Monday,11,September,2017,17:51:57:49447
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WAUZZZ8VXHA111806 License Plate:
Mileage: 443km-275mi Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
55 5F 6C A5 A9 BB BC CF
VIN: WAUZZZ8VXHA111806 Mileage: 443km-275miles
Address 01: Engine (J623-DJHB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 J HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0003
Revision: --H13---
Coding: 0A2500322466010B3004
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TFS0208V0906259J 001005
ROD: EV_ECM20TFS0208V0906259J_AU37.rod
VCID: 47C853A87F21E64FDA0-8012
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0GC 300 011 M HW: 0GC 927 711 G
Component: GSG DQ381 H06 0706
Revision: 00H06V07
ASAM Dataset: EV_TCMDQ381061 001
ROD: EV_TCMDQ381061_AU37.rod
VCID: 2C020C04C6872517D72-8078
Part No SW: 8V0 614 517 C HW: 8V0 614 517 C
Component: ESC H25 0621
Revision: 00000000 Serial number: 60397000000649
Coding: 329C938D549A1BAA8B990B644197694CC92AD8D1D0829677184150B482A812
ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
ROD: EV_Brake1UDSContiMK100IPB_035_AU37.rod
VCID: 392C255039D580BF5C4-806C
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0431255185
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3B203F5833E9B2AF4E8-806E
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0130
Revision: 20002000 Serial number: 00000001160033
Coding: 03100014110000011000000000001500
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
VCID: 40DA48B45A0FD1771BA-8014
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: F3C8019800PAG0MUFU03
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001704100986
ROD: EV_BCMBOSCH_017_VW27.rod
VCID: 7EA6F64C607B6787296-802A
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 161213 043 0580
Serial number: 170105221848
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 62622536
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 02 12 2016 00000537
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY170042MK1
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000068428422
Sun Roof:
Subsystem 6 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST001GBFZ600000
Coding: 901E00
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 B HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0038
Serial number: 000308417617030
Coding: 0370167051
ASAM Dataset: EV_EPHVA2CAU3700000 009032
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: 4FF87B8897513E0F920-801A
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: 3500E7C319FFC42474988055000026
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: EV_ACCBOSCHVW416_001_VW37.rod
1166 - Databus
Reset counter: 58
Mileage: 133 km
Date: 2017.08.28
Time: 17:40:45
Dynamic environmental data: 02 8D
Control Module temperature: 34 °C
Voltage terminal 15: 14.1 V
Velocity_vehicle_reference: -0.31 m/s
Longitudinal_acceleration_vehicle_reference: -0.57 m/s²
1167 - Databus
Reset counter: 58
Mileage: 133 km
Date: 2017.08.28
Time: 17:40:45
0110 - Transport Mode Active
U1105 00 [008] - -
Reset counter: 48
Mileage: 16 km
Date: 2017.08.19
Time: 12:07:04
Control Module temperature: 32 °C
Voltage terminal 15: 12.3 V
Longitudinal_acceleration_vehicle_reference: -0.00 m/s²
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 G HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0082
Serial number: 291216033
ASAM Dataset: EV_AudiMagneRide 002008
ROD: EV_AudiMagneRide_002_AU37.rod
VCID: 45D459A0452DF45F28C-8010
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2MDLHI
Coding: 98CCC000000000005C54000000C800000065
VCID: 107AB8F44AEF61F7CBA-8044
Subsystem 1 - Part No SW: ----------- HW: 480 001 302 17
Serial number: 35700000000A055C0228
Subsystem 2 - Part No SW: ----------- HW: 480 001 302 17
Serial number: 358000000000BCDC512T
Subsystem 3 - Part No SW: ----------- HW: 480 401 302 17
Serial number: 3510001C1247FF9374DG
Subsystem 4 - Part No SW: ----------- HW: 480 401 302 17
Serial number: 3520001BF247FF95E26U
Subsystem 5 - Part No SW: ----------- HW: 480 400 901 17
Serial number: 3550002BF23C4E34F0EQ
Part No SW: 8V0 953 521 KF HW: 5Q0 953 549 E
Revision: -------- Serial number: 11021704220661
Coding: EC18
VCID: 084A909432BF293713A-805C
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 8V0 920 790 HW: 8V0 920 790
Component: FBenRDW H14 0046
Coding: 248D08527F9800080181E8001000000000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001023
ROD: EV_DashBoardFPKAU37X.rod
VCID: 79ACE550795540BF1C4-802C
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005929571
Coding: 030100043F085A005B008278BC0B00000001010000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 2F381B08F7915E0FF20-807A
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170124143057 21454
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75410803001701215371
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
Component: Haldex4Motion H52 7755
Serial number: HA1-00020.01.17
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000019143010
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 343214641EB77DD78F2-8060
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 3Q0 907 566 D HW: 3Q0 907 566
Component: MRR1Rear H16 0410
Revision: --------
Coding: 44C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
Component: TSG FS 020 0041
Serial number: 160117EAE21921
Coding: 005D1A205C01040000001003
VCID: 43D047B84B19CA6F068-8016
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9307
ROD: EV_SteerAssisMQB_013_VW37.rod
VCID: 3A2E3A5C3CD38BA755E-806E
Address 47: Sound System (J525) Labels:* None
Part No SW: 81A 035 466 A HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0420
Revision: 00000001 Serial number: AUZ8ZAG5F005HLZ
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 2310E738AB59EA6F668-8076
Component: TSG BFS 020 0041
Serial number: 210117EAJ13697
Coding: 005D12205E01040000001003
VCID: 42DE42BC5403C3670DE-8016
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 8V0 907 357 A HW: 7P6 907 357 B
Component: MxB-ECU 001 0230
Coding: 0EE602102B200200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
VCID: 3E26364C20FBA787696-806A
13705498 - Databus
Reset counter: 67
Mileage: 228 km
Date: 2017.09.01
Time: 13:47:43
Part No SW: 8V1 035 041 A HW: 8V1 035 041
Component: MU-P-LND-RW 053 0875
Serial number: A838A0HB004342
Coding: 017353080000000011511102000A00102F0027E6017001045E
VCID: 2D040100FD9D2C1FC0C-8078
Subsystem 1 - Part No SW: V03 959 801 FQ HW: -----------
Component: ROW 2017 --- 0062
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9G1Y00TSK
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0855
Serial number: ALJAL105121600010063
Component: Gracenote2 --- 4011
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0273100102002001400040
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 13021711K10669
Coding: 040307030000010101022346C048A90080000E200020
ROD: EV_MFKBoschMQBB_VW36.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 170118200853
ROD: EV_SoundActuaGen2AU64X_VW26.rod
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 100117EAA09413
Coding: 000C12204001040000001002
ROD: EV_DCURearDriveMAXCONT_VW37.rod
Component: TSG HBFS 020 0041
Serial number: 100117EAA09416
ROD: EV_DCURearPasseMAXCONT_VW37.rod
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 3Q0 907 590 D HW: 3Q0 907 590
Revision: --------
Coding: 44C002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
VCID: 36362E6C08CB6FC7B16-8062
End----------(Elapsed Time: 01:53, VBatt start/end: 12.2V/12.1V)-----------
