Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
Thread: MK6 Golf Edition 35 Lost ABS Coding - Race Car
    Sep 2016
    Riga, Latvia
    If I take the coding of the working car
    143B800D492500FC281201E492200061700000
    VIN WVWZZZ1KZCW3 32707
    and substitute the VIN bytes, I end up with:
    WVWZZZ1KZCW3 33492
    143B800D492500FD280F01ED921B0061700000
    Just like Jetta, 97
    I tried the same and result is identical.
  2. #12
    Sep 2016
    Riga, Latvia
    I could be useful to see and compare both engine codings. Why HEX-NET isn't communicating with ECU on both cars?
  3. #13
    Aug 2016
    Switzerland
    Maybe the engines are running modified software?
  4. #14
    Dallas (McKinney) ,TX ,USA
    Quote Originally Posted by MNZ View Post
    I tried both of the lower coding you have posted there and both not working, rejected.
    This coding is accepted yes, but the issue is that the ESP is not showing as de-activated as the other good car is. We can't run with ESP as it is a race car.
    After coding most of the sensors will be out of the line, and you have to adopt all sensors.
    Did you do that?
    Immobilizer/ECU
    Mk6 cluster in Mk5 -CLIK
    email : marinmm2001@yahoo.com
  5. #15
    Sep 2017
    New Zealand
    All basic settings are done, only fault code left is due to airbag module being removed from vehicle. So ABS is now ok, I just have to be sure ESP is not going to intervene on track.
    VIN: WVWZZZ1KZCW333492 License Plate: CUP79
    Address 03: ABS Brakes Labels: None
    Control Module Part Number: 5C0 907 379 CL HW: 1K0 907 379 BL
    Component and/or Version: ESP MK60EC1 H31 XA04
    Software Coding: 143B800D492580FD280F01ED921B0161700000
    Work Shop Code: WSC 75000 666 121355
    VCID: 7AB83A57F5BAFB96C4-802E
    Reset counter: 87
    Mileage: 9819 km
    Date: 2005.14.23
    Time: 00:07:47
    Count: 1
    Count: 25088
    Count: 8226
    Count: 48384
    The reason Address 01 is not shown is due to Syvecs ECU being fitted to vehicles, these replace stock ECU. Everything else remains stock including DSG transmission and Syvecs sends same data to all units as stock ECU.
  6. Likes Jetta ,97 liked this post
  7. #16
    Sep 2017
    New Zealand
    Ok I have decoded the steering angle sensor from Address 44 - Steering Assist. So now the ESP has no reference and can't activate.
    I will try on track this weekend.
  8. Likes Jetta ,97 liked this post
  9. #17
    Does this part # go to this car?
    VIN: WVWZZZ1KZ9P009260
    Part No SW: 03G 906 018 FB HW: 03G 906 018 FB
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Coding: 11 4B 00 0C 09 22 00 03 88 0D 00 EA 90 19 00 00 00 00 Stripped LHD
    European Parts Emporium/Performance / Immobilizer Solutions LLC
  10. #18
    Romania
    A friend of mine has experienced an ABS problem and has changed the ABS unit. Unfortunately he didn''t save the previous ABS codding. So, the new module mounted on the car is not codded. Please find attach the scan. If you be so kind to give me the correct codding in order to codding the ABS properly.
     Monday,25,September,2017,20:26:06:56830
    VCDS Version: 17.8.0.1 (x64)
    VIN: WVWZZZ1KZ9P009260   License Plate:
    Mileage: 184620km-114717mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
    VIN: WVWZZZ1KZ9P009260   Mileage: 184620km-114717miles
    Address 01: Engine        Labels: 03G-906-018-BMN.clb
       Component: R4 2.0l PPD1.2 G    2527
       Revision: --H52---    Serial number: VWX7Z0H53N57WQ
       Coding: 0000072
       Shop #: WSC 10101 599 07319
       VCID: 6AD0378145A2171634-803E
    Readiness: N/A
       Revision: 00H35001
       VCID: 74EC29F9D766D1E69E-8020
                        Reset counter: 134
                        Count: 4608
                        Count: 195
                        Count: 43776
                        Count: 65024
       Part No SW: 1K0 907 044 DD    HW: 1K0 907 044 DD
       Component: ClimatronicPQ35 130 1213
       Revision: 00130023    Serial number: 00000000000000
       VCID: 6CDC31994F56092646-8038
       Revision: 00H54000    Serial number: 00000008483095
       Coding: 038B0F2700041500471400001400000000097F075C000100000000000000
       Shop #: WSC 00028 028 00001
       VCID: 336EEAE552E896DE47-8066
       Component: Wischer 210508 021  0501
       Coding: 00038805
       Shop #: WSC 00028
                        Reset counter: 134
                        Mileage: 184627 km
                        Voltage: 12.25 V
    00154 - Windshield Wiper Motor;  Passenger Side (V217)
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 134
                        Mileage: 184627 km
                        Voltage: 12.20 V
    02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                        Reset counter: 134
                        Mileage: 184627 km
                        Voltage: 12.20 V
       Component: 37 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD220JF1
       Coding: 0013111
       VCID: 3D7ACCDD64AC50AEA1-8068
       Subsystem 1 - Serial number: 6332MSME2D216E65K
       Subsystem 2 - Serial number: 6342MSME3A74185CM
       Subsystem 3 - Serial number: 6352QSME6A6121159
       Subsystem 4 - Serial number: 6362QSME6A612373G
       Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
       Component: J0527           752 0101
       Coding: 0002022
       VCID: 0102702D58D4F44E85-8054
       Part No SW: 1K0 920 874 B    HW: 1K0 920 874 B
       Component: KOMBIINSTRUMENT VDD 2416
       Revision: V0002000    Serial number: VWX7Z0H53N57WQ
       Coding: 0007103
       Shop #: WSC 65536 645 577705
       VCID: 2C5CF1998FD6C92606-8078
       Component: J533  Gateway   H07 0062
       Revision:   H07 01    Serial number: 010608F1000893
       Coding: E9817F060002020002
       VCID: 356AD4FD5C9C88EE69-8060
       Component: IMMO            VDD 2416
       Component: Tuer-SG         006 1219
       Coding: 0000180
       VCID: 3874DDC94B8E758672-806C
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.070 H08 1901
       Coding: 809002005103087F2D04840560084F03E0FC00
       VCID: 030E7A2542C8E65E97-8056
       Coding: 0000180
       VCID: 3972D8CD70846C8E8D-806C
    00110 - Right Mirror Turn Signal Lamp (L132)
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74EC29F91766D1E69E-8020
    00496 - Sensor for Vehicle Leveling; Front
                010 - Open or Short to Plus
       Part No: 1K0 035 186 AF
       Component: Radio GR0       035 0034
       Revision: 0003505S    Serial number: VWZ2Z2H1131535
       Coding: 0040400
       Component: Tuer-SG         006 1302
       Coding: 0000144
       Shop #: WSC 00028 028 1012545
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:47)--------------------------
  11. #19
    Aug 2016
    Switzerland
    WVWZZZ1KZ9P009260
    LHD
    FWD
    Manual gearbox
    2.0 TDI
    312/253mm brakes?
    TPMS guess yes
    normal ESP deactivation
    114B600C09220003880D06EA90190042040C00
  12. Likes Uwe liked this post
  13. #20
    Romania
    without TPMS.
