Hi does the can gateway need to be coded to the vehicle? The old gate way has no comms, new one fitted and now have comms with gateway and coding done ok but still can not get the vehicle to start, no engine codes the only comms code i have is for the drivers wiper motor which i suspect is for a faulty motor. I have asked our local Seat for the security access code but they dont want to help. Thanks in advance for any help.
VCDS Version: 17.8.0.1 (x64)
Dealer/Shop Name: central autopoint ltd
VIN: VSSZZZ5PZ8R070749 License Plate: KJ08
Mileage: 121250km-75341mi Repair Order:
Chassis Type: 5P (1K0)
VIN: VSSZZZ5PZ8R070749 Mileage: 121250km-75341miles
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 SK HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 1444
Revision: --H08--- Serial number: SEX7Z0H331H00A
Coding: 0050071
Shop #: WSC 06402 785 00200
VCID: 7AFC7E703555D196C4-802E
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F8ACF646EF734BEB3-806A
Part No: 5P0 907 044 K
Component: ClimatronicPQ35 011 0702
VCID: 3878A4784BD9038672-806C
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Revision: 00H54000 Serial number: 00000005550841
Coding: E1880F2F00041000431800000000000000007F075C400000000000000000
Shop #: WSC 18434 020 328969
VCID: 71EE595C682392CE75-8024
Subsystem 2 - Part No: 1P0 955 559 Labels: 1P0-955-559.CLB
Component: REGENLICHTSENSORH04 0090
Coding: 00152622
Shop #: WSC 18434
Subsystem 3 - Component: Fehler Lin-Slave 01
02071 - Local Databus
Reset counter: 220
Mileage: 121257 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 11.65 V
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 220
Mileage: 121257 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 11.65 V
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: S9 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1XNKNK
Coding: 0021305
VCID: 3D76B56C64FB26AEA1-8068
Subsystem 1 - Serial number: 6332MSME3234193A6
Subsystem 2 - Serial number: 6342MSME3235670DB
Subsystem 3 - Serial number: 6351HSME14792D3BH
Subsystem 4 - Serial number: 6361HSME154961486
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0002042
VCID: 78F864780B59C386B2-802C
Component: E0221 001 0010
Part No: 5P0 920 927 B
Component: KOMBIINSTRUMENT VO3 0450
Coding: 0002401
Shop #: WSC 80093 222 69422
VCID: 3460904857B1E7E65E-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001055300136
Coding: 3D3F0340070203
Shop #: WSC 01324 785 00200
VCID: 2A5C8E308575A116F4-807E
Component: IMMO VO3 0450
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1132
Revision: 31008001 Serial number: 00000080888201
Coding: 0000688
VCID: 3B72BB747AEF289E9F-806E
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.077 H08 1901
VCID: 3664AA4041CDF5F660-8062
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Coding: 998000005183CC7F0006850560085F86107C80
VCID: 03020394429F905E97-8056
Subsystem 5 - Part No: 5P0 951 171 C
Component: Innenraumueberw.009 4865
Coding: 00000000
Shop #: WSC 06402
Subsystem 7 - Component: NGS n.mounted
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1132
Revision: 31008001 Serial number: 00000071788119
Coding: 0000688
VCID: 3C70B8687FE12FA696-8068
Part No: 5P2 035 186 A
Component: Radio BVX 0006
Coding: 0040464
VCID: 2F6A9F24BE97C43E23-807A
Part No SW: 1K0 959 703 M HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1114
Revision: 11006001 Serial number: 00000002925434
Coding: 0000144
VCID: 3A7CBE7075D5119684-806E
Part No SW: 1K0 959 704 M HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1114
Revision: 11006001 Serial number: 00000002978395
Coding: 0000144
End-------------------------(Elapsed Time: 01:50)--------------------------
