Replacing door module
flippamike
Pirate
Walking the Plank
LP/IP
Hi People,
I have been replacing two care modules on different Golf 7's. Both needed to upgrade their module for folding mirrors.
The old module is 5Q4 959 393E, and the new module is 5Q0959593A restored the module with the old code and activated the folding mirrors. Works perfect!
After starting the car a error popups about the Start Stop system. Am i missing a step, do i need to register the module to the Gateway or is there something else ?
Thanks in advance.
Michael
Shiz94
C?ID=312561
Did you sort this? If not have a look in coding not sure about yours but my door modules have to have start/stop coding into them. Hope it helps
flippamike
Pirate
Walking the Plank
LP/IP
Sorry for the delay, had to go back to the shop.. but thanks guys for thinking along, so here is the auto scan Uwe.
@Shiz94, can you send me in the right direction where that coding is done ?
Removed.  Data from clone/pirate copies of VCDS is not welcome here.
NEtech
C?ID=56995
You should update VCDS, so we can all error codes.:cool:
flippamike
Pirate
Walking the Plank
LP/IP
Hi NEtech,
I have to say on this car there was something wrong with the folding mirrors so kept the coding and waiting for the new mirrors. Only changed the module.
You think i have to reverse the coding because of the Fault in 42?
Again:
flippamike
Pirate
Walking the Plank
LP/IP
The last scan is done with 17.8, the first one with a lower version.
