I have replaced all o2 and manifold sensors and still getting a check engine light. Also, my headlights are brand new with brand new ballast, ignitor, and bulbs.(Fault Codes Are Below)
My air wont blow cold at all and I just recharged it yesterday! and it has a brand new ac pressure sensor switch. cause I was getting low voltage cold
P.S check out the video. can anyone tell me where the fuse/relay for ac pressure sensor and climate control
Friday,22,September,2017,17:11:53:05661
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WAUKGAFB7AN036515 License Plate:
Mileage: 142070km-88278mi Repair Order:
Chassis Type: FB-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 47 4C 4F 52 53 55
56 5F 62 6C 72
VIN: WAUKGAFB7AN036515 Mileage: 142070km-88278miles
Address 01: Engine (CCA) Labels: None
Part No SW: 4F1 910 551 D HW: 4F1 907 551
Component: 3.0l V6 TFSI 0050
Revision: --H06--- Serial number:
Coding: 0105000A190F0120
Shop #: WSC 08175 444 103843
VCID: 2412E4F0D2DA9EF71F2-8070
001169 - Secondary Air Injection System: Bank 1
P0491 - 000 - Insufficient Flow - MIL ON
Fault Status: 11100010
Mileage: 142073 km
Date: 2017.09.22
Time: 13:59:21
RPM: 1248 /min
Mass Air / Rev.: 228.9 mg/str
Temperature: 36.0°C
Bin. Bits: 00000010
Voltage: 12.55 V
Bin. Bits: 00000010
001170 - Secondary Air Injection System: Bank 2
P0492 - 000 - Insufficient Flow - MIL ON
Mileage: 142073 km
Date: 2017.09.22
Time: 13:59:21
RPM: 1248 /min
Temperature: 36.0°C
Bin. Bits: 00000010
Voltage: 12.55 V
Bin. Bits: 00000010
Readiness: 1110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F9 910 156 A HW: 09L 927 156 C
Component: AG6 09L 3,0TFSI USA 0010
Revision: --H04--- Serial number: 4539555
Shop #: WSC 02325 785 00200
VCID: 2A0E0AC8B0FE488725E-807E
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AL HW: 4F0 614 517 BA
Component: ESP8 quattro H03 0060
Coding: 0020921
VCID: 6E86C6D84C9664A7B96-803A
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602501421794
Coding: 0000007
Shop #: WSC 02324 785 00200
VCID: 2514F9F4D9E067FF08C-8070
Component: FBSAUDIC6 EZS H03 0020
Component: FBSAUDIC6 KSG H03 0020
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 B HW: 4F1 820 043 AL
Component: KLIMABETAETIGUNGH30 0080
Revision: 00000074 Serial number: 00000030482307
Coding: 0524326
VCID: 1D64D114F1B0AF3F50C-8048
00532 - Supply Voltage B+
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 66
Mileage: 142073 km
Date: 2017.09.22
Time: 19:06:11
Voltage: 2.50 V
Part No SW: 4F0 910 279 Q HW: 4F0 907 279 A
Component: ILM Fahrer H24 0340
Coding: 0139123
Shop #: WSC 02335 785 00200
VCID: 372823BC734CE56FAA0-8062
Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00146221
Shop #: WSC 02335
Reset counter: 66
Mileage: 142072 km
Date: 2017.09.22
Time: 19:04:00
Reset counter: 66
Mileage: 142072 km
Date: 2017.09.22
Time: 19:04:00
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4F0 035 110 A HW: 4F0 035 110
Component: CDC-MP3-Alp H44 0140
Revision: AA001001
VCID: 1574C9340580F77F98C-8040
Address 15: Airbags (J234) Labels:| 4F0-910-655-10.clb
Part No SW: 4F0 910 655 R HW: 4F0 959 655 H
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FA0012RDS
Coding: 303142373034303030314A55304C34463053
ROD: EV_Airba10AURB4.rod
VCID: 36362EB878C61C67B16-8062
Subsystem 1 - Part No SW: 4F0 910 339 B HW: 4F0 959 339 B
Component: BF-Gewichtss. H03 0060
Serial number: 5810000R0000003W4J
Serial number: 3574SRB400009FDD0ABV
Serial number: 3584SRB400009F94E27L
Serial number: 3516HRB402VC0AS50SV6
Serial number: 3526HRB402VC0AS4OKNE
Serial number: 3554NRB40000517EBB79
Serial number: 3564NRB4000051197E1Z
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90026092900003
Coding: 0012141
VCID: 2708F3FCA3EC75EF3A0-8072
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels:. 4F0-920-xxx-17.clb
Part No SW: 4F0 920 983 H HW: 4F0 920 983 H
Component: KOMBIINSTR. H08 0144
Revision: 00000000 Serial number: CN450YEA9
Coding: 8BD60A050B00CF05020201
Shop #: WSC 02391 823 56573
VCID: 313C1DA491283B5FE44-8064
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0035
Revision: LB100029 Serial number: 2900L09A1700BA
Coding: 000303
VCID: 392C25844958F31F5C4-806C
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0125
Serial number: 00000000002790718207
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001010017085
Coding: 00581B00004011110000
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000102168472
Coding: 011F57204E40410001
VCID: 46D65E7808A68CE7216-8012
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H29 0250
Revision: 02500029 Serial number: 01229654010000
Coding: 4618269
VCID: 353429B46940177FB8C-8060
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 035 223 P HW: 4F0 035 223 P
Component: BOSE G3 C6 H01 0100
Revision: AG001300 Serial number: 00000000041814
Coding: 05000000
VCID: 290CF5C4B9F8439F2C4-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 A HW: 4F0 907 274
Component: J793 RKA+ H02 0100
Revision: 00000506 Serial number: 00005061074829
Coding: 0623301
VCID: 221EE2E8C8CE90C76DE-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H13 0100
Revision: Serial number: 00000000509539
Coding: 0002014
VCID: 5EE69618BC36F427096-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000102131826
VCID: 45D4597435A087FF28C-8010
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000222
Shop #: WSC 02145 785 00200
VCID: 211CEDE4CDC88BDF744-8074
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0060
Coding: 0000026
VCID: 698CB5C47578839FEC4-803C
Subsystem 1 - Part No: -----------
Component: AFS-Modul links
Subsystem 2 - Part No: -----------
Component: AFS-Modul rechts
02071 - Local Databus
Fault Status: 11100100
Reset counter: 66
Mileage: 142073 km
Date: 2017.09.22
Time: 19:04:11
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335J-097535137
Coding: 020000010000000000
VCID: 1D64D114FDB0AF3F50C-8048
Part No SW: 4E0 035 664 A HW: 4E0 035 664 A
Component: H-BN-NA H45 0042
Revision: -------- Serial number: 488J/097520192
Coding: 010200000002E1EE41000304EF6300030000
VCID: 221EE2E8C4CE90C76DE-8076
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356JX091091752
Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F1 919 611 T
Component: Bedienteil MM H01 0060
Serial number: 00000001422512
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000009496373
Coding: 010E57204040220001
VCID: 43D0476C3B94B9CF068-8016
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 D HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H03--- Serial number: 525PA8-J9925BW
Coding: 1000304
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000009496374
End----------(Elapsed Time: 01:48, VBatt start/end: 13.6V/13.6V)-----------
