Dear Ross-Tech community,
I own a 2009 Polo 6R Confortline 1.6TDI DSG7 since new (12/2009).
I ordered it with the automatic wipe (with rain light sensor) and I would like now to retrofit the automatic light.
The car is originally setup with a Body Control Module (BCM) Nr 6R0 937 087 D.
I have bought the stuff and manufactured an additional wiring harness with two relays, a mini plug to fit the new light switch and the connectors to the BCM (pin 1 and pin 37).
I have bought an used BCM Nr 6R0 937 088 F and I intend now to swap it with the original one to be able to set it up with the automatic light.
I have followed the tutorial to swap the BCM but, when plugging the battery again after BCM replacement, there is no CAN link with the VCDS and the Gearbox is the only recognized module.
Finally I tried to train myself to setup the remote controls on the original BCM (as I will have to do it on the new one) but I did not found this option in the Central Electric Module Adaptation list moreover the confort and central locking modules are not readable with the VCDS.
My questions are multiple:
- Can somebody confirm me if the BCM Nr 6R0 937 088 F is able to manage the automatic light? (if not, which BCM numbers can?)
- When swaping the BCM, how shall I do to configurate de CAN Gateway Module installation list, the CAN Gateway Module code and the Central Electric Module code as the CAN does not link with the VCDS?
- What is the easiest way to setup the remote controls on a swaped BCM?
Thank you for your help.
