Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Missing coding information 2017 Tiguan AD1
    Dec 2016
    NL
    Hey guys and girls,
    Just took delivery of my new 2017 Tiguan with almost everything fitted. Original un-modified pre-changing stuff auto-scan log below.
    Unfortunately, i'm missing a lot of coding information. Most control units i don't need to code. The central electronics unit and infotainment unit coding is also missing and those units i do need to change coding on.
    The car is fully loaded option wise (except for aux heating and direct TPMS), unfortunately some simple stuff was left out in the ordering process (which was hard to begin with since i wanted everything on this car and over here in the Netherlands not everything is available to order for reasons unknown.
    I'm trying to enable the following stuff which i have managed to in the respective control units, but not in the infotainment and central electrics:
    - Traffic sign recognition (Works now, but no settings/information about it in the infotainment system because of no coding info).
    - Easy entry/exit (electric seat moves back a little when opening door). Works now but same issue as above; no settings in infotainment.
    - Pedestrian recognition (I have ACC/camera/everything but for some reason pedestrian recognition is not in the settings menu in the infotainment/instruments). See a few options here and there regarding this but some are parts of the experimental coding so i'd rather not touch that until its a definitive version.
    - Looking to add Direct TPMS in the future, but extended CAN and central electrics is currently lacking coding info.
    The first two things i'd like to get working rather sooner than later, is the missing info because the control units are unknown to ross-tech, or is there some other issue? VCDS and HEX interface HN1-003118 (maybe my interface is too old? its about 2 years old now) updated to latest software.
    Thanks in advance!
    Tom
    AUTOSCAN:
    Friday,15,September,2017,23:35:55:41109
    VCDS Version: 17.8.0.1 (x64)  HEX-NET CB: 0.4401.4
    VIN: WVGZZZ5NZJW000000   License Plate: 12-345-6
    Mileage: 298km-185mi   Repair Order: 12345
    Chassis Type: 5N-VW37 (3Q0)
    Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C
              42 44 47 4B 52 5F 69 6C 6D 75 82 A5 BB BC CA CF D6 D7
    VIN: WVGZZZ5NZJW000000   Mileage: 298km-185miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CUAA)       Labels:. 03N-906-026-CUA.clb
       Part No SW: 03N 906 026 D    HW: 03N 907 309
       Component: R4 2.0l BTD   H24 3680
       Revision: A1H24---
       Coding: 01250032047605083000
       ASAM Dataset: EV_ECM20BTD01103N906026D 004005
       ROD: EV_ECM20BTD01103N906026D_004.rod
       VCID: 2C14C9DD47ABA22606-8078
    Readiness: 0100 0010
    Address 02: Auto Trans (J743)       Labels: None
       Part No SW: 0DL 300 011 M    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2001
       Revision: 00H06V07
       VCID: 3228D7A5658FF4D64C-8066
       Revision: 00000000    Serial number: 62057000001070
       Coding: 0AEE6B9A54220B744779070762C66950D62AD0E2E046967DB86250F8C2AA4200002F641A1B13111435351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
       VCID: 77BE26B1CE6DD1FEBB-8022
       Component: VWKESSYMQB    037 0906
       Revision: 00037000    Serial number: 0451329535
       Coding: 132C2C0723
       VCID: 3E30F395A1D720B6B8-806A
       Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
       Component: GEB.F.Heckoef  H17 0903
       Serial number: 98226912
       Component: Sitzmemory    H08 0022
       Serial number: Y0006QGM20164
       Coding: 0010000000000500818281808181000000008181000000F400
       ASAM Dataset: EV_SeatMemorPasseSide 002022
       ROD: EV_SeatMemorPasseSide_VW37.rod
       VCID: 3C34F99DB7CB32A696-8068
       Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
       Component: AC Automat    H35 4301
       Revision: 20K08000    Serial number: 00000B00605887
       Coding: 0002012420241001110510020010112A
       ASAM Dataset: EV_ACClimaPrehVW37X 002023
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: 4AD8AF45ED1F9C1614-801E
       Subsystem 2 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
       Component: E265KlimaHeck  H02 0201
       Serial number:       04031501850571
       Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H36 0253
       Serial number: 01001721700533
       ROD: EV_BCMBOSCH_018.rod
       VCID: 095A5049A899D70EDD-805C
       Subsystem 1 - Part No SW: 5NB 955 119     HW: 5NB 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 170630  033 0372
       Serial number: 00000001706280300593
       Component: RLHS  042 0105
       Serial number: S8Y17M08D14H01M31S46
       Coding: 00A8EE
       Serial number: 000000000ZY1718333XN
       Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
       Serial number: 00002856223971734394
       Part No SW: 3Q0 919 298 B    HW: 3Q0 919 298
       Component: PLA 3.0 12K   H09 0029
       Serial number: 001607177478001
       Coding: 0A31667A51
       ASAM Dataset: EV_EPHBO2CVW3260000 010016
       ROD: EV_EPHBO2CVW3260000_VW37.rod
       Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H02 0233
       Coding: 320067CB5CFF8728749C8145804087
       Serial number: 12071741350391
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 383CE58D83F31E8672-806C
       Part No SW: 5Q0 959 655 BK    HW: 5Q0 959 655 BK
       Serial number: 003VXR33ZYC9
       Coding: 98FCC0C00C8000005C5400CF004800000065
       VCID: 0A586F45AD9FDC16D4-805E
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 5NB857705C0216R00777
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 5NB857706C0217R00515
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 000 808 17
       Serial number: 35700000000B2B19A62O
       Subsystem 4 - Part No SW: -----------    HW: 480 000 808 17
       Serial number: 35800000000156842728
       Subsystem 5 - Part No SW: -----------    HW: 480 400 208 17
       Serial number: 3510001BB260B4F1B4BB
       Subsystem 6 - Part No SW: -----------    HW: 480 402 807 17
       Serial number: 3520001A524CDB11F48B
       Subsystem 7 - Part No SW: -----------    HW: 480 402 907 17
       Serial number: 3550001C322EA2B5730%
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 402 907 17
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001B526D7C0386BB
       Subsystem 9 - Part No SW: -----------    HW: 480 402 907 17
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001B526D7C0475EE
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 402 907 17
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001B526D7C04615Z
       Subsystem 11 - Part No SW: -----------    HW: 480 002 707 17
       Serial number: I0M00000000D91C0252+
       Subsystem 12 - Part No SW: -----------    HW: 480 002 707 17
       Serial number: I0N000000002A1C0252W
       Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
       Revision: FF034034    Serial number: 20170802501343
       Coding: 0C10
       ROD: EV_SMLSVALEOMQB_VW37.rod
       VCID: 73A612A1DA15BDDE87-8026
       Part No SW: 5NA 920 791 B    HW: 5NA 920 791 B
       Component: KOMBI         407 3193
       Coding: 07A400187F88000801886B0B3401000880000000
       VCID: 42C88765D52F4456DC-8016
       Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5304
       Serial number: 23071710800155
       Coding: 0B0500344F017300FB07225E9E0F00010001070000000000000000000000
       ROD: EV_GatewNF_VW37.rod
       VCID: 3326D2A19A95FDDE47-8066
       Serial number: 29170001574160027313
       Coding: 2DFFFF
       Subsystem 3 - Part No SW: 5QA 915 181 E    HW: 5QA 915 181 E
       Serial number: 4480423804
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 F    HW: 5Q0 907 155 F
       Component: U13DCAC  H25 0780
       Serial number: 0024537
       Serial number: HA1-00020.06.17
       Coding: 0101
       ROD: EV_AllWheelContrHA1VW37X_004_VW37.rod
    Address 29: Left Light (J1018)       Labels: None
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH08 0014
       VCID: 45C29C79C401736EF9-8010
       Serial number: 17000199457001
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB_VW37.rod
       VCID: 71AA18A9A0098FCE75-8024
       Serial number: Y0006QGM20144
       Coding: 0010000000000500018281808181000000008181000000F400
       ROD: EV_SeatMemorDriveSide_002_VW48.rod
    Address 39: Right Light (J1023)       Labels: None
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
       Component: MRR1Rear      H20 0510
       Revision: --------
       Coding: 14C002
       VCID: 3A38FF85BDFF0C9684-806E
       Serial number: 080717EG809145
       Coding: 003F1B20D200048000001000
       VCID: 43C68261CA354D5ED7-8016
       Part No SW: 5QF 909 144     HW: 5QF 909 144 _
       Component: EPS_MQB_ZFLS  506 5572
       Coding: 9307
       ROD: EV_SteerAssisMQB_013_VW37.rod
       VCID: 075E5671BE8DA17ECB-8052
       Part No SW: 3Q0 035 465     HW: 3Q0 035 465
       Component: MIB2_amp_P_VW H60 0440
       Revision: 00000001    Serial number: VWZ8Z1HJD00TYB7
       Coding: 1223060001A00A2AAA0000000000
       ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
       ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
       VCID: 6B960AC18225651E4F-803E
       Serial number: 21071710803739
       Coding: 000000050100085207104F010A0000000000000000000000000000000000
       ROD: EV_MultiModulContiVW48X_VW37.rod
       VCID: 72A817A5A50FB4D68C-8026
       Serial number: 070717EG609369
       Coding: 003F1120DE00048000001000
       Part No SW: 5NA 035 022 A    HW: 5NA 035 022
       Component: MU-H-LND-EU   H54 1121
       Serial number: A846G0HS006021
       Coding: 02730601000000005111010200880A101F0106E401200400DE
       VCID: 312AD8A96089CFCE35-8064
       Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
       Component: ABT_High-2  H50 9130
       Serial number: VWZ6ZJT2116065
       Subsystem 2 - Part No SW: V03 959 800 QQ    HW: -----------
       Component: ECE 2017  --- 0157
       Component: Gracenote2  --- 1016
       Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
       Component: Anhaenger     H27 0264
       Revision: 8A001003    Serial number: 0449274529
       Coding: 0100000202000000
       Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
       Component: Areaview 2    H13 0608
       Serial number: C854707JG016316
       Coding: 01230600A30F200000204814
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
       VCID: 393AE089B8F9078E8D-806C
       Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0261
       Revision: --------    Serial number: 31450492700000
       Coding: 0AA8
       Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
       Component: OCULowMQBLGE  H17 0717
       Revision: --------
       Coding: 02230601EA42380D3F1CBE020045400382E608
       ASAM Dataset: EV_OCULowMQBLGE 004044
       ROD: EV_OCULowMQBLGE_004_VW27.rod
       Part No SW: 5NA 919 608 B    HW: 5NA 919 608 B
       Component: HeadupDisplay 023 0302
       Coding: 564060
       ASAM Dataset: EV_HeadUpDisplContiVW481 001015
       ROD: EV_HeadUpDisplContiVW481.rod
       VCID: 47DE9671FE0D617E0B-8012
       Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H08 0272
       Serial number: 29071712K20584
       Coding: 000307060000040100262347C150A90088000E200040
       ROD: EV_MFKBoschMQBB_VW36.rod
       Serial number: 120717EG908013
       Coding: 002A11200101048000001000
       ROD: EV_DCURearDriveMAXCONT_VW37.rod
       Serial number: 190617EFJ09168
       ROD: EV_DCURearPasseMAXCONT_VW37.rod
    Address CA: Sunroof (J245)       Labels:* None
       Coding: 208040732602
       ROD: EV_SunRoofCONTIAU736.rod
       VCID: 3D32F499ACD13BAEA1-8068
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
       Revision: --------
       Coding: 14C002
       VCID: 373EE6B18EED11FE7B-8062
       VCID: 16600B35E92708F640-8042
    End----------(Elapsed Time: 02:34, VBatt start/end: 12.5V/12.5V)-----------
    HEX-NET is fine, but data for some of the modules in this vehicle is still sparse.
    Dec 2016
    NL
    Thats unfortunate. Anything I can do to help apart from the autoscan?
    Dec 2016
    NL
    Regarding the missing central electronics coding info:
    This thread highlights the same issue I encounter; regarding the coding showing all zero's. Unfortunately I didn't see it until now. I'll have a look through the adaptation channels as per your suggestion in that thread.
    Tommy: Yes, all the old code Bits/Bytes are there in the BCM- it's just a question of finding them. Best way that I've found with these newer BCMs from MQB platform vehicles is to make your self an admap of the module, then grab yourself a large glass and pour-in a dram or two,or..... of single malt scotch. Then open the .CSV from the admap with something like MS Excel. You will find that the channel count is about 1,800-ish, so use the "find" function to locate the correct channel. The other handy thing (besides the scotch) is to have a copy of Google translate open.
    PS: I have a couple of admaps of BCMs from 2017 Tiggy (Australia) in my database - if you can't find what you are looking for, then I might be able to help (at least i'll try)
    VW Golf MkVII (103TSI) my13
  6. Likes Uwe liked this post
    Dec 2016
    NL
    Good tip. Already found a similar function in the adaptation menu itself, but not sure if it really displays all coding related to my search so i'll sure give that a try.
    Got the traffic sign recognition working now including the menu about it in the discover pro. Did the same with the Pedestrian recognition but that kept giving a 'function not available' message so i figured i'm missing some coding somewhere. The drivers assistance module (front camera) doesnt accept me coding said option so i think thats the issue.
    Also found some references to TPMS so that should be doable later on too.
    Easy access is the only thing i cant find in the infotainment module adaptations. Using expiremental coding on the respective seat controllers i've managed to turn that on, but the 'display easy acces settings menu' adaptation in the discover pro unit is not there, or its using a different name or abbreviation. According to the cars manual, the should be a menu about it in the unit.
    Dec 2016
    NL
    So, tweaked a little more.
    Pedestrian assist is on my car, ejections system underneath the hood and the sensors in the bumper are all there, factory document with option codes shows it too, menu item is just not there in the discover pro. If I change the adaptation channels to show said menu, its there, but trying to change any settings results in a 'function not available at this moment' prompt. Maybe they changed something in the control unit that controls the hood system, which no longer allows you to change anything regarding the settings?
    TSR is working now as i said earlier.
    I have trailer assist but that also doesn't show in the menu and cant get that to show either. I can find the adaptations regarding that setting but activating them do not result in any menu changes.
    Easy entry same thing (seats reclining a few centimeters when getting out), but I cant even find the right adaptation for that in the infotainment module. Its either there under a different name, or i'm missing something.
    Cheers!
  9. #8
    Dec 2016
    NL
    Update #3:
    Pedestrian assist is probably an entry for a different model, maybe something with active pedestrian warning or something. I misread the manual, there is no menu option stated in there so i'm probably looking for something that isn't supposed to be there.
    Trailer assist is something that only activates when actually connecting a trailer to the car, and there are no settings for it.
    Still on the easy access mod though. I've found some 'menuesteuerung' adaptations in the central electronics module that trigger menu options on the infotainment unit. A logical assumption would be that there are other control modules that have similar adaptation channels (the seat controllers for example).
  10. #9
    Dec 2016
    NL
    Back again,
    Got the easy entry working including the menu options on the infotainment.
    VCDS 17.10Beta added the necessary coding options.
    To enable, go into long coding in unit 36 'seat memory driver' and click yes when asked if you want to use experimental coding.
    Enable the following bits:
    - Byte 3 bit 1 (easy_entry_front)
    - Byte 9 bit 6 (easy_entry_front_over_MMI)
    If you have both an electrically adjustable driver and passenger seat, additionally enable the following bits:
    In control unit 36 'seat memory driver':
    - Byte 6 bit 4 (easyentry_enable_passenger_over_driverMMI) If you enable this bit if you don't have an electrically adjustable passenger seat, easy entry will not work.
    In control unit 06 'seat memory passenger':
    Check 'soft reset' when applying the coding, and also reboot the infotainment unit. You can also turn of the ignition and lock the car for a minute.
    Cheers!
  11. Likes Uwe, Eric, PetrolDave liked this post
  12. #10
    Dec 2016
    DE
    Didn‘t work on my 2017 Skoda Octavia RS. Maybe something is missing there. Could you post an Auto-Scan for comparison?
