ROD File Not Found in VCDS V17.8.0.1
Audis3fl
Hong Kong
I have encountered an issue "Unable to find a .ROD file for: EV_MUStd6C3DELP 001013(VW37) after I have enabled some of the adaptations under 5F.
Here is the auto-scan/error after the 5F module got updated. I can't get into the 5F adaptation because of this error.
Friday,06,October,2017,21:01:32:08534
VIN: WAUZZZ8V2HA071009   License Plate:
Mileage: 5759km-3578mi   Repair Order:
Control Module Part Number: 81A 035 877
  Component and/or Version: MU-S--ROA     710 0740
           Software Coding: 01735300FF0A000011150001000A00002F0025C60150010000
            Work Shop Code: WSC 06314
                      VCID: 688AB00ED2F1CE27F3A-803C
Advanced Identification/FAZIT
     Identification: GRO-633
     Date: 14.09.16
     Manufacturer number: 0701
     Test stand number: 1185
Flash Status
     Programming Attempts(application): 0/0
     Programming Attempts(data): 65535/0/1
     Successful Attempts(data): 65535/0/1
     Flash Date: 00.01.01
     Flash Tool Code(data): 00021 790 06314
Misc.
     Hardware number: 81A 035 877
     Workshop System Name: J794
     Equipment/PR Code: 000000008193B03A
     Dataset Number: 8V0909545E
     Dataset Version: 0014
     ASAM Dataset: EV_MUStd6C3DELP
     ASAM Dataset Revision: 001013
Car Info
     Chassis Number: WAUZZZ8V2HA071009
VCDS Info:
       Labels: None
       ROD: ERROR - EV_MUStd6C3DELP 001013 (VW37)
Saturday,16,September,2017,19:43:26:08534
VIN: WAUZZZ8V2HA071009   License Plate: KT7873
Mileage: 4877km-3030mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 52 55 5F 6C A9
          BB BC
VIN: WAUZZZ8V2HA071009   Mileage: 4877km-3030miles
Address 01: Engine (J623-DJHA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 J    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0A2500122406010B3000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TFS0208V0906259J 001004
   ROD: EV_ECM20TFS0208V0906259J_AU37.rod
   VCID: 47C853B2BF2FE15FDA0-8012
   Part No SW: 0GC 300 011     HW: 0DE 927 711 C
   Component: GSG DQ381     H12 0403
   Revision: 00H12V32
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061_AU37.rod
   VCID: 5F98ABD207BF899F020-800A
   Part No SW: 8V0 907 379 B    HW: 8V0 907 379 B
   Component: ESC           H25 0610
   Revision: 00000000    Serial number: 62756000000252
   Coding: 329C938D54A01BAA89910B64419A694CC92AD891D082967600410004020812
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   ROD: EV_Brake1UDSContiMK100IPB_035_AU37.rod
   VCID: 43D047A28B17CD7F068-8016
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Revision: 00021000    Serial number: 0420677469
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B203F42F3E7B5BF4E8-806E
   Part No SW: 8V0 820 043 M    HW: 8V0 820 043 M
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000001071746
   Coding: 03100014110000011000000000001500
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 3C223C5EF6E9B287472-8068
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 4838825800PAG0MUFU03
   Part No SW: 5Q0 937 085 BF    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H34 0236
   Serial number: 02001628601607
   ROD: EV_BCMBOSCH_017_VW27.rod
   VCID: 7EA6F656A0756097296-802A
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 160919  043 0580
   Serial number:         161010183513
   Coding: 0A47F7
   Serial number: 62370670
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 13 08 2016  00001753
   Serial number: 000000000ZY162580YQT
   Serial number: 00000000000036686419
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST0018V3GN00000
   Coding: 901E00
262936 - Sensor for anti-theft alarm system
          B1330 29 [008] - Signal Implausible
                    Reset counter: 16
                    Mileage: 4866 km
                    Date: 2017.09.16
                    Time: 08:14:43
   Part No SW: 5QA 919 294     HW: 5QA 919 294
   Component: PDC 8 KanalH07 0031
   Serial number: 000308418616285
   Coding: 0530151011
   ASAM Dataset: EV_EPHVA18AU3700000 009027
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 094C958AE9BB572F0C4-805C
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR27PULS
   Coding: 98CCC000000000005C54000000C800000065
   VCID: 107AB8EE8AE166E7CBA-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 001 910 16
   Serial number: 35700000000B57D4FE1%
   Subsystem 2 - Part No SW: -----------    HW: 480 001 910 16
   Serial number: 35800000000457D4FE1-
   Subsystem 3 - Part No SW: -----------    HW: 480 402 110 16
   Serial number: 35100019D2280CC2D456
   Subsystem 4 - Part No SW: -----------    HW: 480 402 110 16
   Serial number: 3520001A3229A9E384A9
   Subsystem 5 - Part No SW: -----------    HW: 480 401 608 16
   Serial number: 3550002AF218C2A4D29H
   Part No SW: 8V0 953 521 JP    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 17101604401336
   Coding: 8418
   VCID: 117CBDEA81EB6FEFC44-8044
   Part No SW: 8V0 920 873 B    HW: 8V0 920 873 B
   Component: KOMBI         H04 8316
   Coding: 278D081A2B8000081801AA001001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009054
   VCID: 3D24315AEDF3BB8F70C-8068
16776973 - Databus
                    Reset counter: 232
                    Mileage: 4877 km
                    Date: 2017.09.16
                    Time: 19:22:35
   Revision: --------    Serial number: 0005456738
   Coding: 030100043F085A005B0082683C0B00000001010000000000000000000000
   VCID: 7CA2FC5EB6697287072-8028
   Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
   Component: J453 MFL  H04 0003
   Serial number: 20161004101706 20356
   Serial number: 75410803001610142562
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7755
   Serial number: HA1-00015.09.16
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   VCID: 45D459BA8523F34F28C-8010
   Revision: 00000000    Serial number: 16000178149003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_004_VW37.rod
   VCID: 3432147EDEB97AC78F2-8060
   Serial number: 081016EJ805918
   Coding: 001C1A205C01040000001002
   Coding: 8107
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 3A2E3A46FCDD8CB755E-806E
   Serial number: 071016EJ709599
   Coding: 001C12205E01040000001002
   VCID: 42DE42A6940DC4770DE-8016
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Coding: 0EEE00102B200200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   VCID: 3E263656E0F5A097696-806A
   Part No SW: 81A 035 877     HW: 81A 035 877
   Component: MU-S--ROA     710 0740
   ASAM Dataset: EV_MUStd6C3DELP 001013
   ROD: EV_MUStd6C3DELP_AU37.rod
   Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY208358
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 BB    HW: 8V0 919 614 BB
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL107071600010867
   Coding: 0273100102002001400040
   VCID: 392C254AF9DB87AF5C4-806C
   Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
   Serial number: 160912200311
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 041016EJ309082
   Coding: 000C12204001040000001002
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   Serial number: 041016EJ308901
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
End----------(Elapsed Time: 01:32, VBatt start/end: 12.6V/12.6V)-----------
Saturday,16,September,2017,19:44:22:08534
     Date: 14.09.16
Flash Status
Misc.
Car Info
VCDS Info:
       Labels: None
Saturday,16,September,2017,19:59:14:08534
          BB BC
   Revision: --H13---
   Revision: 00H12V32
   Coding: 030C0C
   Component: AQ_Hum_Sensor  4H0907658B or 0005
   Coding: 0A47F7
   Coding: 00006C
   Light switch:
   Sun Roof:
   Coding: 901E00
                    Reset counter: 16
                    Mileage: 4866 km
                    Date: 2017.09.16
                    Time: 08:14:43
   Coding: 0530151011
   Coding: 8418
   Coding: 278D081A2A8000081801AA001001000000000000
   Coding: 0001
   Coding: 8107
End-------------------------(Elapsed Time: 01:31)--------------------------
Saturday,16,September,2017,20:02:49:08534
          BB BC
   Revision: --H13---
Readiness: 1110 0001
   Revision: 00H12V32
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 00006C
   Light switch:
   Sun Roof:
   Coding: 901E00
   Coding: 0530151011
   Coding: 8418
   Coding: 0001
   Coding: 8107
End----------(Elapsed Time: 01:30, VBatt start/end: 12.5V/12.5V)-----------
Eric
HC800000
I don't see a missing ROD error in the three autoscans you posted above. Was it a temporary glitch due to your HEX-v2 not being able to retrieve the car's VIN for some reason? This could happen inbetween loading the ROD file and displaying the adv ID information.
RS200Z
C?ID=251076
I have also encountered the same error with module 5F on several face lifted A3 1.0. The error is intermittent. Whenever I get the No ROD file found error in module 5F, I exit (close the module) and select it again and it is able to enter without any errors. Hope this helps to provide a clue for troubleshooting.
The exact error is "Unable to find a .ROD file for: EV_MUStd6C3DELP 001013 (VW48)"
Here's a copy of the AutoScan on one of the FL A3 I encountered. Also, I am using the HEX+CAN USB cable.
Wednesday,18,October,2017,10:17:08:57576
VIN: WAUZZZ8V7H1048714   License Plate: SKQ9789D ALVIN HOW
Mileage: 21400km-13297mi   Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F BB BC
VIN: WAUZZZ8V7H1048714   Mileage: 21400km-13297miles
Address 01: Engine (J623-CHZD)       Labels: None
   Part No HW: 04C 907 309 AE
   Component: R3 1.0l TFS   H25 3494
   Revision: W1H25---
   Coding: 02250032232401083000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM10TFS01104C906026AB 002006
   ROD: EV_ECM10TFS01104C906026AB_002.rod
   VCID: 55A1CC1734E1BEEE89-8000
   CAN Converter 01:
   Part No SW: 0CW 300 040 S    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1004
   Revision: 00005026    Serial number: CU501611236553
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 44870153CF7B3766EE-8010
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 63336000000352
   Coding: 13F18AA224241274897E0E0180C725C8512448917001A4720221F0040208420000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
   VCID: 78FFA5A3C333A386B2-802C
   Revision: 00021000    Serial number: 0424381575
   Coding: 030C0C
   VCID: 3B757AAFB285489E9F-806E
   Revision: 20001000    Serial number: 00000001104028
   Coding: 03100003110000001000000000001400
   VCID: 3C7779B3B78B4FA696-8068
   Serial number: D999CD5800PAG0MUFU03
   Serial number: 02001632901538
   VCID: 7EF3B3BBE1179DB6F8-802A
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 160806  043 0585
   Serial number:         160810221224
   Coding: 0A47F7
   Serial number: 62464250
   Coding: 00006C
   Light switch:
   Serial number: 11 09 2016  00000298
   Part No SW: 5QA 919 283 A    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0038
   Serial number: 000308419616316
   Coding: 0600140011
   Shop #: WSC 11673 001 1048576
   ASAM Dataset: EV_EPHVA14AU3700000 009029
   ROD: EV_EPHVA14AU3700000_009_VW37.rod
   VCID: 489F1563F353130602-801C
   Serial number: 003TDR2CB3BP
   VCID: 102FFD03CB839BC61A-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 002 511 16
   Serial number: 357000000001D82CA02K
   Subsystem 2 - Part No SW: -----------    HW: 480 002 511 16
   Serial number: 35800000000DE82CA02Y
   Subsystem 3 - Part No SW: -----------    HW: 480 402 211 16
   Serial number: 3510001A7231F2C5C3C8
   Subsystem 4 - Part No SW: -----------    HW: 480 402 211 16
   Serial number: 3520001B92388B50E400
   Subsystem 5 - Part No SW: -----------    HW: 480 400 511 16
   Serial number: 3550002C9234FA337120
   Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 28111608490078
   Coding: A018
   VCID: 0D11E477DCB1B62EF1-8058
   Part No SW: 8V0 920 872 N    HW: 8V0 920 872 N
   Coding: 27A41A182A8000080100A8001000000000000000
   Component: GW MQB High   515 5286
   Serial number: 29111610522429
   Coding: 030100043F0857005B000248100B00000001010000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 2F6D5EFF76FDA43E23-807A
   Serial number: 20161125043527 20604
   Serial number: 75410803001611307625
   Revision: 00000000    Serial number: 16000198818001
   VCID: 346751939FDB87E65E-8060
   Serial number: 111116EKB06211
   Coding: 001C1B205C01040000001002
   VCID: 4385024FCA75305ED7-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 8107
   VCID: 45811C57C4410E6EF9-8010
   Serial number: 121116EKC16487
   Coding: 001C13205E01040000001002
   VCID: 428B074BD56F3956DC-8016
   Coding: 0ECE00102B200200
   VCID: 3E7373BBA1975DB6B8-806A
   Part No SW: 81A 035 824 A    HW: 81A 035 824 A
   Component: MU-S--ER      710 0771
   Coding: 01730100FF00000011110001000A00002F0024160170010002
   VCID: 2149A8C73029024EA5-8074
   Serial number: AUZ8Z9GY2093D6
   Serial number: ALJAL105081600010239
   Serial number: 081116EK71821A
   Coding: 000C13204001040000001002
   Serial number: 081116EJ902034
End-------------------------(Elapsed Time: 04:22)--------------------------
