Results 1 to 8 of 8
Thread: Engines codes after 2012 a7 3.0t water pump and thermostat replacement
    Aug 2017
    I just replaced this water pump and themostat on this 3.0t engine. I keep getting this codes after the repair. Please give me some suggestions. Thanks for all your time!!
    Saturday,12,August,2017,16:06:03:60975
    VCDS Version: 17.8.0.1  HEX-NET CB: 0.4401.4
    Mileage: 167222km-103906mi   Repair Order:
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 28 36 3B 3C 42 44 46 47
              52 53 55 56 5F 62 6C 6D 72 8F 90
    VIN: WAU2GAFC0CN0XXXXX   Mileage: 167222km-103906miles
    3B-Sensor Elect. -- Status: Malfunction 0010
    Address 01: Engine (J623-CGXB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 907 551 A    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0010
       Revision: --H07---
       Coding: 1A2A0034052600060000
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
       ROD: EV_ECM30TFS0214G0907551A_003.rod
       VCID: A71EAC22DE03BB7E6B-80F2
    10 Faults Found:
    6185 - EVAP Purge Valve (N80)
              P1425 00 [039] - Short to Ground
                        Mileage: 167222 km
                        Date: 2017.08.12
                        Time: 15:57:15
                        Engine speed: 698.00 /min
                        Normed load value: 13.3 %
                        Coolant temperature: 90 ∞C
                        Intake air temperature: 56 ∞C
                        Voltage terminal 30: 13.812 V
                        Engine speed: actual: 672 /min
                        MAF_ENVD: 136.17647 mg/stroke
                        Coolant temperature (unfiltered): 90.75 ∞C
                        Engine: operating status: IS
                        Engine load: 13.281250 %
                        Vehicle speed: actual: 0 km/h
    6001 - Right Engine Mount Solenoid Valve (N145)
              P1576 00 [039] - Short to Ground
                        Mileage: 167222 km
                        Date: 2017.08.12
                        Time: 15:57:15
                        Engine speed: 689.00 /min
                        Normed load value: 13.7 %
                        Engine load: 13.671875 %
    6004 - Left Engine Mount Solenoid Valve (N144)
              P1572 00 [039] - Short to Ground
                        Mileage: 167222 km
                        Date: 2017.08.12
                        Time: 15:57:15
    7814 - Coolant Pump for Intercooler
              P190C 00 [039] - No Signal
                        Mileage: 167222 km
                        Date: 2017.08.12
                        Time: 15:57:16
                        Engine speed: 685.00 /min
                        Voltage terminal 30: 14.015 V
                        MAF_ENVD: 141.62353 mg/stroke
    7105 - Oile Pressure Regulating Valve
              P164E 00 [039] - Electrical Malfunction
                        Mileage: 167222 km
                        Date: 2017.08.12
                        Time: 15:57:18
                        Engine speed: 704.00 /min
                        Normed load value: 12.9 %
                        Intake air temperature: 55 ∞C
                        Engine speed: actual: 704 /min
                        Coolant temperature: 90.75 ∞C
                        TQI_AV_ENVD: 52 Nm
                        Battery voltage: 13.914063 V
    12875 - Thermostat for Cylinder Head
              P199D 00 [039] - Short to GND
                        Mileage: 167222 km
                        Date: 2017.08.12
                        Time: 15:57:14
                        Engine speed: 692.00 /min
                        Voltage terminal 30: 13.913 V
    9497 - Secondary Air Injection System Valve (N112)
              P0414 00 [039] - Shorted
                        Mileage: 167222 km
                        Date: 2017.08.12
                        Time: 15:57:14
                        Engine speed: 686.00 /min
                        Battery voltage: 13.812500 V
                        STATE_LS_ENVD[1]: 4
    9500 - Secondary Air Injection System Valve 2 (N320)
              P0417 00 [039] - Shorted
                        Mileage: 167222 km
                        Date: 2017.08.12
                        Time: 15:57:14
                        STATE_LS_ENVD[2]: 4
    9494 - Secondary Air Injection Pump Relay (J299)
              P2257 00 [039] - Short to Ground
                        Mileage: 167222 km
                        Date: 2017.08.12
                        Time: 15:57:14
                        Engine speed: 696.00 /min
                        AMP_ENVD: 981.7285 hPa
    18198 - Coolant pump
              P1B1C 00 [039] - Mechanical malfunction
                        Mileage: 167222 km
                        Date: 2017.08.12
                        Time: 15:57:15
    Readiness: 1110 1101
       Part No SW: 4G0 927 158 P    HW: 0BK 927 156 R
       Component: 0BK 30TFSIUSA H08 0003
       Revision: --H08---
       Coding: 000002
       ASAM Dataset: EV_TCMAL551211 002017
       VCID: BB366052328B0F9E1F-80EE
       Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
       Component: ESP PREMIUM   H09 0250
       Coding: 44A70F0322E5F0C05B00
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ESPPremiAU57X 004017
       VCID: B4244B6E1FD5C0E6DE-80E0
       Part No SW: 4H0 907 064 BR    HW: 4H0 907 064 BR
       Component: BCM2 2.0      H31 0330
       Coding: 0D8A2000000000000000
       VCID: FAB8A5567531F69644-80AE
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000154747012
       Part No SW: 4G0 820 043 L    HW: 4G0 820 043 L
       Component: KLIMA 4 ZONEN H11 0062
       Serial number: 09091100040096
       Coding: 668320BA48
       ASAM Dataset: EV_AirCondiComfoUDS 002033
       VCID: A81CAF1ED31DB40662-80FC
    0247 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 141
                        Mileage: 167222 km
                        Date: 2017.08.12
                        Time: 15:32:49
                        Outside air temperature: 32.5 ∞C
                        Engine speed: 175 /min
       Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0100
       Revision: 11012002    Serial number: 00000001044821
       Coding: 02002091163C9FE0C1008884A0003928CF9CD208A2080125800008402000
       VCID: EE9099063979AA36E8-80BA
       Component: WWS57X 110731  H35 0051
       Serial number:         110805110850
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11665408
       Coding: 02562B
       Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
       Component: E1 - LDS  H07 0044
       Serial number: 05 09 2011  00000660
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R0LDT02
       Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0024271048
       Coding: 0F3000
       Subsystem 6 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0280
       Serial number: WA102069000000410884
       Coding: 020300
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: BF18C5C5000000000001
    Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
       Part No SW: 8X0 035 110 B    HW: 8X0 035 110
       Component: CDC-MP3-Pana  H41 0480
       Revision: 00000007
       VCID: AC14530ECFE5982686-80F8
       Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0050
       Revision: 11001001    Serial number: 55901125101203
       Coding: 280104
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: BD326E4A2C9F01AE21-80E8
       Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
       Component: Airbag10.43   H31 0032
       Revision: --------    Serial number: 003D8001CD3A
       Coding: 303145313131303030314A55304C34473853
       VCID: B32648721ADBC7DEC7-80E6
       Serial number: 6940000Y150001FEDZ08
       Serial number: 3575HRB404V0OPI250M
       Serial number: 3585HRB405D0NI366OV.
       Serial number: 3515JRB404R0M5SQ886.
       Serial number: 3525JRB405L0N49O9177
       Serial number: 3554VRB404V0NI3IKHIR
       Serial number: 3564VRB40530NI3I216+
       Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
       Revision: --------    Serial number: 90372KI9000II
       Coding: 000414
       VCID: B83C7F5E0BBD2486F2-80EC
       Subsystem 1 - Part No SW: 4G0 951 528 F    HW: 4G0 951 528 F
       Component: E221 - MFL  H09 0009
       Serial number: 24 07 2011  33108987
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
       Part No SW: 4G8 920 982     HW: 4G8 920 982
       Component: TBenUsa       H71 0375
       Revision: 26181114    Serial number: 658050911593014
       Coding: 0BE601060B03D705020100
       ASAM Dataset: EV_RBD4K 004040
       ROD: EV_RBD4K.rod
       VCID: F1AA827A2047B5CEF5-80A4
       Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000249279
       Coding: 00C1033000
       ROD: EV_GatewUDS_AU57.rod
       VCID: B2284D76E5C1CED6CC-80E6
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650411549
       Part No SW: 4G0 919 158 D    HW: 4G0 919 158 D
       Component: KLIMA FOND    H07 0062
       Serial number: 26081100041017
       Coding: 00
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
       VCID: B02C477EEBCDFCC6BA-80E4
       Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
       Component: MEM-FS        H03 0153
       Revision: AA000000    Serial number: 00000011476684
       Coding: C0581B008F002001000001010101102030303232203232
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0004
       Revision: --------    Serial number: EJ1BPA4201UBTS0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: AD125E0AFCFF912E91-80F8
    2097156 - Internal Control Module Memory Check Sum Error
              B2000 00 [109] -  -
                        Fault Frequency: 0
                        Mileage: 163961 km
                        Date: 2017.06.16
                        Time: 13:55:35
                        DCU Temperature: 0 ∞C
                        Voltage Clamp 15: 14.0 V
                        Voltage Clamp 30: 13.5 V
                        Ignition Cycle Count: 21686
                        Voltage UBDZ: 13.5 V
                        Voltage VDD1: 1.5 V
                        Voltage VDD3: 3.3 V
                        Voltage VDD3_STUCK: 1.9 V
                        Voltage VDD5: 5.0 V
                        Voltage VBG2: 2.5 V
                        Voltage GNDA: 0.0 V
    2117632 - Internal Control Module Memory Check Sum Error
              B2000 00 [109] -  -
                        Fault Frequency: 0
                        Mileage: 163961 km
                        Date: 2017.06.16
                        Time: 13:55:35
                        Voltage VDD1: 1.5 V
                        Voltage VDD3: 3.3 V
                        Voltage VDD5: 5.0 V
                        Voltage VBG2: 2.5 V
                        Voltage GNDA: 0.0 V
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 4G0 907 566 J    HW: 4G0 907 566
       Component: J769  SWA MasterH01 0030
       Revision: 00H01000    Serial number: 6PZ 010 287-08
       Coding: 0000007
       VCID: B6207166C1A9D2F6E0-80E2
       Subsystem 1 - Part No: 4G0 907 568 J
       Component: J770  SWA Slave H01 0030
       Subsystem 2 - Serial number: 6PZ 010 287-28
       Subsystem 3 - Serial number: 5F16.08.1100H010003CZ21944ˇ
       Subsystem 4 - Serial number: Z21944ˇ
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011F57225E00628002000412
       Shop #: WSC 02312 785 00200
       VCID: C2C81DB65D617E565C-8096
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0020146212
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0158289811
       Coding: 0126023A20FAF48580B00A80020100000000000000000000000000000000
       Component: GTO BF  H01 0070
       Serial number: 00000000000000048040
       Subsystem 3 - Part No SW: 7P5 959 591     HW: 4H0 959 591
       Component: J245 PS40.033  H07 0006
       Serial number:     WOO1320725.
       Coding: 101F00
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00000371286
       Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H09 0027
       Serial number: WA102073000000463265
    03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
                000 -  -  - Intermittent
                        Reset counter: 141
                        Mileage: 167222 km
                        Date: 2017.08.12
                        Time: 15:25:10
       Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0130
       Revision: CJ007000    Serial number: 00000000020665
       Coding: 030000
       VCID: 9C7483CE9F4568A6F6-80C8
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       Coding: 011F57225E00628002000402
       VCID: C1CA12BA5867654E45-8094
       Revision: --------    Serial number: 00000000125015
       ROD: EV_ParkiBrake_AU57.rod
       VCID: AA185516CD11861674-80FE
    Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
       Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
       Component: ....AFS13.... H01 0012
       Serial number: 110913-0004-016
       Coding: 1223A633701AA400
       ASAM Dataset: EV_AdvanFrontSyste 005001
       ROD: EV_AdvanFrontSyste_AU21.rod
    H01 0020
       Coding: 3A0000
    H01 0020
       Coding: 3A0000
       Part No SW: 4G0 035 082 B    HW: 4G0 035 082
       Component: Radio U SIRIU H53 0076
       Revision: AB001007    Serial number: 156I+0B7550772
       Coding: 020007010000000001
       VCID: 9F0EB4C28E5373BE13-80CA
       Part No SW: 4G0 035 746 C    HW: 4G0 035 746
       Component: H-BNT-NA      H48 0423
       Revision: --------    Serial number: 031IS0B7514812
       Coding: 090200040003E1EF55128B0E00000003100001000000000000
       VCID: A71EAC22D603BB7E6B-80F2
       Subsystem 1 - Part No: 8R0 060 884 AD
       Component: NAR 2011  0505
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDB1301FWK%
       Subsystem 3 - Part No SW: 4G1 919 610 A    HW: 4G1 919 610 A
       Component: E380 BDT C7  H08 0203
       Serial number: 90349KI50003W
       Subsystem 4 - Part No: 8R0 060 961 B
       Component: CD-Database  3371
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010F17224000628002000002
       VCID: C4C41BAE477570666E-8090
       Part No SW: 4G0 907 441 B    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0061
       Revision: --H04---    Serial number: 525 PA8J14G0TK
       Coding: 1080013
       VCID: A600A1261109A27650-80F2
       Part No SW: 4G8 959 107 P    HW: 4G8 959 107 G
       Component: HDSG-Modul    H13 0039
       Revision: 12013001    Serial number: 237100321
       Coding: 0A3305C102
       ASAM Dataset: EV_HDSGAu573 001014
       ROD: EV_HDSGAu571.rod
       VCID: C2C81DB655617E565C-8096
       Component: TSG HR        H04 0212
    Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 0006E008031F0300070308014244CA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: EFAE84023673A33EE3-80BA
    Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: F0AC877E2B4DBCC6FA-80A4
    End----------(Elapsed Time: 02:38, VBatt start/end: 14.2V/14.2V)----------
    Hello and welcome to the VCDS forum OP.
    Sounds like you should unplug your thermostat and electric water pump for inspection & since work was just aforementioned in this work detail. You might have bent a pin causing a short on the sensor bus.
    Please review WD for shared tracks and check fuses plus all terminals and ground connectivity.
    Isolate to test and verify.
    You could benefit from the JPPSG in this forums sticky.
    Aug 2017
    Thanks for your reply!! The thing that confuse me the most is it is saying the themostat itself is short to gound, which doesn't really have any electrical part.
    "Thermostat for Cylinder Head" is not the main thermostat.
  5. Likes Jack@European_Parts liked this post
    Aug 2017
    I thought it only has one?
    You must observe the WD and trace by isolation.
    Maybe you plugged something in a incorrect location or damaged something while in there.
    Did you have or what codes did you have before the work detail?
    Why did you perform this aforementioned work?
    Aug 2017
    Originally was a coolant leak complain. It was a broken coolant pipe under the supercharger between the heater cord and the themostat. The car was due for a water pump and themostat. So they were all replaced after that. The engine light came on with the coolant warning still remained after the repair. I am going to take a look at the WD and see if i did anything wrong when putting those 7 connectors back near the supercharger.
  9. #8
    Stoke on Trent, England
    I've read in a SSP a long time ago they show and electrical thermostat. I shall have to search through the thousands I have.
    UPDATE:
    I've found Map-Controlled Engine Cooling Thermostat (F265) in SSP 252 1.4 L 77 kW Engine with Petrol Direct Injection System in the Lupo FSI
    http://www.volkspage.net/technik/ssp/ssp/SSP_252.pdf
    SSP 222 Electronically Mapped Cooling System
    http://www.volkspage.net/technik/ssp/ssp/SSP_222.pdf
    I'm sure there was another engine with electrical thermostat.
    New User Keith
