Page 1 of 32 12311 ... LastLast
Results 1 to 10 of 316
Thread: Current Versions
    Current Versions
    HEX-NET interface & VCDS-Mobile:
    CodeBlock: V0.4409
    FW: 0.254
    CFB: 0.10
    BL: 0.27
    Dataset: 10000048
    You can see these versions on the About page of VCDS-Mobile.
    Preferred: Use the native Windows utility for updating, configuring, or registering the HEX-NET. It is included with VCDS and accessible from the Options screen (see this thread).
    Alternative 1: Make sure your HEX-NET is connected to a network in Infrastructure mode and can access the internet.
    Click [Options] -> [Check for updates].
    Alternative 2: connect your HEX-NET to a computer and use the Java configuration utility:
    Windows/Linux: HexNetConfigV2.014.jar
    Mac OS: HexNetConfigV2.014
    Note for people who bought their HEX-NETs way back when and haven't updated them in just about forever: The new config utilities linked above are only compatible with CodeBlock 0.42xx and higher. You can only get from a CodeBlock below 0.42xx to something current with VCDS-Mobile per this thread. If you need to configure a HEX-NET that does not yet have CodeBlock 0.42xx, please use the older version of HexNetConfig here:
    Windows/Linux: HexNetConfigV1.963.jar
    Mac OS: HexNetConfigV1.963
    HEX-NET compatible VCDS for Windows: 17.1.8
    To update: In VCDS click [Options], select the User Interface and Identification tab, and then [Check for updates],
    or you can simply download and install any newer version from this page
    We will endeavor to keep the data in this post current.
    PS: If you can't get JAR files to run on a Windows 8.1 or Windows 10 PC, try Johann Löfflmann's Jarfix.
    Mar 2014
    Thank you, Uwe. I was actually thinking today about suggesting just such a thread. You beat me to it.
    Important Note: The first time you install CB v0.42xx, (from v0.41xx) you must do so using the web interface (VCDS-Mobile: [Options] -> [Check for Updates]. You cannot update from CB 0.41xx to CB 0.42xx using the PC-based utility. Once you've got a CB v0.42xx in your HEX-NET, the old utility v1.9xx is deprecated and can no longer be used. You should then replace it with the current v2.xxx utility, and you should be able to use the new utility for all updates after that. Of course, you should also be able to do updates via the web interface if you choose.
    Changelog:
    CB V0.4409
    * Fix for data loading/rod redirect issues
    * Fix for UDS mv drops with grouped requests + turbo mode
    * Fix for Immo3 extra info parsing
    CB V0.4407
    * Updated UDS address list
    * Fix for certain rare comms issues
    * Support for release channel switching
    CB V0.4401
    * Speed improvements for Auto-Scan
    * Fixes for CAN OBDII
    * Fix for turbo mode with dual-ecu (0x31)
    * Support for UDS Multifunc. Module (4B)
    CB V0.4341
    * VCDS support for LT3/Crafter platform
    * HTTP tweaks
    * Registration process updates
    CB V0.4336
    * Support for larger CAN packets
    * Coding timing tweak for certain modules
    * Fix for ROD parsing issue
    * Tweaks to missing ROD logic
    CB V0.4334
    * Tweaks for kline timing
    * Tweaks for http downloads
    * Improvements for DS downloads
    * Fix for registered use counting
    * Fix for label redirect
    * Fix VIN refresh issues
    CB V0.4323
    * Improved autoscan reliability w/ MLBevo modules
    * Fix for some OBDII data pids
    * Fix for static IP settings
    * Fix for freeze at MV list generation
    CB V0.4321
    * Support for additional MIB2/MLBevo modules
    * Fix for turbo mode with CAN modules
    * Fix for rod sync timeout with web interface
    * Fix for rod redirect issue
    CB V0.4316
    * Support for CAN Extended IDs
    * Fix bug with ASAM download stuck at zero
    * Fix for ROD loading
    CB V0.4313
    * Show file size in FW download
    * Fix for coding length of certain modules
    * Fix for certain UDS modules missing in autoscan
    * Fix SSID encoding through web config
    CB V0.4309
    * Fixes several bugs with loading ASAM data that could lead to update loops
    * Fixes bug with mobile updates exceeding 100%
    CB V0.4305
    * Fix for HTTP retry in certain cases
    * Avoid DTC in B7 TDI 2.5 fuel pump
    CB V0.4304
    * Background support for updating/clearing labels
    * Fix for VCDS comms issue when clearing faultcodes with certain modules
    * VCDS VIN api
    CB V0.4301
    * Fix for reading DTCs from certain modules
    * Don't check ASAM data in AP mode
    * Changes to idle timer handling
    * Heartbeat shows USB enum status
    * Support for registration functions
    * Fixes for some rods
    * Fix for EEPROM sync
    CB V0.4231
    * Updated address list
    * Fixes/Optimizations for networking
    * Fixes for comms issues particularly with large packets
    CB V0.4222
    * Optimizations for ASAM download under high latency
    * Improved junk CAN frames handling
    * Improved latency tracking
    CB V0.4215
    * Support for new update version 2.0+ update utility
    * Fixes for certain CAN modules, particularly for service 22 ID
    * TP1.6 tries to fall back to kline if it doesn't receive the sync byte
    * Fixes for text measuring values (display and logging)
    * Retry on no response to service 22 ID
    * Fix for downloading ASAM data
    * Fix for TP2.0 comms with certain ABS
    CB V0.4123
    * Fixes for ROD update issues
    * Support for CAN broadcast
    * Auto wifi prioritization
    * Fix for autoscan issue with certain modules with many subsystems
    CB V0.4119
    * Fix for fs sync issue
    * Fix for fallback led status
    * Fixes for rod update
    * Supports vcds read/write values
    * Fix for service 22 grouped packet
    * Supports USB updates
    CB V0.4114
    * Support for Wifi FW updates
    * Fix for KW2000 packets with long format header
    CB V0.4112
    * Improvements to HTTP timing that should make downloads faster to start and more reliable
    * Tweaks to autoscan formatting
    CB V0.4111
    * Tweaks for CAN timing
    * Fix for manually entering group zero when not in label file
    * Fix for possible memory leak when force closing a session during kline comms
    CB V0.4110
    * Support for MV/BS group zero
    CB V0.4109
    * Support for TP1.6 1281
    * Reliability and performance tweaks for VCDS comms
    CB V0.4108
    * Fix for additional modules in the Phaeton
    CB V0.4107
    * Fix for comms with certain modules, particularly those in the Phaeton
    CB V0.4106
    * Fix for certain measuring block formatting
    * Tweaks to log format to include some more info like time and VIN when available
    * Tweaks for server comms
    * Fixes for some UDS modules, particularly with coding
    * Improvements to VCDS comms
    CB V0.4105
    * Fix for a bug in 0.4104 which can hang retrieving the gateway list
    * Fix for certain measuring blocks where less than 4 values are present
    * Tweaks for CAN timing for some slower/picky modules
    CB V0.4104
    * Support for dual CAN ECUs
    * Support for MQB gateway list
    * Tweaks for VCDS comms
    * Tweak to subsystem timing that may improve some modules
    CB V0.4102
    * Fixes for VCDS comms
    * Updates addresses
    * Fix for ASAM data autoscan redirect
    CB V0.41
    * Fixes an issue with kline comms
    CB V0.4019
    * Fixes several kline comms issues
    * Tweaks to VCDS comms with certain kline modules
    CB V0.4018
    * Fix for comms with 1281 modules
    * Tweaks to 1281 timing to better tolerate slower modules
    * Fix for TP1.6 CAN modules
    * Fix for Gateway list for some gateways
    * Tweaks to Kline retry/timeout
    * Fixes for Autoscan
    CB V0.4016
    * Fixes bug where autoscan could hang after first module
    CB V0.4015
    * Fixes a bug where a VIN from a previous vehicle could show up during an autoscan
    CB V0.4014
    * Compatibility fix for retrieving GVL in VCDS
    CB V0.4013
    * Fix for CAN status in VCDS options-test
    * Compatibility fix for certain CAN modules with VCDS, particularly ones with subsystems
    * Fix for certain UDS modules that could interfere with Autoscan results
    * Tweaks to Autoscan formatting to more closely reflect VCDS output
    * "Check for Updates" from options page now also checks for any ASAM data you may be missing
    DS 00000050
    * Improvements for web updates
    DS 10000048
    * New chassis and label data
    DS 10000045
    * New Label Files
    * New ASAM data
    DS 10000042
    * Updated label and chassis data
    DS 10000039
    DS 00000036
    * Updated chassis file and ASAM data
    DS 00000035
    * New codes list
    * New ASAM data
    DS 00000034
    * Improved VIN management
    DS 00000033
    * New label files
    * Minor fixes to several webpages
    DS 00000030
    * Updated label files
    DS 00000029
    * Updated ASAM data
    DS 00000028
    * Update file for wifi FW, version 310C
    DS 00000027
    * Updated info for some newer cars
    * Tweak to update page
    DS 00000026
    * Reports registration status warning after checking for updates if interface has not yet been registered with the cloud server.
    * Files needed for some of the above changes
    FW V0.254
    * Fixes to Mass Storage for Windows 10 (creators update) support
    * Tweaks to wifi low power mode
    FW V0.253
    * Improvements to wifi scanning and wifi comms
    * Filesystem improvements
    * Improvements to DHCP handling
    * Better kline sync processing
    FW V0.244
    * Tweaks to Wifi comms
    * Fixes for EEPROM sync
    FW V0.238
    * Support for displaying signal strength
    * Wifi networking fixes
    FW V0.223
    * Optimized EEPROM handling
    FW V0.215
    * Fixes for FS issues, beeps on critical FS init failure
    FW 0.214
    * Fixes for USB mass storage support
    FW 0.210
    * Fix for a USB Mass Storage issue with certain hubs
    FW 0.208
    * Fixes concurrency and sync issues that could cause a 404 page to be displayed
    FW 0.196
    * Several tweaks to kline handling
    * Fix for properly clearing kline buf on close
    * Tweaks to TCP timing for performance
    FW 0.187
    * Various tweaks and bug fixes, mostly for rare cases
    FW 0.184
    * Fixes some networking issues
    HexNetConfig V1.963
    * New wifi config interface
    New 2.xxx utilities for CB V0.42xx+
    Mac: HexNetConfigV2.014
    Legacy 1.xxx utilities:
    Mac: HexNetConfigV1.963
    NC USA
    Confirm ASAM update works as designed.
    Now I better get that interface VCDS-Cloud registered
  5. Likes Uwe liked this post
    Mar 2014
    May I suggest that when you guys update this thread that you add a new post simply stating "update" or something along with editing the first post and change log. That way the date on the thread will update and users will be able to see on what date an update was released. The 3/10/14 date is not changing because you're only editing the posts so I thought I was running the latest version only to discover I actually was not.
    I suppose I could always click on the thread first thing but figured this might help as well.
  7. Likes Uwe, jakematic liked this post
    VCDS Beta 14.2.3:
    * Fixes timing problem with TCP communications on some PCs/Network boards.
    * Shows what sub-nets it tried to find a HEX-NET on if it fails to find one.
    * Adds configurable Network timeout on Options screen when NET port is in use.
    * Shows mileage in Auto-Scans on cars using UDS instrument clusters
    * Shows real-ish dates in freeze-frame data even on cars that don't know the actual date.
    Requires latest Codeblock V0.4016, so if you haven't updated your HEX-NET itself recently, please do so first.
    Mar 2014
    Updated all today to latest software / firmware /DB etc.. and HEX-NET it is working really well.. really smooth, Fast and fluid.. VCDS Mobile and CLOUD working well on my laptop.. now will set it up on my HTC phone
  10. Likes Dana, Uwe liked this post
  11. #8
    CB V0.4018 released, see details above
  12. #9
    VCDS Beta 14.4.0:
    * Adds an option to manually enter a HEX-NET's IP address.
    * Includes numerous stability improvements and bug fixes for HEX-NET interfaces
    * Requires CB V0.4018 in your HEX-NET, so update that first please!
    CB V0.4019 is out, fixes some kline comms issues
