Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Mk6 Jetta MFSW retrofit
    Oct 2017
    New member to the forum signing in!
    So, the project I am currently workin on is to fit a MFSW steering wheel to my 2011 Jetta. The parts I have already acquired are the steering wheel itself (Mk6 Golf GTD), 2x repair wire (000 979 009 E) and the MFSW harness is on its way at this moment. So the only part I am lacking at this moment is the steering wheel control module.
    So far I have been relying in these instructions: http://http://forums.vwvortex.com/sh...W-Retrofit-DIY
    Below you can see the auto-scan of my car, which seems to tell me that the module I have at the moment is 5K0 953 569. There is an extensive chart in the ross-tech website of the modules, which also tells me that this module is not compatible with the MFSW. The question is that which module should I buy to make this retrofit work?
    Thursday,05,October,2017,17:28:36:10843
    VIN: WVWZZZ16ZCM049136   License Plate: NIL-731
    Mileage: 126240km-78441mi   Repair Order:
    Chassis Type: 16-VW32 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ16ZCM049136   Mileage: 126240km-78441miles
    Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
       Part No SW: 03C 906 016 BS    HW: 03C 907 309 F
       Component: MED17.5.5     H12 4772
       Revision: LCH12---    Serial number: 00000000000000
       Coding: 00190012002400000000
       Shop #: WSC 36000 205 00000
       ASAM Dataset: EV_ECM14TFS01103C906016BS 001010
       ROD: EV_ECM14TFS01103C906016BS.rod
       VCID: 71BCDC16512BBF3FA44-8024
    Readiness: 1110 0101
       Revision: 00H31001
       Coding: A43B40F809260003250C02E7901F0040210000
       VCID: 7BA0FE3E03E7C56F0E8-802E
       Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
       Component: AC Manuell    H19 0304
       Revision: 00001015
       Coding: 0000004002
       Shop #: WSC 00066 000 00120
       VCID: 005A89D26A81A6B75BA-8054
       Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
       Component: BCM PQ35 B    011 0048
       Revision: BA011001
       Coding: 00000A3A902D02C040080080000000E40300008870808D605CC000000040
       VCID: 353428066543D31FB8C-8060
       Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
       Serial number: 003G6M00RMHR
       Coding: 00003242
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 323E131A94ADC4279DE-8066
       Serial number: 3572MSME32021342ZZZA
       Serial number: 3582MSME20031342ZZZ9
       Serial number: 3516KSME492D2912ZZZV
       Serial number: 3526KSME2B0A7112ZZZO
       Part No SW: 1K5 953 521 AG    HW: 5K0 953 569
       Revision: FF010040    Serial number: 20110812200384
       Coding: 4080140000
       Shop #: WSC 00066 000 00185
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 72BED31A542D84275DE-8026
       Part No SW: 5C6 920 871     HW: 5C6 920 871
       Coding: 171E01
       VCID: 698CB47679FB47FFEC4-803C
       Revision:   H42       Serial number: 11091101270763
       Coding: 351002
       VCID: 6A8ECB7A7CFD4CE7E5E-803E
       Revision: 13110009    Serial number: 0003310477
       Coding: 0000B5
       Shop #: WSC 01383 790 50316
       VCID: 5BE09EBEA3A7256F6E8-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1508
       Serial number: 00000006025349
       Coding: 000090
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 68     3201
       Revision: 00H20000
       VCID: 343215026239CA178F2-8060
       Revision: 15110009    Serial number: 0003392657
       Coding: 0000B4
       VCID: 5CE29DA2A6A92257672-8008
       Slave Passenger:
       Component: J389__TSG-HR  006 1508
       Serial number: 00000006049112
       Coding: 000090
       Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
       Component: Radio RCD310  032 0079
       Revision: 01000001    Serial number: VWZ1Z2L3156511
       Coding: 05000400040006
       VCID: 72BED31A54AD84275DE-8026
    End----(Elapsed Time: 00:48, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    Thank you in advance for helping out the newbie
    Mar 2017
    Steering control module with revision "CH" will support the buttons on the MK6 mfsw. You should also change your cruise control stalk to a new one with revision "G".
    You can problerly also use another control module, but these I don't know of.
  3. Likes Uwe, Jetta ,97, Jukman liked this post
    Oct 2017
    Thanks for the reply! So the correct module would be 1K0-953-549-CH and this will work even though the original module has a completely different part number?
    And the cruise control stalk: wouldn't the correct part be 5K0054691D because of both MFI and MFSW? So replacing this part will remove the buttons on the right hand side switch, because the MFI will be operated from the steering wheel?
    Mar 2017
    Yes - this will work since your car share same electronics with the MK6 golf.
    Part numbers for cruise control stalk 1K0953513G
    Part number for wiper stalk is 1K0953519H
    Oct 2017
    Thank you for the part numbers! How about the wiper stalk, should it be replaced too or will the original work?
    So these are the parts that have to be replaced:
    -Steering wheel (duh...)
    -Steering control module
    -Wiring harness
    -Cruise control stalk
    -Wiper stalk (?)
    Is there anything else that should be replaced, such as the slip ring?
    Mar 2017
    Wiper stalk will work without replacing. I did just replace mine to the one listed above to get rid of the buttons that will control the MFA. Don't like having stuff in the car with no function - your current wiper stalk buttons to control the MFA will not work once you install the MK6 multi function steering wheel.
    Not sure what you have to replace the wire harness?
    Your slipring should be fine
    Oct 2017
    Okay, will be replacing the wiper stalk then for the same reason.
    From what I have understood, the wiring harness is required with the MFSW. The new steering wheel did not come with an airbag, so I will be using the airbag from my current SW and this one is missing one connector that plugs into the control module.
  9. #8
    Oct 2017
    Let's give this thread an update. The steering wheel control module I bought did not fit into my Jetta, it appears that mine has the module integrated into the slip ring. The module I bought did not therefore fit into my car.
    So I am planning to buy a new control module, and so far I have three options: 5K0-953-569-L, 5K0-953-569-AL and 5K0-953-569-H. All of these are highline models and support the mfsw, but does all of these fit or are there differences between these units?
  10. #9
    Oct 2017
    Any help with this one? Thinking about pulling the trigger with 5K0-953-569-AL/H.
  11. #10
    May 2017
    AL or AH should both be fine, both support MFSW buttons and cruise control. Only thing that is a little bothering is, that the Ross-Tech map does not show if your current control module has steering angle sensor in the module or not. It is TBD on Ross-Tech's site for your current module.
    Also you have a new airbag wiring harness ordered for MFSW buttons? DO NOT use any repair wires and try to make it yourself. Buy a ready made wiring to be safe.
    New wiper stalk is not mandatory as you can code the buttons on that out but of course for aesthetic reasons correct stalk is nice
