I have a Polo that logs code P2463 with the ignition on/engine off. The DPF has been removed and cleaned by an DPF workshop. The car is in limp mode and cannot be road tested. I have tried to reset/test everything related with VCDS. I am not familiar with all the readings and think that I am overlooking something simple. The DPF sensor output is 1.02V KOEO. Also , are there any sites that show logs of good vehicle.
Thank you
Thank you
Wednesday,18,October,2017,14:01:26:15239
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 17.8.0.1 HEX-NET CB: 0.4401.4
Dealer/Shop Name: Daley Auto Electrics
VIN: WVWZZZ6RZCU014711 License Plate: 928RWQ
Mileage: 45860km-28496mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZCU014711 Mileage: 45860km-28496miles
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MH HW: 03L 907 425 B
Component: R4 1.6l TDI H33 9980
Revision: --H33--- Serial number:
Coding: 00254016002500080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023MH 003013
ROD: EV_ECM16TDI02103L906023LL.rod
VCID: 78BC357BC3E8CC86B2-802C
16856 - Diesel Particle Filter
P2463 00 [173] - Excessive Soot Accumulation
Mileage: 45861 km
Date: 2017.10.18
Time: 00:22:42
Coolant temperature: 45 °C
Intake air temperature: 29 °C
Voltage terminal 30: 12.536 V
Particle filter: soot mass measured-MASS_SOOT_PHY_PF: -2.30 g
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 40.00 g
Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 235 km
Counter for regeneration time of diesel particle filter-T_INT_RGN_ACT_INI_PF_ENVD_H: 2595.2255 s
Particle filter: difference pressure-DIP_PF: 0.00 hPa
Particle filter: offset for differential press.-DIP_PF_AD[0]: -0.08 hPa
Service regeneration: Release conditions 3-FRF_STATE_RGN: 1
Readiness: 1 1 0 0 1
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 060 F HW: 0AM 927 769 D
Component: GSG DSG AG7 431 3650
Revision: 00043014 Serial number: CU501308035135
Shop #: WSC 40139 959 99896
VCID: 2D12D42FB52AB92E11-513C
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0001
Revision: --------
Coding: 230228E3416E00B6C42C14E382D200821300
Shop #: WSC 31414 790 31414
VCID: 075E4687B216B37ECB-8052
Reset counter: 128
Mileage: 45848 km
Date: 2011.12.20
Time: 08:32:33
Hex Value: 0x4000
Hex Value: 0x0002
Hex Value: 0x1204
Hex Value: 0x04B4
Hex Value: 0x0069
Hex Value: 0x7F7F
Hex Value: 0x7E3A
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 383CF57B8B680C8672-806C
00710 - Defroster Flap Positioning Motor (V107)
Reset counter: 88
Mileage: 45860 km
Date: 2012.03.03
Time: 15:55:19
01272 - Positioning Motor for Central Flap (V70)
Reset counter: 88
Mileage: 45860 km
Date: 2012.03.03
Time: 15:55:19
01271 - Positioning Motor for Temperature Flap (V68)
Reset counter: 128
Mileage: 45860 km
Date: 2012.03.04
Time: 08:18:38
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0251
Revision: BF046001 Serial number: 0434 203110971
Coding: 24B02BBF08A1000001380800242B0ED00080410F60040000200000000000
VCID: 45C28C8FCC9A616EF9-8010
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 230711 05 54 0403
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU030061100013283
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU001071100011924
Coding: 08BC30
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Serial number: 0328604
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU005071100012021
Coding: 08BC32
Subsystem 6 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU001071100013239
Coding: 08BC32
00975 - Heated Rear Window (Z1)
Reset counter: 88
Mileage: 45860 km
Date: 2012.03.03
Time: 14:33:22
Part No SW: 6R0 959 655 L HW: 6R0 959 655 L
Component: VW10Airbag027 H09 0020
Revision: -------- Serial number: 003GY0042EVI
Coding: 003237
ROD: EV_AirbaVW10BPAVW250_VW25.rod
VCID: 4BD6BAB7E2FE971E2F-801E
Serial number: 3575HRB40690IRE2DP6R
Serial number: 3585HRB40650JR9KCP8$
Serial number: 3515RRB405P0KOIAKP8N
Serial number: 3525RRB405P0KOIA8GOJ
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
Component: KOMBI H03 0505
Coding: 140A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW25.rod
VCID: 3A38EF73BD641E9684-806E
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0251
Revision: BF046001
Coding: 002300
VCID: 70AC0D5BA39894C67A-8024
Component: IMMO H03 0505
VCID: 6A981F338D446E1634-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F2ECE27EA26CB3E23-807A
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 032 0079
Revision: 01000001 Serial number: VWZ1Z2L3434891
Coding: 05000400020001
VCID: 3326C257920EEFDE47-8066
End----------(Elapsed Time: 01:36, VBatt start/end: 12.4V/12.4V)-----------
