Hi every one, been lurking around for a while and this is my first post.
My name's Ross and I'm from Melbourne, Australia.
I own a 2000 Audi TTQ and a 2010 TTRS.
I'm going to get some KW V3 coilover for my TTRS and the car has got magnetic ride.
I've done a bit of research and discovered that the magride communicates with the instrument cluster, CAN gateway, ABS and headlight range.
Using my VCDS cable i managed to code it out of the instrument and headlight range successfully, but i can't code it out of the ABS module as it says is coded with Software Version Management and when i pull the fuse out Can bus comes with a no communication error, i believe this can be solved by disconnecting the unit altogether from the wiring loom, but what about the ABS coding?
Here's a scan from my car.
Thanks.
Thanks.
Sunday,10,September,2017,11:21:15:52801
VCDS Version: 17.8.0.1
VIN: TRUZZZ8J
Mileage: 80970km-50312mi Repair Order:
Chassis Type: 8J-AU35 (1K0)
Scan: 01 03 08 09 10 14 15 16 17 19 22 25 2E 37 42 44 46 47 52 55
56 77
VIN: TRUZZZ8J Mileage: 80970km-50312miles
Address 01: Engine (CEP) Labels:. 07K-907-404-CEP.clb
Part No SW: 8J0 907 404 HW: 8J0 907 404
Component: 2.5l R5/4V TFSI 0040
Revision: F4H03--- Serial number: AUX7Z0INFN902F
Coding: 0113000C180F0160
Shop #: WSC 01236 785 00200
VCID: 6AD0DF4945B1A81634-803E
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 910 517 HW: 8J0 614 517 C
Component: ESP MK60E1 0010
Revision: 00H60001
Coding: 0618391
VCID: 69D2A04540B7A30E3D-803C
Part No SW: 8J0 820 043 AP HW: 8J0 820 043 AP
Component: J255 Klima 1 Zone 0090
Revision: 00H08006 Serial number: 00000001142791
Coding: 1573957
VCID: 74ECC13117756EE69E-8020
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 B HW: 8P0 907 063 B
Component: BCM PQ35 H 105 0573
Revision: 00105 AJ
Coding: 0E000AAFB0031A202070C0E00180084C517658AA3020D929DC0008440040
Shop #: WSC 01236 758 00200
VCID: 336E022D92FB29DE47-8066
Subsystem 1 - Part No SW: 8J2 955 119 A HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H08 0070
Coding: 00FD10
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02492C
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93640931306909
Coding: 00000B
VCID: 428057E9DD419056DC-8016
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 8J0 910 376 C HW: 8J0 907 376 C
Component: J250 Raddaempfung 0080
Revision: --H20--- Serial number: 190DPH 9160118
Coding: 0000072
VCID: 2F660E5DBED30D3E23-807A
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -r Airbag 9.43 H03 0020
Revision: 93H03002 Serial number: 0036K00415D9
Coding: 0011634
VCID: 79F2F0053017138ECD-802C
Subsystem 1 - Serial number: 6332DRB40A2B8F9A5
Subsystem 2 - Serial number: 6342DRB40A2E4C9A2
Subsystem 3 - Serial number: 63747RB4051AF86B$
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004041
VCID: 46884BF93169AC76F0-8012
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 930 G HW: 8J0 920 930 G
Component: KOMBIINSTR. VDO H03 0490
Revision: D0H03004 Serial number: 224NI004001099
Coding: 0069728
Shop #: WSC 40070 822 96273
VCID: 30640D21A3ED12C63A-8064
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0231
Revision: H16 Serial number: 4340K09B038177
Coding: E9AB1F06500612004101
Part No SW: 2K0 907 554 HW: 2K0 907 554
Component: Haldex 4Motion 5003
Coding: 0000005
VCID: 6BDEDA4D4A4BB11E4F-803E
Revision: D0H03004 Serial number: AUX7Z0INFN902F
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8P0 035 785 HW: 8P0 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020202
VCID: 74ECC131D7756EE69E-8020
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8J0 035 193 HW: 8J0 035 193
Component: RNS-E PU EU H03 0220
Revision: 0000005S Serial number: AUZBZ7J6305225
Coding: 0610725
VCID: 67D6A67D56A3957E2B-8032
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8J8 959 801 E HW: 8J8 959 801 E
Component: Tuer-SG H03 0080
Coding: 0000533
VCID: 3F865E1D6EB3FDBEB3-806A
Part No: 8J0 909 144 J
Component: EPS_ZFLS Kl. 239 3001
Revision: 00H17000
VCID: 3776363D4683C5FE7B-8062
Address 47: Sound System (J525) Labels:* 8J0-035-223.lbl
Part No SW: 8J0 035 223 F HW: 8J0 035 223 F
Component: Audi TT Amp5K H05 0170
Revision: -------- Serial number: BP208393367006
Coding: 070101060002
ASAM Dataset: EV_AudioAmpli5ChannBNO1 003011
ROD: EV_AudioAmpli5ChannBNO1_003.rod
VCID: 2756E67D5E23557EEB-8072
Part No SW: 8J8 959 802 E HW: 8J8 959 802 E
Coding: 0000532
VCID: 40845DE1134D8246CA-8014
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Coding: 0000011
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0610725
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H38 0600
Revision: 00000000 Serial number: 00000005144982
Coding: 0011422
Shop #: WSC 40070 822 85997
VCID: 75EAFC351C0F77EEA9-8020
End-------------------------(Elapsed Time: 02:25)--------------------------
