- Joined
- Mar 17, 2017
- Messages
- 13
- Reaction score
- 8
- Location
- South Carolina, USA
- VCDS Serial number
- C?ID=276685
I am considering taking my 2011 VW Jetta Sportwagen in for the USA EPA settlement repair. Will the VCDS software function in a similar manner as prior to the EPA fix. More specifically, I have used VCDS to adjust the speedometer and odometer after installing VW Passat 18 inch tires and wheels which have a larger circumference than the original 17 inch tires.. I also turned off the Tire Pressure monitoring system since the wheels are missing the tire pressure sensors. Also, I turned off the seat belt chime. After undergoing the VW dealer EPA repair, will I be able to use VCDS again to make these adjustments to the ECM?
