Results 1 to 8 of 8
Thread: Unstable admap database accross RT software versions- why does this happen?
    I've raised this matter in the past, but I remain intrigued (and it's a little bit annoying) that VCDS appears to drop adaptation channels between SW versions - only for some (all?) seemingly lost channels to subsequently reappear in later releases (and other channels to be lost).
    I'm not sure how widespread this issue is among different VAG vehicles, but it's certainly apparent in my mk7 Golf (and it's a repeatable phenomenon in other mk7's) and I suspect that it's prevalent across MQB platform vehicles.
    So here's an example in which I was recently involved where a local forum member was unable to complete the auto rain-close tweak. In a remarkable coincidence, the forum member's BCM was exactly the same as in my car as follows:
    forum member - BCM
    SW:5Q0-937-084-N   HW:5Q0-937-084-N ---  Cent. Elect. --- SA: 03147,,,,
    ;Component:BCM MQBAB M   H14 0106, Coding:03000842C241027B0FA44080B1040328100A000000000000000000000000,,,
    ;EV_BCMCONTI,10001,EV_BCMBOSCH_010.rod,,
    ;Thursday,29,June,2017,08:31:39:20275
    ;VCDS Version: Beta 17.6.0 (x64)  Data version: 20170602 DS274
    DV52 - BCM
    SW:5Q0-937-084-N   HW:5Q0-937-084-N ---  Cent. Elect. --- SA: 31347
    ;Component:BCM MQBAB M   H14 0106, Coding:03001842C24102FB0FA4400000040308100A000000000000000000000000
    ;EV_BCMCONTI,010001,EV_BCMBOSCH_010.rod
    ;Friday,30,June,2017,18:20:07:16808
    Both of us made an admap of our BCMs using the Beta 17.6.0 (x64) version software and I confirmed that the database contents for the channel descriptors in both files was identical (not surprising!)
    I then compared the ver 17.6.0 database to the records in an admap that I had previously made using release ver 16.8.0.
    Using MS Access for the comparison exercise, I found that:
    1. ver 17.6.0 software had lost 68 x old adaptation channels that were previously listed in ver 16.8.0 admap
    2. ver 17.6.0 software had 78 x new adaptation channels that were not previously in ver 16.8.0 admap.
    3. many (all?) of these "new" adaptation channels could be found in admaps that I had made in much earlier SW versions (i.e. past channel descriptors that had leading bracketed numbers) - so these channels were not "new" - but rather, they were channels that ver 16.8.0 had lost
    Here's the list of those adaptation channels that appeared in the BCM admap using version 16.8.0 BUT do not appear in the BCM admap using Beta version 17.6.0:
    ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung
    ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1
    IDE01268-ENG02321-Windshield wiper-Tippendes_Frontwaschen
    IDE01268-ENG02322-Windshield wiper-Frontwischer_Abtauposition
    IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant
    IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl
    IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl
    IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1
    IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2
    IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen
    IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken
    IDE04924-ENG126816-Driving light and parking light-Standlicht aus
    IDE04927-ENG126845-Window heater-FSH Automatik
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel
    IDE05142-ENG02314-Access control-Heckfreigabe_Ohne_Verzoegerung
    IDE05142-ENG02315-Access control-Deaktivierung_Laderaumschliessung_extern
    IDE05142-ENG02316-Access control-LS_Taster_Togglefunktion
    IDE05142-ENG02317-Access control-Nutzfahrzeug_Schliessung
    IDE05142-ENG02318-Access control-Wiederverriegelung_Laderaum
    IDE05142-ENG06090-Access control-Mindestbetaetigung_HDF_Innentaster
    IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster
    IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein
    IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden
    IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang
    IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe
    IDE07470-ENG02308-After-run for park light-Bedingungen zur Standlichtbegrenzung
    IDE07470-ENG02309-After-run for park light-Bedingungen zur Parklichtbegrenzung
    IDE07470-ENG02310-After-run for park light-Faktor fuer Verfgbarkeitstimer
    IDE07470-ENG02311-After-run for park light-Standlicht-Verfgbarkeit
    IDE08542-ENG02339-Access control 2-Spiegelanklappen_bei_Wiederverriegelung
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus
    IDE08542-ENG125656-Access control 2-Regenschliessen_art
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar
    IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel
    IDE08542-ENG128459-Access control 2-easycloselight_aktiv
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe
    IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig
    IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach
    IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken
    IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken
    IDE10298-Alternating park position 1
    IDE10299-Alternating park position 2
    MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement
    MAS01490-ENG116830-Energy management-Energy_Management_Adaptation
    MAS05934-ENG02319-Convert. top oper.-Remote Lock Unlock Timer s1
    MAS05934-ENG02320-Convert. top oper.-Remote Lock Unlock Timer s3
    MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen
    MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein[TABLE]
    And here's the list of those adaptation channels that appeared in ver 17.6.0 BUT do not appear in Beta version 16.8.0:
    ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute
    ENG116832-ENG122996-Wischgeschwindigkeiten-Dauerwischen Stufe 1 Zyklen pro Minute
    ENG116832-ENG122997-Wischgeschwindigkeiten-Dauerwischen Stufe 2 Zyklen pro Minute
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6
    ENG117283-Frontwaschfunktion
    ENG122926-RLS_wiper_position_parking
    ENG122927-RLS_close_glazing
    ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on
    ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off
    ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on
    ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off
    ENG122929-RLS_LIN_Communication
    ENG122930-RLS_tunel_gateway_recognize
    ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high
    ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low
    ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle
    ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht
    ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day
    ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn
    ENG122933-error_mask
    ENG122934-erase_error_table
    ENG122935-RLS_Washer_Front
    ENG148505-ENG100480-InnenbeleuchtungKL 58xs min-Y2
    ENG148505-ENG100773-InnenbeleuchtungKL 58xs min-Y3
    ENG148505-ENG101574-InnenbeleuchtungKL 58xs min-X1
    ENG148505-ENG102140-InnenbeleuchtungKL 58xs min-X3
    ENG148505-ENG115658-InnenbeleuchtungKL 58xs min-x0
    ENG148505-ENG115659-InnenbeleuchtungKL 58xs min-y0
    ENG148505-ENG99557-InnenbeleuchtungKL 58xs min-X2
    ENG148505-ENG99777-InnenbeleuchtungKL 58xs min-Y1
    IDE00001-ENG112304-Production mode-Heckwischer
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung
    IDE00001-ENG115731-Production mode-Virtuel_pedal
    IDE00001-ENG116710-Production mode-Frontwischer deaktivieren
    IDE00001-ENG98647-Production mode-Interior lighting
    IDE00001-ENG99061-Production mode-Access control
    IDE00820-Activating and deactivating all development messages
    IDE02152-Characteristics in production mode
    IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel
    IDE04924-ENG148888-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus
    IDE04927-ENG116708-Window heater-Abschalttemperatur fr Heckscheibenheizung
    IDE04927-ENG116709-Window heater-Abschalttemperatur fr Frontscheibenheizung
    IDE04928-ENG148904-Anti-theft device-šberwachung Innenentriegelungshebel
    IDE05142-ENG115722-Access control-Electrical rear lid
    IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung
    IDE05145-ENG116062-Light configuration-Lasttyp 10
    IDE05145-ENG116100-Light configuration-Lasttyp 12
    IDE05145-ENG116119-Light configuration-Lasttyp 13
    IDE05145-ENG116176-Light configuration-Lasttyp 16
    IDE05145-ENG116214-Light configuration-Lasttyp 18
    IDE05145-ENG116309-Light configuration-Lasttyp 23
    IDE05145-ENG116347-Light configuration-Lasttyp 25
    IDE05145-ENG116366-Light configuration-Lasttyp 26
    IDE05145-ENG116423-Light configuration-Lasttyp 29
    IDE05145-ENG116461-Light configuration-Lasttyp 31
    IDE05145-ENG116518-Light configuration-Lasttyp 34
    IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung
    IDE07007-ENG148876-A/C heater function via remote control-RemoteStart Betrieb Dauer
    IDE07007-ENG148891-A/C heater function via remote control-Anzahl zulaessiger Remotestarts
    IDE08542-ENG115671-Access control 2-Regenschlieáen
    IDE08787-ENG148893-Auxiliary functions-Menuesteuerung Garagentoroeffner
    IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken
    MAS01471-lower stop
    MAS01472-upper stop
    MAS01490-Energy management
    With the greater emphasis on adaptation channels in MQB vehicles (to the extent now that some newer modules have all their code-string software switches transferred to channels), the propensity for the channel database to be not stable across SW versions is becoming quite problematic.
    Is this a continuing dynamic that is fundamental to the nature of VCDS - or can it be addressed?
    VW Golf MkVII (103TSI) my13
    Do you get any different amount of channels, with or without SA ?
    In the snip you show from "forum member", he used SA 03147.
    NEtech: good point! Yes, I do get a different channel count:
    • ver 17.6.0 admap with SA = 1797
    • ver 17.6.0 admap without SA = 1757
    But you have been able to explain some of the difference between the two SW version admaps because my earlier ver 16.8.0 admap was made without a SA (its channel count was 1787). So I repeated the exercise by comparing admaps without SA (i.e. comparing apples with apples)
    Nevertheless the basic underlying problem is still evident as the following tables suggest:
    Admap channels in ver 17.6.0 BUT not in ver 16.8.0 (channel count=38) - no SA
    IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung
    IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung
    IDE04928-ENG148904-Anti-theft device-Überwachung Innenentriegelungshebel
    IDE08542-ENG115671-Access control 2-Regenschließen
    MAS01471-lower stop
    MAS01472-upper stop
    Admap channels in ver 16.8.0 BUT not in ver 17.6.0 (channel count =68) - no SA
    IDE07470-ENG02310-After-run for park light-Faktor fuer Verfügbarkeitstimer
    IDE07470-ENG02311-After-run for park light-Standlicht-Verfügbarkeit
    So - a little better (thank you for gently pointing out my faux pas), but alas the underlying problem is still evident.
    Whilst I am a little concerned that this issue has not been mentioned by any one else, I am embolden in my assertion by the fact that both my ver 17.6.0 admap and the admap of the "forum member" are both missing two of the auto rain-close tweak channels (and my table above suggests that its missing a further 66 x channels).
    Thanks again for taking the time to respond - genuinely appreciated!
  4. Likes NEtech, PetrolDave liked this post
    Since this isn't actually HEX-NET related, I've split these messages into their own thread from this one in the HEX-NET support section.
    Differences between 16.8.0 and later versions are expected. Prior to 16.8.1, we were using the latest version of source data for a root ASAM ID without regard to versioning specified in the ASAM ID from the module. As of 16.8.1, we started to take said versioning into account.
    In principle, if there are channels that were defined in 16.8.0 (and earlier) for a specific module that aren't defined in later versions, that should mean they aren't defined in the version-specific source data we have access to. To verify that (for example) the Regenschliessen channels for this BCM are not in the source data will require manually digging into that data, something that isn't likely to happen until after the Independence Day break...
  6. Likes DV52 liked this post
    I've procured this module and wired it on our test bench, then told ODIS we were diagnosing Helen's 8V A3 (since it can be installed on such a car). Here's the up-to-date ODIS adaptation map:
    Version number: B41_4_0_3-20170529
    Release: 4.1.4
    Diagnostic kernel: 310.6.5 (Volkswagen AG)
    MCD: 3.0.0
    ECF: 31.1.0 (20161207)
    PDU-API: 9.0.0
    VIN:
    Manufacturer: Audi
    Model: Audi A3 USA/CDN 2015>
    Model year: 2015 (F)
    Version: (value not available)
    Engine code: (value not available)
    Trip odometer: -2
    MCD project: AU37X
    MCD project version: 31053.2.316
    ECU: 0009 - Central Electrics
     11.07.2017 16:41:29
    LL_CentrElectUDS (EV_BCMMQB / 010019)
    Master - 001 Identification
    11.07.2017 16:41:29 Top^
    System description	BCM MQBAB M
    SoftwareVersion	0106
    HardwareVersion	H14
    VW/Audi part number	5Q0937084N
    Hardware part number	5Q0937084N
    Coding	0B 00 08 42 C2 C1 00 5B 0B A4 40 00 B1 04 03 08 10 08 00 00 00 00 00 00 00 00 00 00 00 00
    ASAM/ODX file identification	EV_BCMCONTI
    ASAM/ODX file version	010001
    Master - 007 Read adaptation
    [VO]_Innenbeleuchtung Fotosensor [$0513]:
    [LO]_x0:	0
    [LO]_x1:	50
    [LO]_x2:	100
    [LO]_x3:	200
    [LO]_x4:	253
    [LO]_x5:	0
    [LO]_x6:	0
    [LO]_x7:	0
    [LO]_x8:	0
    [LO]_x9:	0
    [LO]_x10:	0
    [LO]_y0:	0 lx
    [LO]_y1:	50 lx
    [LO]_y2:	100 lx
    [LO]_y3:	200 lx
    [LO]_y4:	500 lx
    [LO]_y5:	0 lx
    [LO]_y6:	0 lx
    [LO]_y7:	0 lx
    [LO]_y8:	0 lx
    [LO]_y9:	0 lx
    [LO]_y10:	0 lx
    After-run for park light [$0D13]:
    [LO]_Bedingungen zur Beendigung des Standlichtnachlaufs:	not active
    [LO]_Standlicht-Nachlaufzeit:	1.0 min
    [VO]_Leuchte27NSL RC6 [$056B]:
    [LO]_Lasttyp 27:	not active
    [LO]_Lampendefektbitposition 27:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 27:	0
    [LO]_Lichtfunktion A 27:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 27:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 27:	0
    [LO]_Lichtansteuerung HD AB 27:	[VO]_always
    [LO]_Lichtfunktion C 27:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 27:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 27:	0
    [LO]_Dimming Direction CD 27:	[VO]_maximize
    [LO]_Lichtfunktion E 27:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 27:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 27:	0
    [LO]_Dimming Direction EF 27:	[VO]_maximize
    [LO]_Lichtfunktion G 27:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 27:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 27:	0
    [LO]_Dimming Direction GH 27:	[VO]_maximize
    [VO]_RLS_wiper_position_parking [$1525]:
    Function not available (SID:$22 NRC:$31)
    lower turn position [$0D18]:
    Function cancelled, subsystem does not respond (SID:$22 NRC:$25)
    [VO]_Leuchte24SL HRA65 [$0568]:
    [LO]_Lasttyp 24:	[VO]_18 - 2* 5W
    [LO]_Lampendefektbitposition 24:	1A
    [LO]_Fehlerort mittleres Byte DTC-DFCC 24:	2A
    [LO]_Lichtfunktion A 24:	[VO]_Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
    [LO]_Lichtfunktion B 24:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 24:	100
    [LO]_Lichtansteuerung HD AB 24:	[VO]_only_if_closed
    [LO]_Lichtfunktion C 24:	[VO]_Coming Home oder Leaving Home aktiv
    [LO]_Lichtfunktion D 24:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 24:	100
    [LO]_Dimming Direction CD 24:	[VO]_maximize
    [LO]_Lichtfunktion E 24:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 24:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 24:	0
    [LO]_Dimming Direction EF 24:	[VO]_maximize
    [LO]_Lichtfunktion G 24:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 24:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 24:	0
    [LO]_Dimming Direction GH 24:	[VO]_maximize
    Rear Window Wiper [$0D20]:
    [LO]_Komfortwischen Heck:	active
    [LO]_Menuesteuerung Komfortwischen HW:	not active
    [LO]_Automatisches Heckwischen:	not active
    [LO]_Traenenwischen Heck:	active
    [LO]_Heckwischer Weiterlauf:	not active
    [LO]_Kein automatisches Abparken:	not active
    [LO]_Komofortwischen Heck Intervallpausenzeit Stufe Intervall:	7 s
    [LO]_Komofortwischen Heck Intervallpausenzeit Stufe Automatik:	7 s
    [LO]_Komofortwischen Heck Intervallpausenzeit Stufe 1:	5 s
    [LO]_Komofortwischen Heck Intervallpausenzeit Stufe 2:	3 s
    [VO]_Leuchten14AL LB6 [$055E]:
    [LO]_Lasttyp 14:	not active
    [LO]_Lampendefektbitposition 14:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 14:	0
    [LO]_Lichtfunktion A 14:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 14:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 14:	0
    [LO]_Lichtansteuerung HD AB 14:	[VO]_always
    [LO]_Lichtfunktion C 14:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 14:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 14:	0
    [LO]_Dimming Direction CD 14:	[VO]_maximize
    [LO]_Lichtfunktion E 14:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 14:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 14:	0
    [LO]_Dimming Direction EF 14:	[VO]_maximize
    [LO]_Lichtfunktion G 14:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 14:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 14:	0
    [LO]_Dimming Direction GH 14:	[VO]_maximize
    [VO]_Wischgeschwindigkeiten [$1506]:
    DWA Vehicle inclination sensor [$0D1B]:
    A/C heater function via remote control [$0D0F]:
    [LO]_Anzahl zulaessiger Remotestarts:	2
    [LO]_RemoteStart Betrieb Dauer:	10 min
    Country coding [$15AF]:
    Roller test bench mode, functional [$04FB]:
    --no display--:	not active
    Comfort illumination [$0D04]:
    [LO]_Coming Home Verbaustatus:	Manual
    [LO]_Menuesteuerung Coming Home Werkseinstellung:	active
    [LO]_Menueeinstellung Cominghome:	30 seconds
    [LO]_Coming home Leuchten:	Low beam
    [LO]_Coming-home Einschaltereignis:	[VO]_driver door
    [LO]_Helligkeitsschwelle Infrarot-Messung:	0
    [LO]_Leaving-Home Verbausstatus:	not enabled
    [LO]_Menuesteuerung Leaving-home Freischaltung per BAP:	not active
    [LO]_Menueeinstellung Leaving-home Zeit per BAP:	not active
    [LO]_Helligkeitsschwelle Forward-Messung:	0
    [VO]_Leuchte2SL VLB10 [$0552]:
    [LO]_Lasttyp 2:	not active
    [LO]_Lampendefektbitposition 2:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 2:	0
    [LO]_Lichtfunktion A 2:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 2:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 2:	0
    [LO]_Lichtansteuerung HD AB 2:	[VO]_always
    [LO]_Lichtfunktion C 2:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 2:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 2:	0
    [LO]_Dimming Direction CD 2:	[VO]_maximize
    [LO]_Lichtfunktion E 2:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 2:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 2:	0
    [LO]_Dimming Direction EF 2:	[VO]_maximize
    [LO]_Lichtfunktion G 2:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 2:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 2:	0
    [LO]_Dimming Direction GH 2:	[VO]_maximize
    [VO]_Leuchte26NSL LA72 [$056A]:
    [LO]_Lasttyp 26:	not active
    [LO]_Lampendefektbitposition 26:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 26:	0
    [LO]_Lichtfunktion A 26:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 26:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 26:	0
    [LO]_Lichtansteuerung HD AB 26:	[VO]_always
    [LO]_Lichtfunktion C 26:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 26:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 26:	0
    [LO]_Dimming Direction CD 26:	[VO]_maximize
    [LO]_Lichtfunktion E 26:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 26:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 26:	0
    [LO]_Dimming Direction EF 26:	[VO]_maximize
    [LO]_Lichtfunktion G 26:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 26:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 26:	0
    [LO]_Dimming Direction GH 26:	[VO]_maximize
    [VO]_Innenbeleuchtung Tasterdimmung [$0510]:
    [LO]_tasterdimmung x0:	0 ms
    [LO]_tasterdimmung x1:	2,000 ms
    [LO]_tasterdimmung x2:	3,000 ms
    [LO]_tasterdimmung x3:	4,000 ms
    [LO]_tasterdimmung x4:	5,100 ms
    [LO]_tasterdimmung y0:	1.0 %
    [LO]_tasterdimmung y1:	5.0
    [LO]_tasterdimmung y2:	15.0
    [LO]_tasterdimmung y3:	40.0
    [LO]_tasterdimmung y4:	100.0
    [VO]_erase_error_table [$1509]:
    [VO]_Innenbeleuchtung KL 58xt max [$0517]:
    [LO]_x0:	0 lx
    [LO]_x1:	8 lx
    [LO]_x2:	50 lx
    [LO]_x3:	500 lx
    [LO]_y0:	100.0 %
    [LO]_y1:	100.0 %
    [LO]_y2:	100.0 %
    [LO]_y3:	100.0 %
    [VO]_Leuchte 0 BLK VL B36 [$0550]:
    [LO]_Lasttyp 0:	[VO]_12 - Blinkleuchten
    [LO]_Lampendefektbit Position 0:	34
    [LO]_Fehlerort mittleres Byte DTC-DFCC 0:	14
    [LO]_Lichtfunktion A 0:	[VO]_Blinken links Hellphase
    [LO]_Lichtfunktion B 0:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 0:	100
    [LO]_Lichtansteuerung HD AB 0:	[VO]_always
    [LO]_Lichtfunktion C 0:	[VO]_Blinken links Dunkelphase
    [LO]_Lichtfunktion D 0:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 0:	0
    [LO]_Dimming Direction CD 0:	[VO]_maximize
    [LO]_Lichtfunktion E 0:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 0:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 0:	0
    [LO]_Dimming Direction EF 0:	[VO]_maximize
    [LO]_Lichtfunktion G 0:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 0:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 0:	0
    [LO]_Dimming Direction GH 0:	[VO]_maximize
    upper stop [$0D15]:
    Writing parameter [$0D09]:
    GFA key [$00BD]:
    GFA key:
    [VO]_Leuchte29RFL RA64 [$056D]:
    [LO]_Lasttyp 29:	[VO]_9 - allgemeine Glühlampe 27W, auch H15
    [LO]_Lampendefektbitposition 29:	1C
    [LO]_Fehlerort mittleres Byte DTC-DFCC 29:	33
    [LO]_Lichtfunktion A 29:	[VO]_Nebelschlusslicht wenn kein Anhaenger gesteckt
    [LO]_Lichtfunktion B 29:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 29:	100
    [LO]_Lichtansteuerung HD AB 29:	[VO]_only_if_closed
    [LO]_Lichtfunktion C 29:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 29:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 29:	0
    [LO]_Dimming Direction CD 29:	[VO]_maximize
    [LO]_Lichtfunktion E 29:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 29:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 29:	0
    [LO]_Dimming Direction EF 29:	[VO]_maximize
    [LO]_Lichtfunktion G 29:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 29:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 29:	0
    [LO]_Dimming Direction GH 29:	[VO]_maximize
    Driving light and parking light [$0D01]:
    [LO]_Kontrollleuchte fuer Begrenzungslicht:	[VO]_integriert in Suchbeleuchtung
    [LO]_Schlusslicht mit Bremslichtfunktion:	not active
    [LO]_Standlicht aus bei LDS=ABL und S-Kontakt aus:	active
    [LO]_Parklicht ueber LSS aktiviert:	One-sided
    [LO]_Standlichtreduzierung mit beidseitigem Parklicht:	active
    [LO]_Zahl der aktiven Scheinwerfer auf 2 limitieren:	not active
    [LO]_Warnung Fahrt mit Standlicht:	not active
    [LO]_Zeitwert Einschaltzeit Abbiegelicht:	15 min
    [LO]_Lichthupe bei Zuendung aus moeglich:	active
    [LO]_Lichtwarnungsverhalten:	[VO]_klemmenabhaengig
    [LO]_Menueeinstellung CHO LHO:	[VO]_Menuesteuerung Zeit aktivieren
    [LO]_Allwetterlicht Einschaltgrenze:	0 km/h
    [LO]_Allwetterlicht Ausschaltgrenze:	0 km/h
    [LO]_Nebelschlusslicht Warngeschwindigkeit:	0 km/h
    [VO]_Leuchte4TFL LB4 [$0554]:
    [LO]_Lasttyp 4:	[VO]_9 - allgemeine Glühlampe 27W, auch H15
    [LO]_Lampendefektbitposition 4:	48
    [LO]_Fehlerort mittleres Byte DTC-DFCC 4:	20
    [LO]_Lichtfunktion A 4:	[VO]_Tagfahrlicht
    [LO]_Lichtfunktion B 4:	[VO]_Coming Home oder Leaving Home aktiv
    [LO]_Dimmwert AB 4:	100
    [LO]_Lichtansteuerung HD AB 4:	[VO]_always
    [LO]_Lichtfunktion C 4:	[VO]_Standlicht vorn (Positionslicht, Begrenzungslicht)
    [LO]_Lichtfunktion D 4:	[VO]_Parklicht links (beidseitiges Parklicht aktiviert li & re)
    [LO]_Dimmwert CD 4:	35
    [LO]_Dimming Direction CD 4:	[VO]_maximize
    [LO]_Lichtfunktion E 4:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 4:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 4:	0
    [LO]_Dimming Direction EF 4:	[VO]_maximize
    [LO]_Lichtfunktion G 4:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 4:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 4:	0
    [LO]_Dimming Direction GH 4:	[VO]_maximize
    Interior lighting [$0D03]:
    [LO]_Menuesteuerung Ambientebeleuchtung Effektbeleuchtung:	not active
    [LO]_Innenlicht bei offenem Heckdeckel einschalten:	active
    [LO]_KL30G ohne PWM:	not active
    [LO]_KL58 Einschalten mit Rampe:	not active
    [LO]_KL58 Verriegelungsausschalten:	not active
    [LO]_Lichtsensor wirkt auf Suchbeleuchtung:	active
    [LO]_Suchbeleuchtung Festwert:	100 %
    [VO]_Leuchte3SL VRB21 [$0553]:
    [LO]_Lasttyp 3:	not active
    [LO]_Lampendefektbitposition 3:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 3:	0
    [LO]_Lichtfunktion A 3:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 3:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 3:	0
    [LO]_Lichtansteuerung HD AB 3:	[VO]_always
    [LO]_Lichtfunktion C 3:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 3:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 3:	0
    [LO]_Dimming Direction CD 3:	[VO]_maximize
    [LO]_Lichtfunktion E 3:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 3:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 3:	0
    [LO]_Dimming Direction EF 3:	[VO]_maximize
    [LO]_Lichtfunktion G 3:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 3:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 3:	0
    [LO]_Dimming Direction GH 3:	[VO]_maximize
    [VO]_Leuchte7ABL RB1 [$0557]:
    [LO]_Lasttyp 7:	[VO]_11 - Abblendlicht
    [LO]_Lampendefektbitposition 7:	40
    [LO]_Fehlerort mittleres Byte DTC-DFCC 7:	1B
    [LO]_Lichtfunktion A 7:	[VO]_Abblendlicht rechts
    [LO]_Lichtfunktion B 7:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 7:	100
    [LO]_Lichtansteuerung HD AB 7:	[VO]_always
    [LO]_Lichtfunktion C 7:	[VO]_Coming Home oder Leaving Home aktiv
    [LO]_Lichtfunktion D 7:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 7:	0
    [LO]_Dimming Direction CD 7:	[VO]_minimize
    [LO]_Lichtfunktion E 7:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 7:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 7:	0
    [LO]_Dimming Direction EF 7:	[VO]_maximize
    [LO]_Lichtfunktion G 7:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 7:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 7:	0
    [LO]_Dimming Direction GH 7:	[VO]_maximize
    [VO]_Leuchte22BR MA57 [$0566]:
    [LO]_Lasttyp 22:	[VO]_42 - LED dritte Bremsleuchte
    [LO]_Lampendefektbitposition 22:	29
    [LO]_Fehlerort mittleres Byte DTC-DFCC 22:	2C
    [LO]_Lichtfunktion A 22:	[VO]_Bremslicht
    [LO]_Lichtfunktion B 22:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 22:	100
    [LO]_Lichtansteuerung HD AB 22:	[VO]_always
    [LO]_Lichtfunktion C 22:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 22:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 22:	0
    [LO]_Dimming Direction CD 22:	[VO]_maximize
    [LO]_Lichtfunktion E 22:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 22:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 22:	0
    [LO]_Dimming Direction EF 22:	[VO]_maximize
    [LO]_Lichtfunktion G 22:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 22:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 22:	0
    [LO]_Dimming Direction GH 22:	[VO]_maximize
    [VO]_Leuchte28RFL LC11 [$056C]:
    [LO]_Lasttyp 28:	[VO]_9 - allgemeine Glühlampe 27W, auch H15
    [LO]_Lampendefektbitposition 28:	B
    [LO]_Fehlerort mittleres Byte DTC-DFCC 28:	34
    [LO]_Lichtfunktion A 28:	[VO]_Rueckfahrlicht
    [LO]_Lichtfunktion B 28:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 28:	100
    [LO]_Lichtansteuerung HD AB 28:	[VO]_only_if_closed
    [LO]_Lichtfunktion C 28:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 28:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 28:	0
    [LO]_Dimming Direction CD 28:	[VO]_maximize
    [LO]_Lichtfunktion E 28:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 28:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 28:	0
    [LO]_Dimming Direction EF 28:	[VO]_maximize
    [LO]_Lichtfunktion G 28:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 28:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 28:	0
    [LO]_Dimming Direction GH 28:	[VO]_maximize
    [VO]_error_mask [$1508]:
    upper turn position [$0D19]:
    Transport mode [$04FF]:
    [LO]_Funkschluessel:	active
    [VO]_Leuchte21BR RC8 [$0565]:
    [LO]_Lasttyp 21:	[VO]_13 - Bremsleuchten
    [LO]_Lampendefektbitposition 21:	20
    [LO]_Fehlerort mittleres Byte DTC-DFCC 21:	3A
    [LO]_Lichtfunktion A 21:	[VO]_Bremslicht
    [LO]_Lichtfunktion B 21:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 21:	100
    [LO]_Lichtansteuerung HD AB 21:	[VO]_always
    [LO]_Lichtfunktion C 21:	[VO]_Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
    [LO]_Lichtfunktion D 21:	[VO]_Parklicht rechts
    [LO]_Dimmwert CD 21:	25
    [LO]_Dimming Direction CD 21:	[VO]_maximize
    [LO]_Lichtfunktion E 21:	[VO]_Coming Home oder Leaving Home aktiv
    [LO]_Lichtfunktion F 21:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 21:	25
    [LO]_Dimming Direction EF 21:	[VO]_maximize
    [LO]_Lichtfunktion G 21:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 21:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 21:	0
    [LO]_Dimming Direction GH 21:	[VO]_maximize
    [VO]_Leuchte30FR LC72 [$056E]:
    [LO]_Lasttyp 30:	[VO]_18 - 2* 5W
    [LO]_Lampendefektbitposition 30:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 30:	2
    [LO]_Lichtfunktion A 30:	[VO]_Fussraumlicht
    [LO]_Lichtfunktion B 30:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 30:	30
    [LO]_Lichtansteuerung HD AB 30:	[VO]_always
    [LO]_Lichtfunktion C 30:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 30:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 30:	0
    [LO]_Dimming Direction CD 30:	[VO]_maximize
    [LO]_Lichtfunktion E 30:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 30:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 30:	0
    [LO]_Dimming Direction EF 30:	[VO]_maximize
    [LO]_Lichtfunktion G 30:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 30:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 30:	0
    [LO]_Dimming Direction GH 30:	[VO]_maximize
    [VO]_Innenbeleuchtung KL 58xs PWM [$051B]:
    [LO]_x0:	0.0 %
    [LO]_x1:	50.0 %
    [LO]_x2:	100.0 %
    [LO]_y0:	0.0 %
    [LO]_y1:	50.0 %
    [LO]_y2:	100.0 %
    [VO]_Innenbeleuchtung Hochdimmen [$0511]:
    [LO]_x0:	0 ms
    [LO]_x1:	200 ms
    [LO]_x2:	400 ms
    [LO]_x3:	600 ms
    [LO]_x4:	800 ms
    [LO]_x5:	1,000 ms
    [LO]_x6:	1,200 ms
    [LO]_x7:	1,400 ms
    [LO]_x8:	1,600 ms
    [LO]_x9:	1,800 ms
    [LO]_x10:	2,000 ms
    [LO]_y0:	0.0 %
    [LO]_y1:	1.0 %
    [LO]_y2:	3.0 %
    [LO]_y3:	5.0 %
    [LO]_y4:	11.0 %
    [LO]_y5:	22.0 %
    [LO]_y6:	40.0 %
    [LO]_y7:	80.0 %
    [LO]_y8:	95.0 %
    [LO]_y9:	100.0 %
    [LO]_y10:	100.0 %
    Seat heater level current consumption allocation [$0D1E]:
    [LO]_Sitzheizung Stufe 1 untere Schaltschwelle:	0.00 °C
    [LO]_Sitzheizung Stufe 1 obere Schaltschwelle:	0.00 °C
    [LO]_Sitzheizung Stufe 2 untere Schaltschwelle:	0.00 °C
    [LO]_Sitzheizung Stufe 2 obere Schaltschwelle:	0.00 °C
    [LO]_Sitzheizung Stufe 3 untere Schaltschwelle:	0.00 °C
    [LO]_Sitzheizung Stufe 3 obere Schaltschwelle:	0.00 °C
    [LO]_Sitzheizung Stufe 4 untere Schaltschwelle:	0.00 °C
    [LO]_Sitzheizung Stufe 4 obere Schaltschwelle:	0.00 °C
    [LO]_Sitzheizung Stufe 5 untere Schaltschwelle:	0.00 °C
    [LO]_Sitzheizung Stufe 5 obere Schaltschwelle:	0.00 °C
    [LO]_Sitzheizung Stufe 6 untere Schaltschwelle:	0.00 °C
    [LO]_Sitzheizung Stufe 6 obere Schaltschwelle:	0.00 °C
    [LO]_Sitzheizung Filterkonstante fuer Waermefluss:	0 s
    [LO]_Sitzheizung Regeltemperaturkorrektur bei Waermefluss:	1.10 °C
    [VO]_Leuchte11SHUTTER RB22 [$055B]:
    [LO]_Lasttyp 11:	not active
    [LO]_Lampendefektbitposition 11:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 11:	0
    [LO]_Lichtfunktion A 11:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 11:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 11:	0
    [LO]_Lichtansteuerung HD AB 11:	[VO]_always
    [LO]_Lichtfunktion C 11:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 11:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 11:	0
    [LO]_Dimming Direction CD 11:	[VO]_maximize
    [LO]_Lichtfunktion E 11:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 11:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 11:	0
    [LO]_Dimming Direction EF 11:	[VO]_maximize
    [LO]_Lichtfunktion G 11:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 11:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 11:	0
    [LO]_Dimming Direction GH 11:	[VO]_maximize
    [VO]_Leuchte1BLK VRB20 [$0551]:
    [LO]_Lasttyp 1:	[VO]_12 - Blinkleuchten
    [LO]_Lampendefektbitposition 1:	3E
    [LO]_Fehlerort mittleres Byte DTC-DFCC 1:	15
    [LO]_Lichtfunktion A 1:	[VO]_Blinken rechts Hellphase
    [LO]_Lichtfunktion B 1:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 1:	100
    [LO]_Lichtansteuerung HD AB 1:	[VO]_always
    [LO]_Lichtfunktion C 1:	[VO]_Blinken rechts Dunkelphase
    [LO]_Lichtfunktion D 1:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 1:	0
    [LO]_Dimming Direction CD 1:	[VO]_maximize
    [LO]_Lichtfunktion E 1:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 1:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 1:	0
    [LO]_Dimming Direction EF 1:	[VO]_maximize
    [LO]_Lichtfunktion G 1:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 1:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 1:	0
    [LO]_Dimming Direction GH 1:	[VO]_maximize
    [VO]_Leuchte5 TFL RB32 [$0555]:
    [LO]_Lasttyp 5:	[VO]_9 - allgemeine Glühlampe 27W, auch H15
    [LO]_Lampendefektbitposition 5:	4C
    [LO]_Fehlerort mittleres Byte DTC-DFCC 5:	21
    [LO]_Lichtfunktion A 5:	[VO]_Tagfahrlicht
    [LO]_Lichtfunktion B 5:	[VO]_Coming Home oder Leaving Home aktiv
    [LO]_Dimmwert AB 5:	100
    [LO]_Lichtansteuerung HD AB 5:	[VO]_always
    [LO]_Lichtfunktion C 5:	[VO]_Standlicht vorn (Positionslicht, Begrenzungslicht)
    [LO]_Lichtfunktion D 5:	[VO]_Parklicht rechts
    [LO]_Dimmwert CD 5:	35
    [LO]_Dimming Direction CD 5:	[VO]_maximize
    [LO]_Lichtfunktion E 5:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 5:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 5:	0
    [LO]_Dimming Direction EF 5:	[VO]_maximize
    [LO]_Lichtfunktion G 5:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 5:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 5:	0
    [LO]_Dimming Direction GH 5:	[VO]_maximize
    [VO]_Leuchte31AMBL 1C61 [$056F]:
    [LO]_Lasttyp 31:	not active
    [LO]_Lampendefektbitposition 31:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 31:	0
    [LO]_Lichtfunktion A 31:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 31:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 31:	0
    [LO]_Lichtansteuerung HD AB 31:	[VO]_always
    [LO]_Lichtfunktion C 31:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 31:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 31:	0
    [LO]_Dimming Direction CD 31:	[VO]_maximize
    [LO]_Lichtfunktion E 31:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 31:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 31:	0
    [LO]_Dimming Direction EF 31:	[VO]_maximize
    [LO]_Lichtfunktion G 31:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 31:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 31:	0
    [LO]_Dimming Direction GH 31:	[VO]_maximize
    [VO]_RLS_Washer_Front [$1528]:
    [VO]_Leuchte17TFL R BLK SRB3TFL R BLK SR KC3 [$0561]:
    [LO]_Lasttyp 17:	not active
    [LO]_Lampendefektbitposition 17:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 17:	0
    [LO]_Lichtfunktion A 17:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 17:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 17:	0
    [LO]_Lichtansteuerung HD AB 17:	[VO]_always
    [LO]_Lichtfunktion C 17:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 17:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 17:	0
    [LO]_Dimming Direction CD 17:	[VO]_maximize
    [LO]_Lichtfunktion E 17:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 17:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 17:	0
    [LO]_Dimming Direction EF 17:	[VO]_maximize
    [LO]_Lichtfunktion G 17:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 17:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 17:	0
    [LO]_Dimming Direction GH 17:	[VO]_maximize
    [VO]_Leuchte34AMBL 4C37 [$0572]:
    [LO]_Lasttyp 34:	not active
    [LO]_Lampendefektbitposition 34:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 34:	0
    [LO]_Lichtfunktion A 34:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 34:	[VO]_nicht aktiv
    [LO]_Dimmwert AB 34:	0
    [LO]_Lichtansteuerung HD AB 34:	[VO]_always
    [LO]_Lichtfunktion C 34:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 34:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 34:	0
    [LO]_Dimming Direction CD 34:	[VO]_maximize
    [LO]_Lichtfunktion E 34:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 34:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 34:	0
    [LO]_Dimming Direction EF 34:	[VO]_maximize
    [LO]_Lichtfunktion G 34:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 34:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 34:	0
    [LO]_Dimming Direction GH 34:	[VO]_maximize
    [VO]_RLS_lights_for_autobahn [$1527]:
    [VO]_RLS_close_glazing [$1526]:
    [VO]_InnenbeleuchtungKL 58xs min [$0514]:
    [LO]_x0:	0 lx
    [LO]_x1:	8 lx
    [LO]_x2:	50 lx
    [LO]_x3:	510 lx
    [LO]_y0:	10.0 %
    [LO]_y1:	10.0 %
    [LO]_y2:	50.0 %
    [LO]_y3:	50.0 %
    [VO]_Leuchte13NL RB5 [$055D]:
    [LO]_Lasttyp 13:	[VO]_10 - allgemeine Scheinwerfer
    [LO]_Lampendefektbitposition 13:	42
    [LO]_Fehlerort mittleres Byte DTC-DFCC 13:	23
    [LO]_Lichtfunktion A 13:	[VO]_Nebellicht rechts
    [LO]_Lichtfunktion B 13:	[VO]_Abbiegelicht rechts
    [LO]_Dimmwert AB 13:	100
    [LO]_Lichtansteuerung HD AB 13:	[VO]_always
    [LO]_Lichtfunktion C 13:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 13:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 13:	0
    [LO]_Dimming Direction CD 13:	[VO]_maximize
    [LO]_Lichtfunktion E 13:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 13:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 13:	0
    [LO]_Dimming Direction EF 13:	[VO]_maximize
    [LO]_Lichtfunktion G 13:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 13:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 13:	0
    [LO]_Dimming Direction GH 13:	[VO]_maximize
    lower stop [$0D16]:
    Deactivate production mode [$04FC]:
    --no display--:	[VO]_not_active
    DWA Interior monitoring parameter set [$0D1C]:
    [VO]_Leuchte12NL LB45 [$055C]:
    [LO]_Lasttyp 12:	[VO]_10 - allgemeine Scheinwerfer
    [LO]_Lampendefektbitposition 12:	38
    [LO]_Fehlerort mittleres Byte DTC-DFCC 12:	22
    [LO]_Lichtfunktion A 12:	[VO]_Nebellicht links
    [LO]_Lichtfunktion B 12:	[VO]_Abbiegelicht links
    [LO]_Dimmwert AB 12:	100
    [LO]_Lichtansteuerung HD AB 12:	[VO]_always
    [LO]_Lichtfunktion C 12:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 12:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 12:	0
    [LO]_Dimming Direction CD 12:	[VO]_maximize
    [LO]_Lichtfunktion E 12:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 12:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 12:	0
    [LO]_Dimming Direction EF 12:	[VO]_maximize
    [LO]_Lichtfunktion G 12:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 12:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 12:	0
    [LO]_Dimming Direction GH 12:	[VO]_maximize
    [VO]_Innenbeleuchtung Abdimmen [$0512]:
    [LO]_x0:	0 ms
    [LO]_x1:	200 ms
    [LO]_x2:	400 ms
    [LO]_x3:	600 ms
    [LO]_x4:	800 ms
    [LO]_x5:	1,000 ms
    [LO]_x6:	1,200 ms
    [LO]_x7:	1,400 ms
    [LO]_x8:	1,600 ms
    [LO]_x9:	1,800 ms
    [LO]_x10:	2,000 ms
    [LO]_y0:	100.0 %
    [LO]_y1:	100.0 %
    [LO]_y2:	95.0 %
    [LO]_y3:	80.0 %
    [LO]_y4:	40.0 %
    [LO]_y5:	20.0 %
    [LO]_y6:	10.0 %
    [LO]_y7:	5.0 %
    [LO]_y8:	3.0 %
    [LO]_y9:	1.0 %
    [LO]_y10:	0.0 %
    Assistance light functions [$0D0C]:
    [LO]_Notbremsanzeige NBA:	active
    [LO]_Menuesteuerung Fernlichtassistent:	Not present
    [LO]_Fernlichtassistent Zeitverzoegerungswert:	0 ms
    [LO]_Fernlichtassistent Reset:	not active
    [LO]_Menuesteuerung Fernlichtassistent Werkseinstellung:	Not present
    [LO]_Assistenzfahrlicht bei Regen:	active
    [LO]_AFL Zeitverzoegerung:	0 ms
    [LO]_Lichtsensorempfindlichkeit:	[VO]_sensitive
    Ambient lighting [$0D1F]:
    [LO]_Defaultwert Ambienteprofil Fussraum:	30 %
    [LO]_Defaultwert Ambienteprofil Tuer:	100 %
    [LO]_Defaultwert Ambienteprofil Vorn:	100 %
    [LO]_Tuerinnengriffbeleuchtung mit I-Tafel:	not installed
    [LO]_Tuerinnengriff mit Tuertafel:	not installed
    [LO]_Innenlichtinszenierung:	not enabled
    [LO]_Ambientelicht mit raste heckdeckel:	not enabled
    [VO]_Leuchte9FL RB2 [$0559]:
    [LO]_Lasttyp 9:	[VO]_10 - allgemeine Scheinwerfer
    [LO]_Lampendefektbitposition 9:	41
    [LO]_Fehlerort mittleres Byte DTC-DFCC 9:	1D
    [LO]_Lichtfunktion A 9:	[VO]_Fernlicht rechts
    [LO]_Lichtfunktion B 9:	[VO]_Lichthupe generell
    [LO]_Dimmwert AB 9:	100
    [LO]_Lichtansteuerung HD AB 9:	[VO]_always
    [LO]_Lichtfunktion C 9:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 9:	[VO]_nicht aktiv
    [LO]_Dimmwert CD 9:	0
    [LO]_Dimming Direction CD 9:	[VO]_maximize
    [LO]_Lichtfunktion E 9:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 9:	[VO]_nicht aktiv
    [LO]_Dimmwert EF 9:	0
    [LO]_Dimming Direction EF 9:	[VO]_maximize
    [LO]_Lichtfunktion G 9:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 9:	[VO]_nicht aktiv
    [LO]_Dimmwert GH 9:	0
    [LO]_Dimming Direction GH 9:	[VO]_maximize
    [VO]_RLS_LIN_Communication [$1529]:
    Read parameter address [$0D0A]:
    Parameter address:	0
    [VO]_Innenbeleuchtung KL 58xd PWM [$051D]:
    [LO]_x0:	0
    [LO]_x1:	10
    [LO]_x2:	100
    [LO]_x3:	150
    [LO]_x4:	220
    [LO]_x5:	253
    [LO]_y0:	3.0 %
    [LO]_y1:	5.0 %
    [LO]_y2:	15.0 %
    [LO]_y3:	40.0 %
    [LO]_y4:	82.0 %
    [LO]_y5:	100.0 %
    Acknowledgement signals [$0D0E]:
    [LO]_Akustische Rueckmeldung entriegeln:	No
    [LO]_Akustische Rueckmeldung verriegeln:	No
    [LO]_Dauer der Akustischen Rueckmeldung vom Einfachhorn:	normal
    Optical feedback during locking:	Decelerate
    [LO]_Optische Rueckmeldung Komfortschliessen:	active
    [LO]_Optische Rueckmeldung 3.Bremsleuchte:	not active
    [LO]_Menuesteuerung akustische Rueckmeldung:	not active
    [LO]_Akustische Rueckmeldung global:	not active
    [LO]_Akustische Rueckmeldung Signalhorn:	active
    Light configuration [$0D0B]:
    [LO]_BAP Bitposition 0:	34
    [LO]_Reserved 0:	0
    [LO]_Lichtfunktion A 0:	2
    [LO]_Lichtfunktion B 0:	0
    [LO]_Lichtfunktion C 0:	3
    [LO]_Lichtfunktion D 0:	0
    [LO]_Lichtfunktion E 0:	0
    [LO]_Lichtfunktion F 0:	0
    [LO]_Lichtfunktion G 0:	0
    [LO]_Lichtfunktion H 0:	0
    [LO]_BAP Bitposition 1:	3E
    [LO]_Reserved 1:	0
    [LO]_Lichtfunktion A 1:	4
    [LO]_Lichtfunktion B 1:	0
    [LO]_Lichtfunktion C 1:	5
    [LO]_Lichtfunktion D 1:	0
    [LO]_Lichtfunktion E 1:	0
    [LO]_Lichtfunktion F 1:	0
    [LO]_Lichtfunktion G 1:	0
    [LO]_Lichtfunktion H 1:	0
    [LO]_BAP Bitposition 2:	0
    [LO]_Reserved 2:	0
    [LO]_Lichtfunktion A 2:	0
    [LO]_Lichtfunktion B 2:	0
    [LO]_Lichtfunktion C 2:	0
    [LO]_Lichtfunktion D 2:	0
    [LO]_Lichtfunktion E 2:	0
    [LO]_Lichtfunktion F 2:	0
    [LO]_Lichtfunktion G 2:	0
    [LO]_Lichtfunktion H 2:	0
    [LO]_BAP Bitposition 3:	0
    [LO]_Reserved 3:	0
    [LO]_Lichtfunktion A 3:	0
    [LO]_Lichtfunktion B 3:	0
    [LO]_Lichtfunktion C 3:	0
    [LO]_Lichtfunktion D 3:	0
    [LO]_Lichtfunktion E 3:	0
    [LO]_Lichtfunktion F3:	0
    [LO]_Lichtfunktion G 3:	0
    [LO]_Lichtfunktion H 3:	0
    [LO]_BAP Bitposition 4:	48
    [LO]_Reserved 4:	0
    [LO]_Lichtfunktion A 4:	20
    [LO]_Lichtfunktion B 4:	30
    [LO]_Lichtfunktion C 4:	31
    [LO]_Lichtfunktion D 4:	9
    [LO]_Lichtfunktion E 4:	0
    [LO]_Lichtfunktion F 4:	0
    [LO]_Lichtfunktion G 4:	0
    [LO]_Lichtfunktion H 4:	0
    [LO]_BAP Bitposition 5:	4C
    [LO]_Reserved 5:	0
    [LO]_Lichtfunktion A 5:	20
    [LO]_Lichtfunktion B 5:	30
    [LO]_Lichtfunktion C 5:	31
    [LO]_Lichtfunktion D 5:	10
    [LO]_Lichtfunktion E 5:	0
    [LO]_Lichtfunktion F5:	0
    [LO]_Lichtfunktion G 5:	0
    [LO]_Lichtfunktion H 5:	0
    [LO]_Lasttyp 6:	[VO]_11 - Abblendlicht
    [LO]_BAP Bitposition 6:	36
    [LO]_Reserved 6:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 6:	1A
    [LO]_Lichtfunktion A 6:	11
    [LO]_Lichtfunktion B 6:	0
    [LO]_Dimmwert AB 6:	100
    [LO]_Lichtansteuerung HD AB 6:	[VO]_always
    [LO]_Lichtfunktion C 6:	30
    [LO]_Lichtfunktion D 6:	0
    [LO]_Dimmwert CD 6:	0
    [LO]_Dimming Direction CD 6:	[VO]_minimize
    [LO]_Lichtfunktion E 6:	0
    [LO]_Lichtfunktion F 6:	0
    [LO]_Dimmwert EF 6:	0
    [LO]_Dimming Direction EF 6:	[VO]_maximize
    [LO]_Lichtfunktion G 6:	0
    [LO]_Lichtfunktion H 6:	0
    [LO]_Dimmwert GH 6:	0
    [LO]_Dimming Direction GH 6:	[VO]_maximize
    [LO]_BAP Bitposition 7:	40
    [LO]_Reserved 7:	0
    [LO]_Lichtfunktion A 7:	12
    [LO]_Lichtfunktion B 7:	0
    [LO]_Lichtfunktion C 7:	30
    [LO]_Lichtfunktion D 7:	0
    [LO]_Lichtfunktion E 7:	0
    [LO]_Lichtfunktion F 7:	0
    [LO]_Lichtfunktion G 7:	0
    [LO]_Lichtfunktion H 7:	0
    [LO]_Lasttyp 8:	[VO]_10 - allgemeine Scheinwerfer
    [LO]_BAP Bitposition 8:	37
    [LO]_Reserved 8:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 8:	1C
    [LO]_Lichtfunktion A 8:	13
    [LO]_Lichtfunktion B 8:	15
    [LO]_Dimmwert AB 8:	100
    [LO]_Lichtansteuerung HD AB 8:	[VO]_always
    [LO]_Lichtfunktion C 8:	0
    [LO]_Lichtfunktion D 8:	0
    [LO]_Dimmwert CD 8:	0
    [LO]_Dimming Direction CD 8:	[VO]_maximize
    [LO]_Lichtfunktion E 8:	0
    [LO]_Lichtfunktion F 8:	0
    [LO]_Dimmwert EF 8:	0
    [LO]_Dimming Direction EF 8:	[VO]_maximize
    [LO]_Lichtfunktion G 8:	0
    [LO]_Lichtfunktion H 8:	0
    [LO]_Dimmwert GH 8:	0
    [LO]_Dimming Direction GH 8:	[VO]_maximize
    [LO]_BAP Bitposition 9:	41
    [LO]_Reserved 9:	0
    [LO]_Lichtfunktion A 9:	14
    [LO]_Lichtfunktion B 9:	15
    [LO]_Lichtfunktion C 9:	0
    [LO]_Lichtfunktion D 9:	0
    [LO]_Lichtfunktion E 9:	0
    [LO]_Lichtfunktion F 9:	0
    [LO]_Lichtfunktion G 9:	0
    [LO]_Lichtfunktion H 9:	0
    [LO]_Lasttyp 10:	not active
    [LO]_BAP Bitposition 10:	0
    [LO]_Reserved 10:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 10:	0
    [LO]_Lichtfunktion A 10:	0
    [LO]_Lichtfunktion B 10:	0
    [LO]_Dimmwert AB 10:	0
    [LO]_Lichtansteuerung HD AB 10:	[VO]_always
    [LO]_Lichtfunktion C 10:	0
    [LO]_Lichtfunktion D 10:	0
    [LO]_Dimmwert CD 10:	0
    [LO]_Dimming Direction CD 10:	[VO]_maximize
    [LO]_Lichtfunktion E 10:	0
    [LO]_Lichtfunktion F 10:	0
    [LO]_Dimmwert EF 10:	0
    [LO]_Dimming Direction EF 10:	[VO]_maximize
    [LO]_Lichtfunktion G 10:	0
    [LO]_Lichtfunktion H 10:	0
    [LO]_Dimmwert GH 10:	0
    [LO]_Dimming Direction GH 10:	[VO]_maximize
    [LO]_BAP Bitposition 11:	0
    [LO]_Reserved 11:	0
    [LO]_Lichtfunktion A 11:	0
    [LO]_Lichtfunktion B 11:	0
    [LO]_Lichtfunktion C 11:	0
    [LO]_Lichtfunktion D 11:	0
    [LO]_Lichtfunktion E 11:	0
    [LO]_Lichtfunktion F 11:	0
    [LO]_Lichtfunktion G 11:	0
    [LO]_Lichtfunktion H 11:	0
    [LO]_BAP Bitposition 12:	38
    [LO]_Reserved 12:	0
    [LO]_Lichtfunktion A 12:	18
    [LO]_Lichtfunktion B 12:	22
    [LO]_Lichtfunktion C 12:	0
    [LO]_Lichtfunktion D 12:	0
    [LO]_Lichtfunktion E 12:	0
    [LO]_Lichtfunktion F 12:	0
    [LO]_Lichtfunktion G 12:	0
    [LO]_Lichtfunktion H 12:	0
    [LO]_BAP Bitposition 13:	42
    [LO]_Reserved 13:	0
    [LO]_Lichtfunktion A 13:	19
    [LO]_Lichtfunktion B 13:	23
    [LO]_Lichtfunktion C 13:	0
    [LO]_Lichtfunktion D 13:	0
    [LO]_Lichtfunktion E 13:	0
    [LO]_Lichtfunktion F 13:	0
    [LO]_Lichtfunktion G 13:	0
    [LO]_Lichtfunktion H 13:	0
    [LO]_BAP Bitposition 14:	0
    [LO]_Reserved 14:	0
    [LO]_Lichtfunktion A 14:	0
    [LO]_Lichtfunktion B 14:	0
    [LO]_Lichtfunktion C 14:	0
    [LO]_Lichtfunktion D 14:	0
    [LO]_Lichtfunktion E 14:	0
    [LO]_Lichtfunktion F 14:	0
    [LO]_Lichtfunktion G 14:	0
    [LO]_Lichtfunktion H 14:	0
    [LO]_Lasttyp 15:	not active
    [LO]_BAP Bitposition 15:	0
    [LO]_Reserved 15:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 15:	0
    [LO]_Lichtfunktion A 15:	0
    [LO]_Lichtfunktion B 15:	0
    [LO]_Dimmwert AB 15:	0
    [LO]_Lichtansteuerung HD AB 15:	[VO]_always
    [LO]_Lichtfunktion C 15:	0
    [LO]_Lichtfunktion D 15:	0
    [LO]_Dimmwert CD 15:	0
    [LO]_Dimming Direction CD 15:	[VO]_maximize
    [LO]_Lichtfunktion E 15:	0
    [LO]_Lichtfunktion F 15:	0
    [LO]_Dimmwert EF 15:	0
    [LO]_Dimming Direction EF 15:	[VO]_maximize
    [LO]_Lichtfunktion G 15:	0
    [LO]_Lichtfunktion H 15:	0
    [LO]_Dimmwert GH 15:	0
    [LO]_Dimming Direction GH 15:	[VO]_maximize
    [LO]_Lasttyp 16:	not active
    [LO]_BAP Bitposition 16:	0
    [LO]_Reserved 16:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 16:	0
    [LO]_Lichtfunktion A 16:	0
    [LO]_Lichtfunktion B 16:	0
    [LO]_Dimmwert AB 16:	0
    [LO]_Lichtansteuerung HD AB 16:	[VO]_always
    [LO]_Lichtfunktion C 16:	0
    [LO]_Lichtfunktion D 16:	0
    [LO]_Dimmwert CD 16:	0
    [LO]_Dimming Direction CD 16:	[VO]_maximize
    [LO]_Lichtfunktion E 16:	0
    [LO]_Lichtfunktion F 16:	0
    [LO]_Dimmwert EF 16:	0
    [LO]_Dimming Direction EF 16:	[VO]_maximize
    [LO]_Lichtfunktion G 16:	0
    [LO]_Lichtfunktion H 16:	0
    [LO]_Dimmwert GH 16:	0
    [LO]_Dimming Direction GH 16:	[VO]_maximize
    [LO]_BAP Bitposition 17:	0
    [LO]_Reserved 17:	0
    [LO]_Lichtfunktion A 17:	0
    [LO]_Lichtfunktion B 17:	0
    [LO]_Lichtfunktion C 17:	0
    [LO]_Lichtfunktion D 17:	0
    [LO]_Lichtfunktion E 17:	0
    [LO]_Lichtfunktion F 17:	0
    [LO]_Lichtfunktion G 17:	0
    [LO]_Lichtfunktion H 17:	0
    [LO]_Lasttyp 18:	[VO]_12 - Blinkleuchten
    [LO]_BAP Bitposition 18:	8
    [LO]_Reserved 18:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 18:	16
    [LO]_Lichtfunktion A 18:	2
    [LO]_Lichtfunktion B 18:	0
    [LO]_Dimmwert AB 18:	100
    [LO]_Lichtansteuerung HD AB 18:	[VO]_always
    [LO]_Lichtfunktion C 18:	3
    [LO]_Lichtfunktion D 18:	0
    [LO]_Dimmwert CD 18:	0
    [LO]_Dimming Direction CD 18:	[VO]_maximize
    [LO]_Lichtfunktion E 18:	0
    [LO]_Lichtfunktion F 18:	0
    [LO]_Dimmwert EF 18:	0
    [LO]_Dimming Direction EF 18:	[VO]_maximize
    [LO]_Lichtfunktion G 18:	0
    [LO]_Lichtfunktion H 18:	0
    [LO]_Dimmwert GH 18:	0
    [LO]_Dimming Direction GH 18:	[VO]_maximize
    [LO]_Lasttyp 19:	[VO]_12 - Blinkleuchten
    [LO]_BAP Bitposition 19:	18
    [LO]_Reserved 19:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 19:	18
    [LO]_Lichtfunktion A 19:	4
    [LO]_Lichtfunktion B 19:	0
    [LO]_Dimmwert AB 19:	100
    [LO]_Lichtansteuerung HD AB 19:	[VO]_always
    [LO]_Lichtfunktion C 19:	5
    [LO]_Lichtfunktion D 19:	0
    [LO]_Dimmwert CD 19:	0
    [LO]_Dimming Direction CD 19:	[VO]_maximize
    [LO]_Lichtfunktion E 19:	0
    [LO]_Lichtfunktion F 19:	0
    [LO]_Dimmwert EF 19:	0
    [LO]_Dimming Direction EF 19:	[VO]_maximize
    [LO]_Lichtfunktion G 19:	0
    [LO]_Lichtfunktion H 19:	0
    [LO]_Dimmwert GH 19:	0
    [LO]_Dimming Direction GH 19:	[VO]_maximize
    [LO]_Lasttyp 20:	[VO]_13 - Bremsleuchten
    [LO]_BAP Bitposition 20:	10
    [LO]_Reserved 20:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 20:	39
    [LO]_Lichtfunktion A 20:	24
    [LO]_Lichtfunktion B 20:	0
    [LO]_Dimmwert AB 20:	100
    [LO]_Lichtansteuerung HD AB 20:	[VO]_always
    [LO]_Lichtfunktion C 20:	8
    [LO]_Lichtfunktion D 20:	9
    [LO]_Dimmwert CD 20:	25
    [LO]_Dimming Direction CD 20:	[VO]_maximize
    [LO]_Lichtfunktion E 20:	30
    [LO]_Lichtfunktion F 20:	0
    [LO]_Dimmwert EF 20:	25
    [LO]_Dimming Direction EF 20:	[VO]_maximize
    [LO]_Lichtfunktion G 20:	0
    [LO]_Lichtfunktion H 20:	0
    [LO]_Dimmwert GH 20:	0
    [LO]_Dimming Direction GH 20:	[VO]_maximize
    [LO]_BAP Bitposition 21:	20
    [LO]_Reserved 21:	0
    [LO]_Lichtfunktion A 21:	24
    [LO]_Lichtfunktion B 21:	0
    [LO]_Lichtfunktion C 21:	8
    [LO]_Lichtfunktion D 21:	10
    [LO]_Lichtfunktion E 21:	30
    [LO]_Lichtfunktion F 21:	0
    [LO]_Lichtfunktion G 21:	0
    [LO]_Lichtfunktion H 21:	0
    [LO]_BAP Bitposition 22:	29
    [LO]_Reserved 22:	0
    [LO]_Lichtfunktion A 22:	24
    [LO]_Lichtfunktion B 22:	0
    [LO]_Lichtfunktion C 22:	0
    [LO]_Lichtfunktion D 22:	0
    [LO]_Lichtfunktion E 22:	0
    [LO]_Lichtfunktion F 22:	0
    [LO]_Lichtfunktion G 22:	0
    [LO]_Lichtfunktion H 22:	0
    [LO]_Lasttyp 23:	[VO]_18 - 2* 5W
    [LO]_BAP Bitposition 23:	A
    [LO]_Reserved 23:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 23:	29
    [LO]_Lichtfunktion A 23:	8
    [LO]_Lichtfunktion B 23:	0
    [LO]_Dimmwert AB 23:	100
    [LO]_Lichtansteuerung HD AB 23:	[VO]_only_if_closed
    [LO]_Lichtfunktion C 23:	30
    [LO]_Lichtfunktion D 23:	0
    [LO]_Dimmwert CD 23:	100
    [LO]_Dimming Direction CD 23:	[VO]_maximize
    [LO]_Lichtfunktion E 23:	0
    [LO]_Lichtfunktion F 23:	0
    [LO]_Dimmwert EF 23:	0
    [LO]_Dimming Direction EF 23:	[VO]_maximize
    [LO]_Lichtfunktion G 23:	0
    [LO]_Lichtfunktion H 23:	0
    [LO]_Dimmwert GH 23:	0
    [LO]_Dimming Direction GH 23:	[VO]_maximize
    [LO]_BAP Bitposition 24:	1A
    [LO]_Reserved 24:	0
    [LO]_Lichtfunktion A 24:	8
    [LO]_Lichtfunktion B 24:	0
    [LO]_Lichtfunktion C 24:	30
    [LO]_Lichtfunktion D 24:	0
    [LO]_Lichtfunktion E 24:	0
    [LO]_Lichtfunktion F 24:	0
    [LO]_Lichtfunktion G 24:	0
    [LO]_Lichtfunktion H 24:	0
    [LO]_Lasttyp 25:	[VO]_18 - 2* 5W
    [LO]_BAP Bitposition 25:	28
    [LO]_Reserved 25:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 25:	30
    [LO]_Lichtfunktion A 25:	8
    [LO]_Lichtfunktion B 25:	30
    [LO]_Dimmwert AB 25:	100
    [LO]_Lichtansteuerung HD AB 25:	[VO]_always
    [LO]_Lichtfunktion C 25:	0
    [LO]_Lichtfunktion D 25:	0
    [LO]_Dimmwert CD 25:	0
    [LO]_Dimming Direction CD 25:	[VO]_maximize
    [LO]_Lichtfunktion E 25:	0
    [LO]_Lichtfunktion F 25:	0
    [LO]_Dimmwert EF 25:	0
    [LO]_Dimming Direction EF 25:	[VO]_maximize
    [LO]_Lichtfunktion G 25:	0
    [LO]_Lichtfunktion H 25:	0
    [LO]_Dimmwert GH 25:	0
    [LO]_Dimming Direction GH 25:	[VO]_maximize
    [LO]_BAP Bitposition 26:	0
    [LO]_Reserved 26:	0
    [LO]_Lichtfunktion A 26:	0
    [LO]_Lichtfunktion B 26:	0
    [LO]_Lichtfunktion C 26:	0
    [LO]_Lichtfunktion D 26:	0
    [LO]_Lichtfunktion E 26:	0
    [LO]_Lichtfunktion F 26:	0
    [LO]_Lichtfunktion G 26:	0
    [LO]_Lichtfunktion H 26:	0
    [LO]_BAP Bitposition 27:	0
    [LO]_Reserved 27:	0
    [LO]_Lichtfunktion A 27:	0
    [LO]_Lichtfunktion B 27:	0
    [LO]_Lichtfunktion C 27:	0
    [LO]_Lichtfunktion D 27:	0
    [LO]_Lichtfunktion E 27:	0
    [LO]_Lichtfunktion F 27:	0
    [LO]_Lichtfunktion G 27:	0
    [LO]_Lichtfunktion H 27:	0
    [LO]_BAP Bitposition 28:	B
    [LO]_Reserved 28:	0
    [LO]_Lichtfunktion A 28:	25
    [LO]_Lichtfunktion B 28:	0
    [LO]_Lichtfunktion C 28:	0
    [LO]_Lichtfunktion D 28:	0
    [LO]_Lichtfunktion E 28:	0
    [LO]_Lichtfunktion F 28:	0
    [LO]_Lichtfunktion G 28:	0
    [LO]_Lichtfunktion H 28:	0
    [LO]_BAP Bitposition 29:	1C
    [LO]_Reserved 29:	0
    [LO]_Lichtfunktion A 29:	26
    [LO]_Lichtfunktion B 29:	0
    [LO]_Lichtfunktion C 29:	0
    [LO]_Lichtfunktion D 29:	0
    [LO]_Lichtfunktion E 29:	0
    [LO]_Lichtfunktion F 29:	0
    [LO]_Lichtfunktion G 29:	0
    [LO]_Lichtfunktion H 29:	0
    [LO]_BAP Bitposition 30:	0
    [LO]_Reserved 30:	0
    [LO]_Lichtfunktion A 30:	43
    [LO]_Lichtfunktion B 30:	0
    [LO]_Lichtfunktion C 30:	0
    [LO]_Lichtfunktion D 30:	0
    [LO]_Lichtfunktion E 30:	0
    [LO]_Lichtfunktion F 30:	0
    [LO]_Lichtfunktion G 30:	0
    [LO]_Lichtfunktion H 30:	0
    [LO]_BAP Bitposition 31:	0
    [LO]_Reserved 31:	0
    [LO]_Lichtfunktion A 31:	0
    [LO]_Lichtfunktion B 31:	0
    [LO]_Lichtfunktion C 31:	0
    [LO]_Lichtfunktion D 31:	0
    [LO]_Lichtfunktion E 31:	0
    [LO]_Lichtfunktion F 31:	0
    [LO]_Lichtfunktion G 31:	0
    [LO]_Lichtfunktion H 31:	0
    [LO]_Lasttyp 32:	not active
    [LO]_BAP Bitposition 32:	0
    [LO]_Reserved 32:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 32:	0
    [LO]_Lichtfunktion A 32:	0
    [LO]_Lichtfunktion B 32:	0
    [LO]_Dimmwert AB 32:	0
    [LO]_Lichtansteuerung HD AB 32:	[VO]_always
    [LO]_Lichtfunktion C 32:	0
    [LO]_Lichtfunktion D 32:	0
    [LO]_Dimmwert CD 32:	0
    [LO]_Dimming Direction CD 32:	[VO]_maximize
    [LO]_Lichtfunktion E 32:	0
    [LO]_Lichtfunktion F 32:	0
    [LO]_Dimmwert EF 32:	0
    [LO]_Dimming Direction EF 32:	[VO]_maximize
    [LO]_Lichtfunktion G 32:	0
    [LO]_Lichtfunktion H 32:	0
    [LO]_Dimmwert GH 32:	0
    [LO]_Dimming Direction GH 32:	[VO]_maximize
    [LO]_Lasttyp 33:	not active
    [LO]_BAP Bitposition 33:	0
    [LO]_Reserved 33:	0
    [LO]_Fehlerort mittleres Byte DTC-DFCC 33:	0
    [LO]_Lichtfunktion A 33:	0
    [LO]_Lichtfunktion B 33:	0
    [LO]_Dimmwert AB 33:	0
    [LO]_Lichtansteuerung HD AB 33:	[VO]_always
    [LO]_Lichtfunktion C 33:	0
    [LO]_Lichtfunktion D 33:	0
    [LO]_Dimmwert CD 33:	0
    [LO]_Dimming Direction CD 33:	[VO]_maximize
    [LO]_Lichtfunktion E 33:	0
    [LO]_Lichtfunktion F 33:	0
    [LO]_Dimmwert EF 33:	0
    [LO]_Dimming Direction EF 33:	[VO]_maximize
    [LO]_Lichtfunktion G 33:	0
    [LO]_Lichtfunktion H 33:	0
    [LO]_Dimmwert GH 33:	0
    [LO]_Dimming Direction GH 33:	[VO]_maximize
    [LO]_BAP Bitposition 34:	0
    [LO]_Reserved 34:	0
    [LO]_Lichtfunktion A 34:	0
    [LO]_Lichtfunktion B 34:	0
    [LO]_Lichtfunktion C 34:	0
    [LO]_Lichtfunktion D 34:	0
    [LO]_Lichtfunktion E 34:	0
    [LO]_Lichtfunktion F 34:	0
    [LO]_Lichtfunktion G 34:	0
    [LO]_Lichtfunktion H 34:	0
    [VO]_Leuchte33AMBL 3C36 [$0571]:
    [LO]_Lampendefektbitposition 33:	0
    [LO]_Lichtfunktion A 33:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 33:	[VO]_nicht aktiv
    [LO]_Lichtfunktion C 33:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 33:	[VO]_nicht aktiv
    [LO]_Lichtfunktion E 33:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 33:	[VO]_nicht aktiv
    [LO]_Lichtfunktion G 33:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 33:	[VO]_nicht aktiv
    Access control [$0D08]:
    [LO]_Funk bei Klemme 15 ein:	not active
    [LO]_Notschliessfunktion:	active
    [LO]_Automatisches Verriegeln bei Geschwindigkeit:	active
    [LO]_automatisches Entriegeln:	active
    [LO]_Geschwindigkeitsabhaengige Tankdeckelverriegelung:	active
    [LO]_ZV Tuerentriegelung:	[VO]_Globale Entriegelung
    [LO]_CAN Wecken bei Softtouchbetaetigung:	not active
    [LO]_Wiederoeffnung Elektrische-Schiebetuer:	not active
    [LO]_Oeffnung Heckdeckel bei Wiederentriegelung:	not active
    [LO]_Heckdeckel-Bedienstellen nachCrash temporaer sperren:	active
    [LO]_Valet parking:	not active
    [LO]_Direkter Auswurf des Heckdeckels:	active
    [LO]_ZV entriegelt auch Heckdeckel:	active
    [LO]_Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt:	not active
    [LO]_Autolock Autounlock wirkt auf Heck:	active
    [LO]_ZV Heck nur direkt auswerfen:	not active
    [LO]_Manuelle ZV Variantenprogrammierung:	not active
    [LO]_Wiederholte Heckansteuerung beim Schliessen FT oder BT:	not active
    [LO]_Schliessung der Schiebetuer bei geoeffneter Tankklappe:	not active
    [LO]_Bewusstes Safe mit 2. Betaetigung der FFB:	not active
    [LO]_ZV-Entriegelung nach Seitencrash:	not active
    [LO]_Elektrische Laderaumabdeckung:	not active
    [LO]_Menuesteuerung Tuerentriegelung:	active
    [LO]_Menuesteuerung ZV Autolock-Unlock:	[VO]_adjustable
    [LO]_Autounlock NAR:	not active
    [LO]_Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster:	not active
    Daytime running lights [$0D02]:
    [LO]_Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht:	not active
    [LO]_Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich:	not active
    [LO]_Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge:	active
    [LO]_Standlicht aktiviert zusaetzlich Tagfahrlicht:	not active
    [LO]_Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten:	not active
    [LO]_Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht:	not active
    [LO]_Tagfahrlichtkontrollleuchte:	not active
    [LO]_Fahrlicht bei Tag:	Daytime running lights
    [LO]_Tagfahrlicht nur in Schalterstellung AUTO:	not active
    [VO]_Innenbeleuchtung KL 58xs max [$0515]:
    [LO]_x0:	0 lx
    [LO]_x1:	8 lx
    [LO]_x2:	50 lx
    [LO]_x3:	500 lx
    [LO]_y0:	100.0 %
    [LO]_y1:	100.0 %
    [LO]_y2:	100.0 %
    [LO]_y3:	100.0 %
    Energy management [$0D11]:
    [LO]_Energy_Management_Adaptation:	active
    [VO]_Leuchte10SHUTTER LB23 [$055A]:
    [LO]_Lampendefektbitposition 10:	0
    [LO]_Lichtfunktion A 10:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 10:	[VO]_nicht aktiv
    [LO]_Lichtfunktion C 10:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 10:	[VO]_nicht aktiv
    [LO]_Lichtfunktion E 10:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 10:	[VO]_nicht aktiv
    [LO]_Lichtfunktion G 10:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 10:	[VO]_nicht aktiv
    IKA key [$00BE]:
    IKA key:
    [VO]_Leuchte18BLK HLA60 [$0562]:
    [LO]_Lampendefektbitposition 18:	8
    [LO]_Lichtfunktion A 18:	[VO]_Blinken links Hellphase
    [LO]_Lichtfunktion B 18:	[VO]_nicht aktiv
    [LO]_Lichtfunktion C 18:	[VO]_Blinken links Dunkelphase
    [LO]_Lichtfunktion D 18:	[VO]_nicht aktiv
    [LO]_Lichtfunktion E 18:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 18:	[VO]_nicht aktiv
    [LO]_Lichtfunktion G 18:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 18:	[VO]_nicht aktiv
    Convert. top oper. [$0D12]:
    [LO]_Komfortbedienung Verdeck global:	active
    [LO]_Komfortbedienung Verdeck oeffnen:	active
    [LO]_Komfortbedienung Verdeck schliessen:	active
    [LO]_Verdeck oeffnen via Schliesszylinder:	active
    [LO]_Verdeck schliessen via Schliesszylinder:	active
    [LO]_Verdeck oeffnen via Funkfernbedienung:	active
    [LO]_Verdeck schliessen via Funkfernbedienung:	active
    [LO]_Verdeck oeffnen via Kessy:	active
    [LO]_Verdeck schliessen via Kessy:	active
    [LO]_Doppelpuls nur Verdeck:	active
    [LO]_Verdeck mit Schiebedach:	not active
    [LO]_Heckdeckel sperren bei Verdeckbetrieb:	not active
    [LO]_Heckschloss oeffnen durch Verdeck-SG:	not active
    [VO]_Leuchte16BLK SLB35BLK SL KC9 [$0560]:
    [LO]_Lampendefektbitposition 16:	0
    [LO]_Lichtfunktion A 16:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 16:	[VO]_nicht aktiv
    [LO]_Lichtfunktion C 16:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 16:	[VO]_nicht aktiv
    [LO]_Lichtfunktion E 16:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 16:	[VO]_nicht aktiv
    [LO]_Lichtfunktion G 16:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 16:	[VO]_nicht aktiv
    [VO]_Dimmkennlinie Suchbeleuchtung [$15B2]:
    Production mode [$04FE]:
    Activating and deactivating all development messages [$0902]:
    Position during interval mode [$0D17]:
    Anti-theft device [$0D07]:
    [LO]_Alarmsignal:	[VO]_frequency modulated
    [LO]_Verzoegerung Panikalarm:	[VO]_keine verzoegerung
    [LO]_DWA Alarmverzoegerung:	[VO]_driver door contact thatcham
    [LO]_DWA Camper Modus:	not active
    [LO]_Überwachung Innenentriegelungshebel:	not active
    [LO]_Sirenen Alarmzahl:	[VO]_10 Alarme
    [LO]_Akustischer Alarm Signalhorn:	not active
    Turn signal control [$0D00]:
    [LO]_Warnblinken bei Verdeckentriegelung:	not active
    [LO]_Komfortblinken Blinkzyklen:	3
    [LO]_Sonderfunktionen:	not enabled
    [LO]_Signalprioritaet fuer Blinker:	[VO]_SMLS
    [LO]_Blinkkontrolleuchte fuer Anhaenger:	[VO]_separate
    [LO]_Warnblinktastersuchbeleuchtung Aktivierung:	[VO]_always active
    [LO]_Komfortblinken:	active
    [LO]_Warnblinktastersuchbeleuchtung Grundwert:	0.0 %
    [LO]_Warnblinktastersuchbeleuchtung Faktor:	0.200 %
    [VO]_Leuchte32AMBL 2C35 [$0570]:
    [LO]_Lampendefektbitposition 32:	0
    [LO]_Lichtfunktion A 32:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 32:	[VO]_nicht aktiv
    [LO]_Lichtfunktion C 32:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 32:	[VO]_nicht aktiv
    [LO]_Lichtfunktion E 32:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 32:	[VO]_nicht aktiv
    [LO]_Lichtfunktion G 32:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 32:	[VO]_nicht aktiv
    [VO]_RLS_Lights_on_at_Rain [$152B]:
    [VO]_Innenbeleuchtung KL 58xd max [$0519]:
    [LO]_x0:	0 lx
    [LO]_x1:	8 lx
    [LO]_x2:	200 lx
    [LO]_x3:	300 lx
    [LO]_x4:	500 lx
    [LO]_y0:	16.0 %
    [LO]_y1:	16.0 %
    [LO]_y2:	100.0 %
    [LO]_y3:	100.0 %
    [LO]_y4:	100.0 %
    DWA Interior monitoring [$0D1A]:
    [VO]_RLS_tunel_gateway_recognize [$152A]:
    [VO]_Leuchte25KZL HA59 [$0569]:
    [LO]_Lampendefektbitposition 25:	28
    [LO]_Lichtfunktion A 25:	[VO]_Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
    [LO]_Lichtfunktion B 25:	[VO]_Coming Home oder Leaving Home aktiv
    [LO]_Lichtfunktion C 25:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 25:	[VO]_nicht aktiv
    [LO]_Lichtfunktion E 25:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 25:	[VO]_nicht aktiv
    [LO]_Lichtfunktion G 25:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 25:	[VO]_nicht aktiv
    [VO]_Leuchte19BLK HRC31 [$0563]:
    [LO]_Lampendefektbitposition 19:	18
    [LO]_Lichtfunktion A 19:	[VO]_Blinken rechts Hellphase
    [LO]_Lichtfunktion B 19:	[VO]_nicht aktiv
    [LO]_Lichtfunktion C 19:	[VO]_Blinken rechts Dunkelphase
    [LO]_Lichtfunktion D 19:	[VO]_nicht aktiv
    [LO]_Lichtfunktion E 19:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 19:	[VO]_nicht aktiv
    [LO]_Lichtfunktion G 19:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 19:	[VO]_nicht aktiv
    Window heater [$0D06]:
    [LO]_Temperaturabhaengige Einschaltzeit HSH:	active
    [LO]_Temperaturabhaengige Einschaltzeit FSH:	[VO]_default
    [LO]_Heckscheibenheizung Zeitwert:	600 s
    Running time of heated front window:	0 s
    [LO]_Abschalttemperatur für Heckscheibenheizung:	35.0 °C
    [LO]_Abschalttemperatur für Frontscheibenheizung:	-50.0 °C
    [VO]_LuB Lichtrouter Kennlinie 1 [$051E]:
    [LO]_x0:	0
    [LO]_x1:	10
    [LO]_x2:	100
    [LO]_x3:	150
    [LO]_x4:	220
    [LO]_x5:	253
    [LO]_y0:	0.0 %
    [LO]_y1:	6.0 %
    [LO]_y2:	16.0 %
    [LO]_y3:	30.0 %
    [LO]_y4:	60.0 %
    [LO]_y5:	100.0 %
    Auxiliary functions [$0D10]:
    [LO]_Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT:	not active
    [LO]_Spoiler Einfahrunterdrueckung nach manuellem Ausfahren:	not active
    [LO]_Signalhorn ohne KL15:	active
    [LO]_Klemmenfehler auf CAN ausgeben:	active
    [LO]_Menuesteuerung Garagentoroeffner:	not active
    [VO]_Innenbeleuchtung KL 58xt PWM [$051C]:
    [LO]_x0:	0.0 %
    [LO]_x1:	50.0 %
    [LO]_x2:	100.0 %
    [LO]_y0:	0.0 %
    [LO]_y1:	50.0 %
    [LO]_y2:	100.0 %
    [VO]_Innenbeleuchtung KL 58xt min [$0516]:
    [LO]_x0:	0 lx
    [LO]_x1:	8 lx
    [LO]_x2:	50 lx
    [LO]_x3:	500 lx
    [LO]_y0:	10.0 %
    [LO]_y1:	10.0 %
    [LO]_y2:	100.0 %
    [LO]_y3:	100.0 %
    Access control 2 [$0D0D]:
    [LO]_Komfortbedienung global:	active
    Comfort opening:	active
    Comfort closing:	active
    [LO]_Komfortoeffnen nur FH Fahrertuer:	not active
    [LO]_Funk Komfort schliessen:	active
    [LO]_Funk Komfort oeffnen:	active
    [LO]_Schliesszylinder Komfort oeffnen:	active
    [LO]_Schliesszylinder Komfort schliessen:	active
    [LO]_SAD Richtung Komfortoeffnen:	[VO]_open
    [LO]_SAD Komfort schliessen:	active
    [LO]_SAD Komfort oeffnen:	active
    [LO]_Freigabenachlauf FH bei Kl 15 aus:	active
    [LO]_Freigabenachlauf FH bei Tueroeffnen abbrechen:	active
    [LO]_Regenschliessen:	not active
    [LO]_Spiegelabsenkung bei Rueckwaertsfahrt:	not active
    [LO]_Spiegelverstellung Synchron:	active
    [LO]_Kessy Komfort oeffnen:	No
    [LO]_Kessy Komfort schliessen:	No
    [LO]_Kessy Komfortbedienung Reichweitenbegrenzung:	No
    [LO]_Menuesteuerung Spiegelabsenkung:	not active
    [LO]_Funk Spiegelanklappen:	not active
    [LO]_Funk Spiegelanklappung Modus:	[VO]_by convenience operation via remote control key
    [LO]_Menuesteuerung synchrone Spiegelverstellung:	active
    [LO]_Menuesteuerung Funk Spiegel anklappen:	not active
    [LO]_Menuesteuerung Komfortbedienung einstellbar:	[VO]_adjustable
    [LO]_Menuesteuerung Regenschliessen:	not active
    [LO]_SAD PreCrash Konturschliessen:	not active
    [LO]_FH SAD Kl15Aus Freigabezeit:	600 s
    [LO]_Fahrertuerbedienung Fensterheber oeffnen:	active
    [LO]_Fahrertuerbedienung Fensterheber schliessen:	active
    [VO]_Innenbeleuchtung KL 58xd min [$0518]:
    [LO]_x0:	0 lx
    [LO]_x1:	8 lx
    [LO]_x2:	220 lx
    [LO]_x3:	300 lx
    [LO]_x4:	500 lx
    [LO]_y0:	6.0 %
    [LO]_y1:	6.0 %
    [LO]_y2:	100.0 %
    [LO]_y3:	100.0 %
    [LO]_y4:	100.0 %
    Dyn. turn signal modes [$0D21]:
    [LO]_Schluessel_Anlern_Blinken:	not active
    [LO]_UGDO_ Anlern_Blinken:	not active
    [LO]_ZV_Blinken_zu:	not active
    [LO]_ZV_Blinken_auf:	not active
    [LO]_Telematikblinken_STS_Blinken:	not active
    [LO]_DWA_Schaerfungsquittung:	not active
    [LO]_DWA_Alarm_Blinken:	not active
    [LO]_Taxialarmblinken:	not active
    [LO]_Panikblinken:	not active
    [LO]_Multi_kollisions_Blinken:	not active
    [LO]_Notwarn_blinken_NBA_Phase_2:	not active
    [LO]_Richtungs_blinken_rechts:	not active
    [LO]_Richtungs_blinken_links:	not active
    [LO]_ABBA_Blinken:	not active
    [LO]_Crashblinken:	not active
    [LO]_Warnblinken_Zuendung_EIN:	not active
    [LO]_Warnblinken_Zuendung_AUS:	not active
    [VO]_DWA_Interior_Monitoring_Data_Set_Development [$1532]:
    [VO]_Leuchte6ABL LC5 [$0556]:
    [LO]_Lampendefektbitposition 6:	36
    [LO]_Lichtfunktion A 6:	[VO]_Abblendlicht links
    [LO]_Lichtfunktion B 6:	[VO]_nicht aktiv
    [LO]_Lichtfunktion C 6:	[VO]_Coming Home oder Leaving Home aktiv
    [LO]_Lichtfunktion D 6:	[VO]_nicht aktiv
    [LO]_Lichtfunktion E 6:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 6:	[VO]_nicht aktiv
    [LO]_Lichtfunktion G 6:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 6:	[VO]_nicht aktiv
    [VO]_Kopfraumheizung [$1690]:
    [LO]_blower_speed:	1
    [LO]_temperature:	-3
    [VO]_Leuchte8FL LB39 [$0558]:
    [LO]_Lampendefektbitposition 8:	37
    [LO]_Lichtfunktion A 8:	[VO]_Fernlicht links
    [LO]_Lichtfunktion B 8:	[VO]_Lichthupe generell
    [LO]_Lichtfunktion C 8:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 8:	[VO]_nicht aktiv
    [LO]_Lichtfunktion E 8:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 8:	[VO]_nicht aktiv
    [LO]_Lichtfunktion G 8:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 8:	[VO]_nicht aktiv
    Service position [$0D14]:
    Characteristics in production mode [$287A]:
    [VO]_RLS_Night_Sensitivity [$152C]:
    [VO]_offset_illumination [$15B0]:
    Windshield wiper [$0D05]:
    [LO]_Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung:	0
    [LO]_SRA Verzoegerungszeit:	0 ms
    [LO]_SRA Waschzeit:	0 ms
    [LO]_SRA Einweichpausenzeit:	0 ms
    [LO]_SRA Nachwaschzeit:	0 ms
    [LO]_SRA Pausenzeit:	0 ms
    [LO]_SRA bei Waschwassermangel:	not active
    [LO]_Frontwischer Referenzlauf:	not active
    [LO]_Variable Regensensoraktivierung:	active
    [LO]_Wischer stop bei KL15 aus:	not active
    [LO]_Wischer abparken bei Oeffnen der Motorhaube:	not active
    [LO]_Regensensor aktivieren:	Deactivating
    [LO]_Menuesteuerung Frontwischer:	not active
    [LO]_Frontwischer Notlaufprogramm:	active
    [LO]_Tippwischen mit erhoehter Wischfrequenz:	active
    [LO]_Geschwindigkeitsabhaengige Wischstufenrueckschaltung:	active
    [LO]_Traenenwischen Front Status:	not active
    [LO]_Adaptives Nachwischen bei SRA:	not active
    [LO]_Wischer Stopp bei Oeffnen der Motorhaube:	not active
    [VO]_Innenbeleuchtung KL 58xd log Bus [$051A]:
    [LO]_x0:	0.0 %
    [LO]_x1:	6.0 %
    [LO]_x2:	16.0 %
    [LO]_x3:	30.0 %
    [LO]_x4:	60.0 %
    [LO]_x5:	100.0 %
    [LO]_y0:	6
    [LO]_y1:	6
    [LO]_y2:	100
    [LO]_y3:	150
    [LO]_y4:	220
    [LO]_y5:	253
    [VO]_Leuchte23SL HLC10 [$0567]:
    [LO]_Lampendefektbitposition 23:	A
    [LO]_Lichtfunktion A 23:	[VO]_Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
    [LO]_Lichtfunktion B 23:	[VO]_nicht aktiv
    [LO]_Lichtfunktion C 23:	[VO]_Coming Home oder Leaving Home aktiv
    [LO]_Lichtfunktion D 23:	[VO]_nicht aktiv
    [LO]_Lichtfunktion E 23:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 23:	[VO]_nicht aktiv
    [LO]_Lichtfunktion G 23:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 23:	[VO]_nicht aktiv
    [VO]_Vernetzungs- Diagnosefunktionen [$0502]:
    [VO]_Frontwaschfunktion [$1507]:
    Static AFS light [$0D1D]:
    [LO]_bei Rueckwaertsfahrt:	Off
    [LO]_Vorschrift:	[VO]_ECE R119
    [LO]_Untere Geschwindigkeitsschwelle:	0.0 km/h
    [LO]_Obere Geschwindigkeitsschwelle:	40.0 km/h
    Steering wheel angle, offset:	-0.25 °
    [LO]_Unterer Lenkradwinkel:	30 °
    [LO]_Oberer Lenkradwinkel:	90 °
    [LO]_Abdimmgeschwindigkeit:	50.0 %/s
    [LO]_Maximaltemperatur:	100.0 °C
    [LO]_obere Grenztemperatur:	95.0 °C
    [LO]_untere Grenztemperatur:	80.0 °C
    [VO]_Leuchte15AL RB44 [$055F]:
    [LO]_Lampendefektbitposition 15:	0
    [LO]_Lichtfunktion A 15:	[VO]_nicht aktiv
    [LO]_Lichtfunktion B 15:	[VO]_nicht aktiv
    [LO]_Lichtfunktion C 15:	[VO]_nicht aktiv
    [LO]_Lichtfunktion D 15:	[VO]_nicht aktiv
    [LO]_Lichtfunktion E 15:	[VO]_nicht aktiv
    [LO]_Lichtfunktion F 15:	[VO]_nicht aktiv
    [LO]_Lichtfunktion G 15:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 15:	[VO]_nicht aktiv
    [VO]_Leuchte20BR LA71 [$0564]:
    [LO]_Lampendefektbitposition 20:	10
    [LO]_Lichtfunktion A 20:	[VO]_Bremslicht
    [LO]_Lichtfunktion B 20:	[VO]_nicht aktiv
    [LO]_Lichtfunktion C 20:	[VO]_Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
    [LO]_Lichtfunktion D 20:	[VO]_Parklicht links (beidseitiges Parklicht aktiviert li & re)
    [LO]_Lichtfunktion E 20:	[VO]_Coming Home oder Leaving Home aktiv
    [LO]_Lichtfunktion F 20:	[VO]_nicht aktiv
    [LO]_Lichtfunktion G 20:	[VO]_nicht aktiv
    [LO]_Lichtfunktion H 20:	[VO]_nicht aktiv
    Since it appears you're all set up to compare that stuff, I'll let you have a go, but from looking up Craig's issues and a couple of the ones you found "missing", I'm guessing there won't be many ODIS has but VCDS doesn't.
  8. Likes Dana, Uwe liked this post
  9. #6
    Quote Originally Posted by Eric View Post
    ................. stuff not included (for simplicity)
    Eric: First, I assume that your post is directed to me as the identifier of this matter - but I'm not entirely sure that my assumption is correct!
    Anyhow - if I'm correct, then my apology for the misunderstanding. My question was about the channel stability across different versions of VCDS software. It was not about VCDS losing channels that ODIS has reported.
    But I'm happy to help in whatever capacity that I can
  10. #7
    Võru, Estonia
    Hello
    I noticed with lates 17.10Beta that when on Driver door control module, there was adaption line has changed.
    Previous version was like this:
    "ENG109279-ENG99426-System_Parameter_0-System Parameter Byte8" and it contained one value.
    New 17.10 has something like this:
    "ENG109279-ENG99426-System_Parameter_0" and contains a list of bytes. The needed byte8 also that i was after.
    This is something new right and meant for some future proof stuff?
    Module in question:
       Component: TUER-SG FT    002 0533
       Revision: 12110009    Serial number: 0005353355
       Coding: 0211FF
       Shop #: WSC 05311 115 12345
       ROD: EV_TSGFPQ35BRFVW46X_VW46.rod
       VCID: 35342B4985CD6C797BEF-8060
       Slave Driver:
       Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0501
       Serial number: 00000002986002
       Coding: 0100D8
    Volkswagen Golf MKV 2.0TDI-8V 4MOTION MY2007 SEAT LEON FR 1.8TSI MY2018 Some of the work I've done and cared to make a picture.
    Our webpage and Facebook page Heads up, it's in Estonian language.
    The world is my oyster...
  11. #8
    Hello
    I think that previously, each byte was shown as a separate channel, while now they are lumped together into a single, multi-byte channel.
