- Jan 29, 2014
- 3,941
- 5,865
- Lansdale, PA, USA
- HC800000
Thanks. Mailed to support@ debug and log files for 2 runs with 1024 debug option on.
Unfortunately I didn't realize that VCDS concatenated both runs into one debug file - that's why it is huge . And there doesn't seem to be obvious point where second debug starts in the file. Originally planned just to have a short run and mail the results. But continued after the first one to gather more data in case the first one fails to glitch.
Anyways, seems that it made it's way through ... at least I haven't received reject note...
Confirmed same issue, the "Turbocharger 1 turbine inlet; temp. sensor 1 bank 1; raw value" result sometimes confuses VCDS with regards to the "Lambda value at inlet of particulate filter". I'll mull on it
