- Joined
- Apr 16, 2014
- Messages
- 72
- Reaction score
- 23
- Location
- Hudson Valley, USA
- VCDS Serial number
- C?ID=63476
My wife's 2008 Audi A4 Quattro 2.0T was out with my son, and came back with a check engine light.
Upon logging the HEX-NET and my iPhone into the same wireless network in infrastructure mode, I found that the HEX-NET could ONLY read non engine related data. Attempting to read OBDII yielded a # 33 Time out Error after three tries at obtaining the data. The DTCs could not be erased and I have no idea what DTCs there in reality are since Common sensors in the range from 01-Engine to 03-ABS cannot be read. Running a full diagnostic yields results starting with 08-Auto HVAC to the end of the scan. I tried everything short of disconnecting the A4's battery, because I don't know where the zRadio Code is.
This is the only Audi running now out of three while the two others are waiting for parts. I would like to find out what is throwing the OBDII check engine code.
Here is the last scan, THE ENTIRE SCAN...in reviewing all of the past scans that were still available, I realized that the HEX-NET has not been reading any OBDII data:
VCDS Mobile 0.4341.0.4
VIN: WAUAF78E48A1.....
Chassis Type:8E
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Part No SW: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000 000
VCID: 6D9D5AB72C63FF8B4345B30F79-5160
No fault codes found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No SW: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 00003
Shop #: WSC 06335 000
VCID: 3D3DAAF73C83AF0BB365A3CFE9-4B00
30-00 - Open or Short to Plus
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No SW: 8E0 953 549 Q
Component: Lenksäulenmodul 0801
Coding: 02141
VCID: 41C5D607407BCBEBD78DCF1FA5-4B00
Address 17: Instruments Labels: 8E-17.clb
Part No SW: 8E0 920 951 N HW: 8E0920951N
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial Number: 00000000000000
Coding: 0022268
Shop #: WSC 08201 444 85739
VCID: 352DB2D704B3674B7B154B6F41-5184
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No SW: 8E0 959 433 CP
Component: Komfortgerät T7B 4336
Coding: 11820
VCID: 8145960780FB8BEB170D8F1F65-4B00
Subsystem 1 - Part No SW: 8E1-959-801-G
Component: Türsteuer.FS BRM 0706
35-00 - -
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
35-00 - -
00913 - Window Regulator Switch; Front Right Driver (E81)
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8E0 035 195 AF HW: 8E0035195AF
Component: R Symphony2+ H01 0270
Revision: 00H01000 Serial Number: AUZ1Z4G6904208
Coding: 0210012
Shop #: WSC 06335 000 00000
VCID: 6B9954AF1277E2BB5D319D1787-5160
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0907273A
Component: Reifendruck 3 H04 0130
Coding: 0062121
Shop #: WSC 06435 000 00000
VCID: 2A1791ABDD0D3BB3E6A7D0EBD0-5160
01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
