Hello I am new and tried the VCDS Mobile on my Sharan 7N.
I have the Problem that when I try to display the advanced measuring blocks, diffrent blocks are displayed as I ticked.
Exsample when I choose engine RPM, selector lever position is displayed.
Regards,
Stefan
Regards,
Stefan
#hndoc:?docid=00003218&xt=hnh:7375572EC997A3735D1535AD14556087ED26150874C992B4A6ED83D9FFD7BC87
VCDS Mobile 0.4401.0.4
VIN: WVWZZZ7NZFV000463
Scan: 01 03 08 09 10 15 16 17 18 19 22 25 42 44 46 4C 52 53 56 61
62 69 6C 6D 72 BE BF
BE-Sliding Door Left -- Status: OK 0000
BF-Sliding Door Right -- Status: OK 0000
Address 01: Engine (CFFB J623) Labels: 03-01.clb
Part No SW: 03L 906 018 HK HW: 03L 907 309 Q
Component: R4 2.0l TDI H28 9978
Revision: 44H28---
Coding: 0019001A043601080000
Shop #: WSC 00240 216 00000
ASAM Dataset: EV_ECM20TDI01103L906018HK 003013
ROD: EV_ECM20TDI01103L906018HK.rod
VCID: 7AB761EB46C9D1EFB3C740AA04-802F
No fault codes found.
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 S HW: 7N0614109S
Component: J104 C3 450M VDE2 0040
Revision: --H07--- Serial Number: 00000008126427
Coding: 0018973
Shop #: WSC 00020 790 00000
VCID: 3D3DAAF71767BED7D665A3CE2D-8068
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 7N0 907 044 R HW: 7N0 907 044 R
Component: Clima-Sharan H02 0404
Revision: 00001K02
Coding: 021000C449
Shop #: WSC 00020 999 00000
ROD: EV_ClimatronicSharan.rod
VCID: 3FC1D0FF1D6B34C7C479B9E607-806A
Part No SW: 5K0 937 084 K HW: 5K0 937 084 K
Component: BCM PQ35 B 122 0173
Revision: BA122001
Coding: 40590A3F8125F3C0508800C05400006443D11308426D2D226480872000C1
VCID: 3A37A1EB064909EFF34780AAC4-806F
Subsystem 1 - Part No SW: 7N1-955-119-A Labels: 1Kx-955-119.clb
Component: WWS 140401033 0044
Coding: 004DBD
Subsystem 2 - Part No SW: 5Q0-955-547 Labels: 5Q0-955-547.clb
Component: RLFS 024 0042
Coding: 0228BB
Subsystem 3 - Part No SW: 7N0-951-171-A
Component: DWA-Sensor 00002 0206
Subsystem 4 - Part No SW: 1K0-951-605-C
Component: LIN BACKUP HOH05 1501
03789 - Terminal 75 Limp Mode Active
Address 10: Park/Steer Assist (J446) Labels: 1Q0-919-475.clb
Part No SW: 7N0 919 475 A HW: 7N0 919 475
Component: PARKHILFE 8K H06 0012
Revision: --------
Coding: 318001
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: 3935BEE7034F1AF7FA3D77BED9-806C
Part No SW: 7N0 959 655 C HW: 7N0 959 655 C
Component: VW10Airbag00N H12 0014
Coding: 00304E
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428.rod
Subsystem 1 - Part No SW: ----
Component: S.Sens.Fahr.V--- ---
Serial Number: 3493ETS607DFCCC199DR
Subsystem 2 - Part No SW: ----
Component: S.Sens.Beif.V--- ---
Serial Number: 3503ETS60B2EBCD19DDF
Subsystem 3 - Part No SW: ----
Component: S.Sens.Fahr.H--- ---
Serial Number: 3513ETS608DF5B519DDA
Subsystem 4 - Part No SW: ----
Component: S.Sens.Beif.H--- ---
Serial Number: 3523ETS607A5CD119DD2
Address 16: Steering wheel (J527) Labels: 5K-16.lbl
Part No SW: 5K0 953 501 CT HW: 5K0 953 569 AL
Revision: FF010042
Coding: 5180240000
VCID: 7EBF6DFB5AE1FDCF8FEF6CFA58-802B
Part No SW: 7N0 920 870 L HW: 7N0 920 870 L
Component: KOMBI H03 0905
Coding: 140F01
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 3B39A4EF097328E7E8518DD633-806E
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No SW: 7N0 963 271 G
Component: Zuheizer 051 3041
Revision: 00051000 Serial Number: 09028242000000
Coding: 0000041
VCID: 3833BBE338459BFF05336AB2EA-806D
Address 19: CAN Gateway (J533) Labels: 7N-19.clb
Part No SW: 7N0 907 530 AQ HW: 7N0 907 530 AL
Component: J533 Gateway H58 1653
Revision: H58
Coding: 468002
VCID: 7F4190FF5DEBECC784F979E647-802A
Part No SW: 0AY 907 554 F HW: 0AY 907 554 F
Component: Haldex4Motion H52 7521
Coding: 0401
ROD: EV_AllWheelContrHA1VW37X_VW36.rod
VCID: 4EDFFD3BAAC1AD4F3F0F5CBAC8-801B
Component: IMMO H03 0905
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EA97D1ABB669E16FC32710EAD4-80BF
Address 42: Door Elect, Driver (J386) Labels: 7N0-959-793.clb
Part No SW: 7N0 959 793 F HW: 7N0 959 793 F
Component: TSG FA H03 0553
Revision:
Coding: 01102E208000411011
VCID: 45CDC2177FB776178EB5FB2EB5-8010
Part No SW: 5N1 909 144 R HW: 5N1909148J
Component: J500__APA-BS KL.325 1401
Revision: 1BH04739 Serial Number: 00141220089601
Coding: 0000258
VCID: 41C5D6076B9FDA37B28DCF1E61-8014
Address 46: Failed to respond
Address 52: Door Elect, Pass. (J387) Labels: 7N0-959-792.clb
Part No SW: 7N0 959 792 F HW: 7N0 959 792 F
Component: TSG BF H03 0553
Revision:
Coding: 01102C208000411011
VCID: 44CBDF13748D4F1F99ABEE2246-8011
Part No SW: 3AA 907 801 J HW: 3AA907801J
Component: J540 EPB4 VW-63206 0012
Revision: H19 Serial Number: 00000000003355
Coding: 0024167
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 190 C HW: 3C8 035 190 C
Component: Radio RCD510 052 0213
Revision: 00000001
Coding: 0500040004000D
VCID: 23097C8F91C36827C06185B6FB-8076
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1653
Coding: 330F7859
VCID: F1A5C6C79BBF0AB7826D5F5E71-80A4
Subsystem 1 - Part No SW: 1K0-915-181-H
Component: J367-BDM H07 0180
Address 62: Door, Rear Left (J388) Labels: 7N0-959-794.clb
Part No SW: 7N0 959 794 J HW: 7N0 959 794 H
Component: TSG HL H01 0556
Revision:
Coding: 01006C200000411001
VCID: 4AD7F12B56A9996F63E7306AF4-801F
Address 69: Trailer (J345) Labels: 7N0-907-383.clb
Part No SW: 7N0 907 383 HW: 7N0 907 383
Component: Anhaenger H09 0120
Revision: 3I001003
Coding: 410C040001000000
VCID: F3A9CCCFE1A338A7708175766B-80A6
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7N0 907 441 HW: 7N0907441
Component: J772__Rearview 0020
Revision: 00H13000 Serial Number: 525 PA8J441339
Coding: 0030011
VCID: EE9FDDBB8A81954F9F4F3C3A28-80BB
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 7N0 959 107 E HW: 7N0 959 107 A
Component: HDSG-Modul H11 0243
Revision: 41011001
Coding: 0733334003
ASAM Dataset: EV_HDSGVW428 201138
ROD: EV_HDSGVW428_VW36.rod
Address 72: Door, Rear Right (J389) Labels: 7N0-959-794.clb
Component: TSG HR H01 0556
Revision:
Address BE: Sliding Door Left (J558) Labels: 7N0-959-244.clb
Part No SW: 7N0 959 244 B HW: 7N0 959 244 B
Component: Schiebetuer_l 005 2414
Shop #: WSC 00000 000
ASAM Dataset: EV_AST A03704
ROD: EV_AST.rod
VCID: 3833BBE3384503FF05336AB2EA-806D
Address BF: Sliding Door Right (J731) Labels: 7N0-959-244.clb
Component: Schiebetuer_r 005 2414
ROD: EV_AST.rod
