Reprogramming Audi A4 odometer
old marekt garage
C?ID=318556
Hi everyone ,
I need help with reprogramming clock-odometer 8E0 920 950G
Audi A4 2004 1.9TDI AFV 130HP
I've automatic gearbox CVT.
I change odometer from B7 A4 full coulor FIS ( I dont now exaccly number right now )
Everything working fine , exept .
Gearbox sighn ( its missing )
I dont see on display-FIS witch gear Im running.
I can look on gear lever to find out .
I need help .
What kind of programming I need to make it right .
This is my logs.
Thursday,12,October,2017,15:35:56:30587
VCDS Version: 17.8.0.1  HEX-NET CB: 0.4401.4
VIN: WUAZZZ8E47A802415   License Plate: VE04YKV
Mileage: 198210km-123161mi   Repair Order:
          67 69 75 76 77
VIN: WUAZZZ8E47A802415   Mileage: 198210km-123161miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 LJ
   Component: 1,9l R4 EDC G000AG  5934
   Coding: 00001
   Shop #: WSC 63251
   VCID: 6A981DEF1408921634-4B1E
17994 - Engine Mount Solenoid Valves (N144/N145)
            P1586 - 35-10 - Short to Plus - Intermittent
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 8E0 910 155 Q    HW: 01J 927 156 HT
   Component: V30 01J 1.9l PD RdW 3230
   Revision: 00000006    Serial number: 00000000578267
   Shop #: WSC 63251 000 00000
   VCID: 3326C08B534213DE47-5160
   Part No: 8E0 614 517
   Component: ABS/ESP front       4529
   Coding: 04259
   Shop #: WSC 06435
   VCID: 65826ED3FD16BD6E19-51A8
   Part No: 8E0 820 043 AC
   Component:   A4 Klimaautomat   1424
   Coding: 00000
   Shop #: WSC 63251
   VCID: 628875CFEC38CA56FC-5160
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 -  -
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  RDW 0517
   Coding: 00001
   Shop #: WSC 63251
   VCID: 3522FE930D360DEE69-4B00
            35-00 -  -
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 J
   Component: Airbag 8.4EP        1002
   Coding: 0010602
   VCID: 3E30E1BF6800CEB6B8-5184
            000 -  -  - Intermittent
            001 - Upper Limit Exceeded - Intermittent - MIL ON
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 02142
   Shop #: WSC 28150
   VCID: 3E30E1BF3800CEB6B8-4B00
            49-00 - No Communications
01304 - Radio
            35-00 -  -
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8E0 920 983 B    HW: 8E0 920 983 B
   Component: KOMBI+WFS 4     H14 0200
   Revision: 0200        Serial number: 00000000000000
   Coding: 0006411
   Shop #: WSC 00762 210 84242
   VCID: 2E10D1FFB8603E3628-5184
01304 - Radio
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0006411
01304 - Radio
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0704
   Coding: 00001
   VCID: 6B9618EB1BF28B1E4F-50F4
   Part No: 8E0 959 433 BC
   Component: Komfortgerát T3B    1512
   Coding: 07115
   Shop #: WSC 63251
   VCID: 73A6008B43C253DE87-4B00
   Subsystem 1 - Part No: 8E2959802B
   Component: Tõrsteuer.FS BRM 0205
   Subsystem 2 - Part No: 8E2959801B
   Component: Tõrsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0205
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0205
01370 - Alarm triggered by Interior Monitoring
            35-00 -  -
            35-00 -  -
            35-00 -  -
            35-00 -  -
End----------(Elapsed Time: 05:41, VBatt start/end: 12.4V/12.3V)-----------
AIB Wolfgang
Hello
Thats why you have to do an Auto-Scan and create a module map first.
Then mount the "new" Cluster.
Please look for right coding and then go to "adaption channels. Here you will find the missing informations
