Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Leak in Air Intake with Lean at Idle and EVAP
    Oct 2017
    Lithuania
    Hello guys,
    first of all - thanks for such robust and quality product. Sleek design and speedy workflow on Hex V2 is simply amazing.
    On the other hand, I have a lasting problem with my car and hopefully, we could find an area for discussion. Started with EVAP problem, and now finishing with air intake, lean system and EVAP is back again.
    PR-build
    I have Audi A5, 2014 2.0TFSI quattro, 162kw.
    Car modifications
    1. Stage 1 remap
    2. Wagner intercooler
    3. Pipecross air filter
    VCDS Auto-scan
    Wednesday,11,October,2017,16:12:09:00499
    VIN: WAUGFBFR9EA   License Plate:
    Mileage: 70360km-43719mi   Repair Order:
    Chassis Type: FR-AU48 (8R0)
    Scan: 01 03 05 06 08 09 15 16 17 19 2E 36 42 44 46 47 52 53 56 77
    VIN: WAUGFBFR9EA   Mileage: 70360km-43719miles
    Address 01: Engine (MY15-CAED)       Labels:. 06H-907-115-CDN.clb
       Part No SW: 8K5 907 115 M    HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H09 0005
       Revision: ECH09---
       Coding: 5A190013242600062000
       Shop #: WSC 45864 002 1048576
       ASAM Dataset: EV_ECM20TFS0118K5907115M 001006
       ROD: EV_ECM20TFS0118K5907115M.rod
       VCID: 3C223C4206EBB8D7472-8068
    5646 - Leak in Air Intake System
              P2279 00 [237] - -
                        Mileage: 70281 km
                        Date: 2017.10.10
                        Time: 16:12:16
                        Engine speed: 759.50 /min
                        Normed load value: 7.1 %
                        Coolant temperature: 80 C
                        Intake air temperature: 26 C
                        Voltage terminal 30: 14.677 V
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    4105 - Bank 1; System too Lean at Idle
              P2187 00 [101] - -
                        Mileage: 70356 km
                        Date: 2017.10.10
                        Time: 16:00:22
                        Engine speed: 916.50 /min
                        Vehicle speed: 33 km/h
                        Coolant temperature: 97 C
                        Intake air temperature: 24 C
                        Voltage terminal 30: 14.654 V
                        Unlearning counter according OBD: 80
    4007 - Idle Control System RPM
              P0507 00 [038] - Higher than Expected.
                        Mileage: 70362 km
                        Date: 2017.10.10
                        Time: 16:07:52
                        Engine speed: 904.00 /min
                        Coolant temperature: 98 C
                        Intake air temperature: 36 C
                        Voltage terminal 30: 14.300 V
    4219 - EVAP Emission Control Sys
              P0441 00 [096] - Incorrect Flow
                        Mileage: 70293 km
                        Date: 2017.10.10
                        Time: 23:21:50
                        Engine speed: 706.50 /min
                        Normed load value: 5.5 %
                        Intake air temperature: 37 C
                        Voltage terminal 30: 14.489 V
                        Ethanol content in fuel: 0.0 %
                        Fuel content due to degassing of engine oil: 0.00 %
                        Cold start valve: activation duration: 0.00 ms
                        Cold start valve: mileage at last purge: 0 km
                        Cold start valve: date at last purge: 0
    Readiness: 0000 0101
       Part No SW: 8K0 907 379 CM    HW: 8K0 907 379 CM
       Component: ESP8 quattro  H09 0020
       Coding: 07150001
       Shop #: WSC 06325 000 00000
       VCID: 06569EAA08273207616-8052
       Part No SW: 8K0 907 064 JL    HW: 8K0 907 064 JL
       Component: BCM2 2.0      H14 0650
       Coding: 03804040000000000000
       Shop #: WSC 23444 000 00000
       VCID: 035087BE3B15072F468-8056
       Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
       Serial number: 0514000021999015
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Serial number: 0214000011670010
       Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
       Component: MEM-BFS       H10 0077
       Revision: AA000000    Serial number: 00000091217173
       Coding: 08037025002400001000
       VCID: 45D459A675A1F91F28C-8010
       Part No SW: 8K1 820 043 R    HW: 8K1 820 043 R
       Component: KLIMA 1 ZONE  H02 0121
       Revision: A1000000    Serial number: 01140220140609
       Coding: 6402208000
       VCID: 3728236E3F4D9B8FAA0-8062
       Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
       Revision: 06016001    Serial number: 00000061429002
       Coding: 26000097813CAFC00000400300003D0D4F1C138822090301000004004400030100000000000000
       Shop #: WSC 23444 123 12345
       VCID: 76B6EE6A78C72287716-8022
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 070214  H15 0080
       Serial number: SWF14020075358
       Coding: 00FD11
       Serial number: 22252219
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000802140857
       Serial number: D8784117000000000001
       Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
       Component: AirbagVW-AU10 H47 0610
       Serial number: 003KJDB13PY0
       Coding: 30414333483030303030554A304C38543053
       VCID: 4ACE6A9A5C3F1667C5E-801E
       Serial number: 6334MSME422E2A61E
       Serial number: 6344MSME435E2F4EZ
       Serial number: 6352QSME024234484
       Serial number: 6362QSME7F412476O
       Serial number: 63732SME2C56337C6
       Serial number: 63832SME0B3D4B706
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862NBF001PC
       Coding: 000016
       VCID: 48CA509242B3E477D3A-801C
       Part No SW: 8T0 920 901 M    HW: 8T0 920 901 M
       Component: KOMBIINSTR.   H11 0564
       Revision: 00100000    Serial number: Z962CD32F
       Coding: 8F7D010002010008020001
       Shop #: WSC 06325 123 12345
       VCID: 3E26364A1077AAC7696-806A
       Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
       Component: GW-BEM 5CAN   H11 0060
       Revision: 1V090029    Serial number: 2941V14201055E
       Coding: 80C303FF00
       Serial number: 1360122503
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020202
       VCID: 392C255609598DFF5C4-806C
       Component: MEM-FS        H10 0077
       Revision: AA000000    Serial number: 00000091220542
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H09 0305
       Coding: 011C03224000120102
       VCID: 56F68EEA98074287516-8002
       Part No SW: 8K0 909 144 R    HW: 8K0 909 144 B
       Component: RCEPS         H40 0511
       Revision: 00001000    Serial number: 0024519382
       Coding: 100000010001
       Shop #: WSC 06324 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008018
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 40DA48B26A03DC371BA-8014
       Revision: 00002001    Serial number: 0325065423
       Coding: 0106069A08FA00448330003200000000
       Component: J245EE20SKB13  H05 0220
       Part No SW: 8R1 035 223 A    HW: 8R1 035 223
       Component: DSP STD       H08 0230
       Revision: 26S00000
       Coding: 0203010102
       VCID: 2B000F1EF3052F6FDE8-807E
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H09 0305
       VCID: 55F489E68501499F58C-8000
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H01 0005
       Revision: --------    Serial number: 30000000167623
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 3A2E3A5A0CDF86E755E-806E
       Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
       Component: Con3 Sirius   H09 0471
       Revision: 00000003    Serial number: AUZ5Z6N2003819
       Coding: 00020002010485038959830903
       VCID: 43D047BE7B95C72F068-8016
       Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
       Component: Display
       Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005335836
       Coding: 0010370
       VCID: 3E26364A1C77AAC7696-806A
    End----------(Elapsed Time: 01:24, VBatt start/end: 12.3V/12.2V)-----------
    Recent repairs
    Well, it all started somewhat back in April. EVAP P0441 incorrrect flow appeared. All parts were changed into new OEM, except Vapor Canister, swapped it from a used car. From that point:
    1. Changed Evap Purge Valve
    2. Changed Secondary Air Injection Pump Hose with Vapor Canister Filter (was bulbing at the top of the rear driver side)
    3. Changed Vapor Canister with pressure switch.
    All these changes didn't helped to get rid of the incorrect flow issue. Accordingly, I registered at Audi to solve the problem.
    1. They inspected the system and changed Vacuum System Purge Valve with Hose Set.
    2. Updated ECU as there was a new software version from Audi.
    Now that seemed to solve the problem at that point, for one day. After that, I started getting three more faults:
    P2279 00 [237]
    P2187 00 [101]
    Accordingly, here is what we did further:
    1. Changed PCV valve (didn't helped)
    2. Audi inspected all the possible components for vacuum leak - everything seems tight.
    And after some time, old good friend EVAP appeared again.
    Specific issues
    What I started getting with these errors:
    1. Idle jumping from 650 to 950rpm with clima off
    2. When rpm sets in place, car shakes a bit, doesn't run perfectly smooth, even through rpm's are at one point.
    3. After filling a full tank, I need to spin on the starter for a few times in order to start the car for a first time. Further - no problems.
    4. System is running lean. Not 100% sure I am looking at the right values on UDS, but here they are:
    Next steps
    Audi offers me to change Vapor canister pressure switch and see whether it solves the issue. On the other hand, I already changed some working parts which in fact didn't solved the issue. Accordingly, I am looking for any other possible ways this could be INSPECTED FIRST, before changing parts.
    If I run Tank Ventilation Test in basic settings, it ends as Not OK.
    1. If it is EVAP causing this Leak in Air Intake and Lean at Idle, I am not sure where to dig further... Any ideas?
    2. Can it be failing oxygen sensors? Is there any chance to read their values and inspect the problem from them?
    3. Intake manifold?
    4. Fuel injectors?
    5. Somehow clogged/squeezed fuel lines at the top of the fuel tank?
    6. MAF? Tested it by running full throttle and values were in described range.
    Any suggestion is highly appreciated! Thank you up front for any help!
    I don't have any ideas as to what might be wrong with this car, but that is a fantastic first post!
  3. Likes Jack@European_Parts, T10 liked this post
    Verified VCDS User Ashraf6119's Avatar
    Dec 2015
    Have you checked the High Fuel Pressure Pump......?
    Oct 2017
    Lithuania
    Quote Originally Posted by Ashraf6119 View Post
    What in particular to look for - the pressure it delivers or any manual inspection/check should be initiated?
    Overall, few other things I have in mind, simplified. Since there is an additive air/not enough fuel situation (at least errors direct towards this), I see two main reasons:
    1. Air is somewhere going into the system after the MAF, that way creating too much air dense mixture, which is not measured properly. This cause not enough fuel delivery, even though everything with fuel supply could be OK.
    2. There is a proper amount of air, no actual leaks, but with failure in fuel delivery, not enough fuel is passed into a mixture. Accordingly, ECU thinks there are too much air.
    Now with option one - it is most likely not the case, as no visible/noticeable/traceable leaks were found, no cracks, nothing. UNLESS this is something with intake manifold itself. What could be checked to make sure the intake is not failing in some fashion?
    Option 2 - not enough fuel. That way fuel delivery unit should create not sufficient pressure or there are not 100% bandwidth in fuel lines, etc?
    These are only my logical guesses, though... Does such presumptions make sense or I am missing something major?
    This set of codes almost screams air leak somewhere:
    P2279 00 [237]
    P2187 00 [101]
    I don't see how too little fuel would cause a higher-than-commanded speed.
  7. Likes T10, Jack@European_Parts liked this post
    Was the tank valve upgraded to the later part # & to work with the firmware update as per the TSB?
    False air leaks are easy to locate by isolation.
    Crimp off to correct the idle and then fix that zone.
    Verify TV and intake leaks directly by chemical identifier and water mist to induce misfire.
    Verify the PSI/vacuum of the block for proper switching not just the PCV.
    http://forums.ross-tech.com/showthre...you!-Air-leaks!
    European Parts Emporium/Performance / Immobilizer Solutions LLC
  9. Likes Ashraf6119 liked this post
  10. #7
    I have had the breather oil separator causing issues, is it worth trying a new one, because if that's faulty, you won't see any visible air leaks.
    Search for 06H 103 495AK and have a look at the item. It has been superseded so may be the older ones have a known issue.
  11. Likes Jack@European_Parts liked this post
  12. #8
    Oct 2017
    Lithuania
    Jack - since the inspection and valve upgrade was made @ Audi, I would expect they did the best to make sure these aspects were covered...They used that chemical around all the possible junctions and not certain whether looking 2nd time myself could make it any better?
    Quote Originally Posted by Gary View Post
    Thanks, Gary. Breather oil separator aka PCV already replaced to the latest OEM part. Was expecting that red button could be the issue (https://youtu.be/hQEciqR1ST8?t=1m40s), but unfortunately - not.
    Taking another look into the P2279 documentation:
    Vacuum Leak- assuming this one is inspected with no prior leaks.
    Intake Manifold Runner Position out of Specification - is there any chance to diagnose this?
    Faulty Positive Crankcase Ventilation (PCV) or Heating Element (N79) - PCV changed. What N79 stands for?
    The main reason why I expect this is something to be with tank/fuel delivery, is because of EVAP problems in the past, as well as not starting instantly after filling a full tank up to the click. And when it finally starts, it works rough and shaky. BUT it happens only on a first engine run after the fill. Here is the video:
    Also, just noticed one strange thing, which I haven't noticed while recording - take a look at a temperature gauge - I filled the tank after driving ~25km, so the engine was at full working temp. Why the gauge dropped down after going to its position? There is NO CHANCE it could cool down Maybe its another guide to follow, N79? Not sure at all what it could mean, though.
    Overall, I am just a regular guy, who likes to make some tweaks to the car by himself. Not that much experienced)
  13. Likes Jack@European_Parts, Uwe, Gary liked this post
  14. #9
    Bullshit........ you sir...... are not a regular guy..... but I like your process!
    Okay I am in agreement that something is going on in tank and I would pump up the tank and crimp off the lines and then watch hold PSI.
    Then zone by zone verify what is permitting vapors to enter as a leak.
    I also think it could be compounded & that the block itself could be leaking air or vacuum or over vacuum from BVP on the mechanical not being limited through restrictive orifice and if it does will lose the vacuum needed to initiate the LDP functions or even a proper evap stream when N80 pulsed.
  15. #10
    Oct 2017
    Lithuania
    Jack, thanks once again for your insights! At the moment I do not have availability to make mechanical inspection, accordingly, trying to clear all variables from the diagnostics side. I am with UDS, not that much easy like it would be with CAN measurement blocks, but well - I am trying
    Fuel Rail Pressure
    With temp over 80 degrees Celsius, no engine running, the fuel pressure goes from starting 40Mpa value up to 80Mpa in 3-4minutes. No problems with fuel pressure, right?
    Fuel trims with and without errors
    Even though I am not 100% certain whether I used proper trim data, these are quite self explanatory. The idea was to leave it on idle for some time, then apply the throttle and then keep it for idle. I wanted to see how the short/long term trims builds in two conditions. Firstly, with all the errors, then without.
    O2 oxygen values with P2279 and without
    I wanted to see how the oxygen sensor voltage builds in two conditions - when errors are already there and when ECU is building from the values of 0.
    UPDATED:
    Here are my insights/questions in regards to the data. As you can see, I applied throttle to indicate the changes in the system.
    1. When throttle applied, long term adaptation drops drastically, by 50%. This showcases a vacuum leak?
    2. With errors in the system, short term adaptation doesn't bounce too much. However, once cleared away, the movement of this value jumps significantly. In addition, why the long term adaptation goes to such high figures of >50%?
    3. O2 sensors in both cases are far from oscillation in a wave form. Is this is a result of vacuum leak as well? Have no idea about this. Maybe other values say something?
    4. What "leakage recognition from oxygen sensor control" value stands for? Couldn't find any reasonable information about this.
    Overall - I am not crazy! Just like to see the data in charts, rather than numbers. It might help to see something Thank you!
  16. Likes Gary, Uwe liked this post
