Scirocco R36 swap ABS Coding
jeroenveer
C?ID=299782
I Need some help with coding of a ABS unit.
The Car is a Scirocco 2010.
The engine is replaced from a 1.4 TFSI to a US R36 BLV.
The car VIN number has been placed in the engine ECU.
It gives a inccorecltly codes error on the ABS unit i tried to change the ABS coding from 1.4 to 3.6 setting but it does not accept
When i re save the current code it also does not accept.
I hope someone can help me with the correct coding.
The abs also states is does not see the ECU i fixed that by making a CAN controller sending the missing CAN messages.
Monday,19,June,2017,16:03:09:06109
VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4341.4
VIN: WVWZZZ13ZBV017489   License Plate:
Mileage: 109080km-67779mi   Repair Order:
Chassis Type: 13 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 52 56
VIN: WVWZZZ13ZBV017489   Mileage: 109080km-67779miles
Address 01: Engine        Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 B    HW: Hardware No
   Component: P3.6-FSI-LEV2   G00 9622
   Revision: --H08---    Serial number: VWZCZ000000000
   Coding: 0000175
   Shop #: WSC 05314 000 00000
   VCID: 210A313CF8DE3749C6-8074
Readiness: 0110 0101
   Part No SW: 09G 927 750 AJ    HW: 09G 927 750 AJ
   Component: AQ 250 6F           0829
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 05311 000 00000
   VCID: 79BA395C30CE8F89AE-802C
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Revision: 00H31001
   Coding: 743B40F5492300012E0F02EC92220050310800
   Shop #: WSC 00020 790 12345
   VCID: 76A03260C1D0E0F1C3-8022
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.10
                    Time: 01:45:40
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 197
                    Count: 42496
                    Count: 253
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.10
                    Time: 01:44:29
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 8194
                    Count: 42496
                    Count: 253
   Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00020 999 12345
   VCID: 7DB22D4CECE6B3A982-8028
13701376 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2017.06.19
                    Time: 01:47:00
          B10AB F0 [009] - Too Low
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2017.06.19
                    Time: 01:47:00
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0068
   Revision: BC021001
   Coding: 40180A3B88251AC0408800C0340009644B553A08636D8560E48406000041
   VCID: 3E30EA40A96068B1DB-806A
   Subsystem 1 - Part No SW: 1K8 955 119 F    HW: 1K8 955 119 F
   Component: Wischer 23071  10  0603
   Coding: 009795
   Component: RLS 170910 05  54  0403
   Coding: 0330ED
Address 10: Park/Steer Assist (J446)       Labels: 1K0-919-475.clb
   Part No SW: 1K0 919 475 L    HW: 1K0 919 475 L
   Component: PARKHILFE     005 1806
   Revision: 00005000    Serial number: 0 263 004 450
   Coding: 300001
   Shop #: WSC 00397 211 99999
   VCID: 3B36E354BA727D99FC-806E
01312 - Powertrain Data Bus
                    Reset counter: 210
                    Mileage: 109087 km
                    Date: 2011.11.06
                    Time: 02:42:20
02070 - Rear Parking Aid Sensors
                    Fault Status: 01101011
                    Fault Frequency: 61
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.06
                    Time: 00:00:38
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.06
                    Time: 00:00:37
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.06
                    Time: 00:00:37
01545 - Sensor for Parking Aid; Rear Left (G203)
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.06
                    Time: 00:00:37
01548 - Sensor for Parking Aid; Rear Right (G206)
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.06
                    Time: 00:00:36
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0G AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D030GLR
   Coding: 0012359
   Shop #: WSC 00020 790 00000
   VCID: 6FAE07047E8AD13900-803A
   Subsystem 1 - Serial number: 6332MSME56352D36E
   Subsystem 2 - Serial number: 6342MSME563067346
   Subsystem 3 - Serial number: 6352QSME0C6F2F2C+
   Subsystem 4 - Serial number: 6362QSME20711F24A
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20100929100593
   Coding: 1082140000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWSXS.rod
   VCID: 79BA395CF8CE8F89AE-802C
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Coding: 820000
   Part No SW: 1K8 920 872     HW: 1K8 920 872
   Coding: 170900
   VCID: 70AC0478ABB4CEC119-8024
9459739 - Fuel Level Sensor 2
          B1058 1B [009] - Resistance Too High
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2017.06.19
                    Time: 01:50:05
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H25 5603
   Revision:   H25       Serial number: 240910F1001263
   Coding: EDA21F0640021200004000
   VCID: 2E10DA00B90098314B-807A
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 C
   Component: HALDEX 4Motion      0108
   Coding: 0000001
   VCID: 2D12DD0CB406E32972-8078
   VCID: 6A9816108D68341157-803E
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Component: SG EXT.PLAYER H13 0111
   Revision: A1001003    Serial number: 7668662153
   Coding: 020000
   VCID: 271E2F2456FAC97988-8072
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3C8 035 279 L    HW: 3C8 035 279 L
   Component: RNS315-EU   H70 0407
   Serial number: --------------
   Coding: 0000045104000C0000009008
   ASAM Dataset: EV_RNS315EUV2UDS 001705
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 3424C8689F2CB2E13D-8060
   Component: EUR_W_V4  0050
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.clb
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2129
   Coding: 0152631
   VCID: 393AF95C704E4F89EE-806C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   VCID: 312AC17CA83E87C956-8064
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 109087 km
                    Date: 2011.11.10
                    Time: 01:53:43
                    Battery Volts: 12.0 V
                        DD
                    Temperature: 27.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.clb
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0152886
   VCID: 3A38E65075484491E7-806E
End----------(Elapsed Time: 01:02, VBatt start/end: 12.0V/12.0V)-----------
You need to install the ABS controller from the other powertrain.
No further help from me until I see VIN # of donor and proper assignment of equipment.
WVWZZZ13ZBV017489
Coding: 0000175
Coding: 0000072
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE <<<<<<<<<<<<<<<<<<<< This is correct for a Scirocco not an R36
Revision: 00H31001
"Charism"2H0Without "drive select"
"Multimedia", video/DVD/notebook connection9WCWithout "Multimedia" in vehicle
Activated carbon canister1E1Activated carbon canister
Additional body covers, side6EAWithout additional side body covers
(stone guard)
Additional child seat anchors3B4Child seat anchor for
child seat system ISOFIX
Additional tires (winter tires)2WAWithout additional tires
Air bag4UFDriver's and front passenger air bag
with front passenger air bag
deactivation
Antennas8ZHAntenna for AM/FM reception, "diversity"
Anti-theft protection system7AAElectronic vehicle immobilization device
Auxiliary heating9M0Without auxiliary/parking heater
Backrest release3H9Backrest release for front seats with
"Easy Entry"
Base engineTU04-cylinder gasoline engine 1.4 L
unit 03C.K
BatteriesJ2DBattery 380 A (68 Ah)
Battery/alternator capacityNY0Standard battery/alternator capacity
Body measures5C0Without special body measures
Body styleK8CCoupe
Brake pad wear indicator9U1Brake pad wear indicator
Brake type, front1ZEDisc brakes, front (Geomet D)
Brake type, rear1KDDisc brakes, rear
Braking systems1ATElectronic stabilization program (ESP)
Breakaway interior mirror4L6Breakaway interior rear view mirror,
automatically dimming
Bumper2JCComfort bumpers
Carrier frequency for radio remote control5D1Carrier frequency 433.92 MHz-434.42 Mhz
CD changer/CD player7A0Without CD changer/CD player
CD ROM/DVD/SD card7QPCD ROM (Benelux countries)
Center armrest6E3Front center armrest
Climatic zones0Y1Standard climatic zones
Compass/traffic sign displayQR0Without compass/traffic sign display/
traffic signs recognition
Component part sets with country-specific design requirementsB0AComponent parts set without
Cruise control8T2Cruise control system (CCS)
electronic
Customized installationFC0Without customized installation
Delivery equipment2A0Without delivery equipment
Door and lid locking system4I2Radio remote controlled central locking
operated from inside without safe lock
Door and side trim panels4AFDoor and side trim panel in foam film
and woven fabric
Doors0A12 doors
Drive layout1X0Front wheel drive
Electric interface for external useUF6Electric interface for external use
(MDI)
Emission standard7MGEmission standard EU5
Engine cooling system8Z5Not hot country
Engine specificationsD4X4-Zylinder-Ottomotor 1,4L/90 KW
TSI
Grundmotor ist: TU0/TL1
Equipment levelsA8FSports equipment
Exterior mirror setting6XQExterior mirrors: with memory function,
electrically foldable/adjustable,
separately heated
Fire extinguisher6A0Without fire extinguisher
First aid kit / warning triangle1T2Warning triangle
Floor mats0TAWithout floor mats
Front fog light/additional headlight8WDIntegrated front fog light
Front license plate bracket6W1License plate bracket front (large)
Front seat, left3TGSports comfort seats front, left
Front seat, right3SGSports comfort seats front, right
Front stabilizer0AEFront stabilizer
Front underbody guard1SAWithout additional front underbody guard
Fuel quantity for initial filling1Z2Increase in initial standard fuel
filling
Fuel systems1A5Kraftstoffsystem Otto-Einspritzer (FSI)
Gearshift knob/handle6Q2Leather gearshift knob/handle
General operating permit, alterationsC07Operating permit, alteration
Generators8GUAlternator 140 A
Hand brake lever handle6PCLeather hand brake lever handle
Headlight8BGTwin-headlight for driving on the right,
with integrated high beam
Headlight activation8K3Separate daytime running lights with
low beam assistant and "Coming Home"
feature
Headlight washer system8X0Without headlight washer system
Headlight-range adjustment8Q1Headlight-range adjustment
Headrests3J1Height-adjustable headrests for front
seats
Heat accumulator system/additional heater7E0W/o heat accumulator/auxiliary heating
Heated washer nozzles9T0Without heated washer nozzles
Heating and air conditioning system9AKClimatronic with impact pressure
control free of cfc
Hill hold controlUG1Hill hold control
Horns8Y1Two-tone horn
Identification plates1EXSpecial identification plate for EC
for M1 passenger vehicle
Insert for the filling up of unleaded fuel/fuel type2G7Filler neck module 1 with insert
Inserts5MADecorative inserts
Installation differentiation for vehicle components0EMInstallation differentiation for
transmission MQ 200
vehicle components
Instrument insertsU5AInstrument insert, km/h speedometer
Interior light in foot area6T1Interior light in footwell
Left exterior mirror5SLLeft exterior mirror: aspherical
Left vanity mirror4SDLeft vanity mirror, illuminated
Light assistance system8G0Without light assistant
Lock operation for tailgate/trunk lid4E2Tailgate/trunk lid release
from inside (electrically)
Lockable wheel bolts1PEWheel bolts with anti-theft protection
(unlockable)
Luggage compartment cover3U1Foldable trunk cover
Luggage net/pocket on backrest(s)4U0Without luggage nets/pockets
on backrests
Lumbar support7P0Without lumbar support
in seat backrests
Manufacturing sequence differentiation0FAStandard manufacturing sequence
Mass damper for steering wheels1Q0Without mass damper for steering wheel
Multi-function display/trip computer9Q5Multi-function display with control
Nameplate set0PPNameplate set "BlueMotion"
Navigation device7T2Navigation system (LOW)
Outer rear seat belts3ZB3-point seat belts, outer rear with ECE
label
Owner's manuals0VHInformation kit in Dutch
Paint preservative/transit coating5K5Transit coating film with additional
transport protection measures
Park distance control7X1Park distance control
Partition3CAWithout partition
Pedal clusterVF0Standard pedal cluster
Platform group class7PAPlatform group class 1
Platform module floor pan, rear4P0Rear floor panel module, type 1
Radios8AYRadio/navigation system
Rear fog light8TCRear fog light for driving on the right
Rear license plate bracket6P1License plate bracket rear (ECE)
Rear seats3KCRear seat bench unsplit, backrest split
folding
Rear stabilizer0BERear stabilizer
Rear window wiper and washer system8M1Rear window wiper and washer system
with intermittent control
Refrigerator1W2Glove compartment cooling system
Restraint systems, front3QT3-point seat belts with tensioner and
height adjustment, front
Right exterior mirror5RQRight exterior mirror: convex
Right vanity mirror4TDRight vanity mirror illuminated
Roof insert/convertible top3FAWithout roof insert (standard roof)
Safety headrest system3K0Without safety headrest system
Scuff plates7M5Without protective film for scuff plate
Seat adjustment3L3Manual height adjustment for front seats
Seat belt check9P3Seat belt reminder, electric contact in
buckle
Seat coveringN3AFabric seat covering
Seat heater4A0Without seat heater
Service interval prolongationQG1Service interval prolongation
Shock absorption, chassis, frontG07Front shock absorption
Shock absorption, chassis, rear1JCRear shock absorption for sports design
Side air bag4X3Side air bag front with curtain air bag
Side and rear windows4KCSide and rear windows in heat-insulating
glass
Smoking/non-smoking package9JANon-smoking package
Socket7B212-volt socket in luggage boot
Spare wheel/breakdown set1G6Space-saving spare wheel
Speaker installation8RM8 speakers (passive)
Special editionsE0ANo special edition
Special labels/plates2KWLabels/plates in German, French, and
Dutch
Start/stop system/regenerative braking7L6Start/stop system with regenerative
braking
Steering1N3Speed-related variable steering assist
(Servotronic)
Steering system arrangementL0LLeft-hand drive vehicle
Steering wheels2FJLeather trimmed multi-function sports
steering wheel
Sticker (customized or special edition)0KAWithout stickers and badges
Taillight assemblies8SATaillight assemblies, standard design
Telephone/telematics9W0W/o car phone preparation/installation
Tire pressure warning light7K0Without tire pressure warning light
Tire suppliersV0ATires w/o specification of tire brand
TiresHY9Tires 205/50 R17 89H
Tool kit and jack1S1Tool kit and jack
Trailer hitch1D0Without trailer hitch
Transmission specificationsG0K6-speed manual transmission
TV reception/digital radio receptionQV0W/o TV reception/digital radio reception
Type approval countries/countries with special requirementsB31Type approval the Netherlands
Vehicle class differentiation units/platform components7KBVehicle class differentiation -130-
Vehicle specificationsF0ANo special purpose vehicle, standard
equipment
Washer fluid level indicator8W0Without washer fluid level indicator
Weight category front axleL10Suspension range 10
installation control only, no
requirement forecast
Weight category rear axle0YAWeight range 1
Wheel covers1NLCovers for alloy wheels
WheelsC2GAlloy wheels 7J x 17
Window regulator4R4Power windows with comfort operation and
circuit breaker
Windshield glass type4GFWindshield in heat-insulating glass
Windshield wiper intermittent control8N3Windshield wiper intermittent control
with rain sensor
PJWSpace and weight saving spare wheel
PLBMirror package
PNANavigation feature RNS 310 (for RCD 310)
RGYRadio system for RNS315
W31Highline package without panoramic
sunroof country: NL
WDIMultimedia socket MEDIA-IN
Vehicle Identification No.WVWZZZ13ZBV017489
ModelScirocco 1.4
BlueMotion
SCI
Date of production12.10.2010
Year2011
Sales type1372GX
Engine CodeCAXA
Transmission CodeLNY
Axle drive6S
Equipment AZ
Roof color7B
Exterior color / Paint Code7B / R7L
Additional follow up.
The power class will need to be updated in the cluster and matched to the correct ABS module with proper VIN #.
jeroenveer
C?ID=299782
Thank you for the reply.
The passat abs unit does not fit because it has a different connector.
I am also not sure it will work correctly in the scirocco.
what do you mean with "assignment of equipment." the gateway list?
The current abs unit is the original of the scirocco, only engine ecu has been swaped with r36 ecu and a tcm ecu has been added for the automatic gearbox.
VIN Passat WVW VU93C77E00 6203
VIN Scirocco WVW ZZZ13ZBV01 7489
Try changing the PC in cluster to match the drive train or make and install a custom plug to the correct abs module for the swap.
jeroenveer
C?ID=299782
I unplugged the 4motion ecu and disabled it in the gateway.
now all codes are gone and ABS is OK!
It seems that this ABS unit does not work with 4motion?
Correct or the PC is miss assigned.
Post a complete new auto-scan.........
jeroenveer
C?ID=299782
This is the scan with the Haldex NOT connected.
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56
   Coding: 0000175
   Coding: 0000072
   Revision: 00H31001
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.14
                    Time: 21:28:31
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 8194
                    Count: 41984
                    Count: 256
                    Count: 65532
   Revision: 00003001
   Coding: 0000000002
          U1111 00 [008] - -
                    Reset counter: 210
                    Mileage: 109087 km
                    Date: 2017.06.20
                    Time: 01:47:00
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2017.06.20
                    Time: 01:47:00
   Revision: BC021001
   Coding: 40180A3B88251A0040880040340008644B553A08636D8160E48406000041
   Coding: 009795
   Coding: 0330ED
00924 - Relay for Headlamp Cleaning System (J39)
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:45:45
                        Term 15 Off
                    Voltage: 12.30 V
00984 - Left Tail Light (M4)
                    Fault Status: 00101010
                    Reset counter: 210
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 02:27:51
                        Term 15 Off
                    Voltage: 12.05 V
                    Reset counter: 210
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 02:27:51
                        Term 15 Off
                    Voltage: 12.05 V
01565 - Luggage Compartment Light (W3)
                    Fault Status: 01101010
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:49:14
                        Term 15 On
                    Voltage: 12.85 V
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 02:27:51
                        Term 15 Off
                    Voltage: 12.05 V
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 02:27:51
                        Term 15 Off
                    Voltage: 12.05 V
   Coding: 300001
                    Fault Frequency: 15
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:52
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:51
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:51
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:51
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:51
   Coding: 0012359
   Coding: 1082140000
   Coding: 820000
   Coding: 170900
   Coding: EDA01F0640021200004000
   Coding: 020000
   Coding: 0152631
   Revision: 00H17000
   Coding: 0152886
End----------(Elapsed Time: 00:59, VBatt start/end: 11.8V/11.8V)-----------
This is the scan with the Haldex connected.
Friday,23,June,2017,11:39:38:06109
22-AWD -- Status: Not registered 0001
   Coding: 0000175
   Coding: 0000072
   Revision: 00H31001
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.14
                    Time: 21:33:53
                    Count: 12
                    Count: 29184
                    Count: 8223
                    Count: 41984
                    Count: 256
                    Count: 65533
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.14
                    Time: 21:28:31
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 8194
                    Count: 41984
                    Count: 256
                    Count: 65532
   Revision: 00003001
   Coding: 0000000002
          U1111 00 [008] - -
                    Reset counter: 210
                    Mileage: 109087 km
                    Date: 2017.06.20
                    Time: 01:47:00
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2017.06.20
                    Time: 01:47:00
   Revision: BC021001
   Coding: 009795
   Coding: 0330ED
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:45:45
                        Term 15 Off
                    Voltage: 12.30 V
                    Reset counter: 210
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 02:27:51
                        Term 15 Off
                    Voltage: 12.05 V
                    Reset counter: 210
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 02:27:51
                        Term 15 Off
                    Voltage: 12.05 V
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:49:14
                        Term 15 On
                    Voltage: 12.85 V
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 02:27:51
                        Term 15 Off
                    Voltage: 12.05 V
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 02:27:51
                        Term 15 Off
                    Voltage: 12.05 V
   Coding: 300001
                    Fault Frequency: 15
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:52
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:51
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:51
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:51
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:51
   Coding: 0012359
   Coding: 1082140000
   Coding: 820000
   Coding: 170900
   Coding: 0000001
   Coding: 020000
   Coding: 0152631
   Revision: 00H17000
   Coding: 0152886
End----------(Elapsed Time: 01:03, VBatt start/end: 11.8V/11.8V)-----------
and this is the scan with the haldex connected but i am blocking the haldex CAN bus messages to the car with my Haldex Controller
Friday,23,June,2017,11:42:15:06109
   Coding: 0000175
   Coding: 0000072
                    Fault Status: 00101101
                    Fault Frequency: 15
                    Reset counter: 198
                    Fault Frequency: 15
                    Reset counter: 198
                    Fault Frequency: 15
                    Reset counter: 198
   Revision: 00H31001
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.14
                    Time: 21:37:08
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 8194
                    Count: 41984
                    Count: 65533
   Revision: 00003001
   Coding: 0000000002
          U1111 00 [008] - -
                    Reset counter: 210
                    Mileage: 109087 km
                    Date: 2017.06.20
                    Time: 01:47:00
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2017.06.20
                    Time: 01:47:00
   Revision: BC021001
   Coding: 009795
   Coding: 0330ED
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:45:45
                        Term 15 Off
                    Voltage: 12.30 V
                    Reset counter: 210
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 02:27:51
                        Term 15 Off
                    Voltage: 12.05 V
                    Reset counter: 210
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 02:27:51
                        Term 15 Off
                    Voltage: 12.05 V
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:49:14
                        Term 15 On
                    Voltage: 12.85 V
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 02:27:51
                        Term 15 Off
                    Voltage: 12.05 V
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 02:27:51
                        Term 15 Off
                    Voltage: 12.05 V
   Coding: 300001
                    Fault Frequency: 16
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:52
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:51
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:51
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:51
                    Reset counter: 170
                    Mileage: 109087 km
                    Date: 2011.11.12
                    Time: 01:35:51
   Coding: 0012359
   Coding: 1082140000
   Coding: 820000
   Coding: 170900
   Coding: 0000001
   Coding: 020000
   Coding: 0152631
   Revision: 00H17000
   Coding: 0152886
End----------(Elapsed Time: 01:02, VBatt start/end: 11.8V/11.8V)-----------
Yeah you need to do some home work on retrofits.......or have custom messages broadcasted by the engine controller or emulated.
Spacewalker
C?ID=159607
743B40F5492300012E0F02EC92220051310800
code ABS for 3,6
is only one coding for that engine
your current coding
is still for 1,4 etc
