Hi all,
I hope this is the right place to post this, I'm looking for a label file for the very new facelift infotainment unit from the golf 7.5. I installed it in my "old" golf 7 and wanted to look at some coding but I got no labels.
got an autoscan if that helps (just ignore the warnings).
Thank you!!
- Chris
Thank you!!
- Chris
Monday,07,August,2017,22:20:18:60997
VCDS Version: 17.8.0.1 (x64)
VIN: WVWZZZAUZEW400910 License Plate: MIB2FACELIFT
Address 5F: Information Electr. Labels: None
Control Module Part Number: 5NA 035 042 HW: 5NA 035 042
Component and/or Version: MU-H-LN-EU H51 0731
Software Coding: 02731001FF00000051110002000808101F0203E4012005009E
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_MUHig4CGen2HBAS 001001 (VW37)
VCID: 72EDB93AA54164D68C-8026
10 Faults Found:
B201A 00 [009] - -
Reset counter: 159
Mileage: 13636 km
Date: 2017.06.13
Time: 00:25:53
Voltage terminal 30: 12.2 V
Status_Software_Version_Management-module_name: MMIBLite/MIBLite
15360256 - Component Protection
U1101 00 [009] - Active
Reset counter: 159
Mileage: 13636 km
Date: 2017.06.13
Time: 00:25:48
Voltage terminal 30: 12.3 V
U11B8 00 [009] - No Communications
Reset counter: 159
Mileage: 13636 km
Date: 2017.06.13
Time: 00:25:48
Interface for external media: status-Status: Open circuit
3073 - Cellular Antenna
B1053 13 [009] - Open Circuit
Reset counter: 159
Mileage: 13636 km
Date: 2017.06.13
Time: 00:25:48
3084 - GSM antenna 2
B1533 13 [009] - Open Circuit
Reset counter: 159
Mileage: 13636 km
Date: 2017.06.13
Time: 00:25:48
6666 - Optical data bus
U1049 00 [008] - Open circuit
Reset counter: 199
Mileage: 13636 km
Date: 2017.06.13
Time: 00:32:31
Temperature of MOST transceiver-max.value: -50 °C
Temperature of MOST transceiver-min.value: -5 °C
Temperature of MOST transceiver-Current: 38 °C
6669 - Optical Data Bus for Digital Sound System
U10CC 00 [008] - Intermittent Disruption
Reset counter: 200
Mileage: 13636 km
Date: 2017.06.13
Time: 00:35:33
Voltage terminal 30: 12.6 V
Temperature of MOST transceiver-Current: 40 °C
7194 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 159
Mileage: 13636 km
Date: 2017.06.13
Time: 00:25:50
BAP-BAP_Function_ID: 02
7219 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 159
Mileage: 13636 km
Date: 2017.06.13
Time: 00:25:50
7223 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 159
Mileage: 13636 km
Date: 2017.06.13
Time: 00:25:50
