- Joined
- Mar 4, 2014
- Messages
- 2
- Reaction score
- 0
- VCDS Serial number
- C?ID=209411
I have aftermarket headlights (need to be aimed) and HID kit. I removed fog lights as well (would like to add different fogs as DRL). I've added a Flat bottom R8 Wheel (no functions are working including horn) with B7 slip ring & control module. And pretty much all fault lights on dash are on. Please check out my scan info and avise me. Thanks
VCDS Version: Release 12.12.2
Data version: 20140212
Tuesday,04,March,2014,12:47:24:34624
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
63 65 67 73 75 76 77
VIN: WUARL48H46K900514 Mileage: 132170km/82126miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8H2 910 560 HW: 008 H29 075 60
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX6Z0E0090568
Coding: 0007714
Shop #: WSC 00672 785 00200
VCID: E7DD31ABD5EA1426BAD-5122
16522 - Oxygen (Lambda) Sensor B1 S2
P0138 - 001 - Signal too High - Intermittent
Fault Status: 00100001
Mileage: 132165 km
RPM: 735 /min
Load: 23.9 %
Temperature: 99.0°C
Temperature: 66.0°C
Absolute Pres.: 0.0 mbar
Voltage: 13.716 V
16523 - Oxygen (Lambda) Sensor B1 S2
P0139 - 004 - Response too Slow
Mileage: 132169 km
RPM: 1436 /min
Load: 13.3 %
Speed: 38.0 km/h
Temperature: 89.0°C
Temperature: 34.0°C
Voltage: 13.716 V
16420 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit - Intermittent
Fault Frequency: 29
Mileage: 132169 km
RPM: 1045 /min
Load: 29.0 %
Temperature: 7.0°C
Temperature: 9.0°C
Voltage: 13.716 V
Readiness: 0100 0101
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 Q
Component: ABS/ESP allrad 4533
Coding: 04597
Shop #: WSC 57389
VCID: 36632CEF12C03DAE71B-5106
35-00 - -
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2832
Coding: 00100
Shop #: WSC 00672
VCID: 6DD1C3832716BE76401-5122
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 00672
VCID: 35612BE30FC636B6781-4AE8
57-00 - Electric Circuit Failure
Part No SW: 8E0 035 593 D HW:
Component: SDAR SIRIUS
Revision: Serial number: AUZ4Z7E2015721
VCID: 2A5B089F8678694EE53-515E
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 D
Component: Airbag 8.4EC 0015
Coding: 0010105
VCID: 3B753DDB79E2E0C68E5-5140
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0801
Coding: 00042
VCID: 41894F334B0E8A16D49-4AE8
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No SW: 8H0 920 980 S HW: 8H0 920 980 S
Component: KOMBI+WFS 3 H12 0030
Revision: 0030 Serial number: AUX6Z0E0090568
Coding: 0017231
Shop #: WSC 01115 444 68394
VCID: 3F8D49CB6DFAFCE6A2D-5122
Address 25: Immobilizer Labels: 8E0-920-9xx-8E2.lbl
Coding: 0017231
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255 B
Component: VSG B6 CABRIO 6593
VCID: 35612BE35FC636B6781-5140
Part No: 8H0 959 760
Component: Sitzmemory EE H06 0010
Coding: 00002
Shop #: WSC 00065
VCID: F4E756E7C43CEFBE0FF-4B00
01447 - Sensor for Driver Seat; Height Adjust (G231)
36-00 - Open Circuit
Address 37: Navigation Labels: None
Part No SW: 8H0 035 192 D HW: 8H0 035 192 D
Component: RNS-E US H70 0040
Revision: 01S Serial number: AUZBZ7E2101024
Coding: 0419637
VCID: 285FF29798745B5EF37-517C
Reset counter: 188
Date: 2004.09.09
Time: 16:29:46
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8H0 959 433 E
Component: Komfortgerát T7B 3320
Coding: 11788
Shop #: WSC 00672
VCID: 36632CEF12C03DAE71B-4AE8
Subsystem 1 - Part No: 8H1959801B
Component: Tõrsteuer.FS BRM 3020
Subsystem 2 - Part No: 8H1959802B
Component: Tõrsteuer.BF BRM 3020
Subsystem 3 - Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0002
00955 - Key 1
35-10 - - - Intermittent
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00070
Shop #: WSC 00672
VCID: 04078627149C5F3EBFF-4B1A
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
30-00 - Open or Short to Plus
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
Address 56: Radio Labels: None
Coding: 0419637
VCID: 285FF29798745B5EF37-5140
Reset counter: 188
Date: 2004.09.09
Time: 16:29:46
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F M H13 0010
Coding: 00006
Shop #: WSC 00065
VCID: 35612BE30FC636B6781-4B00
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 HW: 8E0 907 273
Component: Reifendruck 3 H03 0110
Coding: 0062825
VCID: E9D93793C3FE2256AC9-5140
Fault Status: 11100100
Reset counter: 40
(no units): 19.0
Voltage: 13.70 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
02214 - Tire Pressure Warning
Fault Frequency: 19
Reset counter: 40
(no units): 0.0
Temperature: 40.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H13 0010
Coding: 00005
Shop #: WSC 00065
VCID: 35612BE30FC636B6781-4B1A
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283 A
Component: Parkingsyst. A4 USA D09
Coding: 00125
Shop #: WSC 00672
VCID: 4385453B51129806C65-5122
37-00 - Faulty
01548 - Sensor for Parking Aid; Rear Right (G206)
37-00 - Faulty
Part No SW: 8P0 862 335 B HW: 8P0 862 335 B
Component: FSE_255x BT H18 0160
Revision: 00000001 Serial number: 00000000302542
Coding: 0000807
Fault Frequency: 12
Reset counter: 93
Time Indication: 15
End ---------------------------------------------------------------------
