So i'm trying to fit esp mk60ec1 replacing mk60 on my jetta 2006 tdi to make in near futur park steering working.
So my trouble is when i put ignition key on bit is heard and k47 k155 and k118 are flashing all the time.
And also no long coding (00000000000) and no data to make long coding
All basic setting and bleeding procedure have been done
Important for coding i have 312mm front brake and 288mm at rear and tpms button for indirect tpms, mk6 steering rack and in futur acc
Yes i know a lot of trouble code in many system = reaserch and developpment
Can someone help me for coding
Fred
Friday,15,September,2017,16:15:00:13360
VCDS Version: 17.8.0.1 (x64)
Dealer/Shop Name: Atelier Mécanique auto Roch Sylvain
VIN: 3VWNT31K36M704386 License Plate:
Mileage: 411200km-255507mi Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 0F 10 13 14 15 16 17 18 19 25 2E 36 37 3C 42
44 46 47 52 55 56 5C 62 69 6C 72 77 7D A5
VIN: 3VWNT31K36M704386 Mileage: 411200km-255507miles
18-Aux. Heat -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Cannot be reached 1100
47-Sound System -- Status: Not registered 0001
5C-Lane Maintain. -- Status: Cannot be reached 1100
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0E2716299
Coding: 0050078
VCID: 64CC37C0A76F8F660E-8030
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000604061166
Shop #: WSC 44551 111 44551
VCID: 51A2EE14C8DD0ACE55-8004
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
Shop #: WSC 00066 790 07030
VCID: 7EF865A8E9C345B6F8-802A
6 Faults Found:
03306 - Coding Not Valid
Reset counter: 110
Mileage: 411204 km
Count: 3
Count: 8192
Count: 4161
Count: 39680
Count: 65280
Reset counter: 110
Count: 3
Count: 20992
Count: 195
Count: 40704
Fault Status: 01100101
Reset counter: 110
Mileage: 411204 km
Count: 3
Count: 12288
Count: 212
Count: 40704
Count: 65280
Reset counter: 110
Mileage: 411204 km
Count: 3
Count: 12288
Count: 279
Count: 40704
Count: 65280
Reset counter: 110
Mileage: 411204 km
Count: 3
Count: 12288
Count: 295
Count: 40704
Count: 65280
Reset counter: 110
Mileage: 411204 km
Count: 3
Count: 12288
Count: 270
Count: 40704
Count: 65280
Part No: 1K0 907 044 BC
Component: ClimatronicPQ35 066 0606
VCID: 69D226F4404DD20E3D-803C
01207 - Control Module for Auxiliary Heater (J364)
Revision: 00H54000 Serial number: 00000003888040
Coding: 57038A420128140008000A00080000000049D50300400800000000000000
Shop #: WSC 05124 123 12345
VCID: 336E849C520158DE47-8066
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 05124
Component: RLS 110515 054 0403
Coding: 00471117
Shop #: WSC 05124
Reset counter: 110
Mileage: 411204 km
Voltage: 11.45 V
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E2029966
VCID: 2B5E9CFC8A31001E0F-807E
02633 - Antenna for Satellite Tuner
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 110
Mileage: 411204 km
Time: 14:37:10
Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb
Part No SW: 1T0 919 475 H HW: 1T0 919 475
Component: PARKHILFE PLA H07 0110
Revision: -------- Serial number: 88590932103608
Coding: 11010A
Shop #: WSC 01324 020 00200
VCID: 4084DB50D3B7F346CA-8014
01543 - Parking Aid Warning Chime (H15)
Reset counter: 110
Mileage: 411204 km
Time: 14:37:09
Temperature: 21.0°C
01625 - Front Parking Aid Warning Chime (H22)
Reset counter: 110
Mileage: 411204 km
Time: 14:37:09
Temperature: 21.0°C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 110
Mileage: 411204 km
Time: 14:37:09
Temperature: 21.0°C
Address 13: Auto Dist. Reg
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Revision: 00000000 Serial number: 07021201070002
Coding: 020080
Shop #: WSC 00040 040 00001
VCID: 275660CC56D9247EEB-8072
8 Faults Found:
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 110
Mileage: 411204 km
Time: 14:37:08
00149 - End of Line Programming not Completed
000 - - - MIL ON
Reset counter: 110
Mileage: 411204 km
Time: 14:37:08
00139 - Left Front Body Acceleration Sensor (G341)
Reset counter: 110
Mileage: 411204 km
Time: 14:37:08
00140 - Front Right Body Acceleration Sensor (G342)
Reset counter: 110
Mileage: 411204 km
Time: 14:37:08
00141 - Rear Body Acceleration Sensor (G343)
Reset counter: 110
Mileage: 411204 km
Time: 14:37:08
00774 - Level Control System Sensor; Rear Left (G76)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 110
Mileage: 411204 km
Time: 14:37:08
Reset counter: 110
Mileage: 411204 km
Time: 14:37:08
01769 - Sensor for Vehicle Leveling; Front Right (G289)
Reset counter: 110
Mileage: 411204 km
Time: 14:37:08
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1T AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD01GWKQ
Coding: 0012628
VCID: 2E5895E8B923753628-807A
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME090811291
Subsystem 3 - Serial number: 6342MSME076901140
Subsystem 4 - Serial number: 6351HSME054E546DI
Subsystem 5 - Serial number: 6361HSME063E0053%
Subsystem 6 - Serial number: 63727SME06430A13U
Subsystem 7 - Serial number: 63827SME062D0B20
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0013121
VCID: 7AF069B835EB6996C4-802E
Component: E0221 007 0050
Part No: 1K0 920 872 D
Component: KOMBIINSTRUMENT 3HL 1212
Coding: 0023107
VCID: 2C5C9FE08F3F072606-8078
Address 18: Aux. Heat
Part No SW: 7N0 907 530 AP HW: 7N0 907 530 AK
Component: J533 Gateway H57 1653
Revision: H57 Serial number: 270415F1000274
Coding: 351002
Reset counter: 110
Mileage: 411204 km
Time: 14:37:11
Fault Frequency: 11
Mileage: 411204 km
Time: 14:37:10
02797 - Control Module for Directional Stabilization Assistance (J759)
Reset counter: 110
Mileage: 411204 km
Time: 14:37:10
03272 - Control Module for Audio Interface
Reset counter: 110
Mileage: 411204 km
Time: 14:37:14
Component: IMMO 3HL 1212
Address 2E: Media Player 3
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
02328 - Position Sensor for Rear Seat Height Adjustment (G439)
Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl
Part No: 1K0 919 887 G
Component: Navigation 0050
Coding: 0000101
VCID: 3D7AA2A464459EAEA1-8068
Address 3C: Lane Change
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0000383
VCID: 3668BD8841734DF660-8062
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 31628E94A81D6ACE35-8064
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 1A900E880106483F6D02058FF0088FC490A340
Shop #: WSC 00066 123 12345
VCID: 020011585D3B21569C-8056
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 7 - Part No: 1K0 907 719 C
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456
Component: 08K Audioverst. 0003
Revision: 00002000 Serial number: 00000000027425
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001534
VCID: 3776B08C4679B4FE7B-8062
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74EC4780178F1FE69E-8020
00497 - Sensor for Vehicle Leveling; Rear
01310 - Level Control System Control Module (J197)
Address 56: Radio Labels: 1K0-035-095.lbl
Part No: 1K0 035 095 F
Component: Radio 0050
Coding: 0012046
VCID: 285463F09BC72B06E2-807C
00857 - CD Changer Unit (R41)
Address 5C: Lane Maintain.
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0001432
Address 69: Trailer Labels: 8P0-907-383.clb
Part No SW: 8P0 907 383 HW: 8P0 907 383
Component: ANHAENGERELEKTR H01 0010
Shop #: WSC 01269 785 00200
VCID: 76E87D8801F30DF6A0-8022
02564 - Trailer; Left Tail Lamps (M60)
Fault Status: 00101011
Reset counter: 143
Mileage: 262140 km
Date: 2001.09.15
Time: 19:46:00
02563 - Trailer; Right Tail Lamps (M61)
Fault Status: 00100111
Reset counter: 143
Mileage: 262140 km
Date: 2001.09.15
Time: 06:24:00
02566 - Trailer; Left Turn Signals (M62)
Fault Frequency: 7
Reset counter: 143
Mileage: 262140 km
Date: 2001.09.15
Time: 06:24:00
02565 - Trailer; Right Turn Signals (M63)
Reset counter: 143
Mileage: 262140 km
Date: 2001.09.15
Time: 19:46:00
02562 - Trailer; Brake Lamps
Reset counter: 143
Mileage: 262140 km
Date: 2001.09.15
Time: 19:46:00
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 5N0 907 441 A HW: 5N0 907 441 A
Component: J772__Rearview 0030
Revision: 00H13000 Serial number: 525PA8-JA4A050
Coding: 0100010
Shop #: WSC 01324 011 00200
VCID: 2D5A92E4B4250E2E11-8078
01043 - Control Module; Incorrect Software Version
Reset counter: 110
02203 - Audio / Video Input 1
Reset counter: 110
Mileage: 411204 km
Time: 14:37:08
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0001432
VCID: 32608198AD1B51D64C-8066
Address 77: Telephone Labels: 3C0-035-729.lbl
Part No SW: 3C0 035 729 E HW: 3C0 035 729 E
Component: Telefon 7019
Revision: 00009000 Serial number: 0000000799523
Coding: 0016041
Shop #: WSC 49077 136 85092
VCID: 254A6AC4ECD5366ED9-8070
01523 - Microphone for Telephone (R38)
Reset counter: 110
Mileage: 411204 km
Time: 14:37:12
01524 - Antenna for Telephone
Reset counter: 110
Mileage: 411204 km
Time: 14:37:12
00992 - Consumption Cut-Off Active
Reset counter: 110
Mileage: 411204 km
Time: 14:37:08
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
014 - Defective
Address A5: Frt Sens. Drv. Assist
End-------------------------(Elapsed Time: 04:00)--------------------------
Fred
