Hey guys just got this audi and I'm having issues with ami not working thinking maybe needs a new cable anyways I get this strange error when I scan with vag com I understand the issues with the engine side I need a new intake manifold and the turbo error is due to a damaged connector I will be fixing but the radio error and the cable set error has be stuck thanks in advanced
Thursday,28,September,2017,09:27:16:27676
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
Data version: 2017021 DS267.2
VIN: WAUFFAFL7ANxxxxx License Plate:
Mileage: 46490km-28887mi Repair Order:
Chassis Type: FL (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
72
VIN: WAUFFAFL7ANxxxxx Mileage: 46490km-28887miles
Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AA HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H16 0005
Revision: E1H16---
Coding: 0104010A190F0160
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM20TFS8K2907115AA A01006
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 6ED24DBBB1FB19310B-803A
2970 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 00 [237] - Implausible Signal
Mileage: 46441 km
Date: 2017.09.21
Time: 17:40:24
Engine speed: 4043.00 /min
Normed load value: 93.7 %
Vehicle speed: 60 km/h
Coolant temperature: 96 °C
Intake air temperature: 42 °C
Voltage terminal 30: 13.688 V
4270 - Turbocharger Bypass Valve Control Circuit
P0033 00 [109] - Malfunction / Open Circuit
Mileage: 46456 km
Date: 2017.09.24
Time: 21:25:16
Engine speed: 6265.50 /min
Normed load value: 97.6 %
Vehicle speed: 91 km/h
Coolant temperature: 97 °C
Intake air temperature: 45 °C
Voltage terminal 30: 13.711 V
Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
Part No SW: 8K0 927 158 J HW: 0B6 927 156
Component: 0B6 20TFSIUSA H05 0009
Revision: --H05---
Coding: 001012
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: 3D70BAF7AC1DB2A9C2-8068
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0030
Coding: 150D18
Shop #: WSC 02391 823 56573
VCID: 7AFA71EBF5B34591A7-802E
Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
Component: BCM2 1.1 H02 0327
Coding: 090100
Shop #: WSC 02399 823 56573
VCID: 78FE6BE3CBBF5781D1-802C
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0510000012485014
Component: J764 ELV MLB H37 0042
Serial number: 0210000016145008
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01010320100760
Coding: 64102000
VCID: 000E0303936F1F41E9-8054
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000476797
Coding: 26001091063CAF010000080300003D0D0F1C520802010161000000
VCID: 3C76B7F3BF07BBA1F5-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 240210 H06 0070
Serial number: SWF10020245751
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10795867
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000002002101570
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 Q HW: 8K0 919 475
Component: PARKHILFE 4K H06 0070
Revision: 11001001 Serial number: 51241006109790
Coding: 300103
VCID: 479CD81FF6C1E87968-8012
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H41 0610
Serial number: 003GLD0D1AKB
Coding: 303837354230303030304A55304C384B3053
Shop #: WSC 02135 785 00200
VCID: 4580D217C4CDFA699A-8010
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R1000005S00
Serial number: 6334MSME514223796
Serial number: 6344MSME4F65516CS
Serial number: 6352QSME085215389
Serial number: 6362QSME5A4D153AT
Serial number: 63732SME1751093C.
Serial number: 63832SME723D1610X
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315JBQ000CH
Coding: 000016
VCID: 3D70BAF7A41DB2A9C2-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 M HW: 8K0 920 980 M
Component: KOMBIINSTR. H20 0255
Revision: 00300000 Serial number: CIX440N2A
Coding: 8B1709000300D705020000
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0116
Revision: EB900055 Serial number: 5500E10217822E
Coding: 00C303
VCID: 03040C0F82790459F4-8056
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 100099FB160210
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000010193486
Coding: 011C03204000410001
VCID: 4580D217CCCDFA699A-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0127351819
Coding: 0106063A007A440400B0013200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000226924
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS037 H06 0041
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000010171038
VCID: 4486CF13C7F7C3618D-8010
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000579352
VCID: 34669FD3975773E13D-8060
Part No: 8K5 907 357
Coding: 0000004
VCID: 77FC68DF06A158F9D8-8022
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335CT0A7556412
Coding: 020000020100000001
VCID: 1D305A7704DDD2A9E2-8048
00003 - Control Module
Fault Status: 00101110
Mileage: 46370 km
Date: 2009.06.26
Time: 00:09:05
Bin. Bits: 00000000 00001000
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 664 B HW: 8T1 035 664 B
Component: H-BN-NA H47 0042
Revision: -------- Serial number: 490CX0A7551437
Coding: 010200000006A1EF03000F0E000000030000
VCID: 377CA8DF862198F918-8062
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356BT0A1205848
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000478822
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
02612 - Audio Wire Adapter Set
Reset counter: 201
Mileage: 46444 km
Date: 2017.09.23
Time: 23:18:36
Voltage: 12.90 V
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000103019790
Coding: 010C03204000210001
VCID: 428AC90BDDE3CD51BF-8016
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H03--- Serial number: 525PA8-J0290OX
Coding: 1000006
VCID: 387EABE34B3F978111-806C
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000103019807
End-------------------------(Elapsed Time: 03:05)--------------------------
72
Revision: E1H16---
Mileage: 46441 km
Date: 2017.09.21
Time: 17:40:24
Mileage: 46456 km
Date: 2017.09.24
Time: 21:25:16
Revision: --H05---
Coding: 001012
Coding: 150D18
Coding: 090100
Coding: 64102000
Coding: 00FD11
Coding: 025028
Coding: 300103
Coding: 000016
Coding: 00C303
Coding: 0000004
Mileage: 46370 km
Date: 2009.06.26
Time: 00:09:05
Reset counter: 201
Mileage: 46444 km
Date: 2017.09.23
Time: 23:18:36
Voltage: 12.90 V
Coding: 1000006
