Results 1 to 10 of 11
Thread: OEM Xenon W/LED Headlight Retrofit - 2016 VW Golf SportWagen (MK7)
    Sep 2017
    Brazil
    This is my first post in Ross-Tech forum.
    I have a 2016 VW Golf SportWagen S 1.4 TSI M/T (ROW Spec) and I bought a couple of OEM Xenon W/LED Headlight (W/O side markers) 5GM 941751 B / 5GM 941752 B.
    Before start the headlights retrofit, I checked about this topic in the Ross-Tech and Golf MK7 forum, and to get this process the BCM and CAN Gateway I noticed that will be necessary to replace for “Highline” version.
    I checked my BCM is the reference 5Q0 937 086 AH (BCM PQ37BOSCH 028 0162) and in the CAN Gateway is the reference 5Q0 907 530 AG (GW MQB Low 210 2246), then considering these parts are “Lowline”, I have to replace BCM (my byte 2 does not have a choice of xenon), CAN Gateway (my cannot support AFS, but I do not care about this function).
    After replace these parts I have to go to the dealer who will to remove the “protect component” with FAZIT, besides make VAGCOM adaptation coding changes by myself.
    I would like to confirm if in my case is it possible to follow this process to retrofit and, just in case, could someone provide me what changes I have to apply in light channels considering my vehicle?
    Best Regards,
    Mitio
    Aug 2016
    Switzerland
    Please make it a good habit to start with an autoscan. Even though your TS is quite comprehensive, it is always helpful
  3. Likes Uwe liked this post
    Sep 2017
    Brazil
    Hi, ok, please follow below autoscan:
    Chassis Type: AU (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: 3VWWJ6AU4GM517334   Mileage: 6466km-4017miles
    Address 01: Engine (J623-CHPA)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 016 CR    HW: 04E 907 309 A
       Component: 1,4l R4 TSI   H11 7865
       Revision: WAH11---
       Coding: 01190032230401080000
       Shop #: WSC 00066 790 00226
       ASAM Dataset: EV_ECM14TFS01104E906016CR 002006
       ROD: EV_ECM14TFS01104E906016F.rod
       VCID: 74E7FC58DFBCF6E1FD-8020
       Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
       Component: ESC           H32 0393
       Revision: 00000000    Serial number: 53315000000113
       Coding: 04FA6AA124216973007A060341C7292056249600608294F200230030C002
       Shop #: WSC 01383 790 50316
       VCID: 4B9547A4E2C2C9194C-801E
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5GM 907 426     HW: 5GM 907 426
       Component: AC Manuell    H02 1001
       Revision: 00001K01
       Coding: 02020004100100001000000000000002
       ROD: EV_ACManueBHBVW37X_SK48.rod
       VCID: 0501B19C8426FF69DA-8050
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
       Revision: --------    Serial number: 86582206150023
       Coding: 00000842C241005B0BA44080B10403081000000000000000000000000000
       Shop #: WSC 00066 790 00202
       ROD: EV_BCMBOSCH_016_AU37.rod
       VCID: 000FA0889B04DA41E9-8054
       Component: WWS    150809  043 0581
       Serial number:         151215184224
       Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
       Serial number: 000000000ZY1524724V1
       Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Component: Sirene, DWA  005 0312
       Serial number: 00000000000033487552
    550420 - Databus
                        Fault Frequency: 197
                        Reset counter: 193
                        Mileage: 5488 km
                        Date: 2017.06.11
                        Time: 20:18:07
    12810 - Bulb for Right Back-up Light
              B12CC 15 [008] - Open or Short to Plus
    263442 - Siren / Alarm Horn for Anti-Theft Alarm System
              B131D F7 [008] - No Release by Immobilizer
                        Reset counter: 192
                        Mileage: 5603 km
                        Date: 2017.06.14
                        Time: 08:13:58
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
       Revision: --------    Serial number: 39391530704209
       Coding: 0031051001
       VCID: 43856F84CA920159B4-8016
       Component: AirbagVW20    014 0385
       Serial number: 003F6M016TXT
       VCID: 4189658CD08E1349A6-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 002 310 15
       Serial number: 357670000007A73D371-
       Subsystem 2 - Part No SW: -----------    HW: 480 002 310 15
       Serial number: 3586700000041B3D371T
       Subsystem 3 - Part No SW: -----------    HW: 480 402 410 15
       Serial number: 3516502A31D3F974329F
       Subsystem 4 - Part No SW: -----------    HW: 480 402 310 15
       Serial number: 3526502AB1D3F971B06O
       Subsystem 5 - Part No SW: -----------    HW: 480 400 309 15
       Serial number: 3556502C91D1B624C26J
       Part No SW: 5Q0 953 521 L    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20151127500639
       Coding: 0600
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3B751764B2627999FC-806E
       Part No SW: 5G1 920 740 A    HW: 5G1 920 740 A
       Component: KOMBI         242 6420
       Coding: 03A51100A180880C02093E001000000000000000
       VCID: 2447CC182FDC2661AD-8070
       Part No SW: 5Q0 907 530 AG    HW: 5Q0 907 530 K
       Component: GW MQB Low    210 2246
       Revision: --------    Serial number: 08111510801474
       Coding: 030000043F085700FB000048080F00010001050000000000000000000000
       Shop #: WSC 00066 790 00199
       ROD: EV_GatewConti_013.rod
       VCID: 76E3C650C9C0E4F1C3-8022
       Subsystem 2 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
       Serial number: 4293638103
       Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
       Serial number: 2811150605035T
       Coding: 003002208000020000001000
       Serial number: 00000000000002425552
    65650 - Turn Signal in Exterior Mirror
              B11FD 13 [008] - Open Circuit
                        Reset counter: 193
                        Mileage: 5488 km
                        Date: 2017.06.11
                        Time: 20:18:01
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 0102
       ROD: EV_SteerAssisMQB_VW31.rod
       VCID: 44876C98CF9C06618D-8010
       Serial number: 20111506050CH7
       Coding: 003002208E00020000001000
       VCID: 428B6A80D5880851BF-8016
       Serial number: 00000000000002357512
       Coding: 090000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
       Part No SW: 3Q0 035 824 A    HW: 3Q0 035 824 A
       Component: MU-S--ER      620 0627
       Coding: 02730200FF00000051220001001828001F0100C40120010003
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 2B5527244202E9196C-807E
       Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
       Component: ABT_Std-2  H53 1031
       Serial number: VWZ8Z9RJT00069
    0522 - Front Left Bass Speaker
              B105F 13 [008] - Open Circuit
                        Reset counter: 193
                        Mileage: 5604 km
                        Date: 2017.06.14
                        Time: 12:01:32
                        Voltage terminal 30: 12.1 V
    End-------------------------(Elapsed Time: 03:14)--------------------------
    Address 09: DTCs cleared
    Address 42: DTCs cleared
    VWTSI: In addition to the stuff that you have said, it might be prudent to grab a copy of a WD for your Sportswagon. If you look at the connector on your new headlight assemblies, you should find that they have 14 x pin connector (assuming that they are true OEM). A quick look at your old incandescent headlight fittings should confirm that they have a 10 x pin connector. So, stuff is connected differently between the two types of headlight assemblies and the Xenon factory loom has additional wires.
    You will need to decide how you will manage this difference - either you will need to install additional wires to the car's headlight loom from the new BCM, or you will need to install a cross wiring loom at your existing incandescent lamp connector (and of necessity, lose some functionality from the OEM set-up). Either way, this decision will be a prime determinant for what changes that will be required to the Leuchte-sets in your BCM.
    I'm sure that you will receive further advice from other colleagues here after you post-up an auto-scan
    EDIT: which you have just done!
    VW Golf MkVII (103TSI) my13
  6. Likes Uwe liked this post
    Sep 2017
    Brazil
    Hi Don,
    Thanks for your response.
    You are right, the OEM Xenon Headlights have 14 x pin connector and the currently incandescent headlight have 10 x pin connector. I already bought a 10 to 14 pin adapter connector.
    I would like to install the OEM Xenon Headlights with fewer changes in my Sportswagon even if I lose some functionality like auto leveling and AFS for example, but with Xenon Lamps low/high beam, Led and DRL working without error messages on dashboard.
    If it is possible to retrofit without exchange my BCM, it would be great.
    Sep 2017
    Brazil
    Hi Don,
    Could you tell me how can I grab a copy of a WD for my Sportswagon?
    Thanks,
    Mitio
    Please see: Where do I get a Wiring Diagram.
  10. #8
    Sep 2017
    Brazil
    Hello Guys,
    Please find below my 2016 Golf Sportswagen WD.
    It is my first time handling this type of information, sorry if I made some mistake or did not provide enough information.
    I really appreciate if someone could help me to retrofit my OEM Xenon Headlights.
    CAN
    BASIC EQUIPMENT
    BCM
    CONTROL UNIT FOR CORNERING LIGHTS AND HEADLIGHT RANGE CONTROL
    Thanks,
    VWTSI
  11. #9
    Quote Originally Posted by VWTSI View Post
    Hi Don,
    VWTSI: Hmm............ I'm not familiar with the road rules in Brazil- but will your modified car still be street legal if you fit HIDs without auto leveling? Even down here in the world's back-water, it's mandatory to fit auto-leveling and washers when the car has HIDs!
    As to your question as to whether your existing BCM/ CAN Gateway will suffice, it's really difficult to say without knowing a whole lot more about the degree of "OEM-ness" of the new headlight fittings and the nature of the cross wiring loom. I'm aware of some folk making cheap Chinese knock-off fittings work (which are meant to be OEM) with low-line BCMs, but I'm also aware of many problems when using these fittings. The irony is that the closer the new fittings are to true OEM, the less likely it is that your old control modules will be compatible with your new headlight fittings
    Assuming that Brazil's road rules do permit such retro-fits, you might consider first trying a temporary wiring arrangement and some experimentation - perhaps on one side of the car. Just as a suggestion, perhaps set-up one of the new fittings temporarily (without actually installing it on the car) with the cross wiring loom hooked-up onto the 10 x pin connector and then make some simple Leuchte programming changes to the BCM. This should at least give you a sense of the size of the problem if you keep the existing control modules (perhaps).
  12. Likes Uwe liked this post
  13. #10
    Verified VCDS User andreizx12's Avatar
    Nov 2015
    Romania
