Thursday,14,September,2017,12:12:07:33586
VCDS Version: 17.8.0.1
VIN: WAUVGAFH8BN006359 License Plate: BLACKS5COOLANT
Mileage: 123560km-76776mi Repair Order:
Chassis Type: FH-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 22 26 36 3C 42 46 47 52
53 55 56 5F 62 6C 72
VIN: WAUVGAFH8BN006359 Mileage: 123560km-76776miles
26-Auto Roof -- Status: Malfunction 0010
Address 01: Engine (J623-CCBA) Labels:| 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H07 0003
Revision: --H07---
Coding: 011C000A240F0128
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
ROD: EV_ECM30TFS0218K0907551D.rod
VCID: 326015EA65AC53D64C-8066
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K1 927 156 K HW: 0B5 927 156 F
Component: 0B5 30TFSINAR H07 0006
Revision: --H07--- Serial number: 0000000664
Coding: 000001
ROD: EV_TCMDL501.rod
VCID: 3D7A36D6ACF29CAEA1-8068
10047 - Hydraulic Pressure Sensor 1 (G193)
P1775 00 [040] - Adaptation Limit Reached
Fault Frequency: 87
Reset counter: 40
Mileage: 118037 km
Date: 2017.06.25
Time: 18:09:12
Engine speed: 2022 /min
Transmission input speed: 2022 /min
Transmission output speed: 444 /min
Engine torque: 92 Nm
Transmission fluid temperature: 103 °C
Accelerator position: 17.6 %
Clutch status: Kupplung 2 kann Moment übertragen
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Coding: 290D1A
Shop #: WSC 22198 444 05018
VCID: 0200852A9D8C23569C-8056
Part No SW: 8K0 907 064 CS HW: 8K0 907 064 CS
Component: BCM2 2.0 H05 0431
Coding: 0D0300
Shop #: WSC 02399 823 56573
VCID: 030E802E82962A5E97-8056
Subsystem 1 - Part No SW: 8T0 959 754 S HW: 8T0 959 754 S
Component: FBSAUDIB8 IDG H61 0072
Serial number: 0511000063292014
Component: J764 ELV MLB H37 0042
Serial number: 2310000006194001
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 D HW: 8T0 959 760 D
Component: MEM-BFS H10 0074
Revision: AA000000 Serial number: 00001002037625
Coding: C80170250D2400001000
Shop #: WSC 02391 823 56573
VCID: 448C4332C718ED66EE-8010
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AL HW: 8T1 820 043 AL
Component: KLIMA 3 ZONEN H08 0180
Revision: C3000000 Serial number: 01070920100481
Coding: 6613200E
VCID: 7BFEF8CEFA66529EDF-802E
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000648471
Coding: 26001091063CAF212700080000003D3D0F9CD2C802010161000003
VCID: 3C7C3BD2BFE895A696-8068
Subsystem 1 - Part No SW: 8F1 955 119 HW: 8K1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 100910 H06 0021
Serial number: SWF10090105169
Coding: 00FD11
Component: RLS H04 0003
Serial number: 11053149
Coding: 02562A
Subsystem 3 - Part No SW: 8K0 941 531 AN HW: 8K0 941 531 AN
Component: E1 - LDS H08 0090
Serial number: 00000000000608101040
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 Q HW: 8K0 919 475
Component: PARKHILFE 4K H06 0070
Revision: 11001001 Serial number: 51201026500421
Coding: 200102
VCID: 4796543EF62EC67E0B-8012
Address 15: Airbags (J234) Labels:| 8F0-959-655.clb
Part No SW: 8F0 959 655 A HW: 8F0 959 655 A
Component: AirbagVW-AU10 H10 0430
Serial number: 003A5D066A0A
Coding: 303737353631303030304A55304C38463053
Shop #: WSC 02135 785 00200
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 366829FA89C44FF660-8062
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R1000001FLH
Serial number: 6334MSME57702E13C
Serial number: 6344MSME57710878H
Serial number: 6352QSME1F733D02L
Serial number: 6362QSME18740A2CM
Serial number: 63732SME34724F02-
Serial number: 63832SME3A6F453CF
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90304JIA000F9
Coding: 000036
VCID: 3E7831DAA9F487B6B8-806A
Component: E221 - MFL H02 0010
Part No SW: 8T0 920 983 D HW: 8T0 920 983 D
Component: KOMBIINSTR. H40 0258
Revision: 00100000 Serial number: EI171759A
Coding: 8B1719008300D705020000
VCID: 3F864CDEAEFE8EBEB3-806A
Part No SW: 8T0 907 468 AE HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0117
Revision: FC100058 Serial number: 5800F10906002F
Coding: 00C303
VCID: 040C833287982D66AE-8050
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 10030FF3150910
Reset counter: 247
Mileage: 123566 km
Date: 2017.09.11
Time: 17:11:48
Bin. Bits: 10111
Voltage: 11.80 V
Count: 6
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 A HW: 8K0 907 163 A
Component: 4 Wheel Drive H10 0025
Serial number: 001409100001014
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
VCID: 2E58019A7194773628-807A
Address 26: Auto Roof (J256) Labels:| 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H10 0180
Coding: 030000
ASAM Dataset: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
VCID: 71E2DAE6A02A28CE75-8024
0020 - Convertible Top Compartment Switch; Left
B1181 29 [008] - Signal Implausible
Reset counter: 25
Mileage: 122641 km
Date: 2017.08.17
Time: 15:00:33
0021 - Convertible Top Compartment Switch; Right
B1182 29 [008] - Signal Implausible
Reset counter: 25
Mileage: 120496 km
Date: 2017.07.27
Time: 14:42:39
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00001002037539
Coding: C8197B250D2400001000
Part No SW: 8K0 907 566 F HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0020
Revision: 00H01000 Serial number: 6PZ 009 014-19
Coding: 0000005
VCID: 3A703DCA75DCAB9684-806E
Subsystem 1 - Part No: 8K0 907 568 F
Component: J0770_SWA_Slave_H01 0020
Subsystem 2 - Serial number: 6PZ 009 014-39
Subsystem 3 - Serial number: 5F13.09.1000H010003CR10102ÿ
Subsystem 4 - Serial number: R10102ÿ
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1401
Coding: 011C53724E08332C03
VCID: 53AE706E32767ADE67-8006
Revision: 00002001 Serial number: 0134725847
Coding: 010602BA00FA442180B0033200000000
Subsystem 1 - Part No SW: 8F0 959 719 HW: 8F0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000278043
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8F0 035 223 D HW: 8F0 035 223 C
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34863000813103
VCID: 2142EAA6384AD84EA5-8074
Fault Status: 00101011
Reset counter: 31
Voltage: 12.40 V
Temperature: 40.0°C
Temperature: 41.0°C
Bin. Bits: 00000100
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Reset counter: 247
Voltage: 12.20 V
Temperature: 21.0°C
Temperature: 22.0°C
Bin. Bits: 00000100
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1401
Coding: 011C53324E08332C03
VCID: 52A0756A0D6C73D66C-8006
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000609372
VCID: 346C13F297B85DE65E-8060
Part No: 8K5 907 357
VCID: 77F6E4FE064E76FEBB-8022
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471I.0A7529602
Coding: 020007010000000101
VCID: 5DBA965644B2BCAEC1-8008
Part No SW: 8T1 035 664 C HW: 8T1 035 664 B
Component: H-BN-NA H49 0116
Revision: -------- Serial number: 490I-0A7583321
Coding: 010200030206A1EF55000B0E000000010100
VCID: 387427C28BD0B98672-806C
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Serial number: 9466IH0A0210031
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000623910
Component: CD-Database 1886
Part No SW: 8T0 959 795 L HW: 8T0 959 795 C
Component: TSG HL H07 1401
Coding: 010C13324008372C03
VCID: 54AC737237787DE67E-8000
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8F0 907 441 HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H04--- Serial number: 525PA8-J08B0E2
Coding: 1000009
VCID: 67D6B4BE56EEE67E2B-8032
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H07 1401
End-------------------------(Elapsed Time: 04:15)--------------------------
