anthony james
New Member
hi everyone
this is my first post ever on vcds so i'm sure i have a lot to learn!
i have a 64000 mile audi a5 WAUZZZ8T48Axxxxxx
engine code:CCWA
this car is used for long motorway trips so has been very reliable.
recently occasionaly the engine management light illuminates & reduced power is noticed.
the fault code stored in the engine ecu is:
4807-EGR SYSTEM. P0401 00 (104) INSUFFICIENT FLOW.
this fault will reappear even after a short 3 to 5 mile run (although engine mil on & reduced power only appear after a long run)
i suspect the egr cooler may be blocked,although dpf soot & ash content seem very low,typical i guess of a long distance vehicle.
i have replaced the differential pressure sensor & egr valve just to eliminate the easy to access parts but to no avail.
is there any tests with vcds that i can access?
i am unable to re-code the pressure sensor or complete a regeneration or flow test of the egr cooler?
HEX+CAN
DUAL-K & CAN <-> USB
INTERFACE FOR VCDS
HC497653 Rev.B
any help would be appreciated
regards,
anthony james
engine code:CCWA
HEX+CAN
INTERFACE FOR VCDS
HC497653 Rev.B
Friday,14,July,2017,17:16:27:53873
VCDS Version: 17.1.3.0 (x64)
i do realise that my auto-scan has to be condensed but have not got my haed around that yet!
VIN: WAUZZZ8T48Axxxxxx License Plate:
Mileage: 63727 Repair Order: AJB/DE
Address 01: Engine Labels: 059-907-401-V1.clb
Control Module Part Number: 8K2 907 401 HW: 8K1 907 401 A
Component and/or Version: 3.0TDI EDC17 H01 0006
Software Coding: 0114002C190F0120
Work Shop Code: WSC 06325 000 00000
ASAM Dataset: EV_ECM30TDI0118K2907401 001006 (AU48)
ROD: EV_ECM30TDI0118K2907401.rod
VCID: 6AD0D65E8DAD981157-803E
4807 - EGR System
P0401 00 [100] - Insufficient Flow
Mileage: 102550 km
Date: 2017.07.14
Time: 16:59:50
Engine speed: 1315.00 /min
Normed load value: 30.2 %
Vehicle speed: 77 km/h
Coolant temperature: 90 °C
Intake air temperature: 24 °C
Voltage terminal 30: 13.940 V
Crankshaft speed (RPM): 1315.0 /min
Vehicle speed: 77.79 km/h
Air Ctl m Gov Dvt: -356.5 mg/stroke
AFS dm: 144.8 kg/h
Inj Ctl q Curr: 11.48 mg/stroke
Charge air pressure: actual value: 1374 hPa
Intake air temperature: 25.1 °C
Chassis Type: 8T (8T0)
Scan: 01 02 03 05 06 07 08 09 0E 10 15 16 17 19 1E 36 37 42 46 47
52 53 55 56 77
VIN: WAUZZZ8T48A045400 Mileage: 102550km-63721miles
Address 01: Engine (J623-CCWA) Labels: 059-907-401-V1.clb
Part No SW: 8K2 907 401 HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H01 0006
Revision: --H01---
Shop #: WSC 06325 000 00000
4807 - EGR System
Mileage: 102550 km
Date: 2017.07.14
Time: 16:59:50
AFS dm: 144.8 kg/h
Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
Part No SW: 8K0 927 158 A HW: 0B6 927 156
Component: 0B6 30 TDIRdW H04 0030
Revision: --H04---
Coding: 001001
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 346C08269FE91EE13D-8060
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 Q HW: 8K0 907 379 Q
Component: ESP8 quattro H04 0170
Coding: 140500
VCID: 47964FEAF67F857968-8012
Part No SW: 8K0 907 064 AD HW: 8K0 907 064 AD
Component: BCM2 1.1 H71 0134
Coding: 051000
VCID: 72E0CE3EAD7D50D1EF-8026
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Serial number: 0208000017091011
7 Faults Found:
03285 - Sensor for Contact with Door Handle; Front Left
Fault Status: 00100111
Fault Frequency: 19
Reset counter: 181
Mileage: 99001 km
Date: 2017.05.12
Time: 05:55:29
Fault Frequency: 19
Reset counter: 181
Mileage: 99001 km
Date: 2017.05.12
Time: 05:55:29
03286 - Sensor for Contact with Door Handle; Front Right
Fault Frequency: 21
Reset counter: 183
Mileage: 100064 km
Date: 2017.05.21
Time: 19:14:40
Fault Frequency: 21
Reset counter: 183
Mileage: 100064 km
Date: 2017.05.21
Time: 19:14:40
03287 - Sensors for Contact with Door Handles
Fault Status: 00101010
Reset counter: 169
Mileage: 100617 km
Date: 2017.05.31
Time: 18:23:55
Reset counter: 169
Mileage: 100617 km
Date: 2017.05.31
Time: 18:23:55
Reset counter: 184
Mileage: 102538 km
Date: 2017.07.13
Time: 17:11:20
Address 06: Seat Mem. Pass (J521) Labels: 8T0-959-760.clb
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001001085613
Coding: 08217025002444441000
VCID: 42805EFEDD5DA051BF-8016
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 N HW: 4E0 035 729
Component: Interfacebox H43 5170
Revision: 00000000 Serial number: 329EU087564324
Coding: 0005002
VCID: 448C58E60749AE618D-8010
Subsystem 1 - Part No: 8T0 919 609 C
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000079423
Subsystem 3 - Serial number: 0129.04.080000000100010271ÿ
Subsystem 4 - Serial number: 010271ÿ
Reset counter: 181
Mileage: 102510 km
Date: 2017.07.03
Time: 09:19:11
Bin. Bits: 00000000
Bin. Bits: 0000000
Bin. Bits: 011
Reset counter: 181
Mileage: 102510 km
Date: 2017.07.03
Time: 09:19:11
Part No SW: 8T2 820 043 T HW: 8T2 820 043 T
Component: KLIMA 3 ZONEN H06 0140
Revision: D1000000 Serial number: 0124.04.080847
Coding: 36060000
VCID: 438E5BFAC247A959B4-8016
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000136269
Coding: 260050914014AF010009000300005D5D0F1D438800010141000000
VCID: 3064043663F122C159-8064
Subsystem 1 - Part No SW: 8T2 955 119 C HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 090408 H11 0040
Serial number: SWFBIE 0000386
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10563917
Coding: 024B2D
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000000405080482
Part No SW: 8T2 035 110 C HW: 8T2 035 110 C
Component: MP3-Changer H42 0390
Revision: 00042001 Serial number: AUZ5ZBH8380967
VCID: 2B5E135A8AD741196C-807E
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 C HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0010
Revision: 11001001 Serial number: 75230811716045
Coding: 100101
VCID: 39723912B08BE389EE-806C
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Fault Status: 00101110
Reset counter: 184
Mileage: 60463 km
Date: 2014.12.02
Time: 18:21:40
Temperature: 15.0°C
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD15933L
Coding: 30323433363030303030554A305238543053
VCID: 3C7C2006B7B9D6A1F5-8068
Serial number: 6334MSME3A2430285
Serial number: 6344MSME3A240D0BH
Serial number: 6352QSME6648275FU
Serial number: 6362QSME660B440DM
Serial number: 63732SME62464B35/
Serial number: 63832SME62730E1D3
Address 16: Steering wheel () Labels: 8K0-953-568.clb
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90304HE8000C8
Coding: 000036
VCID: 3D7A2D02A4A3DFA9C2-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 B HW: 8T0 920 981 B
Component: KOMBIINSTR. H28 0221
Revision: 00000000 Serial number: 71Y340P48
Coding: 2F0701000A002600010000
VCID: 3B7E231ABAB7D199FC-806E
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 K HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0092
Revision: EB302042 Serial number: 4200E08418803C
Coding: 000303
VCID: 499249D2E06B73097E-801C
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18018069170408
Reset counter: 180
Mileage: 52542 km
Date: 2014.04.03
Time: 13:01:00
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 D HW: 4E0 035 785 C
Component: SG ext.Player H15 0830
Revision: 00000000
VCID: 2952E952402B53099E-807C
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001001086246
Coding: 08397B25002444441000
Fault Frequency: 17
Mileage: 52542 km
Date: 2014.04.03
Time: 08:27:12
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H51 1060
Revision: 00000000 Serial number: 333EQ087564721
VCID: 3B7E231A7AB7D199FC-806E
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 HW: 8K0 959 793
Component: TSG FA H09 0149
Revision: Serial number: ei##
Coding: 011C12225E012201
VCID: 7DFAED02E4231FA982-8028
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0110740993
Coding: 011B0E8200390481002000
Component: LIN BACKUP HO H03 1301
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 10
Reset counter: 87
Mileage: 52542 km
Date: 2014.04.03
Time: 08:55:36
02615 - Fuel Tank Cap; Lock
Fault Frequency: 10
Reset counter: 87
Mileage: 52542 km
Date: 2014.04.03
Time: 08:55:36
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14003 Serial number: 34814000972100
Coding: 020101
Shop #: WSC 12336 024 394758
VCID: 3F86570AAEAFCDB9D0-806A
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 HW: 8K0 959 792
Component: TSG BF H09 0149
Revision: Serial number: B‰##
VCID: 7CFCE006FF3916A1B5-8028
Fault Frequency: 43
Reset counter: 173
Mileage: 92089 km
Date: 2016.12.12
Time: 09:11:44
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 00000000118414
Address 55: Headlight Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 A HW: 8H0 907 357
Component: AFS 1 H01 0010
Coding: 0000017
Shop #: WSC 06324 000 00000
VCID: 30640436A3F122C159-8064
Component: AFS-Modul links H07 0004
Component: AFS-Modul rechtsH07 0004
Reset counter: 101
Mileage: 74335 km
Date: 2015.07.20
Time: 09:03:22
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Revision: 00000000 Serial number: 336EO087558200
VCID: 2E581A4EB9C534314B-807A
Part No SW: 4E0 910 336 K HW: 4E0 862 335
Component: Handyvorb2 H20 0950
Revision: 00000000 Serial number: 00000005155579
Coding: 0010920
Shop #: WSC 60100 210 91154
VCID: 2A50165E852D581197-807E
regards,
anthony james
