Page 32 of 32 FirstFirst ... 22303132
Results 311 to 316 of 316
Thread: Current Versions
  1. #311
    Jun 2015
    Thank you Benevolent Dictator
  2. #312
    Bump for CB V0.4409
    * Fix for data loading/rod redirect issues
    * Fix for UDS mv drops with grouped requests + turbo mode
    * Fix for Immo3 extra info parsing
  3. Likes Uwe liked this post
  4. #313
    Verified VCDS User hans j's Avatar
    Mar 2014
    Utah
    Mine keeps telling my I'm not up to date, but the updating software says I am up to date. I've been having to use older versions to make it work.
    VCDS 17.12 says I'm at:
    CB 0.4409.4
    FW 0.254
    WiFi 310C
    and says firmware update required.
    Firmware software says:
    CB 0.4409
    FW 0.254
    CFB 0.10
    BL 0.28
    DS 00000050
  5. #314
    You'll need to flip your interface onto the Beta update channel using VCIConfig, as described on the Beta Page in the Release Notes section:
    If you are using a HEX-NET or HEX-V2 interface, you must set the update channel for your interface to "Beta" and update it before you can use this version of VCDS.
  6. Likes Boki Ar, Shaun, hans j liked this post
  7. #315
    You need to switch your interface to the beta channel to get the latest testing firmware that goes with the beta version of VCDS.
    In VCIConfig, go to [Advanced] -> Update channel [Beta] -> [Change Channel]
    Then check for updates again.
    EDIT: As Uwe showed above, with the picture.
  8. Likes Boki Ar, Uwe liked this post
  9. #316
    Mar 2014
    Utah
    That worked! Thanks again.
  10. Likes Boki Ar, Uwe, Shaun liked this post
