Seat Altea 1.9 TDI BXE can gateway security access code
cally76
C?ID=233770
Hi does the can gateway need to be coded to the vehicle? The old gate way has no comms, new one fitted and now have comms with gateway and coding done ok but still can not get the vehicle to start, no engine codes the only comms code i have is for the drivers wiper motor which i suspect is for a faulty motor. I have asked our local Seat for the security access code but they dont want to help. Thanks in advance for any help.
VCDS Version: 17.8.0.1 (x64)
Dealer/Shop Name: central autopoint ltd
VIN: VSSZZZ5PZ8R070749   License Plate: KJ08
Mileage: 121250km-75341mi   Repair Order:
Chassis Type: 5P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ5PZ8R070749   Mileage: 121250km-75341miles
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 SK    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  1444
   Revision: --H08---    Serial number: SEX7Z0H331H00A
   Coding: 0050071
   Shop #: WSC 06402 785 00200
   VCID: 7AFC7E703555D196C4-802E
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8ACF646EF734BEB3-806A
   Part No: 5P0 907 044 K
   Component: ClimatronicPQ35 011 0702
   VCID: 3878A4784BD9038672-806C
   Revision: 00H54000    Serial number: 00000005550841
   Coding: E1880F2F00041000431800000000000000007F075C400000000000000000
   Shop #: WSC 18434 020 328969
   VCID: 71EE595C682392CE75-8024
   Subsystem 2 - Part No: 1P0 955 559   Labels: 1P0-955-559.CLB
   Component: REGENLICHTSENSORH04 0090
   Coding: 00152622
   Shop #: WSC 18434
   Subsystem 3 - Component: Fehler Lin-Slave 01
02071 - Local Databus
                    Reset counter: 220
                    Mileage: 121257 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.65 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 220
                    Mileage: 121257 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.65 V
   Component: S9 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1XNKNK
   Coding: 0021305
   VCID: 3D76B56C64FB26AEA1-8068
   Subsystem 1 - Serial number: 6332MSME3234193A6
   Subsystem 2 - Serial number: 6342MSME3235670DB
   Subsystem 3 - Serial number: 6351HSME14792D3BH
   Subsystem 4 - Serial number: 6361HSME154961486
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           752 0101
   Coding: 0002042
   VCID: 78F864780B59C386B2-802C
   Component: E0221           001 0010
   Part No: 5P0 920 927 B
   Component: KOMBIINSTRUMENT VO3 0450
   Coding: 0002401
   Shop #: WSC 80093 222 69422
   VCID: 3460904857B1E7E65E-8060
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001055300136
   Coding: 3D3F0340070203
   Shop #: WSC 01324 785 00200
   VCID: 2A5C8E308575A116F4-807E
   Component: IMMO            VO3 0450
   Part No SW: 1T0 959 701 G    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1132
   Revision: 31008001    Serial number: 00000080888201
   Coding: 0000688
   VCID: 3B72BB747AEF289E9F-806E
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.077 H08 1901
   VCID: 3664AA4041CDF5F660-8062
   Coding: 998000005183CC7F0006850560085F86107C80
   VCID: 03020394429F905E97-8056
   Subsystem 5 - Part No: 5P0 951 171 C
   Component: Innenraumueberw.009 4865
   Coding: 00000000
   Shop #: WSC 06402
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Component:       NGS n.mounted
   Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1132
   Revision: 31008001    Serial number: 00000071788119
   Coding: 0000688
   VCID: 3C70B8687FE12FA696-8068
   Part No: 5P2 035 186 A
   Component: Radio BVX           0006
   Coding: 0040464
   VCID: 2F6A9F24BE97C43E23-807A
   Part No SW: 1K0 959 703 M    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1114
   Revision: 11006001    Serial number: 00000002925434
   Coding: 0000144
   VCID: 3A7CBE7075D5119684-806E
   Part No SW: 1K0 959 704 M    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1114
   Revision: 11006001    Serial number: 00000002978395
   Coding: 0000144
End-------------------------(Elapsed Time: 01:50)--------------------------
cally76
C?ID=233770
sorry first time poster auto scan done thanks
The gateway coding looks OK to me. There's no VIN or Immo specific matching that needs to do be done, nor is there a security access code that's relevant.
I don't see any obvious reason why the vehicle doesn't start. Please describe its exact behavior when you try to start it. No crank? Crank but won't fire? Cranks, fires, and dies?
You can also have a look at [25-Immobilizer] MVBs 001 and 002, and tell us what you see there, but I'm skeptical that's the source of the problem.
cally76
C?ID=233770
Hi short story vehicle broke down recovered to a local garage with can gateway comms fault they fitted a second hand gateway but still not starting will spin over fine but not firing
We have picked the job up now when i got the vehicle they hadn't programmed the part correctly which i sorted but i wasn't sure if the part needed to be coded to vehicle
I would go through it and clear all fault codes, then see if any come back after a start attempt.
Not firing at all is not indicative of an immobilizer problem, but the fault in the ABS bothers me a bit.
cally76
C?ID=233770
Hi cleared codes only 2 stay on and are there after attempted start
thursday,14,September,2017,09:02:53:35464
VIN: VSSZZZ5PZ8R070749   License Plate: KJ08 3
   Coding: 0050071
   Coding: 0017025
   Coding: 00152622
   Shop #: WSC 18434
                    Reset counter: 220
                    Mileage: 121257 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.80 V
                    Reset counter: 220
                    Mileage: 121257 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.80 V
   Coding: 0021305
   Coding: 0002042
   Coding: 0002401
   Coding: 0000688
   Coding: 00000000
   Shop #: WSC 06402
   Coding: 0000688
   Coding: 0040464
   Coding: 0000144
   Coding: 0000144
cally76
C?ID=233770
Sorted took a step back and started again i checked fuses with tester and then checked with the book and it turns out the previous garage were a lot worse than i thought i replaced the fuses they left out and it starts. Thanks for your help
