- Joined
- Feb 25, 2014
- Messages
- 2,780
- Reaction score
- 4,490
- Location
- Cincinnati, OH
- VCDS Serial number
- C?ID=25607
TL;DR: It works. Configuration and usage is identical to a Mk7 Golf.
Factory state: I have that same menu option. Options are all, driver, or none. Keyfob does nothing. Hands-on the car DOES work if that option isn't set to none. Opening can be done with the driver's door open, hold down the driver's window down button for 3 seconds. Ignition does not need to be on. Driver does only the driver window. All does everything: all four windows, the sunroof shade, and the sunroof pops up. Closing is done by holding your finger on the driver's door handle lock touch area.
Desired state: Keyfob open/close works with adaptations to 09. Opening respects the infotainment all/driver/none setting. Security access 31347 is required. There is no label file for 09 at present so you don't get a popup for that. The Golf 7 instructions seemed duplicative and some of this stuff was enabled already, so I spent a few minutes figuring out the exact minimum changes to make the keyfob work:
channel ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen, not active -> active
channel ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen not active -> active
Nothing else seems to be necessary. ENG141681-IDE02021-ZV Komfort-Comfort closing was already active. ENG141681-IDE02022-ZV Komfort-Comfort opening was not, but keyfob control was tested to work without it. Menu control was already set to adjustable.
