Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: HEX-V2 software periodically freezing using UDS
  1. #21
    Quote Originally Posted by VWT6 View Post
    Thanks. Mailed to support@ debug and log files for 2 runs with 1024 debug option on.
    Unfortunately I didn't realize that VCDS concatenated both runs into one debug file - that's why it is huge . And there doesn't seem to be obvious point where second debug starts in the file. Originally planned just to have a short run and mail the results. But continued after the first one to gather more data in case the first one fails to glitch.
    Anyways, seems that it made it's way through ... at least I haven't received reject note...
    Confirmed same issue, the "Turbocharger 1 turbine inlet; temp. sensor 1 bank 1; raw value" result sometimes confuses VCDS with regards to the "Lambda value at inlet of particulate filter". I'll mull on it
  2. Likes VWT6, Uwe liked this post
  3. #22
    Try this:
    http://download.ross-tech.com/VCDS/d...x64-171004.rar
    I'm pretty happy with this new idea; it should cure all your issues and is even more efficient than before. Let me know if anything looks wrong, but I did quite a bit of testing already.
  4. Likes VWT6, Dana, Zenerdiode, Uwe liked this post
  5. #23
    Jan 2017
    Quote Originally Posted by Eric View Post
    Try this:
    Thanks again. Unfortunately I won't have a chance to try before 15th of Dec. I'll report back then.
  6. Likes Eric liked this post
  7. #24
    Jan 2017
    Try this:
    Yep. A lot better . I did three runs, total of 13551 lines each 12 measuring values with same setup as before. I found one (1) glitch similar to what saw before. Unfortunately it was in first run when I didn't yet have the debug on
  8. Likes Uwe liked this post
  9. #25
    Jan 2017
    Oops.. Well, just being back on-line noticed that there was a firmware update for HEX-V2 (CB: 0.4409.4) which has an improvement related to grouped requests. So, the previous runs were with CB: 0.4408 = the exact same setup as a few weeks ago.
    I'll do another run with updated one soon...
  10. Likes Uwe liked this post
  11. #26
    Jan 2017
    I did a run. Recorded probably just one glitch at time stamp 1232.73 sec in total of more than 160 ksamples - not too bad - emailed the debug files to support@ross-tech.com - if interested...
  12. Likes Eric, Uwe, Dana, Andy liked this post
  13. #27
    Here: http://dltemp.ross-tech.com/VCDS/dow...taller-RC0.exe
    This one took quite a bit of thinking, but I think I've found a way to prevent VCDS from being confused when the data for a given identifier is the same as the identifier itself which is what was happening for your lone glitch with the O2 sensor. Again, I truly appreciate all you've done to help us come this far compared to the original glitches (and freezes)
  14. Likes Dana, DrPeter, Bruce, VWT6, Uwe, Andy liked this post
  15. #28
    Jan 2017
    While you were working on my debug file, I did another run of 30+ minutes using old setup just to gather more data just in case... and noticed two glitches in that run. So it was quite rare event already then.
    First thing in the morning I downloaded the installer and updated also HEX-V2 firmware to CB:0.4410.4 as instructed by the installer. I did two runs, each 32+ minutes. Total of 24820 lines, each 12 measuring values. Not a single glitch and all the values seem to carry plausible values. Thanks again
  16. Likes Dana, Andy, Eric, jyoung8607, Uwe liked this post
  17. #29
    Jun 2014
    Latvia
    Hello.
    Is this 17.12 beta fw update issue is connected with some kind of my vcds status due to this thread?
  18. #30
    Your HEX-NET is not set to Beta Channel. Click the advanced tab and select beta and press change channel. Once changed, Check for updates.
  19. Likes Uwe, Eric liked this post
