Perfcent
New Member
Hi, This is my first post on here, but have been a vagcom user for 10+ years.
Today I am struggling with replacing a steering column lock on a B6 passat 1.9 edc16. I have retrieved a pin with Vag Can Pro which gave me 26466 but the security login in immobiliser would not accept it and said 'wrong key' so I read the Eprom in the ECU by BDM and this gave me pin 25323 WHICH IS ALSO NOT ACCEPTED AND GIVES THE ERROR 'controller refused the key'
Neither pin is accepted, and I noticed the vin/sn is stored as VWZCZ000000000
Thursday,27,July,2017,17:33:16:42627
VCDS Version: 17.1.3.0 (x64)
VIN: WVWZZZ3CZ8E204290 License Plate: PASSAT
Mileage: 196950km-122379mi Repair Order: 0001
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56
VIN: WVWZZZ3CZ8E204290 Mileage: 196950km-122379miles
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 056 L HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 1846
Revision: --H08--- Serial number: VWZCZ000000000
Coding: 0000071
Shop #: WSC 66565 257 00032
VCID: 306B74DCA385D0C159-8064
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000785281057
Coding: 0001282
Shop #: WSC 05311 000 00000
VCID: 1F498760CE1B5FB9F0-804A
Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 76E782C40161BEF1C3-8022
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Revision: 00H54000 Serial number: 01000008124804
Coding: 00880B0700041A00470A00460F000000000848405C000100000000000000
Shop #: WSC 05124 123 12345
VCID: 71EDB1D8680F99C916-8024
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 130208 022 0601
Coding: 00046997
Shop #: WSC 05124
9 Faults Found:
Fault Status: 00111100
Reset counter: 58
Mileage: 196957 km
Date: 2017.07.09
Time: 19:39:00
Voltage: 11.65 V
Reset counter: 58
Mileage: 196957 km
Date: 2017.07.09
Time: 19:39:00
Fault Status: 00111010
Reset counter: 58
Mileage: 196957 km
Date: 2017.07.09
Time: 20:12:00
Voltage: 11.55 V
02403 - Terminal 15 for Interior
Reset counter: 58
Mileage: 196957 km
Date: 2017.07.09
Time: 20:12:00
Reset counter: 58
Mileage: 196957 km
Date: 2017.07.09
Time: 20:12:00
Fault Frequency: 10
Reset counter: 58
Mileage: 196749 km
Date: 2017.04.28
Time: 07:07:00
Voltage: 12.95 V
Fault Frequency: 10
Reset counter: 58
Mileage: 196749 km
Date: 2017.04.28
Time: 07:07:00
Reset counter: 58
Mileage: 196911 km
Date: 2017.05.08
Time: 00:00:00
Voltage: 12.40 V
Reset counter: 58
Mileage: 196911 km
Date: 2017.05.08
Time: 00:00:00
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__006 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP3VTFGF
Coding: 0012342
VCID: 3B7153F07AC32399FC-806E
Subsystem 1 - Serial number: 6333FTS647320468
Subsystem 2 - Serial number: 6343FTS640030318
Subsystem 3 - Serial number: 6353ETS6330LSVNP
Subsystem 4 - Serial number: 6363ETS683OISVNP
Part No SW: 3C0 953 549 AD HW: 3C0 953 549 AD
Component: J0527 0020
Revision: 00026000 Serial number: 3C9953507BA
Coding: 0000014
VCID: 6ED7AAA4793186310B-803A
02768 - Activation Steering Column Lock
Part No SW: 3C0 920 972 HW: 3C0 920 972
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007405
Shop #: WSC 00684 210 104582
VCID: 63C1CB90A2F33B5994-8036
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P082250661
Coding: F9801F060002022003
VCID: 23418B90E2737B59D4-8076
Part No SW: 3C0 959 433 AB HW: 3C0 959 433 AB
Component: IMMO 043 0383
Revision: 00043000 Serial number: 00000000000000
Shop #: WSC 77823 375 1964031
VCID: 6ADFA6B445D96A1157-803E
Component: ELV 029 0380
3C0905861J ELV 029 0380
02835 - Communications between Steering Column Lock and Convenience System
02822 - Electronic Steering Column Lock Incorrectly Installed
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1132
Revision: 32008001 Serial number: 00000563888223
Coding: 0000565
Fault Status: 01100101
Reset counter: 18
00943 - Heated Exterior Mirror; Driver Side (Z4)
Reset counter: 18
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.134 H08 1901
VCID: 366742C441E1FEF103-8062
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 043 0472
Coding: 0191020851030E763004941570085BCE103C01
Component: Neigungssensor 004 0611
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1132
Revision: 32008001 Serial number: 00000171488222
Coding: 0000564
VCID: 3C7350EC7FCD24A1F5-8068
Fault Status: 00100101
Reset counter: 58
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000369067
Coding: 0010000
VCID: 295D99B8805FA1099E-807C
02432 - Supply Voltage for Left Parking Brake Motor (V282)
011 - Open Circuit - MIL ON
Fault Status: 11101011
Fault Frequency: 29
Reset counter: 18
Mileage: 196883 km
Date: 2017.05.04
Time: 02:54:50
Voltage: 10.40 V
Count: 30
Speed: 48.0 km/h
Hex Value: 0x1271
Hex Value: 0x0004
Hex Value: 0x1010
02433 - Supply Voltage for Right Parking Brake Motor (V283)
Fault Frequency: 29
Reset counter: 18
Mileage: 196883 km
Date: 2017.05.04
Time: 02:54:50
Reset counter: 58
Mileage: 196957 km
Date: 2017.07.25
Time: 01:25:02
Voltage: 11.10 V
Count: 76
Hex Value: 0x1241
Hex Value: 0x0081
Hex Value: 0x1010
03200 - Switch for Electric Parking Brake (E538)
Reset counter: 58
Mileage: 196957 km
Date: 2017.07.25
Time: 01:25:02
03190 - Incorrect Vehicle Type
000 - - - MIL ON
Reset counter: 58
Mileage: 196957 km
Date: 2017.07.25
Time: 01:25:02
Part No: 1K0 035 186 AD
Component: Radio GR0 034 0033
Revision: 0003404S Serial number: VWZ2Z2H6121303
Coding: 0020200
Shop #: WSC 05314 000 00000
VCID: 68DBDCBC5BD5580141-803C
End-------------------------(Elapsed Time: 02:00)--------------------------
