Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Long Coding --> 10: Park/Steer Assist (J791), --> Coding Rejected Error 31: Request..
    May 2017
    All the virgin modules I've bought, including park assist modules, have never required any form of flashing. They've always ready with a software and ready to code.
    You just need something inputted to importer, wsc etc. fields in VCDS. Having 0000 values there does not allow coding of virgin modules as there's no initial coding in.
    And do you have both front and rear sensors connected? You have an error stating front parking sensors open circuit which would mean that there's a connection problem to front sensors or you don't have them at all.
    But anyway you can try : 0420051010
  2. Likes Uwe liked this post
  3. #12
    Verified VCDS User martinlop's Avatar
    Oct 2017
    Argentina
    Hi downtime, thanks for the feedback. Will try the new suggested code right the way, but I doubt it.
    answers to your concerns:
    1) yes, have tried with all connected sensors and speakers. now the log keeps saying front sensors are not connected, because I havent perforated the bumper yet (have connected everything from the outside, until Im sure it works, before making any hole on my car.
    2) wsc, importer and eq # have been modified as indicated by UWE, without any results.
    3) from another forum, have learnt that the modules come with different set of "parameters" because they can be utilized for a A4, for a Volskwagen, Skoda and so, therefore are standard flashed, but parameters (before long coding) are different, which kind of make senses to me.
    please find attached 2 things, 1st the information of the module, and 2nd another scan without the fault codes of the sensors
    Sunday,08,October,2017,18:54:04:08873
    VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
    VIN: WAUBCJ8V3G1103064   License Plate:
    Mileage: 8174km-5079mi   Repair Order: registro del modulo
                    Address 10: Park/Steer Assist
    Control Module Part Number: 5Q0 919 298 H
      Component and/or Version: PARKHILFE PLA H12 0053
               Software Coding: 0000000000
                Work Shop Code: WSC 00000
                          VCID: 44D245549E19F5B73F2-8010
    Advanced Identification/FAZIT
         Serial number: 39431427200492
         Identification: ATW-001
         Revision: --------
         Date: 01.10.14
         Manufacturer number: EA02
         Test stand number: 0364
    Flash Status
         Programming Attempts(application): 1/0/0
         Programming Attempts(data): 1
         Successful Attempts(data): 1
         Flash Date: 00.00.00
         Flash Tool Code(data): 00000 000 00046
    Misc.
         Hardware number: 5Q0 919 298
         Workshop System Name: J791
         Equipment/PR Code: 0000000000000000
         Dataset Number: 5GD039v__B_
         Dataset Version: 0081
         ASAM Dataset: EV_EPHVA2CAU3700000
         ASAM Dataset Revision: 003020
    VCDS Info:
           Labels: 5Q0-919-298.clb
           ROD: EV_EPHVA2CAU3700000_003_VW37.rod
    Sunday,08,October,2017,18:22:48:08873
    VIN: WAUBCJ8V3G1103064   License Plate: AB132
    Mileage: 8174km-5079mi   Repair Order: DOMINGO
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 42 44 52 55 5F BB BC
    VIN: WAUBCJ8V3G1103064   Mileage: 8174km-5079miles
    Address 01: Engine (J623-CJSB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 H    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0005
       Revision: --H13---
       Coding: 0A9D00322406010B2000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM18TFS0208V0906264H 001007
       ROD: EV_ECM18TFS0208V0906264H_VW37.rod
       VCID: 41DC4C40810BE09F144-8014
    Readiness: 0010 0001
       Part No SW: 0D9 300 012 F    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4930
       Revision: 06253104    Serial number: TFK01604011950
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021_VW37.rod
       VCID: 196CC420491B985FBC4-804C
       Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
       Component: ESC           H42 0623
       Revision: 00000000    Serial number: 61036000005855
       Coding: 13F16AA234202A6F0377070641C729C8562C54C0E08294F5004150348608
       ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
       VCID: 79ACE4A0A95B785F1C4-802C
       Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
       Component: AC Automat    H14 0060
       Revision: 20028000    Serial number: 00000000912514
       Coding: 03000004110000001000000000001400
       VCID: 323E138C34AD4B079DE-8066
       Component: AQ_Hum_Sensor  H03 0005
       Serial number: 24F9032800PAG0MUFU01
       Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
       Component: BCM MQBAB H   H24 0175
       Serial number: 01061610903953
       Coding: 04041A42C24122FD03804004B10807080000000000000000000000000000
       ROD: EV_BCMBOSCH_015_VW37.rod
       VCID: 04528554DE9935B77F2-8050
       Component: WWS371 160408  043 0585
       Serial number:         160416080445
       Coding: 0A47F7
       Serial number: 61660501
       Coding: 00006C
       Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
       Serial number: 25 01 2016  00001125
       Serial number: 000000000ZY1602637Q8
       Component: Sirene, DWA  005 0313
       Serial number: 00000000000065608331
       Part No SW: 5Q0 919 298 H    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0053
       Revision: --------    Serial number: 39431427200492
       Coding: 0000000000
       ASAM Dataset: EV_EPHVA2CAU3700000 003020
    13636352 - Control module not coded
              U1013 00 [009] - -
                        Reset counter: 82
                        Mileage: 8163 km
                        Date: 2017.10.08
                        Time: 13:38:44
    13697024 - Control Module
              U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
                        Reset counter: 82
                        Mileage: 8163 km
                        Date: 2017.10.08
                        Time: 13:38:45
       Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
       Component: AirbagVW20    015 0388
       Serial number: 003MMR1NJNLW
       Coding: 98CCC000000000005C540000004800000065
       VCID: 005A8944CA8129975BA-8054
       Subsystem 1 - Part No SW: -----------    HW: 480 000 804 16
       Serial number: 3576700000078A916A1.
       Subsystem 2 - Part No SW: -----------    HW: 480 000 804 16
       Serial number: 3586700000003A916A1Q
       Subsystem 3 - Part No SW: -----------    HW: 480 400 904 16
       Serial number: 3516502C11FA3425C2DG
       Subsystem 4 - Part No SW: -----------    HW: 480 400 904 16
       Serial number: 3526502B120414E3515V
       Subsystem 5 - Part No SW: -----------    HW: 480 400 604 16
       Serial number: 3556502C720414F3902%
       Part No SW: 8V0 953 521 EM    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 16041604221228
       Coding: 8018
       ASAM Dataset: EV_SMLSKLOMQB 020001
       VCID: 094C9460F9BB68DF0C4-805C
       Part No SW: 8V0 920 871 R    HW: 8V0 920 871 R
       Component: KOMBI         H03 6423
       Coding: 078D18082B9000080500A8001000000000000000
       ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
       VCID: 4BC06E68B3473ACFFE8-801E
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 15041610801377
       Coding: 030100043F085A005B000248180B00000001010000000000000000000000
       ROD: EV_GatewConti_013_VW37.rod
       Subsystem 2 - Part No SW: 8U0 951 528 B    HW: 8U0 951 528 B
       Serial number: 06 04 2016  C0018702
       Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
       Component: J367-BDMConti  H02 1011
       Serial number: 74185704901603232224
       Serial number: HA1-00019.03.16
       Coding: 0001
       ROD: EV_AllWheelContrHA1VW37X_004_VW48.rod
       VCID: 4ACE6B6CBC3D23C7C5E-801E
       Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
       Serial number: 040316EC316159
       Coding: 001C0A204100040000001002
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 0303
       ROD: EV_SteerAssisMQB.rod
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 290216EBJ08118
       Coding: 001C02204D00040000001002
       VCID: 40DA49448A01E9971BA-8014
       Coding: 01AA000001000000
       ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
       VCID: 75B4E89085431C3F78C-8020
       Part No SW: 8V0 035 840 C    HW: 8V0 035 840 B
       Component: MU-S--ER      042 0461
       Serial number: A3E01204160010
       Coding: 01730100FF0A000021220001001A00002F0001040100010002
       ASAM Dataset: EV_MUStd6C3PASE 002020
       ROD: EV_MUStd6C3PASE_AU37.rod
       VCID: 35342890C5C35C3FB8C-8060
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0014
       Serial number: AUZ8Z9GY30GM3Q
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Component: ControlUnit_B  H41 0054
       Serial number: ALJAL116021600030034
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 240316ECN2439C
       Coding: 000C02204000040000001002
       ROD: EV_DCURearDriveMAXCONT_VW37.rod
       VCID: 43D046489B17F28F068-8016
       Serial number: 240316ECN20631
       ROD: EV_DCURearPasseMAXCONT_VW37.rod
    End----------(Elapsed Time: 01:32, VBatt start/end: 12.6V/12.6V)-----------
  4. #13
    May 2017
    This is my coding for Leon 5F park distance control module :
    0031051011
    I have 5Q0 919 294 module and you have 5Q0 919 298. They seem to have same bits expect byte 0 is different. But try this first and then go from there if it's accepted.
  5. #14
    Oct 2017
    Argentina
    0031051011
    can you please give me your "Advance ID" for the module 10?, it will give me some hint to compare
    Revision: --------
    Date: 01.10.14
    Flash Status
  6. #15
    May 2017
    I will take that when I have some spare time.
    Did you try the coding I gave you?
  7. #16
    Oct 2017
    Argentina
    not yet, as Ive disconnected the module (it was beeping everytime I was higher than 15km/h and also beeping everytime I was driving below 37km/h.
    Very annoying. IŽd better fix the issue and connected back again, cause having that connected makes no sense to drive so. During upcoming weekend will try again, but believe me, I was trying with only 1 bit mod, then several long codes from different mods, (copying from the Seat Leon forum) and also from XAGICO (El club del golf) wasnt working neither.
