VW CC 2014 Rear indicator LED bulb error
jcdub
Ireland
I've havea 2014 VW CC GT that I've fitted LED's into the rear indicators. They work fine but throw up a bulb out error for both sides. Once the ignition is turned on and I activate the indicator both left and right side errors disappeared. It seems that the errors only appear from when the car is locked / unlock and the ignition is off.
Is there a way of turning off this cold check, that is I assume its a cold check? Or maybe recode to allow for the LED bulbs?
Please post an Auto-Scan so people can see exactly what control modules this car has and how they are currently configured.
jcdub
Ireland
Hi Uwe,
Auto as mentioned
Regards
Chassis Type: 3C (7N0)
 Scan: 01 02 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 4C 4F 52
            53 55 56 61 62 72 77
 VIN: WVWZZZ3CZEE505194   Mileage: 66800km-41507miles
Address 01: Engine (J623-CFGC)       Labels: None
     Part No SW: 03L 906 018 TM    HW: 03L 907 309 AE
     Component: R4 2.0l TDI   X28 9979
     Revision: 41X28---    Serial number: 00000000000000
     Coding: 001D0012042501080000
     Shop #: WSC 77879 540 394857
     ASAM Dataset: EV_ECM20TDI01103L906018TM 003003
     ROD: N/A
     VCID: 0815A212B3599E01A1-805C
 No ASAM data for: "EV_ECM20TDI01103L906018TM" (VW46)
     Part No SW: 02E 300 062 N    HW: 02E 927 770 AL
     Component: GSG DSG AG6     521 4006
     Revision: 05652104    Serial number: 00001306042298
     Shop #: WSC 05311 000 00000
     VCID: 2045DAB2F3A94641C9-8074
     Part No SW: 3AA 614 109 AQ    HW: 3AA 614 109 AQ
     Component: J104   C2 450M VDF9 0030
     Revision: --H07---    Serial number: 00000007139132
     Coding: 0008124
     VCID: 7CFDCEC23F81C2A1B5-8028
     Part No SW: 3AA 907 044 BE    HW: 3AA 907 044 BE
     Component: Climatronic   H03 0404
     Revision: 00001K01
     Coding: 071400C849
     Shop #: WSC 00015 115 00000
     VCID: 74EDE6E2DFD18AE1FD-8020
 Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
     Part No SW: 3AA 937 087 R    HW: 3AA 937 087 R
     Component: BCM PQ47 H++  422 0474
     Revision: BD422001
     Coding: 000800000000000000880080940029E42355028860220720E484C72000C1
     Shop #: WSC 05311 123 12345
     VCID: 49936716E0D3A7097E-801C
     Subsystem 1 - Part No SW: 3C8 955 119 G    HW: 3C8 955 119 G  Labels: 1KX-955-119.CLB
     Component: WWS464 300113  010 0604
     Serial number: 300113
     Coding: 00B795
     Component: RLFS  024 0042
     Serial number: Y13M06D11H08M51S47S1
     Coding: 0228DD
 Address 10: Park/Steer Assist (J446)       Labels: 3AE-919-475.clb
     Part No SW: 3AE 919 475 C    HW: 7N0 919 475
     Component: PARKHILFE 8K  H06 0018
     Revision: --------    Serial number: 28261315504770
     Coding: 108104
     ASAM Dataset: EV_EPHVA18VW47X0000 001006
     ROD: EV_EPHVA18VW4280000.rod
     VCID: 3F8779CEA61719B9D0-806A
 Address 14: Susp. Elect. (J250)       Labels: 3C0-907-376.clb
     Revision: 00000000    Serial number: 27051306850001
     Coding: 010180
     Shop #: WSC 05314 000 00000
     VCID: 2757C1AE5687B17988-8072
     Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
     Component: J234__70J VW10 HI   2118
     Revision: 26019000    Serial number: 003L7PBDGUJG
     Coding: 0012362
     Subsystem 1 - Serial number: 6332MTS621651443
     Subsystem 2 - Serial number: 6342MTS603521443
     Subsystem 3 - Serial number: 6351HTS61LDH0CKJ
     Subsystem 4 - Serial number: 6361HTS63PKQ1CKJ
 Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
     Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
     Revision: FF010042    Serial number: 20130610300432
     Coding: 098A270000
     VCID: 6BDFFD9E82EF55192C-803E
     Coding: E20000
 Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
     Part No SW: 3C8 920 981 D    HW: 3C8 920 981 D
     Component: KOMBI         H04 0611
     Coding: 440F01
     Shop #: WSC 05314 115 00000
     VCID: 2F67298E7677E93940-807A
     Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
     Component: J533  Gateway H56 1642
     Revision:   H56       Serial number: 310513F1003151
     Coding: 469007
     VCID: 7CFDCEC2FF81C2A1B5-8028
     Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
     Component:    IMMO         043 0407
     VCID: 387512D24B392E8111-806C
 Address 2E: Media Player 3
 Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
     Part No SW: 1T0 035 686 C    HW: 1T0 035 686 C
     Component: RNS-MID       H09 5238
     Revision: AB001001    Serial number: VWZ6Z7N9158123
     Coding: 04000402040000A0000F
     VCID: 346D26E29751CAE13D-8060
     Subsystem 1 - Part No: 1T0 919 859 B
     Component: EU West V9  7918
     Part No SW: 3C8 959 701     HW: 3C0 959 793 C
     Component: TUER-SG FT    002 0556
     Revision: 12110009    Serial number: 0007089101
     Coding: 0202B7
     Shop #: WSC 05311 115 00000
     ROD: EV_TSGFPQ35BRFVW46X.rod
     VCID: 6DDBF386BCFB5B2932-8038
     Slave Driver:
     Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
     Component: J389__TSG-HR  004 0501
     Serial number: 00000003525291
     Coding: 010090
     Part No: 1K0 909 144 R
     Component: EPS_ZFLS Kl. 209    3501
     Revision: 00H22000
     VCID: 397317D670333789EE-806C
     Component:    KSG PQ47 ELV 043 0645
     Coding: 19910A0001860E763604941D7008DFCE105804
     Component: EZE_2         H56 1642
     Coding: 00000008
     VCID: 6FE7E98EBEF7A93900-803A
     Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
     Component: Analoguhr  005 0004
     Part No SW: 3C8 959 702     HW: 3C0 959 792 C
     Component: TUER-SG BT    002 0556
     Revision: 14110009    Serial number: 0007094176
     Coding: 0202B6
     ROD: EV_TSGBPQ35BRFVW46X.rod
     VCID: 6ED9F48AB1FDA0310B-803A
     Slave Passenger:
     Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
     Component: J388__TSG-HL  004 0501
     Serial number: 00000003520391
     Coding: 010090
     Revision:   H19       Serial number: 00000001111083
     Coding: 0022167
     VCID: 36691CEA412DD8F103-8062
 Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
     Part No SW: 6R0 907 357 B    HW: 6R0 907 357 A
     Component: LWR-ECU       005 0030
    Coding: 07A6020001000000
     ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
     ROD: EV_HeadlRegulVWLWRCC.rod
     VCID: 397317D6B8333789EE-806C
 Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
 Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
     Component: Batt.regelung H56 1642
     Coding: 030F1859
     VCID: 71E3EFF6A8C3BFC916-8024
     Component: J367-BDM  H07 0180
     Serial number: 30151236161490394178
 Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
     Part No SW: 5N0 035 729     HW: 5N0 035 729
     Component: TELEFON       H05 0315
     Revision: 1B001001    Serial number: 00007664863944
     Coding: 0A01000080010101
     ROD: EV_UHVUMI.rod
TBAx
C?ID=287144
Unfortunately removing the warning will not be possible using VCDS.
You will need access to the EEPROM of your CECM.
yogibearal
C?ID=292451
Are you using error free CANBUS style LED bulbs or LED with Resistors, or just regular LED's. In most cases using the right kind of bulbs will not throw the error codes. Rather not have to code for it, although I know in some cases I realize it is needed. With regards to rear indicators - I'm assuming you are referring to the turn signal bulbs? Where the originals dual filament or single filament?
GaryM
Oxford, UK
C?ID=226919
How does one do that?
With a hardware device and accompanying software that has the capability of directly editing memory cells in the EEPROM of the BCM. I've just done exactly this for the front lights on mine which are now running normal LEDs (not CAN Bus or "error-free" LEDs) instead of the original incandescent bulbs without the "bulb out" warning light illuminating as was happening before I made the memory cell configuration changes.
It's probably not really appropriate to mention competitor products on a Ross-Tech forum so if you want the name of it, best to PM me.
