Results 1 to 10 of 10
Thread: Scirocco R36 swap ABS Coding
    Jun 2017
    I Need some help with coding of a ABS unit.
    The Car is a Scirocco 2010.
    The engine is replaced from a 1.4 TFSI to a US R36 BLV.
    The car VIN number has been placed in the engine ECU.
    It gives a inccorecltly codes error on the ABS unit i tried to change the ABS coding from 1.4 to 3.6 setting but it does not accept
    When i re save the current code it also does not accept.
    I hope someone can help me with the correct coding.
    The abs also states is does not see the ECU i fixed that by making a CAN controller sending the missing CAN messages.
    Monday,19,June,2017,16:03:09:06109
    VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4341.4
    VIN: WVWZZZ13ZBV017489   License Plate:
    Mileage: 109080km-67779mi   Repair Order:
    Chassis Type: 13 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 52 56
    VIN: WVWZZZ13ZBV017489   Mileage: 109080km-67779miles
    Address 01: Engine        Labels: 03H-906-032-BLV.clb
       Part No SW: 03H 906 032 B    HW: Hardware No
       Component: P3.6-FSI-LEV2   G00 9622
       Revision: --H08---    Serial number: VWZCZ000000000
       Coding: 0000175
       Shop #: WSC 05314 000 00000
       VCID: 210A313CF8DE3749C6-8074
    Readiness: 0110 0101
       Part No SW: 09G 927 750 AJ    HW: 09G 927 750 AJ
       Component: AQ 250 6F           0829
       Revision: 00H38000    Serial number:
       Coding: 0000072
       Shop #: WSC 05311 000 00000
       VCID: 79BA395C30CE8F89AE-802C
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: 743B40F5492300012E0F02EC92220050310800
       Shop #: WSC 00020 790 12345
       VCID: 76A03260C1D0E0F1C3-8022
    18055 - Check Coding of ECUs on Powertrain Data Bus
                P1647 - 000 -
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.10
                        Time: 01:45:40
                        Count: 3
                        Count: 12
                        Count: 29184
                        Count: 197
                        Count: 42496
                        Count: 253
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.10
                        Time: 01:44:29
                        Count: 3
                        Count: 12
                        Count: 29184
                        Count: 8194
                        Count: 42496
                        Count: 253
       Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
       Revision: 00003001
       Coding: 0000000002
       Shop #: WSC 00020 999 12345
       VCID: 7DB22D4CECE6B3A982-8028
              U1111 00 [009] - -
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2017.06.19
                        Time: 01:47:00
              B10AB F0 [009] - Too Low
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2017.06.19
                        Time: 01:47:00
       Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
       Component: BCM PQ35 M    021 0068
       Revision: BC021001
       Coding: 40180A3B88251AC0408800C0340009644B553A08636D8560E48406000041
       VCID: 3E30EA40A96068B1DB-806A
       Subsystem 1 - Part No SW: 1K8 955 119 F    HW: 1K8 955 119 F
       Component: Wischer 23071  10  0603
       Coding: 009795
       Component: RLS 170910 05  54  0403
       Coding: 0330ED
    Address 10: Park/Steer Assist (J446)       Labels: 1K0-919-475.clb
       Part No SW: 1K0 919 475 L    HW: 1K0 919 475 L
       Component: PARKHILFE     005 1806
       Revision: 00005000    Serial number: 0 263 004 450
       Coding: 300001
       Shop #: WSC 00397 211 99999
       VCID: 3B36E354BA727D99FC-806E
    6 Faults Found:
    01312 - Powertrain Data Bus
                        Reset counter: 210
                        Mileage: 109087 km
                        Date: 2011.11.06
                        Time: 02:42:20
    02070 - Rear Parking Aid Sensors
                        Fault Frequency: 61
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.06
                        Time: 00:00:38
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.06
                        Time: 00:00:37
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.06
                        Time: 00:00:37
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.06
                        Time: 00:00:37
    01548 - Sensor for Parking Aid; Rear Right (G206)
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.06
                        Time: 00:00:36
       Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
       Component: 0G AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 003D1D030GLR
       Coding: 0012359
       Shop #: WSC 00020 790 00000
       VCID: 6FAE07047E8AD13900-803A
       Subsystem 1 - Serial number: 6332MSME56352D36E
       Subsystem 2 - Serial number: 6342MSME563067346
       Subsystem 3 - Serial number: 6352QSME0C6F2F2C+
       Subsystem 4 - Serial number: 6362QSME20711F24A
       Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20100929100593
       Coding: 1082140000
       ROD: EV_SMLSNGVOLWSXS.rod
       VCID: 79BA395CF8CE8F89AE-802C
       Coding: 820000
       Part No SW: 1K8 920 872     HW: 1K8 920 872
       Component: KOMBI         H20 0420
       Coding: 170900
       VCID: 70AC0478ABB4CEC119-8024
    9459739 - Fuel Level Sensor 2
              B1058 1B [009] - Resistance Too High
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2017.06.19
                        Time: 01:50:05
    Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530 A    HW: 1K0 907 951
       Component: J533  Gateway   H25 5603
       Revision:   H25       Serial number: 240910F1001263
       Coding: EDA21F0640021200004000
       VCID: 2E10DA00B90098314B-807A
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554 C
       Component: HALDEX 4Motion      0108
       VCID: 2D12DD0CB406E32972-8078
       Component: IMMO          H20 0420
       VCID: 6A9816108D68341157-803E
       Revision: A1001003    Serial number: 7668662153
       Coding: 020000
       VCID: 271E2F2456FAC97988-8072
       Part No SW: 3C8 035 279 L    HW: 3C8 035 279 L
       Component: RNS315-EU   H70 0407
       Serial number: --------------
       Coding: 0000045104000C0000009008
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 3424C8689F2CB2E13D-8060
       Component: EUR_W_V4  0050
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.clb
       Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
       Component: Tuer-SG         009 2129
       Coding: 0152631
       VCID: 393AF95C704E4F89EE-806C
       Part No: 1K0 909 144 J
       Revision: 00H17000
       VCID: 312AC17CA83E87C956-8064
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 109087 km
                        Date: 2011.11.10
                        Time: 01:53:43
                        Battery Volts: 12.0 V
                            DD
                        Temperature: 27.0C
                        Count: 2
                        Steering Angle: 0.00
                            SteerAng n.Init
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.clb
       Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
       Coding: 0152886
       VCID: 3A38E65075484491E7-806E
    End----------(Elapsed Time: 01:02, VBatt start/end: 12.0V/12.0V)-----------
    You need to install the ABS controller from the other powertrain.
    No further help from me until I see VIN # of donor and proper assignment of equipment.
    WVWZZZ13ZBV017489
    Coding: 0000175
    Coding: 0000072
    Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE <<<<<<<<<<<<<<<<<<<< This is correct for a Scirocco not an R36
    Revision: 00H31001
    "Charism" 2H0 Without "drive select"
    "Multimedia", video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
    Activated carbon canister 1E1 Activated carbon canister
    Additional body covers, side 6EA Without additional side body covers
    (stone guard)
    Additional child seat anchors 3B4 Child seat anchor for
    child seat system ISOFIX
    Additional tires (winter tires) 2WA Without additional tires
    Air bag 4UF Driver's and front passenger air bag
    with front passenger air bag
    deactivation
    Antennas 8ZH Antenna for AM/FM reception, "diversity"
    Anti-theft protection system 7AA Electronic vehicle immobilization device
    Auxiliary heating 9M0 Without auxiliary/parking heater
    Backrest release 3H9 Backrest release for front seats with
    "Easy Entry"
    Base engine TU0 4-cylinder gasoline engine 1.4 L
    unit 03C.K
    Batteries J2D Battery 380 A (68 Ah)
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Body measures 5C0 Without special body measures
    Body style K8C Coupe
    Brake pad wear indicator 9U1 Brake pad wear indicator
    Brake type, front 1ZE Disc brakes, front (Geomet D)
    Brake type, rear 1KD Disc brakes, rear
    Braking systems 1AT Electronic stabilization program (ESP)
    Breakaway interior mirror 4L6 Breakaway interior rear view mirror,
    automatically dimming
    Bumper 2JC Comfort bumpers
    Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
    CD changer/CD player 7A0 Without CD changer/CD player
    CD ROM/DVD/SD card 7QP CD ROM (Benelux countries)
    Center armrest 6E3 Front center armrest
    Climatic zones 0Y1 Standard climatic zones
    Compass/traffic sign display QR0 Without compass/traffic sign display/
    traffic signs recognition
    Component part sets with country-specific design requirements B0A Component parts set without
    Cruise control 8T2 Cruise control system (CCS)
    electronic
    Customized installation FC0 Without customized installation
    Delivery equipment 2A0 Without delivery equipment
    Door and lid locking system 4I2 Radio remote controlled central locking
    operated from inside without safe lock
    Door and side trim panels 4AF Door and side trim panel in foam film
    and woven fabric
    Doors 0A1 2 doors
    Drive layout 1X0 Front wheel drive
    Electric interface for external use UF6 Electric interface for external use
    (MDI)
    Emission standard 7MG Emission standard EU5
    Engine cooling system 8Z5 Not hot country
    Engine specifications D4X 4-Zylinder-Ottomotor 1,4L/90 KW
    TSI
    Grundmotor ist: TU0/TL1
    Equipment levels A8F Sports equipment
    Exterior mirror setting 6XQ Exterior mirrors: with memory function,
    electrically foldable/adjustable,
    separately heated
    Fire extinguisher 6A0 Without fire extinguisher
    First aid kit / warning triangle 1T2 Warning triangle
    Floor mats 0TA Without floor mats
    Front fog light/additional headlight 8WD Integrated front fog light
    Front license plate bracket 6W1 License plate bracket front (large)
    Front seat, left 3TG Sports comfort seats front, left
    Front seat, right 3SG Sports comfort seats front, right
    Front stabilizer 0AE Front stabilizer
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel
    filling
    Fuel systems 1A5 Kraftstoffsystem Otto-Einspritzer (FSI)
    Gearshift knob/handle 6Q2 Leather gearshift knob/handle
    General operating permit, alterations C07 Operating permit, alteration
    Generators 8GU Alternator 140 A
    Hand brake lever handle 6PC Leather hand brake lever handle
    Headlight 8BG Twin-headlight for driving on the right,
    with integrated high beam
    Headlight activation 8K3 Separate daytime running lights with
    low beam assistant and "Coming Home"
    feature
    Headlight washer system 8X0 Without headlight washer system
    Headlight-range adjustment 8Q1 Headlight-range adjustment
    Headrests 3J1 Height-adjustable headrests for front
    seats
    Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
    Heated washer nozzles 9T0 Without heated washer nozzles
    Heating and air conditioning system 9AK Climatronic with impact pressure
    control free of cfc
    Hill hold control UG1 Hill hold control
    Horns 8Y1 Two-tone horn
    Identification plates 1EX Special identification plate for EC
    for M1 passenger vehicle
    Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    Inserts 5MA Decorative inserts
    Installation differentiation for vehicle components 0EM Installation differentiation for
    transmission MQ 200
    vehicle components
    Instrument inserts U5A Instrument insert, km/h speedometer
    Interior light in foot area 6T1 Interior light in footwell
    Left exterior mirror 5SL Left exterior mirror: aspherical
    Left vanity mirror 4SD Left vanity mirror, illuminated
    Light assistance system 8G0 Without light assistant
    Lock operation for tailgate/trunk lid 4E2 Tailgate/trunk lid release
    from inside (electrically)
    Lockable wheel bolts 1PE Wheel bolts with anti-theft protection
    (unlockable)
    Luggage compartment cover 3U1 Foldable trunk cover
    Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets
    on backrests
    Lumbar support 7P0 Without lumbar support
    in seat backrests
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
    Multi-function display/trip computer 9Q5 Multi-function display with control
    Nameplate set 0PP Nameplate set "BlueMotion"
    Navigation device 7T2 Navigation system (LOW)
    Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE
    label
    Owner's manuals 0VH Information kit in Dutch
    Paint preservative/transit coating 5K5 Transit coating film with additional
    transport protection measures
    Park distance control 7X1 Park distance control
    Partition 3CA Without partition
    Pedal cluster VF0 Standard pedal cluster
    Platform group class 7PA Platform group class 1
    Platform module floor pan, rear 4P0 Rear floor panel module, type 1
    Radios 8AY Radio/navigation system
    Rear fog light 8TC Rear fog light for driving on the right
    Rear license plate bracket 6P1 License plate bracket rear (ECE)
    Rear seats 3KC Rear seat bench unsplit, backrest split
    folding
    Rear stabilizer 0BE Rear stabilizer
    Rear window wiper and washer system 8M1 Rear window wiper and washer system
    with intermittent control
    Refrigerator 1W2 Glove compartment cooling system
    Restraint systems, front 3QT 3-point seat belts with tensioner and
    height adjustment, front
    Right exterior mirror 5RQ Right exterior mirror: convex
    Right vanity mirror 4TD Right vanity mirror illuminated
    Roof insert/convertible top 3FA Without roof insert (standard roof)
    Safety headrest system 3K0 Without safety headrest system
    Scuff plates 7M5 Without protective film for scuff plate
    Seat adjustment 3L3 Manual height adjustment for front seats
    Seat belt check 9P3 Seat belt reminder, electric contact in
    buckle
    Seat covering N3A Fabric seat covering
    Seat heater 4A0 Without seat heater
    Service interval prolongation QG1 Service interval prolongation
    Shock absorption, chassis, front G07 Front shock absorption
    Shock absorption, chassis, rear 1JC Rear shock absorption for sports design
    Side air bag 4X3 Side air bag front with curtain air bag
    Side and rear windows 4KC Side and rear windows in heat-insulating
    glass
    Smoking/non-smoking package 9JA Non-smoking package
    Socket 7B2 12-volt socket in luggage boot
    Spare wheel/breakdown set 1G6 Space-saving spare wheel
    Speaker installation 8RM 8 speakers (passive)
    Special editions E0A No special edition
    Special labels/plates 2KW Labels/plates in German, French, and
    Dutch
    Start/stop system/regenerative braking 7L6 Start/stop system with regenerative
    braking
    Steering 1N3 Speed-related variable steering assist
    (Servotronic)
    Steering system arrangement L0L Left-hand drive vehicle
    Steering wheels 2FJ Leather trimmed multi-function sports
    steering wheel
    Sticker (customized or special edition) 0KA Without stickers and badges
    Taillight assemblies 8SA Taillight assemblies, standard design
    Telephone/telematics 9W0 W/o car phone preparation/installation
    Tire pressure warning light 7K0 Without tire pressure warning light
    Tire suppliers V0A Tires w/o specification of tire brand
    Tires HY9 Tires 205/50 R17 89H
    Tool kit and jack 1S1 Tool kit and jack
    Trailer hitch 1D0 Without trailer hitch
    Transmission specifications G0K 6-speed manual transmission
    TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
    Type approval countries/countries with special requirements B31 Type approval the Netherlands
    Vehicle class differentiation units/platform components 7KB Vehicle class differentiation -130-
    Vehicle specifications F0A No special purpose vehicle, standard
    equipment
    Washer fluid level indicator 8W0 Without washer fluid level indicator
    Weight category front axle L10 Suspension range 10
    installation control only, no
    requirement forecast
    Weight category rear axle 0YA Weight range 1
    Wheel covers 1NL Covers for alloy wheels
    Wheels C2G Alloy wheels 7J x 17
    Window regulator 4R4 Power windows with comfort operation and
    circuit breaker
    Windshield glass type 4GF Windshield in heat-insulating glass
    Windshield wiper intermittent control 8N3 Windshield wiper intermittent control
    with rain sensor
    PJW Space and weight saving spare wheel
    PLB Mirror package
    PNA Navigation feature RNS 310 (for RCD 310)
    RGY Radio system for RNS315
    W31 Highline package without panoramic
    sunroof country: NL
    WDI Multimedia socket MEDIA-IN
    Vehicle Identification No. WVWZZZ13ZBV017489
    Model Scirocco 1.4
    BlueMotion
    SCI
    Date of production 12.10.2010
    Year 2011
    Sales type 1372GX
    Engine Code CAXA
    Transmission Code LNY
    Axle drive 6S
    Equipment AZ
    Roof color 7B
    Exterior color / Paint Code 7B / R7L
  3. Likes Ashraf6119 liked this post
    Additional follow up.
    The power class will need to be updated in the cluster and matched to the correct ABS module with proper VIN #.
  5. Likes Uwe, Ashraf6119 liked this post
  6. #4
    Jun 2017
    Thank you for the reply.
    The passat abs unit does not fit because it has a different connector.
    I am also not sure it will work correctly in the scirocco.
    what do you mean with "assignment of equipment." the gateway list?
    The current abs unit is the original of the scirocco, only engine ecu has been swaped with r36 ecu and a tcm ecu has been added for the automatic gearbox.
    VIN Passat WVW VU93C77E00 6203
    VIN Scirocco WVW ZZZ13ZBV01 7489
    Try changing the PC in cluster to match the drive train or make and install a custom plug to the correct abs module for the swap.
    Jun 2017
    I unplugged the 4motion ecu and disabled it in the gateway.
    now all codes are gone and ABS is OK!
    It seems that this ABS unit does not work with 4motion?
    Correct or the PC is miss assigned.
    Post a complete new auto-scan.........
  10. #8
    Jun 2017
    This is the scan with the Haldex NOT connected.
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56
       Coding: 0000175
       Coding: 0000072
       Revision: 00H31001
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.14
                        Time: 21:28:31
                        Count: 3
                        Count: 12
                        Count: 29184
                        Count: 8194
                        Count: 41984
                        Count: 256
                        Count: 65532
       Revision: 00003001
       Coding: 0000000002
              U1111 00 [008] - -
                        Reset counter: 210
                        Mileage: 109087 km
                        Date: 2017.06.20
                        Time: 01:47:00
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2017.06.20
                        Time: 01:47:00
       Revision: BC021001
       Coding: 40180A3B88251A0040880040340008644B553A08636D8160E48406000041
       Coding: 009795
       Coding: 0330ED
    6 Faults Found:
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:45:45
                            Term 15 Off
                        Voltage: 12.30 V
    00984 - Left Tail Light (M4)
                        Fault Status: 00101010
                        Reset counter: 210
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 02:27:51
                            Term 15 Off
                        Voltage: 12.05 V
                        Reset counter: 210
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 02:27:51
                            Term 15 Off
                        Voltage: 12.05 V
                        Fault Status: 01101010
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:49:14
                        Voltage: 12.85 V
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 02:27:51
                            Term 15 Off
                        Voltage: 12.05 V
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 02:27:51
                            Term 15 Off
                        Voltage: 12.05 V
       Coding: 300001
                        Fault Frequency: 15
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:52
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:51
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:51
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:51
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:51
       Coding: 0012359
       Coding: 1082140000
       Coding: 820000
       Coding: 170900
       Coding: EDA01F0640021200004000
       Coding: 020000
       Coding: 0152631
       Revision: 00H17000
       Coding: 0152886
    End----------(Elapsed Time: 00:59, VBatt start/end: 11.8V/11.8V)-----------
    This is the scan with the Haldex connected.
    Friday,23,June,2017,11:39:38:06109
    22-AWD -- Status: Not registered 0001
       Coding: 0000175
       Coding: 0000072
       Revision: 00H31001
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.14
                        Time: 21:33:53
                        Count: 12
                        Count: 29184
                        Count: 8223
                        Count: 41984
                        Count: 256
                        Count: 65533
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.14
                        Time: 21:28:31
                        Count: 3
                        Count: 12
                        Count: 29184
                        Count: 8194
                        Count: 41984
                        Count: 256
                        Count: 65532
       Revision: 00003001
       Coding: 0000000002
              U1111 00 [008] - -
                        Reset counter: 210
                        Mileage: 109087 km
                        Date: 2017.06.20
                        Time: 01:47:00
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2017.06.20
                        Time: 01:47:00
       Revision: BC021001
       Coding: 009795
       Coding: 0330ED
    6 Faults Found:
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:45:45
                            Term 15 Off
                        Voltage: 12.30 V
                        Reset counter: 210
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 02:27:51
                            Term 15 Off
                        Voltage: 12.05 V
                        Reset counter: 210
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 02:27:51
                            Term 15 Off
                        Voltage: 12.05 V
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:49:14
                        Voltage: 12.85 V
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 02:27:51
                            Term 15 Off
                        Voltage: 12.05 V
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 02:27:51
                            Term 15 Off
                        Voltage: 12.05 V
       Coding: 300001
                        Fault Frequency: 15
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:52
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:51
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:51
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:51
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:51
       Coding: 0012359
       Coding: 1082140000
       Coding: 820000
       Coding: 170900
       Coding: 020000
       Coding: 0152631
       Revision: 00H17000
       Coding: 0152886
    End----------(Elapsed Time: 01:03, VBatt start/end: 11.8V/11.8V)-----------
    and this is the scan with the haldex connected but i am blocking the haldex CAN bus messages to the car with my Haldex Controller
    Friday,23,June,2017,11:42:15:06109
       Coding: 0000175
       Coding: 0000072
                        Fault Status: 00101101
                        Fault Frequency: 15
                        Reset counter: 198
                        Fault Frequency: 15
                        Reset counter: 198
                        Fault Frequency: 15
                        Reset counter: 198
       Revision: 00H31001
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.14
                        Time: 21:37:08
                        Count: 3
                        Count: 12
                        Count: 29184
                        Count: 8194
                        Count: 41984
                        Count: 65533
       Revision: 00003001
       Coding: 0000000002
              U1111 00 [008] - -
                        Reset counter: 210
                        Mileage: 109087 km
                        Date: 2017.06.20
                        Time: 01:47:00
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2017.06.20
                        Time: 01:47:00
       Revision: BC021001
       Coding: 009795
       Coding: 0330ED
    6 Faults Found:
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:45:45
                            Term 15 Off
                        Voltage: 12.30 V
                        Reset counter: 210
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 02:27:51
                            Term 15 Off
                        Voltage: 12.05 V
                        Reset counter: 210
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 02:27:51
                            Term 15 Off
                        Voltage: 12.05 V
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:49:14
                        Voltage: 12.85 V
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 02:27:51
                            Term 15 Off
                        Voltage: 12.05 V
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 02:27:51
                            Term 15 Off
                        Voltage: 12.05 V
       Coding: 300001
                        Fault Frequency: 16
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:52
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:51
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:51
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:51
                        Reset counter: 170
                        Mileage: 109087 km
                        Date: 2011.11.12
                        Time: 01:35:51
       Coding: 0012359
       Coding: 1082140000
       Coding: 820000
       Coding: 170900
       Coding: 020000
       Coding: 0152631
       Revision: 00H17000
       Coding: 0152886
    End----------(Elapsed Time: 01:02, VBatt start/end: 11.8V/11.8V)-----------
  11. #9
    Yeah you need to do some home work on retrofits.......or have custom messages broadcasted by the engine controller or emulated.
  12. #10
    Jun 2014
    Poland
    743B40F5492300012E0F02EC92220051310800
    code ABS for 3,6
    is only one coding for that engine
    your current coding
    is still for 1,4 etc
    HOT HOT HOT VW Touran 2005 CCS via MFSW HOT HOT HOT
  13. Likes Jack@European_Parts, Uwe liked this post
