Results 11 to 20 of 22
Thread: Mk6 Jetta MFSW retrofit
    Oct 2017
    Thanks for the reply! Yes I do have the correct harness also waiting for the installation so that one is good to go.
    Is it possible to check through VCDS if my car has the steering angle sensor, possibly from the "live data" section? I also have the wiper stalk without the buttons but the new stalk also has rear windscreen wiper option so I think I'll go with the current stalk. Unless somebody happens to know the right part number for the stalk without the buttons and the rear wiper?
  2. #12
    Aug 2016
    Switzerland
    there's probably a measuring value block or advanced measurement value in the ABS for steering angle sensor (G85)
    looks like your jetta is a AW1 (high, PQ35) so the stalk from a beetle won't work.
    -= How to post an autoscan -=- How to post an autoscan =-= iichels Polo 6R =-= Don't follow me, I'm lost too =-
  3. #13
    Oct 2017
    I found that, thank you. Managed to get steering angle values from there, so that would mean that the original control module also has steering angle sensor, am I right? That there are no other parts where the car could get that information from?
  4. #14
    Oct 2017
    Alrighty, got my new control module and the plan is to give this a go during the weekend. Any advice on how to code the factory new controller, do I just use the original coding (4080140000) for the new module?
  5. #15
    Yeah, start with the factory coding: 4080140000
    After that's accepted go ahead and tweak the MFSW bits with the LCH. Please post the new scan even if you don't need further assistance.
  6. Likes Jukman liked this post
  7. #16
    Oct 2017
    Thanks Dana, hopefully this will be a straight on project from now on.
    I will post the new auto-scan if everything goes as planned.
  8. Likes Dana liked this post
  9. #17
    Oct 2017
    Good news, managed to install the MFSW almost succesfully, horn, css etc. work as they should. The original wiper stalk with buttons also work like before, so I think I can live with that.
    However, the right hand side buttons function only partially: so far I have not noticed that the right-left -arrows do not operate at all, the up and down buttons function as they should. Any ideas on this one, perhaps this has something to do with the still functioning wiper stalk which I thought that it shouldn't work anymore? It also might be something as easy as tweaking with LCH, ran out of time at the moment...
    The original steering wheel coding: 4080140000
    The new coding: 4082140000
    The difference was the result of tweaking with the LCH (MFSW installed).
    The full auto-scan:
    Saturday,10,February,2018,11:48:00:10843
    VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4401.4
    VIN: WVWZZZ16ZCM049136   License Plate: NIL-731
    Mileage: 133950km-83232mi   Repair Order:
    Chassis Type: 16-VW32 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
    VIN: WVWZZZ16ZCM049136   Mileage: 133950km-83232miles
    Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
       Part No SW: 03C 906 016 BS    HW: 03C 907 309 F
       Component: MED17.5.5     H12 4772
       Revision: LCH12---    Serial number: 00000000000000
       Coding: 00190012002400000000
       Shop #: WSC 36000 205 00000
       ASAM Dataset: EV_ECM14TFS01103C906016BS 001010
       ROD: EV_ECM14TFS01103C906016BS.rod
       VCID: 71BCDC16512BBF3FA5F-8024
    Readiness: 1110 0101
       Revision: 00H31001
       Coding: A43B40F809260003250C02E7901F0040210000
       VCID: 7BA0FE3E03E7C56F0F3-802E
       Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
       Component: AC Manuell    H19 0304
       Revision: 00001015
       Coding: 0000004002
       Shop #: WSC 00066 000 00120
       VCID: 005A89D26A81A6B75A1-8054
       Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
       Component: BCM PQ35 B    011 0048
       Revision: BA011001
       Coding: 00000A3A982F02C040080080000000E40380008870808D205CC000000040
       Shop #: WSC 00066 123 12345
       VCID: 353428066543D31FB97-8060
       Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
       Serial number: 003G6M00RMHR
       Coding: 00003242
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 323E131A94ADC4279C5-8066
       Serial number: 3572MSME32021342ZZZA
       Serial number: 3582MSME20031342ZZZ9
       Serial number: 3516KSME492D2912ZZZV
       Serial number: 3526KSME2B0A7112ZZZO
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20171101100167
       Coding: 4082140000
       Shop #: WSC 01286 386 08256
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 025E83DA648DB4A74C5-8056
       Component: E221__MFL-TAS  H07 0013
       Serial number: 0069722
       Coding: 820000
       Part No SW: 5C6 920 871     HW: 5C6 920 871
       Coding: 171E01
       VCID: 698CB47679FB47FFEDF-803C
       Revision:   H42       Serial number: 11091101270763
       Coding: 351002
       VCID: 6A8ECB7A7CFD4CE7E45-803E
       Part No SW: 3C8 035 279 N    HW: 3C8 035 279 N
       Component: RNS315-EU   H70 0407
       Serial number: VWZAZ2N0424764
       Coding: 0600041104000F0000008000
       Shop #: WSC 00015 115 12345
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 36362F0A78C5D807B0D-8062
       Component: EUR_W_V10  0070
    1048630 - CD Changer
              B1101 31 [009] - No Signal
                        Reset counter: 121
                        Mileage: 133957 km
                        Date: 2018.02.10
                        Time: 00:16:25
    1048652 - Telephone Microphone
              B1048 13 [009] - Open Circuit
                        Reset counter: 121
                        Mileage: 133957 km
                        Date: 2018.02.10
                        Time: 00:16:25
       Revision: 13110009    Serial number: 0003310477
       Coding: 0000B5
       Shop #: WSC 01383 790 50316
       VCID: 5BE09EBEA3A7256F6F3-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1508
       Serial number: 00000006025349
       Coding: 000090
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 68     3201
       Revision: 00H20000
       VCID: 343215026239CA178E9-8060
       Revision: 15110009    Serial number: 0003392657
       Coding: 0000B4
       VCID: 5CE29DA2A6A92257669-8008
       Slave Passenger:
       Component: J389__TSG-HR  006 1508
       Serial number: 00000006049112
       Coding: 000090
    End----------(Elapsed Time: 00:50, VBatt start/end: 14.3V/14.4V)-----------
  10. Likes Dana liked this post
  11. #18
    Dec 2016
    NL
    As far as I know, the left right buttons are for next/previous. Seems logical that the media player isn’t aware of the MFSW.
    Current:
  12. #19
    Oct 2017
    The left hand side left-right -buttons work as they should, they change the song or the radio station depending on the media played. But the right hand side buttons should in my opinion operate the MFD. The up and down buttons work as they should.
  13. #20
    Quote Originally Posted by Jukman View Post
    If you still have the stalk controls connected that may be the conflict. For example, having both the factory MF stalk type -and- a retrofitted LIN 2.0 (12 button) Mk6 steering wheel caused issues on the early Mk6 Golf.
    I'd try this coding: 008A140000
    Even if you get an incorrectly coded DTC (i.e. due to the factory stalk instead of a plain/non MF stalk) the wheel buttons may work properly.
  14. Likes Uwe, Jukman liked this post
