Lupo 3l - VCDS mobile
Segil
Sweden
C?ID=314476
I'm new to my HEX-NET / VCDS mobile but have done this on older vcds before when i had a laptop.. I bought the HEX-NET to be able to perform this from my android.
I need to do this: http://wiki.ross-tech.com/wiki/index.php/5-Speed_Electronic_Manual_Transmission_(085)
On my lupo 3l -04 But I cant get any data at all from it.
An auto scan works fine but in advanced measure block i get nothing!
If I create an HUD I do get something.. but its mumbo to me. just a string of numbers
I've tried this on an other lupo 3l with the same result, But on a multivan -07ich everything works fine so i guess the HEX-NET / VCDS mobile works but not for a lupo??
HUD:
Auto scan:
VCDS Mobile 0.4401.0.4
Chassis Type:6X
Scan: 01 02 03 08 15 17 19 25 35 37 44 45 55 56
Address 01: Engine       Labels: 04-01.clb
 Part No SW: 045 906 019 BC
     Component: 1,2l R3 EDC0001DS  5208
     Coding: 00102
   Shop #: WSC 00046 000
       VCID: 57F1185FAB8565768E69C1065F-4B5C
     Subsystem 1 -       Part No SW: WVW-ZZZ-6EZ-5B0
  Component: 01240     VWZ1Z0D270941
No fault codes found.
Address 02: Auto Trans Labels: 6N0-927-735.lbl
     Part No SW: 6N0 927 735 H
  Component: DS085 Getriebe      1390D
  Coding: 00000
        Shop #: WSC 00000 000
    VCID: 3D3DAAF729F9AF26B465A3CE2D-0964
Address 03: ABS Brakes  Labels: 6E0-907-379.clb
      Part No SW: 6E0 907 379 A
   Component: ABS     30 IE CAN  V006
 Coding: 05623
   VCID: 2F2180BFF3954DB636D9092657-4B3C
Address 15: Airbags  Labels: 6Q0-909-605-VW5.lbl
  Part No SW: 1C0 909 605 A
       Component: 32 AIRBAG VW51 0C   0008
 Coding: 13106
   VCID: 2207798BB047F0DEA957788A8C-5184
00532 - Supply Voltage B+
Address 17: Instruments  Labels: 6X0-920-xxx-17.lbl
   Part No SW: 6E0 920 800 J
        Component: KOMBIINSTRUMENT RB8 V10
     Coding: 00134
   Shop #: WSC 40206 000
       VCID: 28136BA3D67B1A8EF793BAF23A-5184
Address 19: CAN Gateway    Labels: 6N0-909-901-19.lbl
     Part No SW: 6N0 909 901
  Component: Gateway K<->CAN
      Coding: 00006
        VCID: F0A3C3C3AE2B924EEF63525202-5184
Address 25: Immobilizer   Labels: 6X0-953-257.lbl
       Part No SW: 6X0 953 257
    Component: IMMO                0008
     Coding: 00001
       VCID: FDBDEAF7E979EF2674E5E3CEED-4B1E
  Component: 01240     VWZ1Z0D2709410
I have a fuzzy recollection that the DS085 transmission used in those cars does some rather unusual stuff that gave VCDS fits early on as well, but I don't remember the details.
If you need to get this done right now, I suggest borrowing a PC.
