I'm trying to run the kiss point and fork position programs but VCDS says "not available". I have the car running, in N, parking brake on, brake depressed. The car does have a trans tune already.
Do you mean that the transmission ECU has been "chip tuned"? If so are you sure that the tuner hasn't disabled the kiss point and fork position calibrations?The car does have a trans tune already.
Tuesday,17,October,2017,19:21:20:61299
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WUAENAFG6CN001875 License Plate:
Chassis Type: FG-AU35 (7N0)
Scan: 01 02 03 08 09 0F 10 11 31 14 15 16 17 19 25 37 42 46 47 52
56 61 65 6C 77 A6
VIN: WUAENAFG6CN001875 Mileage: 25590km-15900miles
11-Engine II -- Status: Sporadic communication error 1000
31-Engine other -- Status: Sporadic communication error 1000
A6-Microphone -- Status: Malfunction 0010
Address 01: Engine (BUJ) Labels: None
Part No SW: 424 910 552 M HW: 420 907 552 B
Component: 5.2L V10HDZ/4V F ª0010
Revision: F5H09--- Serial number: AUX7Z0KNFN90J4
Coding: 011000091B0F0120
Shop #: WSC 61656 001 1048576
VCID: 1D64D1E2C1BF39DF50C-8048
005464 - Throttle Actuator (G186)
P1558 - 002 - Electrical Malfunction - Intermittent
Mileage: 25589 km
Date: 2017.10.17
Time: 19:07:34
RPM: 730 /min
Load: 24.3 %
Temperature: 76.0°C
Temperature: 39.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.097 V
Readiness: 0110 1100
Address 02: Auto Trans Labels: 420-910-156-V2.clb
Part No SW: 420 910 156 M HW: 420 927 156
Component: SL600 5.2L FSI HDZ 0040
Revision: SBH04001 Serial number: 9P2N113BL
Coding: 0000001
Shop #: WSC 02197 785 00200
VCID: 196CC5F2D59745FFBC4-804C
Subsystem 1 - Part No: 420 713 041 C
Component: A11 C02 23.08.11 0A11
Address 03: ABS Brakes Labels: None
Part No SW: 420 907 379 HW: 420 614 517 D
Component: ESP8 quattro H01 0200
Coding: 0000271
VCID: 59EC85F2951785FF7C4-800C
Fault Status: 00101101
Fault Frequency: 38
Reset counter: 169
Mileage: 25518 km
Date: 2017.10.11
Time: 12:34:16
Hex Value: 0x00C0
Hex Value: 0x6222
Hex Value: 0x0024
Hex Value: 0x0191
Hex Value: 0x0000
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Fault Frequency: 27
Reset counter: 169
Mileage: 25518 km
Date: 2017.10.11
Time: 14:00:10
Hex Value: 0x00C0
Hex Value: 0x6222
Hex Value: 0x0027
Hex Value: 0x0193
Hex Value: 0x0000
Part No SW: 420 820 043 G HW: 420 820 043 G
Component: J255 Klima 1 Zone 0100
Revision: 00H06007 Serial number: 00000001201216
Coding: 1572906
VCID: 0E46A6AE1C599247D96-805A
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 S HW: 8P0 907 063 S
Component: BCM PQ35 H 110 0667
Revision: AG110667
Coding: 6E000A00A893362420744CE00920004150F26A001120C92ADC080E1C0045
Shop #: WSC 02391 823 56573
VCID: 44D244860E9528173F2-8010
Subsystem 1 - Part No SW: 423 955 113 HW: 423 955 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiR H23 0040
Coding: 005912
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 025B32
Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7L0607409
Coding: 0000100
VCID: 36362E4E44498A87B16-8062
Reset counter: 244
Mileage: 22977 km
Date: 2017.02.05
Time: 13:18:25
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X2.clb
Part No SW: 8P0 919 475 N HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0140
Revision: 11001001 Serial number: 12501128400493
Coding: 30010C
VCID: 49CC55B229B7F57FCC4-801C
Address 11: Engine II Labels: None
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 420 910 376 A HW: 420 907 376 A
Component: J250 Raddaempfung 0170
Revision: --H16--- Serial number: 190DPH 1269164
Coding: 0000052
VCID: 117CBDD20D678DBFC44-8044
01316 - ABS Control Module
Reset counter: 130
Mileage: 25578 km
Date: 2017.10.17
Time: 16:19:01
Voltage: 12.60 V
Speed: 2.6 km/h
Voltage: 4.99 V
Address 15: Airbags Labels: 420-959-655.lbl
Part No SW: 420 959 655 HW: 420 959 655
Component: SN Airbag 9.43 H02 0020
Revision: 93H02002 Serial number: 003B8000FHNY
Coding: 0021326
VCID: 5DE491E2813F79DF10C-8008
Subsystem 1 - Part No: 8J0 910 339 A
Component: BF-Gewichtsens. H02 0030
Subsystem 2 - Serial number: 05PUT
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB4065E86CD%ÿ†63
Subsystem 5 - Serial number: E86CD%ÿ†63428RB406619C8AVÿ†63
Subsystem 6 - Serial number: 19C8AVÿ†63747RB4067B77F70ÿ†63
Subsystem 7 - Serial number: B77F70ÿ†63847RB4067B7D39/ÿ
Subsystem 8 - Serial number: B7D39/ÿ
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H37 0070
Coding: 0004141
VCID: 41DC4D921D873D3F144-8014
Component: E0221 H06 0030
Address 17: Instruments Labels: 420-920-xxx-17.clb
Part No SW: 420 920 981 K HW: 420 920 981 K
Component: KOMBIINSTR. VDO H02 0650
Revision: D0H02002 Serial number: 224NK002000358
Coding: 0081288
Shop #: WSC 47389 001 1048576
VCID: 1E66D6EECCB922C7496-804A
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 111111F1001090
Coding: 354100
VCID: 3B203F7A736B57EF4E8-806E
01342 - Engine Control Module 2 (Slave 1)
Fault Status: 00110100
Fault Frequency: 44
Reset counter: 163
Mileage: 25518 km
Date: 2017.10.11
Time: 12:34:24
Revision: D0H02002 Serial number: AUX7Z0KNFN90J4
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 423 035 192 H HW: 423 035 192 H
Component: RNS-E PU US H06 0210
Revision: 0000013S Serial number: AUZBZ7L7201361
Coding: 0730677
VCID: 1574C9C2398F619F98C-8040
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 420 959 801 H HW: 420 959 801 H
Component: Tuer-SG H04 0103
Coding: 0005245
Address 47: Sound System Labels: None
Part No SW: 427 035 223 HW: 427 035 223
Component: J525 Amp High H04 0030
Revision: 00H04001 Serial number: 94842000565704
Coding: 0246111
VCID: 4CC26CA62AC5E057F72-8018
Part No SW: 420 959 802 H HW: 420 959 802 H
Coding: 0005245
VCID: 1F18EBEACBB32BCF420-804A
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0730677
Component: Batt.regelung H43 1623
Coding: F3260148
VCID: 71BCDD5261A7EDBFA44-8024
Subsystem 1 - Part No SW: 420 915 181 HW: 420 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650785607
Address 65: Tire Pressure Labels: None
Part No SW: 420 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0040
Revision: 00050040 Serial number: 00000900008154
Coding: 0462426
VCID: 0D44A1A2115FA95F20C-8058
Address 6C: Back-up Cam. Labels: 420-910-441.clb
Part No SW: 420 910 441 A HW: 7L6 907 441 C
Component: J772__Rearview 0010
Revision: --H13--- Serial number: 525PA8-J1Y600O
Coding: 1020412
VCID: 0A4EAABE6031BE6705E-805E
Part No SW: 8P1 862 336 A HW: 8P1 862 336
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005159387
Coding: 0011477
Shop #: WSC 02556 785 00200
Address A6: Microphone (J886) Labels:. 420-907-394.clb
Part No SW: 420 907 394 HW: 420 907 394
Component: BELTMICBOX H09 0060
Coding: 0100010202
Shop #: WSC 02197 785 00000
ASAM Dataset: EV_BeltMicAU715 002011
ROD: EV_BeltMicAU715_002.rod
VCID: 56F68ECEE889AA87516-8002
0032 - Microphone 1 for Passenver Side
B1206 13 [009] - Open Circuit
Fault Frequency: 29
0048 - Microphone 2 for Passenver Side
B1207 13 [009] - Open Circuit
Fault Frequency: 29
0064 - Microphone 3 for Passenver Side
B1208 13 [009] - Open Circuit
Fault Frequency: 28
0080 - Microphone 1 for Drivers Side
B1203 13 [009] - Open Circuit
Fault Frequency: 16
Mileage: 23345 km
Date: 2017.02.26
Time: 08:19:34
0096 - Microphone 2 for Drivers Side
B1204 13 [009] - Open Circuit
Fault Frequency: 16
Mileage: 23345 km
Date: 2017.02.26
Time: 08:19:34
0112 - Microphone 3 for Drivers Side
B1205 13 [009] - Open Circuit
Fault Frequency: 17
End----------(Elapsed Time: 01:34, VBatt start/end: 12.5V/12.4V)-----------
You'll need to ask the tuner I reckon.Yes the TCM has been tuned. No I'm not sure although I don't know why he would disable that or how to check or re-enable it as I'm very new to VCDS.
They have a strange tendency to be clueless or in denial when it comes to this kind of thing.You'll need to ask the tuner I reckon.
VCDS does not do tuning.Presuming it was tuned via vcds
Not true, VCDS cannot be used for flashing firmware - it can change coding and adaptation values (where the original VAG firmware allows) but it cannot change the firmware.I was under the impression that albeit time consuming, the trans could be tuned via vcds
