Results 1 to 8 of 8
Thread: Seat Altea 1.9 TDI BXE can gateway security access code
    Sep 2017
    Hi does the can gateway need to be coded to the vehicle? The old gate way has no comms, new one fitted and now have comms with gateway and coding done ok but still can not get the vehicle to start, no engine codes the only comms code i have is for the drivers wiper motor which i suspect is for a faulty motor. I have asked our local Seat for the security access code but they dont want to help. Thanks in advance for any help.
    VCDS Version: 17.8.0.1 (x64)
    Dealer/Shop Name: central autopoint ltd
    VIN: VSSZZZ5PZ8R070749   License Plate: KJ08
    Mileage: 121250km-75341mi   Repair Order:
    Chassis Type: 5P (1K0)
    VIN: VSSZZZ5PZ8R070749   Mileage: 121250km-75341miles
    Address 01: Engine        Labels: 03G-906-016-BKC.clb
       Part No SW: 03G 906 021 SK    HW: 03G 906 021 AN
       Component: R4 1,9L EDC G000SG  1444
       Revision: --H08---    Serial number: SEX7Z0H331H00A
       Coding: 0050071
       Shop #: WSC 06402 785 00200
       VCID: 7AFC7E703555D196C4-802E
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
       Part No: 1K0 907 379 P
       Component: ASR FRONT MK70      0105
       Coding: 0017025
       VCID: 3F8ACF646EF734BEB3-806A
       Part No: 5P0 907 044 K
       Component: ClimatronicPQ35 011 0702
       VCID: 3878A4784BD9038672-806C
       Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
       Revision: 00H54000    Serial number: 00000005550841
       Coding: E1880F2F00041000431800000000000000007F075C400000000000000000
       Shop #: WSC 18434 020 328969
       VCID: 71EE595C682392CE75-8024
       Subsystem 2 - Part No: 1P0 955 559   Labels: 1P0-955-559.CLB
       Component: REGENLICHTSENSORH04 0090
       Coding: 00152622
       Shop #: WSC 18434
       Subsystem 3 - Component: Fehler Lin-Slave 01
    02071 - Local Databus
                        Reset counter: 220
                        Mileage: 121257 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 11.65 V
    00153 - Windshield Wiper Motor;  Driver Side (V216)
                        Reset counter: 220
                        Mileage: 121257 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 11.65 V
       Component: S9 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD1XNKNK
       Coding: 0021305
       VCID: 3D76B56C64FB26AEA1-8068
       Subsystem 1 - Serial number: 6332MSME3234193A6
       Subsystem 2 - Serial number: 6342MSME3235670DB
       Subsystem 3 - Serial number: 6351HSME14792D3BH
       Subsystem 4 - Serial number: 6361HSME154961486
       Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
       Component: J0527           752 0101
       Coding: 0002042
       VCID: 78F864780B59C386B2-802C
       Component: E0221           001 0010
       Part No: 5P0 920 927 B
       Component: KOMBIINSTRUMENT VO3 0450
       Coding: 0002401
       Shop #: WSC 80093 222 69422
       VCID: 3460904857B1E7E65E-8060
       Revision:   H10       Serial number: 28001055300136
       Coding: 3D3F0340070203
       Shop #: WSC 01324 785 00200
       VCID: 2A5C8E308575A116F4-807E
       Component: IMMO            VO3 0450
       Part No SW: 1T0 959 701 G    HW: 1K0 959 793 M
       Component: J386  TUER-SG FT    1132
       Revision: 31008001    Serial number: 00000080888201
       Coding: 0000688
       VCID: 3B72BB747AEF289E9F-806E
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.077 H08 1901
       VCID: 3664AA4041CDF5F660-8062
                000 -  -
       Coding: 998000005183CC7F0006850560085F86107C80
       VCID: 03020394429F905E97-8056
       Subsystem 5 - Part No: 5P0 951 171 C
       Component: Innenraumueberw.009 4865
       Coding: 00000000
       Shop #: WSC 06402
       Subsystem 7 - Component:       NGS n.mounted
       Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
       Component: J387  TUER-SG BT    1132
       Revision: 31008001    Serial number: 00000071788119
       Coding: 0000688
       VCID: 3C70B8687FE12FA696-8068
       Part No: 5P2 035 186 A
       Component: Radio BVX           0006
       Coding: 0040464
       VCID: 2F6A9F24BE97C43E23-807A
       Part No SW: 1K0 959 703 M    HW: 1K0 959 795 G
       Component: J388   TUER-SG HL   1114
       Revision: 11006001    Serial number: 00000002925434
       Coding: 0000144
       VCID: 3A7CBE7075D5119684-806E
       Part No SW: 1K0 959 704 M    HW: 1K0 959 794 G
       Component: J389   TUER-SG HR   1114
       Revision: 11006001    Serial number: 00000002978395
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:50)--------------------------
    Please post an Auto-Scan so people can the state of the car.
    Ceterum censeo, delenda est Daesh.
    Sep 2017
    sorry first time poster auto scan done thanks
  4. Likes Uwe liked this post
    The gateway coding looks OK to me. There's no VIN or Immo specific matching that needs to do be done, nor is there a security access code that's relevant.
    I don't see any obvious reason why the vehicle doesn't start. Please describe its exact behavior when you try to start it. No crank? Crank but won't fire? Cranks, fires, and dies?
    You can also have a look at [25-Immobilizer] MVBs 001 and 002, and tell us what you see there, but I'm skeptical that's the source of the problem.
    Sep 2017
    Hi short story vehicle broke down recovered to a local garage with can gateway comms fault they fitted a second hand gateway but still not starting will spin over fine but not firing
    We have picked the job up now when i got the vehicle they hadn't programmed the part correctly which i sorted but i wasn't sure if the part needed to be coded to vehicle
    I would go through it and clear all fault codes, then see if any come back after a start attempt.
    Not firing at all is not indicative of an immobilizer problem, but the fault in the ABS bothers me a bit.
    Sep 2017
    Hi cleared codes only 2 stay on and are there after attempted start
    thursday,14,September,2017,09:02:53:35464
    VIN: VSSZZZ5PZ8R070749   License Plate: KJ08 3
       Coding: 0050071
       Coding: 0017025
       Coding: 00152622
       Shop #: WSC 18434
                        Reset counter: 220
                        Mileage: 121257 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.80 V
                        Reset counter: 220
                        Mileage: 121257 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.80 V
       Coding: 0021305
       Coding: 0002042
       Coding: 0002401
       Coding: 0000688
                000 -  -
       Coding: 00000000
       Shop #: WSC 06402
       Coding: 0000688
       Coding: 0040464
       Coding: 0000144
       Coding: 0000144
  9. Likes Uwe liked this post
  10. #8
    Sep 2017
    Sorted took a step back and started again i checked fuses with tester and then checked with the book and it turns out the previous garage were a lot worse than i thought i replaced the fuses they left out and it starts. Thanks for your help
  11. Likes Dana, Uwe liked this post
