- Joined
- May 16, 2014
- Messages
- 5,469
- Reaction score
- 5,935
- Location
- Melbourne, Australia
- VCDS Serial number
- C?ID=194404
I use indirect domestic hot water heating as well; fed from a mod-con boiler.
Sorry buddy, but a furnace makes hot air while a boiler makes hot water.
http://www.differencebetween.com/difference-between-furnace-and-vs-boiler/
Uwe: Do you guys have the same crazy rule that is mandated down here where new hot water units are not allowed to have the temperature exceed 50 degrees C at the outlet? It's apparently implemented to save folk from scalding themselves. The water temperature in the storage unit needs to exceed 55/60 degrees C to avoid the growth of bacteria, but our rules makes us install a mixing valve at the outlet of the tank so that cold water is injected back into the hot water line . Way too much nanny watching IMO -it means that gully traps for kitchens, never get sufficiently warm water to melt grease - which means more work for plumbers!. If adults can't get their water temperature correct in the bathroom, then perhaps there are larger issues at play. And if kids aren't taught this basic requirement at an early age -then .........!
