Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: ACC retrofit in Octavia 2
  1. #21
    Jul 2014
    Greece
    Your ECU not support ACC , even if you can code CCS to ACC. Coding is accepted , but software not understand ACC command.
    Simple connect ACC , recode ABS (current also support ACC) and look errors message
    Hello my friend, can you provide me coding for abs unit above , to enable acc ?
    Or what to change in current coding?
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 113B801C09238001881301E590210142350950
    Shop #: WSC 12345 123 12345
    VCID: 7BDB3BB3FA8BC29EDF-802E
  2. #22
    May 2017
    This should enable ACC in ABS :
    113B801C09238001881301E59021014235C950
    Byte 17 bits 6 and 7 enabled.
  3. Likes 4WDDSG6, Uwe liked this post
  4. #23
    Jul 2014
    Greece
    Thank you very much my friend i will try and let you know about the result.
  5. #24
    Jul 2014
    Greece
    UPDATE
    Hello again , the complete kit for acc installation is ready.
    1) 1K0 953 513 H
    2) 2K5 907 561 A (radar for MQ35)
    3) upgraded sw in engine ecu 4285 from passat cc 1.8 tsi BZB
    4) complete wirring harness
    5) coding for abs unit BJ
    6) coding for abs unit BS if it is not possible BJ unit coding.
    7) front lower grill radar cover from Skoda O3
    i will come back with the results of acc retrofit
    regards
    vv
  6. Likes downtime liked this post
  7. #25
    Jul 2014
    Greece
    one small help please
    my adress 16 is the above
    Part No SW: 1K0 953 549 CK HW: 1K0 953 549 CK
    Component: J0527 055 0111
    Coding: 0000634
    Shop #: WSC 44700 231 72242
    VCID: 7DDF35AB249FCCAEE1-8028
    Subsystem 1 - Part No: 3T0 959 537 A Labels: 3C8-959-537.CLB
    Component: E221__MFL-URO H07 0011
    Coding: 00000131
    what must add in module coding to enable acc ?
  8. #26
    May 2017
    The second last value change to 1. Cruise control via separate stalks 6 positions.
  9. Likes 4WDDSG6 liked this post
  10. #27
    Jul 2014
    Greece
    thank my friend , the NEW coding will be
    0000614
    regards
    vv
  11. #28
    Jun 2014
    2) 2K5 907 561 A (radar for MQ35) radar use Component Protection ........is waste of time to try this one with your car
    only one you can use is 3C0 / 3AA 907 567 from Passat B6/B7/CC
    HOT HOT HOT VW Touran 2005 CCS via MFSW HOT HOT HOT
  12. Likes Uwe liked this post
