassis Type F5 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 19 1B 2B 32 36 3C 42 44 47 52
5F 6C 81 82 8B A5 A9 BB BC
BB-Door Rear Drv -- Status: Not registered 0001
BC-Door Rear Pass -- Status: Not registered 0001
Address 01: Engine (------CWGD) Labels: None
Part No SW: 8W0 907 559 G HW: 06M 907 309 D
Component: 3.0l V6 TFSI H21 0007
Revision: B2H21000
Coding: 1A2A00322366050B34380000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM30TFS0118W0907559G 001010
ROD: N/A
VCID: 4999971AE8BD7C0A37-801C
No ASAM data for: "EV_ECM30TFS0118W0907559G" ()
Address 02: Auto Trans (J217) Labels: None
Part No SW: 8W0 927 158 B HW: 0D5 927 156 H
Component: 0D5 30TSIRdW H03 1004
Revision: --H03---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 41898F3AD08DB44AEF-8014
Part No SW: 8W0 907 379 F HW: 8W0 907 379 D
Component: ESP9 Premium H09 0593
Coding: 1CAA149A30A20A9715A64898407E58A2E6A59A38280C50A812021A4567A559
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHAU49X 012014
ROD: EV_ESP9BOSCHAU49X.rod
VCID: 489F921EF3B7850228-801C
Part No SW: 4M0 959 760 A HW: 4M0 959 760 A
Component: MEM-BFS 008 0031
Serial number: 00000216261499
Coding: 00321004000CB0010003010141010000000000000000000000000000802003
Shop #: WSC 06325 790 00001
ROD: EV_SCMDriveSideCONTIAU736_AU73.rod
VCID: 3663ECE6894303F24A-8062
Address 08: Auto HVAC (E87) Labels: None
Part No SW: 8W0 820 043 G HW: 8W0 820 043 G
Component: Klima Zone 3 H32 0071
Coding: 4608000D5544450D02020100880000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: 377DE1E28E49FAFA51-8062
Subsystem 1 - Part No SW: 4M2 820 021 HW: 4M2 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000001024603
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0005
Serial number: FC19464800PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: Klima Heck H40 0073
Part No SW: 8W0 907 063 BG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0248
Coding: 07501143C13900CD050D59191BAD84B9130B31040000000000000000600016810A4502ABA2B70A
ASAM Dataset: EV_BCM1BOSCHAU736 016006
ROD: N/A
VCID: 01094F3A900D744AAF-8054
Subsystem 1 - Part No SW: 8W6 955 119 A HW: 8W6 955 119 A
Component: 494 RL 160331 036 0471
Serial number: 00000001603290300435
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 20038066X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AB HW: 4M0 941 531 AB
Component: E1 - LDS H06 0008
Serial number: 31 05 2016 00386899
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE127061612010148
Coding: 230000
Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B10236860
Subsystem 6 - Part No SW: 8W0 925 301 BF HW: 8W0 925 301 BF
Component: SL-B9/Q5NF H15 0010
Serial number: 2615000152367004
Subsystem 7 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J873 MKS_FSv H03 0033
Serial number: 7008174235B161902885
Coding: BF0500
Subsystem 8 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J872 MKS_BFSv H03 0033
Serial number: 7008174235B161902867
Coding: B30500
No ASAM data for: "EV_BCM1BOSCHAU736" ()
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8W0 907 561 B HW: 8W0 907 561
Component: LRR4 H09 0220
Coding: 3477FFF358FFEC06747860A0
ASAM Dataset: EV_ACCBOSCHAU49X 002018
ROD: EV_ACCBOSCHAU49X.rod
VCID: 3D71F3CAAC75D0AA8B-8068
Address 15: Airbags (J234) Labels: None
Part No SW: 8W0 959 655 B HW: 8W0 959 655 B
Component: Airbag10.44 H73 0086
Serial number: 003QQ000521K
Coding: AACCF0C00C800000985000F3C0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: N/A
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 8W6857705A0033R00703
Coding: 88001B
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 8W6857706A0235Q00449
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 442 062 508 16
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00C31FBD72214EC
Subsystem 4 - Part No SW: ----------- HW: 442 062 508 16
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00C11FBD7204240
Subsystem 5 - Part No SW: ----------- HW: 442 0B2 307 16
Component: SideSensor_Dr 1C7 0148
Serial number: 35177009D2106CB602BA
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 307 16
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700B92106CB26277
Subsystem 7 - Part No SW: ----------- HW: 442 0C0 308 16
Component: FrontSensor_D 1C5 014A
Serial number: 3557500A920F7C25F11I
Subsystem 8 - Part No SW: ----------- HW: 442 0C0 308 16
Component: FrontSensor_P 1C5 014A
Serial number: 3567500A920F7C24E07M
Subsystem 9 - Part No SW: ----------- HW: 442 0C0 308 16
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500A1211FA12F17/
Subsystem 10 - Part No SW: ----------- HW: 442 430 808 16
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00991FB75F3B21V
Subsystem 11 - Part No SW: ----------- HW: 442 430 808 16
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00991FB75F202DW
No ASAM data for: "EV_AirbaAU10BPAAU736" ()
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 HH HW: 4M0 907 129 HH
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_AU49.rod
VCID: 7DF133CAECF510AACB-8028
Address 17: Instruments (J285) Labels: None
Part No SW: 8W5 920 790 C HW: 8W5 920 790 C
Component: FBenRDW H15 0299
Coding: 248D19DA7CB8060001B3E9601000400000000000
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736.rod
VCID: 428B8036D58BAF52F6-8016
Part No SW: 8W7 907 468 C HW: 8W7 907 468 C
Component: Gateway H27 1298
Revision: 4M090005 Serial number: 0584M273516905
Coding: 0301000100008E405407000000590012F4900007920000000175078E00000000
ASAM Dataset: EV_CGateCONTIAU491 002060
ROD: EV_CGateCONTIAU491.rod
VCID: 4B95AD12E2C16E1A05-801E
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20160816183416 21071
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 0528641304
Part No SW: 8W0 907 144 E HW: 8W0 907 144 C
Component: SCU_MLBevo H03 0706
Coding: 40
ASAM Dataset: EV_SCUZFLSAU49X 002014
ROD: EV_SCUZFLSAU49X.rod
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 16000145953006
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 326BD0F6652B1FD266-8066
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H07 0030
Revision: 5WK12700 Serial number: 605633215250607
Coding: 0001
ASAM Dataset: EV_TVDCQSP22 001007
ROD: N/A
VCID: 79F927DAF8DD2C8AE7-802C
No ASAM data for: "EV_TVDCQSP22" ()
Component: MEM-FS 008 0031
Serial number: 00000213647679
Coding: 00621004000CB0010003010141010000000000000000000000000000802003
Address 3C: Lane Change (J769) Labels: None
Part No SW: 4M0 907 566 B HW: 4M0 907 566
Component: MRR1Rear H13 0230
Revision: --------
Coding: 4EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001015
VCID: 3467D6EE9F3F11E274-8060
Part No SW: 4M0 959 793 E HW: 4M0 959 793 C
Component: TSG FS 009 0055
Serial number: 0000214928819
Coding: 005D5A4250010085000034B2
ROD: EV_DCU2DriveSideMAXHCONT.rod
VCID: 408F8A3EDB87BD42E0-8014
196660 - Motor for Window Regulator
B1487 54 [008] - Missing Calibration / Basic Setting
Reset counter: 40
Mileage: 42 km
Date: 2017.06.08
Time: 00:00:06
Address 44: Steering Assist (J500) Labels: None
Part No SW: 8W0 909 144 F HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0407
Coding: 85888380008080
ASAM Dataset: EV_EPSZFAU49X 002015
ROD: EV_EPSZFAU49X.rod
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAGJA00EG7
Coding: 0194040800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: N/A
VCID: 76E32CE6C9C343F28A-8022
No ASAM data for: "EV_AMPMst16C2Gen2ALPI" ()
Part No SW: 4M0 959 792 E HW: 4M0 959 792 C
Component: TSG BFS 009 0055
Serial number: 0000216016087
Coding: 005D5A425C010085000034B0
ROD: EV_DCU2PasseSideMAXHCONT.rod
VCID: 3F8D89C2A679C2BA99-806A
Reset counter: 40
Mileage: 42 km
Date: 2017.06.08
Time: 00:00:06
Part No SW: 8W0 035 035 C HW: 8W0 035 035 A
Component: MU-P-LND-EU 052 0678
Serial number: A791H0G2501883
Coding: 019454010000000053111102000A00332F0012E7017001009E
ROD: N/A
Subsystem 1 - Part No SW: V03 959 801 FB HW: -----------
Component: ECE 2016/2017 --- 0153
Subsystem 2 - Part No SW: 8W2 919 605 HW: 8W2 919 605
Component: AU49x_DU_HIGH H40 0008
Serial number: AUZ8Z9GBK008XN
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK110081600040235
Component: Gracenote2--- --- 1013
No ASAM data for: "EV_MUHig6C3Gen2HBAS" ()
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4M0 907 428 D HW: 4M0 907 428
Component: Areaview 2 H12 0311
Serial number: C854607JG002497
Coding: 02940401BE0FA10008404080
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_AU49.rod
VCID: 3365D5F29A3116DA6D-8066
Address 81: Gear Shift (J587) Labels: None
Part No SW: 8W2 713 041 D HW: 4M2 713 041 D
Component: GSM-LL H08 0068
Revision: 0L0D5012 Serial number: 20160709000396
ASAM Dataset: EV_GSMWaehlZFAU736 001013
ROD: N/A
VCID: 3561EBEA944508EA43-8060
No ASAM data for: "EV_GSMWaehlZFAU736" ()
Address 82: Heads Up Display (J898) Labels: None
Part No SW: 8W6 919 617 A HW: 8W6 919 617 A
Component: HeadUpDisplay H07 1603
Coding: 4F01C0
ASAM Dataset: EV_HudNSEIKAU736 001015
ROD: EV_HudNSEIKAU736.rod
VCID: 479D9122FEA98A7A21-8012
Address 8B: Adaptive Cruise 2 (J850) Labels: None
Part No SW: 8W0 907 541 B HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 002018
ROD: EV_ACC2BOSCHAU736_AU73.rod
VCID: 3B75FDD2B261DE9AB5-806E
Address A5: Frt Sens. Drv. Assist (R242) Labels: None
Part No SW: 8W6 907 217 HW: 8W6 907 217
Component: BVS H14 0042
Coding: 0404090400000404014023A6CD0000FCB0F0C020E280
ROD: N/A
VCID: 7F0DC9C2E6F902BAD9-802A
No ASAM data for: "EV_BVSMLBevKOSTAAU736" ()
1123600 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 42
Mileage: 47 km
Date: 2017.06.12
Time: 15:10:10
1123601 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 42
Mileage: 73 km
Date: 2017.06.24
Time: 12:07:41
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8W0 907 159 F HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0005
Serial number: 160318200957
VCID: 4487862ECF9FA162C4-8010
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End-------------------------(Elapsed Time: 05:53)--------------------------
